hello:
Je tente de me faire un deamon avec une lib
don voici l’exemple que j’ai casiment repris mai mis dans une class. evidament sa bug…
vu le message de compilation je necomprend rien aux plantage.
0pointer.de/lennart/projects/lib … index.html
fichier *.h
#ifndef DEF_ME_DEMON
#define DEF_ME_DEMON
class c_deamon
public:
c_deamon();
void start_in_daemon();
#endif //fin des macro
This file is part of libdaemon.
Copyright 2003-2008 Lennart Poettering
libdaemon is free software; you can redistribute it and/or modify
it under the terms of the GNU Lesser General Public License as
published by the Free Software Foundation, either version 2.1 of the
License, or (at your option) any later version.
libdaemon is distributed in the hope that it will be useful, but
WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public
License along with libdaemon. If not, see
<http://www.gnu.org/licenses/>.
#include <signal.h>
#include <errno.h>
#include <string.h>
#include <sys/types.h>
#include <sys/time.h>
#include <sys/unistd.h>
#include <sys/select.h>
#include <libdaemon/dfork.h>
#include <libdaemon/dsignal.h>
#include <libdaemon/dlog.h>
#include <libdaemon/dpid.h>
#include <libdaemon/dexec.h>
#include "c_daemon.h"
c_deamon::c_deamon(){}
void c_deamon::start_in_daemon()
pid_t pid;
/* Reset signal handlers */
if (daemon_reset_sigs(-1) < 0) {
daemon_log(LOG_ERR, "Failed to reset all signal handlers: %s", strerror(errno));
return ;
/* Unblock signals */
if (daemon_unblock_sigs(-1) < 0) {
daemon_log(LOG_ERR, "Failed to unblock all signals: %s", strerror(errno));
return ;
int argc;
char *argv[255];
/* Set indetification string for the daemon for both syslog and PID file */
daemon_pid_file_ident = daemon_log_ident = daemon_ident_from_argv0(argv[0]);
/* Check if we are called with -k parameter */
if (argc >= 2 && !strcmp(argv[1], "-k")) {
int ret;
/* Kill daemon with SIGTERM */
/* Check if the new function daemon_pid_file_kill_wait() is available, if it is, use it. */
if ((ret = daemon_pid_file_kill_wait(SIGTERM, 5)) < 0)
daemon_log(LOG_WARNING, "Failed to kill daemon: %s", strerror(errno));
return ;//ret < 0 ? 1 : 0;
/* Check that the daemon is not rung twice a the same time */
if ((pid = daemon_pid_file_is_running()) >= 0) {
daemon_log(LOG_ERR, "Daemon already running on PID file %u", pid);
return ;
/* Prepare for return value passing from the initialization procedure of the daemon process */
if (daemon_retval_init() < 0) {
daemon_log(LOG_ERR, "Failed to create pipe.");
return ;
/* Do the fork */
if ((pid = daemon_fork()) < 0) {
/* Exit on error */
daemon_retval_done();
return ;
} else if (pid) { /* The parent */
int ret;
/* Wait for 20 seconds for the return value passed from the daemon process */
if ((ret = daemon_retval_wait(20)) < 0) {
daemon_log(LOG_ERR, "Could not recieve return value from daemon process: %s", strerror(errno));
return ;
daemon_log(ret != 0 ? LOG_ERR : LOG_INFO, "Daemon returned %i as return value.", ret);
return ;//ret;
} else { /* The daemon */
int fd, quit = 0;
fd_set fds;
/* Close FDs */
if (daemon_close_all(-1) < 0) {
daemon_log(LOG_ERR, "Failed to close all file descriptors: %s", strerror(errno));
/* Send the error condition to the parent process */
daemon_retval_send(1);
goto finish;
/* Create the PID file */
if (daemon_pid_file_create() < 0) {
daemon_log(LOG_ERR, "Could not create PID file (%s).", strerror(errno));
daemon_retval_send(2);
goto finish;
/* Initialize signal handling */
if (daemon_signal_init(SIGINT, SIGTERM, SIGQUIT, SIGHUP, 0) < 0) {
daemon_log(LOG_ERR, "Could not register signal handlers (%s).", strerror(errno));
daemon_retval_send(3);
goto finish;
/*... do some further init work here */
/* Send OK to parent process */
daemon_retval_send(0);
daemon_log(LOG_INFO, "Sucessfully started");
/* Prepare for select() on the signal fd */
FD_ZERO(&fds);
fd = daemon_signal_fd();
FD_SET(fd, &fds);
while (!quit) {
fd_set fds2 = fds;
/* Wait for an incoming signal */
if (select(FD_SETSIZE, &fds2, 0, 0, 0) < 0) {
/* If we've been interrupted by an incoming signal, continue */
if (errno == EINTR)
continue;
daemon_log(LOG_ERR, "select(): %s", strerror(errno));
break;
/* Check if a signal has been recieved */
if (FD_ISSET(fd, &fds2)) {
int sig;
/* Get signal */
if ((sig = daemon_signal_next()) <= 0) {
daemon_log(LOG_ERR, "daemon_signal_next() failed: %s", strerror(errno));
break;
/* Dispatch signal */
switch (sig) {
case SIGINT:
case SIGQUIT:
case SIGTERM:
daemon_log(LOG_WARNING, "Got SIGINT, SIGQUIT or SIGTERM.");
quit = 1;
break;
case SIGHUP:
daemon_log(LOG_INFO, "Got a HUP");
daemon_exec("/", NULL, "/bin/ls", "ls", (char*) NULL);
break;
/* Do a cleanup */
finish:
daemon_log(LOG_INFO, "Exiting...");
daemon_retval_send(255);
daemon_signal_done();
daemon_pid_file_remove();
return ;
int main(int argc, char *argv[]) {
le message d’erreur est le suivant:
[code]/***
http://www.gnu.org/licenses/.
