Caméra Web - WebCam
Bonsoir, je suis relativement nouveau sur Debian et j’éprouve un problème avec ma caméra intégré.
J’aimerais vos conseils et votre aide pour la faire fonctionner. Elle fonctionnait adéquatement il y a deux jours en chargeant le pilote uvcvideo mais depuis que j’ai redémarré elle n’est plus reconnue.
~$ lspci 00:00.0 Host bridge: Intel Corporation 3rd Gen Core processor DRAM Controller (rev 09) 00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v2/3rd Gen Core processor PCI Express Root Port (rev 09) 00:14.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB xHCI Host Controller (rev 04) 00:16.0 Communication controller: Intel Corporation 7 Series/C210 Series Chipset Family MEI Controller #1 (rev 04) 00:1a.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #2 (rev 04) 00:1b.0 Audio device: Intel Corporation 7 Series/C210 Series Chipset Family High Definition Audio Controller (rev 04) 00:1c.0 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 1 (rev c4) 00:1c.2 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 3 (rev c4) 00:1c.3 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 4 (rev c4) 00:1d.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #1 (rev 04) 00:1f.0 ISA bridge: Intel Corporation HM77 Express Chipset LPC Controller (rev 04) 00:1f.2 RAID bus controller: Intel Corporation 82801 Mobile SATA Controller [RAID mode] (rev 04) 00:1f.3 SMBus: Intel Corporation 7 Series/C210 Series Chipset Family SMBus Controller (rev 04) 01:00.0 VGA compatible controller: NVIDIA Corporation Device 0fd4 (rev a1) 01:00.1 Audio device: NVIDIA Corporation Device 0e1b (rev a1) 07:00.0 Ethernet controller: Atheros Communications Inc. AR8151 v2.0 Gigabit Ethernet (rev c0) 08:00.0 Network controller: Intel Corporation Centrino Wireless-N 2230 (rev c4) 09:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5209 PCI Express Card Reader (rev 01) 09:00.1 SD Host controller: Realtek Semiconductor Co., Ltd. RTS5209 PCI Express Card Reader (rev 01)
~$ lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 187c:0515 Alienware Corporation
Bus 003 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 004 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 003 Device 003: ID 187c:0520 Alienware Corporation
Bus 004 Device 003: ID 8087:07da Intel Corp.
Bus 004 Device 004: ID 0955:7002 NVidia Corp.
~$ lsmod | grep uvcvideo
uvcvideo               57744  0
videodev               70889  1 uvcvideo
media                  18148  2 videodev,uvcvideo
usbcore               128741  6 xhci_hcd,ehci_hcd,usbhid,btusb,uvcvideo
Je vous remercie d’avoir pris le temps de vous pencher sur mon problème.
Cordialement
Simon
Tu peux vérifier si le fichier /dev/video0 existe, ce serait bon signe.
Par contre, je vois pas quel est le modèle de ta cam parmi ces infos.
… pourrait aider. Il doit y avoir quelques lignes qui concernent le module uvcvideo.
Si ton ordi est un portable, vérifie que tu n’as pas une touche FN+qqch pour dés(activer) ta webcam.
Non, effectivement lorque j’ai vérifié je n’avais pas ce fichier /dev/video0.
Je vous ferai une copie du résultat dmesg dès que je serai de retour à la maison ce soir.
Concernant FN + quelque chose je vais essayer ça aussi, j’avoue que c’est logique.
Mais savez vous est-ce que je peux trouver la liste des racourcis clavier pour les évênements spéciaux.
Merci :slightly_smiling:
Les touches FN+qqch, elles sont visibles sur ton clavier de portable, vu que ça dépend du constructeur. Donc si on veut trouver cette info ailleurs, faut se renseigner sur les modèles d’ordi, mais bon, sinon suffit de regarder son clavier :stuck_out_tongue: Chez moi elles sont indiquées en bleu.
Évidemment, je vais testé ça dès mon retour, à ce que je peux voir en ligne pour mon AlienWare c’est FN + F9
Merci encore de l’attention particulière que vous portez à mon problème. :041
Donc effectivement depuis que j’ai fait FN+F9 ma WebCam est listé dans ChesseCam mais elle n’affiche qu’un écran noir.
