Voilà, je crois que y’as du boulot là?
P.S.: Je sent que je vais m’y plaire chez-vous, j’espère que je vais en aider plus d’un moi aussi
zeus@kinderolympe:~$ dmesg
us registered, assigned bus number 2
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
ACPI: PCI interrupt 0000:00:11.4[D] -> GSI 11 (level, low) -> IRQ 11
uhci_hcd 0000:00:11.4: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller(#3)
uhci_hcd 0000:00:11.4: irq 11, io base 0000dc00
uhci_hcd 0000:00:11.4: new USB bus registered, assigned bus number 3
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
usb 1-1: new full speed USB device using address 2
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
usb 2-1: new low speed USB device using address 2
usbcore: registered new driver hiddev
usbhid: probe of 2-1:1.0 failed with error -5
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.0:USB HID core driver
input: Wacom Graphire on usb-0000:00:11.3-1
usbcore: registered new driver wacom
drivers/usb/input/wacom.c: v1.30:USB Wacom Graphire and Wacom Intuos tablet driver
usb 1-1.4: new full speed USB device using address 3
CSLIP: code copyright 1989 Regents of the University of California
PPP generic driver version 2.4.2
[eagle-usb] driver V2 loaded
[eagle-usb] New pre-firmware modem detected
[eagle-usb] Uploading firmware…
Linux agpgart interface v0.100 © Dave Jones
agpgart: Detected VIA KT266/KY266x/KT333 chipset
agpgart: Maximum main memory to use for agp memory: 203M
agpgart: AGP aperture is 64M @ 0xe8000000
[eagle-usb] Binding eu_instance_t to USB 001/003
usbcore: registered new driver eagle-usb
cpci_hotplug: CompactPCI Hot Plug Core version: 0.2
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
pciehp: acpi_pciehprm:_SB_.PCI0 evaluate BBN fail=0x5
pciehp: acpi_pciehprm:get_device PCI ROOT HID fail=0x5
usb 1-1.4: USB disconnect, address 3
[eagle-usb] Pre-firmware modem removed
shpchp: acpi_shpchprm:_SB.PCI0 evaluate BBN fail=0x5
shpchp: acpi_shpchprm:get_device PCI ROOT HID fail=0x5
usb 1-1.4: new full speed USB device using address 4
[eagle-usb] New USB ADSL device detected, waiting for DSP code…
[eagle-usb] Interface 0 accepted.
[eagle-usb] created proc entry at : /proc/driver/eagle-usb/001-004
[eagle-usb] ioctl EU_IO_OPTIONS received
[eagle-usb] ioctl EU_IO_DSP received
[eagle-usb] Loading DSP code to device…
[eagle-usb] DSP code successfully loaded to device
input: PC Speaker
inserting floppy driver for 2.6.8-2-386
Floppy drive(s): fd0 is 1.44M
FDC 0 is a post-1991 82077
parport: PnPBIOS parport detected.
parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE]
NET: Registered protocol family 10
Disabled Privacy Extensions on device c02cc960(lo)
IPv6 over IPv4 tunneling driver
[eagle-usb] Modem operational !!
[eagle-usb]  Ethernet device eth0 created.
NET: Registered protocol family 17
eth0: no IPv6 routers present
via_audio: ignoring drain playback error -11
Assertion failed! chan->is_active == sg_active(chan->iobase),sound/oss/via82cxxx_audio.c,via_chan_maybe_start,line=1387
uhci_hcd 0000:00:11.2: remove, state 1
usb usb1: USB disconnect, address 1
usb 1-1: USB disconnect, address 2
usb 1-1.4: USB disconnect, address 4
[eagle-usb] eu_irq : URB canceled by user.
[EAGLE-USB] eu_iso_read_completion: Can’t submit urb (-19)
[eagle-usb] ADSL device removed
uhci_hcd 0000:00:11.2: USB bus 1 deregistered
uhci_hcd 0000:00:11.3: remove, state 1
usb usb2: USB disconnect, address 1
usb 2-1: USB disconnect, address 2
uhci_hcd 0000:00:11.3: USB bus 2 deregistered
uhci_hcd 0000:00:11.4: remove, state 1
usb usb3: USB disconnect, address 1
uhci_hcd 0000:00:11.4: USB bus 3 deregistered
usbcore: deregistering driver wacom
pciehp: acpi_pciehprm:_SB.PCI0 evaluate BBN fail=0x5
USB Universal Host Controller Interface driver v2.2
ACPI: PCI interrupt 0000:00:11.2[D] -> GSI 11 (level, low) -> IRQ 11
uhci_hcd 0000:00:11.2: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller
uhci_hcd 0000:00:11.2: irq 11, io base 0000d400
uhci_hcd 0000:00:11.2: new USB bus registered, assigned bus number 1
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ACPI: PCI interrupt 0000:00:11.3[D] -> GSI 11 (level, low) -> IRQ 11
uhci_hcd 0000:00:11.3: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller(#2)
uhci_hcd 0000:00:11.3: irq 11, io base 0000d800
uhci_hcd 0000:00:11.3: new USB bus registered, assigned bus number 2
[eagle-usb] created proc entry at : /proc/driver/eagle-usb/001-003
shpchp: acpi_shpchprm:_SB.PCI0 evaluate _BBN fail=0x5
usb 1-1.3: new full speed USB device using address 4
Initializing USB Mass Storage driver…
scsi0 : SCSI emulation for USB Mass Storage devices
Vendor: EPSON     Model: Stylus Storage    Rev: 1.00
Type:   Direct-Access                      ANSI SCSI revision: 02
Attached scsi removable disk sda at scsi0, channel 0, id 0, lun 0
USB Mass Storage device found at 4
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
drivers/usb/class/usblp.c: usblp0: USB Bidirectional printer dev 4 if 1 alt 0 proto 2 vid 0x04B8 pid 0x0813
usbcore: registered new driver usblp
drivers/usb/class/usblp.c: v0.13: USB Printer Device Class driver
usb 1-1.3: USB disconnect, address 4
drivers/usb/class/usblp.c: usblp0: removed
