voici le mien:
[code]# xorg.conf.dpkg-new (Xorg X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the xorg.conf.dpkg-new manual page.
(Type “man xorg.conf.dpkg-new” at the shell prompt.)
This file is automatically updated on xserver-xorg package upgrades only
if it has not been modified since the last upgrade of the xserver-xorg
package.
If you have edited this file but would like it to be automatically updated
again, run the following commands as root:
cp /etc/X11/xorg.conf.dpkg-new /etc/X11/xorg.conf.dpkg-new.custom
md5sum /etc/X11/xorg.conf.dpkg-new >/var/lib/xfree86/xorg.conf.dpkg-new.md5sum
dpkg-reconfigure xserver-xorg
Section “Files”
FontPath “unix/:7100” # local font server
# if the local font server has problems, we can fall back on these
FontPath "/usr/lib/X11/fonts/misc"
FontPath "/usr/lib/X11/fonts/cyrillic"
FontPath "/usr/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/Type1"
FontPath "/usr/lib/X11/fonts/CID"
FontPath "/usr/lib/X11/fonts/100dpi"
FontPath "/usr/lib/X11/fonts/75dpi"
EndSection
Section "Module"
Load "bitmap"
Load "dbe"
Load “ddc”
Load “dri”
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "record"
Load "type1"
Load "v4l"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "keyboard"
Option "CoreKeyboard"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "be"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option “Device” "/dev/input/mice"
Option “Protocol” "ExplorerPS/2"
Option “Buttons” "7"
Option “ZAxisMapping” "6 7"
EndSection
Section "Device"
Identifier "NVIDIA Corporation NV34 [GeForce FX 5200]"
Driver "nvidia"
BusID "PCI:1:0:0"
Option “UseFBDev” "true"
Option "NoLogo"
EndSection
Section "Monitor"
Identifier "CPD-E430"
Option "DPMS"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "NVIDIA Corporation NV34 [GeForce FX 5200]"
Monitor "CPD-E430"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes “1280x1024” “1024x768” “800x600” "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
EndSection
#Section “DRI”
Mode 0666
#EndSection[/code]
tu remarqueras notemment des différence au niveau du “dri” et du “UseFBDev”.
je ne sais malheureusement pas t’aider beaucoup plus à ce stade.