~$ ls /dev/video*
/dev/video0
[code]dmesg
[ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Linux version 3.2.0-4-amd64 (debian-kernel@lists.debian.org) (gcc version 4.6.3 (Debian 4.6.3-14) ) #1
SMP Debian 3.2.51-1 [ 0.000000] Command line: BOOT_IMAGE=/vmlinuz-3.2.0-4-amd64 root=/dev/mapper/laptop-root ro single [ 0.000000] BIOS-provided physical RAM map: [ 0.000000] BIOS-e820: 0000000000000000
  • 0000000000091800 (usable) [ 0.000000] BIOS-e820: 0000000000091800 - 00000000000a0000 (reserved) [ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved) [ 0.000000] BIOS-e820:
    0000000000100000 - 00000000995b0000 (usable) [ 0.000000] BIOS-e820: 00000000995b0000 - 000000009a9b0000 (reserved) [ 0.000000] BIOS-e820: 000000009a9b0000 - 000000009f2bf000 (usable) [ 0.000000]
    BIOS-e820: 000000009f2bf000 - 000000009f6bf000 (reserved) [ 0.000000] BIOS-e820: 000000009f6bf000 - 000000009f7bf000 (ACPI NVS) [ 0.000000] BIOS-e820: 000000009f7bf000 - 000000009f7ff000 (ACPI data) [
    0.000000] BIOS-e820: 000000009f7ff000 - 000000009f800000 (usable) [ 0.000000] BIOS-e820: 000000009f800000 - 00000000a0000000 (reserved) [ 0.000000] BIOS-e820: 00000000e0000000 - 00000000f0000000
    (reserved) [ 0.000000] BIOS-e820: 00000000feb00000 - 00000000feb04000 (reserved) [ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved) [ 0.000000] BIOS-e820: 00000000fed10000 -
    00000000fed1a000 (reserved) [ 0.000000] BIOS-e820: 00000000fed1c000 - 00000000fed20000 (reserved) [ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved) [ 0.000000] BIOS-e820:
    00000000ffb00000 - 0000000100000000 (reserved) [ 0.000000] BIOS-e820: 0000000100000000 - 000000035f000000 (usable) [ 0.000000] NX (Execute Disable) protection: active [ 0.000000] SMBIOS 2.7 present. [
    0.000000] DMI: Alienware M17xR4/M17xR4, BIOS A09 06/29/2012 [ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved) [ 0.000000] e820 remove range: 00000000000a0000 -
    0000000000100000 (usable) [ 0.000000] No AGP bridge found [ 0.000000] last_pfn = 0x35f000 max_arch_pfn = 0x400000000 [ 0.000000] MTRR default type: uncachable [ 0.000000] MTRR fixed ranges enabled: [
    0.000000] 00000-9FFFF write-back [ 0.000000] A0000-BFFFF uncachable [ 0.000000] C0000-E7FFF write-protect [ 0.000000] E8000-EFFFF write-combining [ 0.000000] F0000-FFFFF write-protect [ 0.000000] MTRR variable ranges enabled: [ 0.000000] 0 base 000000000 mask F80000000 write-back [ 0.000000] 1 base 080000000 mask FE0000000 write-back [ 0.000000] 2 base 09F800000 mask FFF800000 uncachable [ 0.000000] 3 base 0FF800000 mask FFF800000 write-protect [ 0.000000] 4 base 100000000 mask F00000000 write-back [ 0.000000] 5 base 200000000 mask E00000000 write-back [ 0.000000] 6 base 35F000000 mask FFF000000 uncachable [ 0.000000] 7 base 360000000 mask FE0000000 uncachable [ 0.000000] 8 base 380000000 mask F80000000 uncachable [ 0.000000] 9 disabled [ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106 [ 0.000000] last_pfn = 0x9f800 max_arch_pfn = 0x400000000 [ 0.000000] found SMP MP-table at [ffff8800000fe1b0] fe1b0 [ 0.000000] initial memory mapped : 0 - 20000000 [ 0.000000] Base memory trampoline at [ffff88000008c000] 8c000 size 20480 [ 