[Buster] - Messages d'erreurs au lancement - le retour!
Hello
Je cherche à résoudre les différents messages d’erreur qui apparaissent au lancement de Buster…
Si un expert sur le sujet pouvait jeter un coup d’œil dessus, et m’indiquer quoi faire ce serait cool!
Merci d’avance.
La référence du PC Portable
HP Notebook 15-af008nf 15.6"
Voici le journal que j’ai récupéré au lancement :
sudo journalctl -p err
robgall kernel: do_IRQ: 1.55 No irq handler for vector
robgall kernel: do_IRQ: 2.55 No irq handler for vector
robgall kernel: do_IRQ: 3.55 No irq handler for vector
robgall kernel: kvm: disabled by bios
robgall kernel: uvcvideo: Failed to query (GET_INFO) UVC control 8 on unit 1: -32 (exp. 1).
robgall bluetoothd[529]: Sap driver initialization failed.
robgall bluetoothd[529]: sap-server: Operation not permitted (1)
robgall wpa_supplicant[548]: bgscan simple: Failed to enable signal strength monitoring
robgall lightdm[1887]: gkr-pam: couldn't run gnome-keyring-daemon: No such file or directory
robgall lightdm[1865]: gkr-pam: gnome-keyring-daemon didn't start properly
1 - Les informations de la distribution installée
Operating System: Debian GNU/Linux 10 (buster)
Kernel: Linux 4.19.0-14-amd64
Architecture: x86-64
2 - Les informations du matériel
sudo dmidecode -q
BIOS Information
	Vendor: Insyde
	Version: F.1F
	Release Date: 12/01/2015
	Address: 0xE0000
	Runtime Size: 128 kB
	ROM Size: 4096 kB
	Characteristics:
		PCI is supported
		BIOS is upgradeable
		BIOS shadowing is allowed
		Boot from CD is supported
		Selectable boot is supported
		BIOS ROM is socketed
		EDD is supported
		Japanese floppy for NEC 9800 1.2 MB is supported (int 13h)
		Japanese floppy for Toshiba 1.2 MB is supported (int 13h)
		5.25"/360 kB floppy services are supported (int 13h)
		5.25"/1.2 MB floppy services are supported (int 13h)
		3.5"/720 kB floppy services are supported (int 13h)
		3.5"/2.88 MB floppy services are supported (int 13h)
		8042 keyboard services are supported (int 9h)
		CGA/mono video services are supported (int 10h)
		ACPI is supported
		USB legacy is supported
		Targeted content distribution is supported
		UEFI is supported
	BIOS Revision: 15.31
	Firmware Revision: 99.45
System Information
	Manufacturer: Hewlett-Packard
	Product Name: HP Notebook
	Version: Type1ProductConfigId
	Serial Number: CND5267PGC
	UUID: 6d9383a4-f51a-e511-a26a-5820b167894f
	Wake-up Type: Power Switch
	SKU Number: N0L65EA#ABF
	Family: 103C_5335KV G=N L=CON B=HP
Base Board Information
	Product Name: 8137
	Version: 99.45
	Serial Number: PFHTKD2WV8VRQM
	Asset Tag: Base Board Asset Tag
	Features:
		Board is a hosting board
		Board is replaceable
	Location In Chassis: Base Board Chassis Location
	Type: Motherboard
Chassis Information
	Type: Notebook
	Lock: Not Present
	Version: Chassis Version
	Serial Number: Chassis Serial Number
	Asset Tag: Chassis Asset Tag
	Boot-up State: Safe
	Power Supply State: Safe
	Thermal State: Safe
	Security Status: None
	OEM Information: 0x0000010E
	Height: Unspecified
	Number Of Power Cords: 1
	Contained Elements: 0
	SKU Number: Not Specified
System Slot Information
	Designation: J3606
	Type: x2 PCI Express 2 x2
	Current Usage: Available
	Length: Short
	Characteristics:
		3.3 V is provided
		PME signal is supported
		Hot-plug devices are supported
	Bus Address: 0000:00:02.0
	Designation: J3703
	Type: x1 PCI Express x1
	Length: Short
	Characteristics:
		3.3 V is provided
	Bus Address: 0000:00:04.0
	Designation: J3700
	Length: Short
	Characteristics:
		3.3 V is provided
	Bus Address: 0000:00:05.0
	Designation: J3701
	Length: Short
	Characteristics:
		3.3 V is provided
	Bus Address: 0000:00:06.0
	Designation: J2500
	Length: Short
	Characteristics:
		3.3 V is provided