#include <signal.h>
#include <errno.h>
#include <string.h>
pid_t pid;
return ;
return ;
int argc;
char argv[255];
/ Set indetification string for the daemon for both syslog and PID file */
int ret;
return ;
return ;
/* Do the fork */
/* Exit on error */
return ;
int ret;
return ;
return ;//ret;
int fd, quit = 0;
fd_set fds;
/* Close FDs */
goto finish;
goto finish;
goto finish;
FD_ZERO(&fds);
FD_SET(fd, &fds);
while (!quit) {
fd_set fds2 = fds;
if (errno == EINTR)
continue;
break;
int sig;
/* Get signal */
break;
switch (sig) {
case SIGINT:
case SIGQUIT:
case SIGTERM:
quit = 1;
break;
case SIGHUP:
break;
/* Do a cleanup */
finish:
daemon_log(LOG_INFO, “Exiting…”);
return ;
message d’erreur:
main.o: In function `c_deamon::start_in_daemon()':
main.cpp:(.text+0x4c6): undefined reference to `daemon_reset_sigs'
main.cpp:(.text+0x4f4): undefined reference to `daemon_log'
main.cpp:(.text+0x505): undefined reference to `daemon_unblock_sigs'
main.cpp:(.text+0x533): undefined reference to `daemon_log'
main.cpp:(.text+0x546): undefined reference to `daemon_ident_from_argv0'
main.cpp:(.text+0x54b): undefined reference to `daemon_log_ident'
main.cpp:(.text+0x550): undefined reference to `daemon_log_ident'
main.cpp:(.text+0x555): undefined reference to `daemon_pid_file_ident'
main.cpp:(.text+0x589): undefined reference to `daemon_pid_file_kill_wait'
main.cpp:(.text+0x5c1): undefined reference to `daemon_log'
main.cpp:(.text+0x5cb): undefined reference to `daemon_pid_file_is_running'
main.cpp:(.text+0x5f5): undefined reference to `daemon_log'
main.cpp:(.text+0x5ff): undefined reference to `daemon_retval_init'
main.cpp:(.text+0x61a): undefined reference to `daemon_log'
main.cpp:(.text+0x624): undefined reference to `daemon_fork'
main.cpp:(.text+0x636): undefined reference to `daemon_retval_done'
main.cpp:(.text+0x651): undefined reference to `daemon_retval_wait'
main.cpp:(.text+0x685): undefined reference to `daemon_log'
main.cpp:(.text+0x6c3): undefined reference to `daemon_log'
main.cpp:(.text+0x6db): undefined reference to `daemon_close_all'
main.cpp:(.text+0x709): undefined reference to `daemon_log'
main.cpp:(.text+0x715): undefined reference to `daemon_retval_send'
main.cpp:(.text+0x71f): undefined reference to `daemon_pid_file_create'
main.cpp:(.text+0x74d): undefined reference to `daemon_log'
main.cpp:(.text+0x759): undefined reference to `daemon_retval_send'
main.cpp:(.text+0x78a): undefined reference to `daemon_signal_init'
main.cpp:(.text+0x7b8): undefined reference to `daemon_log'
main.cpp:(.text+0x7c4): undefined reference to `daemon_retval_send'
main.cpp:(.text+0x7d5): undefined reference to `daemon_retval_send'
main.cpp:(.text+0x7e9): undefined reference to `daemon_log'
main.cpp:(.text+0x80d): undefined reference to `daemon_signal_fd'
main.cpp:(.text+0x8cd): undefined reference to `daemon_log'
main.cpp:(.text+0x8fd): undefined reference to `daemon_signal_next'
main.cpp:(.text+0x932): undefined reference to `daemon_log'
main.cpp:(.text+0x97a): undefined reference to `daemon_log'
main.cpp:(.text+0x997): undefined reference to `daemon_log'
main.cpp:(.text+0x9c3): undefined reference to `daemon_exec'
main.cpp:(.text+0x9e1): undefined reference to `daemon_log'
main.cpp:(.text+0x9ed):undefined reference to `daemon_retval_send'
main.cpp:(.text+0x9f2): undefined reference to `daemon_signal_done'
main.cpp:(.text+0x9f7): undefined reference to `daemon_pid_file_remove'
collect2: ld returned 1 exit status
j’ai simplement enlever les return x; pour faire une methode qui ne renvoie rien . et adapter 2 variable qui son celle du main
int argc et char *argv[]
normalement les erreur undefined reference son déclarée dans la lib (enfin je supose)
so vous avez une idée je suis preneur
Merci d’avance