0.000000] init_memory_mapping: 0000000000000000-000000009f800000 [ 0.000000] 0000000000 - 009f800000 page 2M [ 0.000000] kernel direct mapping tables up to 9f800000 @ 1fffc000-20000000 [ 0.000000] init_memory_mapping: 0000000100000000-000000035f000000 [ 0.000000] 0100000000 - 035f000000 page 2M [ 0.000000] kernel direct mapping tables up to 35f000000 @ 9f2b4000-9f2bf000 [ 0.000000] RAMDISK: 36948000 - 3749c000 [ 0.000000] ACPI: RSDP 00000000000fe020 00024 (v02 ALWARE) [ 0.000000] ACPI: XSDT 000000009f7fe210 000B4 (v01 ALWARE ALIENWRE 00000001 01000013) [ 0.000000] ACPI: FACP 000000009f7fa000 0010C (v05 ALWARE ALIENWRE 00000001 ASL 00040000) [ 0.000000] ACPI Warning: FADT (revision 5) is longer than ACPI 2.0 version, truncating length 268 to 244 (20110623/tbfadt-288) [ 0.000000] ACPI: DSDT 000000009f7ec000 0A84D (v01 ALWARE ALIENWRE 00000000 ASL 00040000) [ 0.000000] ACPI: FACS 000000009f7b9000 00040 [ 0.000000] ACPI: SLIC 000000009f7fd000 00176 (v01 ALWARE ALIENWRE 00000001 ASL 00040000) [ 0.000000] ACPI: UEFI 000000009f7fc000 00236 (v01 ALWARE ALIENWRE 00000001 ASL 00040000) [ 0.000000] ACPI: ASF! 000000009f7fb000 000A5 (v32 ALWARE ALIENWRE 00000001 ASL 00040000) [ 0.000000] ACPI: HPET 000000009f7f9000 00038 (v01 ALWARE ALIENWRE 00000001 ASL 00040000) [ 0.000000] ACPI: APIC 000000009f7f8000 0008C (v03 ALWARE ALIENWRE 00000001 ASL 00040000) [ 0.000000] ACPI: MCFG 000000009f7f7000 0003C (v01 ALWARE ALIENWRE 00000001 ASL 00040000) [ 0.000000] ACPI: SLIC 000000009f7eb000 00176 (v01 ALWARE ALIENWRE 00000001 ASL 00040000) [ 0.000000] ACPI: SSDT 000000009f7ea000 006FE (v01 INSYDE H2O BIOS 00001000 ACPI 00040000) [ 0.000000] ACPI: BOOT 000000009f7e8000 00028 (v01 ALWARE ALIENWRE 00000001 ASL 00040000) [ 0.000000] ACPI: SSDT 000000009f7e7000 00406 (v01 INSYDE H2O BIOS 00001000 ACPI 00040000) [ 0.000000] ACPI: ASPT 000000009f7e6000 00034 (v07 ALWARE ALIENWRE 00000001 ASL 00040000) [ 0.000000] ACPI: DBGP 000000009f7e5000 00034 (v01 ALWARE ALIENWRE 00000001 ASL 00040000) [ 0.000000] ACPI: FPDT 000000009f7e3000 00044 (v01 ALWARE ALIENWRE 00000001 ASL 00040000) [ 0.000000] ACPI: SSDT 000000009f7e2000 00926 (v01 PmRef Cpu0Ist 00003000 INTL 20111123) [ 0.000000] ACPI: SSDT 000000009f7e1000 00A92 (v01 PmRef CpuPm 00003000 INTL 20111123) [ 0.000000] ACPI: SSDT 000000009f7dd000 02099 (v01 NvdPeg NvPegTb 00001000 INTL 20111123) [ 0.000000] ACPI: WDTT 000000009f7e0000 00224 (v02 ALWARE ALIENWRE 00000001 ASL 00040000) [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] No NUMA configuration found [ 0.000000] Faking a node at 0000000000000000-000000035f000000 [ 0.000000] Initmem setup node 0 0000000000000000-000000035f000000 [ 0.000000] NODE_DATA [000000035effb000 - 000000035effffff] [ 0.000000] [ffffea0000000000-ffffea000bdfffff] PMD -> [ffff880352600000-ffff88035cffffff] on node 0 [ 0.000000] Zone PFN ranges: [ 0.000000] DMA 0x00000010 -> 0x00001000 [ 0.000000] DMA32 0x00001000 -> 0x00100000 [ 0.000000] Normal 0x00100000 -> 0x0035f000 [ 0.000000] Movable zone start PFN for each node [ 0.000000] early_node_map[5] active PFN ranges [ 0.000000] 0: 0x00000010 -> 0x00000091 [ 0.000000] 0: 0x00000100 -> 0x000995b0 [ 0.000000] 0: 0x0009a9b0 -> 0x0009f2bf [ 0.000000] 0: 0x0009f7ff -> 0x0009f800 [ 0.000000] 0: 0x00100000 -> 0x0035f000 [ 0.000000] On node 0 totalpages: 3132993 [ 0.000000] DMA zone: 56 pages used for memmap [ 0.000000] DMA zone: 5 pages reserved [ 0.000000] DMA zone: 3908 pages, LIFO batch:0 [ 0.000000] DMA32 zone: 14280 pages used for memmap [ 0.000000] DMA32 zone: 628472 pages, LIFO batch:31 [ 0.000000] Normal zone: 33992 pages used for memmap [ 0.000000] Normal zone: 2452280 pages, LIFO batch:31 [ 0.000000] ACPI: PM-Timer IO Port: 0x408 [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x02] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x03] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x05] lapic_id[0x04] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x06] lapic_id[0x05] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x07] lapic_id[0x06] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x08] lapic_id[0x07] enabled) [ 0.000000] ACPI: IOAPIC (id[0x00] address[0xfec00000] gsi_base[0]) [ 0.000000] IOAPIC[0]: apic_id 0, version 32, address 0xfec00000, GSI 0-23 [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl) [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level) [ 0.000000] ACPI: IRQ0 used by override. [ 0.000000] ACPI: IRQ2 used by override. [ 0.000000] ACPI: IRQ9 used by override. [ 0.000000] Using ACPI (MADT) for SMP configuration information [ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000 [ 0.000000] SMP: Allowing 8 CPUs, 0 hotplug CPUs [ 0.000000] nr_irqs_gsi: 40 [ 0.000000] PM: Registered nosave memory: 0000000000091000 - 0000000000092000 [ 0.000000] PM: Registered nosave memory: 0000000000092000 - 00000000000a0000 [ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000 [ 0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000 [ 0.000000] PM: Registered nosave memory: 00000000995b0000 - 000000009a9b0000 [ 0.000000] PM: Registered nosave memory: 000000009f2bf000 - 000000009f6bf000 [ 0.000000] PM: Registered nosave memory: 000000009f6bf000 - 000000009f7bf000 [ 0.000000] PM: Registered nosave memory: 000000009f7bf000 - 000000009f7ff000 [ 0.000000] PM: Registered nosave memory: 000000009f800000 - 00000000a0000000 [ 0.000000] PM: Registered nosave memory: 00000000a0000000 - 00000000e0000000 [ 0.000000] PM: Registered nosave memory: 00000000e0000000 - 00000000f0000000 [ 0.000000] PM: Registered nosave memory: 00000000f0000000 - 00000000feb00000 [ 0.000000] PM: Registered nosave memory: 00000000feb00000 - 00000000feb04000 [ 0.000000] PM: Registered nosave memory: 00000000feb04000 - 00000000fec00000 [ 0.000000] PM: Registered nosave memory: 00000000fec00000 - 00000000fec01000 [ 0.000000] PM: Registered nosave memory: 00000000fec01000 - 00000000fed10000 [ 0.000000] PM: Registered nosave memory: 00000000fed10000 - 00000000fed1a000 [ 0.000000] PM: Registered nosave memory: 00000000fed1a000 - 00000000fed1c000 [ 0.000000] PM: Registered nosave memory: 00000000fed1c000 - 00000000fed20000 [ 0.000000] PM: Registered nosave memory: 00000000fed20000 - 00000000fee00000 [ 0.000000] PM: Registered nosave memory: 00000000fee00000 - 00000000fee01000 [ 0.000000] PM: Registered nosave memory: 00000000fee01000 - 00000000ffb00000 [ 0.000000] PM: Registered nosave memory: 