	Bus Address: 0000:00:07.0
	Designation: J615
	Type: 32-bit PC-98/Card
	Length: Long
	Characteristics:
		5.0 V is provided
		3.3 V is provided
		Cardbus is supported
		Modem ring resume is supported
		SMBus signal is supported
	Bus Address: 0000:00:14.7
OEM Strings
	String 1: $HP$
	String 2: LOC#ABA
	String 3: ABS 70/71 78 79 7A 7B
	String 4: String4 for Original Equipment Manufacturer
	String 5: HP_Mute_LED_0_A
	String 6: String6 for Original Equipment Manufacturer
	String 7: String7 for Original Equipment Manufacturer
	String 8: String8 for Original Equipment Manufacturer
	String 9: FBYTE#3Q6b7K7P7W7jaBapaqasauawbPbSbhbpbzcbce.nF;
	String 10: BUILDID#15WW2THA602#SABF#DABF;
	String 11: String11 for Original Equipment Manufacturer
BIOS Language Information
	Language Description Format: Long
	Installable Languages: 5
		en|US|iso8859-1
		fr|CA|iso8859-1
		es|ES|iso8859-1
		zh|TW|unicode
		zh|CN|unicode
	Currently Installed Language: fr|CA|iso8859-1
System Boot Information
	Status: No errors detected
Portable Battery
	Manufacturer: 13-42
	Manufacture Date: 8/7/2018
	Serial Number: 04369 8/7/2018
	Chemistry: Lithium Ion
	Design Capacity: 38480 mWh
	Design Voltage: 14800 mV
	SBDS Version: 1
	Maximum Error: 8%
	OEM-specific Information: 0x000C090E
Onboard Device
	Reference Designation:
	Type: Other
	Status: Enabled
	Type Instance: 1
	Bus Address: 0000:02:00.0
Physical Memory Array
	Use: System Memory
	Error Correction Type: None
	Maximum Capacity: 4 GB
	Number Of Devices: 2
Memory Device
	Total Width: Unknown
	Data Width: Unknown
	Size: No Module Installed
	Form Factor: SODIMM
	Set: None
	Locator: Bottom
	Bank Locator: CHANNEL A
	Type: Unknown
	Type Detail: Unknown
	Speed: Unknown
	Manufacturer: Empty
	Serial Number: Empty
	Asset Tag: Asset Tag:
	Part Number: Empty
	Rank: Unknown
	Configured Memory Speed: Unknown
	Minimum Voltage: Unknown
	Maximum Voltage: Unknown
	Configured Voltage: Unknown
Memory Device
	Total Width: 64 bits
	Data Width: 64 bits
	Form Factor: SODIMM
	Set: None
	Locator: Top
	Type: DDR3
	Type Detail: Synchronous Unbuffered (Unregistered)
	Speed: 1600 MT/s
	Manufacturer: Samsung
	Serial Number: 123CD8E8
	Part Number: M471B5173QH0-YK0
	Rank: 1
	Configured Memory Speed: 800 MT/s
Memory Device Mapped Address
	Starting Address: 0x00000000000
	Ending Address: 0x000FFFFFFFF
	Range Size: 4 GB
	Partition Row Position: 1
Memory Array Mapped Address
	Range Size: 4 GB
	Partition Width: 255
Processor Information
	Socket Designation: Socket FT1
	Type: Central Processor
	Family: A-Series
	Manufacturer: AMD processor
	ID: 01 0F 70 00 FF FB 8B 17
	Signature: Family 22, Model 0, Stepping 1
	Flags:
		FPU (Floating-point unit on-chip)
		VME (Virtual mode extension)
		DE (Debugging extension)
		PSE (Page size extension)
		TSC (Time stamp counter)
		MSR (Model specific registers)
		PAE (Physical address extension)
		MCE (Machine check exception)
		CX8 (CMPXCHG8 instruction supported)
		APIC (On-chip APIC hardware supported)
		SEP (Fast system call)
		MTRR (Memory type range registers)
		PGE (Page global enable)
		MCA (Machine check architecture)
		CMOV (Conditional move instruction supported)
		PAT (Page attribute table)
		PSE-36 (36-bit page size extension)
		CLFSH (CLFLUSH instruction supported)
		MMX (MMX technology supported)
		FXSR (FXSAVE and FXSTOR instructions supported)
		SSE (Streaming SIMD extensions)
		SSE2 (Streaming SIMD extensions 2)
		HTT (Multi-threading)
	Version: AMD A6-5200 APU with Radeon(TM) HD Graphics
	Voltage: 1.3 V
	External Clock: 100 MHz
	Max Speed: 2000 MHz
	Current Speed: 2000 MHz
	Status: Populated, Enabled
	Upgrade: None
	Serial Number: NotSupport
	Asset Tag: FFFF
	Part Number: FFFF
	Core Count: 4
	Core Enabled: 4
	Thread Count: 4
	Characteristics:
