Cairo-dock+compiz
Quelques soucis avec mon bureau cairo-dock : rectangle noir autour des icônes. Je dois à chaque fois lancer la commande “compiz --replace” au redémarrage systeme.
[quote]$ compiz --replace
Checking if settings need to be migrated …no
Checking if internal files need to be migrated …no
Backend : gconf
Integration : true
Profile : default
Adding plugins
Initializing core options…done
Initializing composite options…done
Initializing opengl options…done
Initializing decor options…done
Initializing vpswitch options…done
Initializing snap options…done
Initializing mousepoll options…done
Initializing resize options…done
Initializing place options…done
Initializing move options…done
Initializing wall options…done
Initializing grid options…done
Initializing session options…done
Initializing gnomecompat options…done
Initializing animation options…done
Initializing fade options…done
Initializing workarounds options…done
Initializing scale options…done
compiz (expo) - Warn: failed to bind image to texture
Initializing expo options…done
Initializing ezoom options…done
Starting gtk-window-decorator
compiz (decor) - Warn: No default decoration found, placement will not be correct