00000000ffb00000 - 0000000100000000 [ 0.000000] Allocating PCI resources starting at a0000000 (gap: a0000000:40000000) [ 0.000000] Booting paravirtualized kernel on bare hardware [ 0.000000] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:8 nr_node_ids:1 [ 0.000000] PERCPU: Embedded 28 pages/cpu @ffff88035ec00000 s82944 r8192 d23552 u262144 [ 0.000000] pcpu-alloc: s82944 r8192 d23552 u262144 alloc=1*2097152 [ 0.000000] pcpu-alloc: [0] 0 1 2 3 4 5 6 7 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 3084660 [ 0.000000] Policy zone: Normal [ 0.000000] Kernel command line: BOOT_IMAGE=/vmlinuz-3.2.0-4-amd64 root=/dev/mapper/laptop-root ro single [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes) [ 0.000000] xsave/xrstor: enabled xstate_bv 0x7, cntxt size 0x340 [ 0.000000] Checking aperture… [ 0.000000] No AGP bridge found [ 0.000000] Calgary: detecting Calgary via BIOS EBDA area [ 0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing! [ 0.000000] Memory: 12270780k/14139392k available (3426k kernel code, 1607420k absent, 261192k reserved, 3312k data, 576k init) [ 0.000000] Hierarchical RCU implementation. [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] NR_IRQS:33024 nr_irqs:744 16 [ 0.000000] Console: colour VGA+ 80x25 [ 0.000000] console [tty0] enabled [ 0.000000] hpet clockevent registered [ 0.000000] Fast TSC calibration using PIT [ 0.004000] Detected 2394.336 MHz processor. [ 0.000002] Calibrating delay loop (skipped), value calculated using timer frequency… 4788.67 BogoMIPS (lpj=9577344) [ 0.000151] pid_max: default: 32768 minimum: 301 [ 0.000263] Security Framework initialized [ 0.000336] AppArmor: AppArmor disabled by boot time parameter [ 0.001307] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes) [ 0.005395] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes) [ 0.007257] Mount-cache hash table entries: 256 [ 0.007417] Initializing cgroup subsys cpuacct [ 0.007493] Initializing cgroup subsys memory [ 0.007573] Initializing cgroup subsys devices [ 0.007646] Initializing cgroup subsys freezer [ 0.007719] Initializing cgroup subsys net_cls [ 0.007792] Initializing cgroup subsys blkio [ 0.007868] Initializing cgroup subsys perf_event [ 0.007966] CPU: Physical Processor ID: 0 [ 0.008037] CPU: Processor Core ID: 0 [ 0.008111] ENERGY_PERF_BIAS: Set to ‘normal’, was ‘performance’ [ 0.008112] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8) [ 0.008644] mce: CPU supports 9 MCE banks [ 0.008726] CPU0: Thermal monitoring enabled (TM1) [ 0.008806] using mwait in idle threads. [ 0.009284] ACPI: Core revision 20110623 [ 0.027239] x2apic not enabled, IRQ remapping init failed [ 0.027706] …TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1 [ 0.067401] CPU0: Intel® Core™ i7-3630QM CPU @ 2.40GHz stepping 09 [ 0.171986] Performance Events: PEBS fmt1+, generic architected perfmon, Intel PMU driver. [ 0.172240] … version: 3 [ 0.172311] … bit width: 48 [ 0.172381] … generic registers: 4 [ 0.172453] … value mask: 0000ffffffffffff [ 0.172527] … max period: 000000007fffffff [ 0.172599] … fixed-purpose events: 3 [ 0.172670] … event mask: 000000070000000f [ 0.172866] NMI watchdog enabled, takes one hw-pmu counter. [ 