		64-bit capable
Cache Information
	Socket Designation: L1 Cache
	Configuration: Enabled, Not Socketed, Level 1
	Operational Mode: Write Back
	Installed Size: 256 kB
	Maximum Size: 256 kB
	Supported SRAM Types:
		Pipeline Burst
	Installed SRAM Type: Pipeline Burst
	Speed: 1 ns
	Error Correction Type: Multi-bit ECC
	System Type: Unified
	Associativity: 2-way Set-associative
Cache Information
	Socket Designation: L2 Cache
	Configuration: Enabled, Not Socketed, Level 2
	Installed Size: 2048 kB
	Maximum Size: 2048 kB
		Pipeline Burst
	Speed: 1 ns
	Associativity: 16-way Set-associative
3 - D’autres informations du matériel
sudo dmidecode -t bios
# dmidecode 3.2
Getting SMBIOS data from sysfs.
SMBIOS 2.8 present.
Handle 0x0000, DMI type 0, 24 bytes
BIOS Information
	Vendor: Insyde
	Version: F.1F
	Address: 0xE0000
	ROM Size: 4096 kB
	Characteristics:
		PCI is supported
		BIOS is upgradeable
		EDD is supported
		ACPI is supported
		UEFI is supported
Handle 0x000B, DMI type 13, 22 bytes
		en|US|iso8859-1
		fr|CA|iso8859-1
		es|ES|iso8859-1
		zh|TW|unicode
		zh|CN|unicode
4 - Et pour finir sur le hardware
lspci
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 16h Processor Root Complex
00:01.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Kabini [Radeon HD 8400 / R3 Series]
00:01.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Kabini HDMI/DP Audio
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 16h Processor Function 0
00:02.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 16h Processor Functions 5:1
00:02.4 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 16h Processor Functions 5:1
00:02.5 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 16h Processor Functions 5:1
00:10.0 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB XHCI Controller (rev 01)
00:11.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode]
00:12.0 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB OHCI Controller (rev 39)
00:12.2 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB EHCI Controller (rev 39)
00:13.0 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB OHCI Controller (rev 39)
00:13.2 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB EHCI Controller (rev 39)
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 3a)
00:14.2 Audio device: Advanced Micro Devices, Inc. [AMD] FCH Azalia Controller (rev 02)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 11)
00:14.7 SD Host controller: Advanced Micro Devices, Inc. [AMD] FCH SD Flash Controller (rev 01)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 16h Processor Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 16h Processor Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 16h Processor Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 16h Processor Function 3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 16h Processor Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 16h Processor Function 5
02:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8188EE Wireless Network Adapter (rev 01)
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL810xE PCI Express Fast Ethernet controller (rev 07)
bluetooth pas grave, il faut modifier le service
gkr-pam je l’ai aussi mais ne me parait pas grave puisque quelques instant après tout va bien
journalctl | grep gkr-pam
févr. 15 15:06:07 debian lightdm[6745]: gkr-pam: unable to locate daemon control file
févr. 15 15:06:07 debian lightdm[6745]: gkr-pam: stashed password to try later in open session
févr. 15 15:06:08 debian lightdm[6745]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
Mais il faut surtout te demander si tu constates qu’une fonction est en panne sur ton PC car les messages c’est souvent du bavardage inutile