0.173027] Booting Node 0, Processors #1 [ 0.173142] smpboot cpu 1: start_ip = 8c000 [ 0.284342] NMI watchdog enabled, takes one hw-pmu counter. [ 0.284506] #2 [ 0.284563] smpboot cpu 2: start_ip = 8c000 [ 0.392115] NMI watchdog enabled, takes one hw-pmu counter. [ 0.397533] #3 [ 0.397591] smpboot cpu 3: start_ip = 8c000 [ 0.507922] NMI watchdog enabled, takes one hw-pmu counter. [ 0.508077] #4 [ 0.508134] smpboot cpu 4: start_ip = 8c000 [ 0.615785] NMI watchdog enabled, takes one hw-pmu counter. [ 0.615945] #5 [ 0.616003] smpboot cpu 5: start_ip = 8c000 [ 0.723655] NMI watchdog enabled, takes one hw-pmu counter. [ 0.723811] #6 [ 0.723869] smpboot cpu 6: start_ip = 8c000 [ 0.831519] NMI watchdog enabled, takes one hw-pmu counter. [ 0.831677] #7 Ok. [ 0.831746] smpboot cpu 7: start_ip = 8c000 [ 0.939336] NMI watchdog enabled, takes one hw-pmu counter. [ 0.939432] Brought up 8 CPUs [ 0.939503] Total of 8 processors activated (38311.02 BogoMIPS). [ 0.946776] devtmpfs: initialized [ 0.949862] PM: Registering ACPI NVS region at 9f6bf000 (1048576 bytes) [ 0.950082] print_constraints: dummy: [ 0.950204] NET: Registered protocol family 16 [ 0.950345] ACPI FADT declares the system doesn’t support PCIe ASPM, so disable it [ 0.950433] ACPI: bus type pci registered [ 0.950572] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000) [ 0.950664] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820 [ 0.971909] PCI: Using configuration type 1 for base access [ 0.972820] bio: create slab at 0 [ 0.972975] ACPI: Added _OSI(Module Device) [ 0.973046] ACPI: Added _OSI(Processor Device) [ 0.973119] ACPI: Added _OSI(3.0 _SCP Extensions) [ 0.973192] ACPI: Added OSI(Processor Aggregator Device) [ 0.974648] ACPI: EC: Look up EC in DSDT [ 0.976013] ACPI: Executed 1 blocks of module-level executable AML code [ 0.991282] ACPI: SSDT 000000009f5f9018 0083B (v01 PmRef Cpu0Cst 00003001 INTL 20111123) [ 0.991834] ACPI: Dynamic OEM Table Load: [ 0.992017] ACPI: SSDT (null) 0083B (v01 PmRef Cpu0Cst 00003001 INTL 20111123) [ 1.002977] ACPI: SSDT 000000009f63ba98 00303 (v01 PmRef ApIst 00003000 INTL 20111123) [ 1.003560] ACPI: Dynamic OEM Table Load: [ 1.003740] ACPI: SSDT (null) 00303 (v01 PmRef ApIst 00003000 INTL 20111123) [ 1.014821] ACPI: SSDT 000000009f5f8d98 00119 (v01 PmRef ApCst 00003000 INTL 20111123) [ 1.015365] ACPI: Dynamic OEM Table Load: [ 1.015546] ACPI: SSDT (null) 00119 (v01 PmRef ApCst 00003000 INTL 20111123) [ 1.028008] ACPI: Interpreter enabled [ 1.028081] ACPI: (supports S0 S3 S4 S5) [ 1.028390] ACPI: Using IOAPIC for interrupt routing [ 1.150158] ACPI: Power Resource [FN00] (off) [ 1.150304] ACPI: Power Resource [FN01] (off) [ 1.150448] ACPI: Power Resource [FN02] (off) [ 1.150597] ACPI: Power Resource [FN03] (off) [ 1.150740] ACPI: Power Resource [FN04] (off) [ 1.151081] ACPI: EC: GPE = 0x17, I/O: command/status = 0x66, data = 0x62 [ 1.151329] ACPI: No dock devices found. [ 1.151401] HEST: Table not found. [ 1.151474] PCI: Using host bridge windows from ACPI; if necessary, use “pci=nocrs” and report a bug [ 1.151896] _SB.PCI0:_OSC invalid UUID [ 1.151897] _OSC request data:1 8 0 [ 1.151900] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe]) [ 1.152525] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7] [ 1.152600] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff] [ 1.152676] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff] [ 1.152764] pci_root PNP0A08:00: host bridge window [mem 0xa0000000-0xfeafffff] [ 1.152858] pci 0000:00:00.0: [8086:0154] type 0 class 0x000600 [ 1.152894] pci 0000:00:01.0: [8086:0151] type 1 class 0x000604 [ 1.152924] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold [ 1.152966] pci 0000:00:14.0: [8086:1e31] type 0 class 0x000c03 [ 1.152990] pci 0000:00:14.0: reg 10: [mem 0xc2300000-0xc230ffff 64bit] [ 1.153061] pci 0000:00:14.0: PME# supported from D3hot D3cold [ 1.153085] pci 0000:00:16.0: [8086:1e3a] type 0 class 0x000780 [ 1.153108] pci 0000:00:16.0: reg 10: [mem 0xc2314000-0xc231400f 64bit] [ 1.153184] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold [ 1.153219] pci 0000:00:1a.0: [8086:1e2d] type 0 class 0x000c03 [ 1.153240] pci 0000:00:1a.0: reg 10: [mem 0xc2319000-0xc23193ff] [ 1.153330] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold [ 1.153356] pci 0000:00:1b.0: [8086:1e20] type 0 class 0x000403 [ 1.153371] pci 0000:00:1b.0: reg 10: [mem 0xc2310000-0xc2313fff 64bit] [ 1.153438] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold [ 1.153462] pci 0000:00:1c.0: [8086:1e10] type 1 class 0x000604 [ 1.153542] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold [ 1.153570] pci 0000:00:1c.2: [8086:1e14] type 1 class 0x000604 [ 1.153648] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold [ 1.153675] pci 0000:00:1c.3: [8086:1e16] type 1 class 0x000604 [ 1.153754] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold [ 1.153787] pci 0000:00:1d.0: [8086:1e26] type 0 class 0x000c03 [ 1.153808] pci 0000:00:1d.0: reg 10: [mem 0xc2318000-0xc23183ff] [ 1.153898] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold [ 1.153923] pci 0000:00:1f.0: [8086:1e57] type 0 class 0x000601 [ 1.154048] pci 0000:00:1f.2: [8086:282a] type 0 class 0x000104 [ 1.154067] pci 0000:00:1f.2: reg 10: [io 0x4048-0x404f] [ 1.154075] pci 0000:00:1f.2: reg 14: [io 0x4054-0x4057] [ 1.154083] pci 0000:00:1f.2: reg 18: [io 0x4040-0x4047] [ 1.154092] pci 0000:00:1f.2: reg 1c: [io 0x4050-0x4053] [ 1.154099] pci 0000:00:1f.2: reg 20: [io 0x4020-0x403f] [ 1.154106] pci 0000:00:1f.2: reg 24: [mem 0xc2317000-0xc23177ff] [ 1.154151] pci 0000:00:1f.2: PME# supported from D3hot [ 1.154170] pci 0000:00:1f.3: [8086:1e22] type 0 class 0x000c05 [ 1.154185] pci 0000:00:1f.3: reg 10: [mem 0xc2315000-0xc23150ff 64bit] [ 1.154207] pci 0000:00:1f.3: reg 20: [io 0x4000-0x401f] [ 1.154263] pci 0000:01:00.0: [10de:0fd4] type 0 class 0x000300
~$ lsusb Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 001 Device 002: ID 187c:0515 Alienware Corporation Bus 003 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub Bus 004 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub Bus 003 Device 003: ID 187c:0520 Alienware Corporation Bus 003 Device 004: ID 064e:8127 Suyin Corp. Bus 004 Device 003: ID 8087:07da Intel Corp. Bus 004 Device 004: ID 0955:7002 NVidia Corp.
Finallement en changeant le ratio de la caméra tout fonctionne bien. Merci beaucoup, problème résolu!
:violin:
