Voilà l’integralité de mon dmesg:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.26-1-686 (Debian 2.6.26-13) (waldi@debian.org) (gcc version 4.1.3 20080704 (prerelease) (Debian 4.1.2-24)) #1 SMP Sat Jan 10 18:29:31 UTC 2009
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009f800 (usable)
[ 0.000000] BIOS-e820: 000000000009f800 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000ce000 - 00000000000d0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000dc000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000007f6d0000 (usable)
[ 0.000000] BIOS-e820: 000000007f6d0000 - 000000007f6e3000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000007f6e3000 - 0000000080000000 (reserved)
[ 0.000000] BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec10000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed00000 - 00000000fed00400 (reserved)
[ 0.000000] BIOS-e820: 00000000fed14000 - 00000000fed1a000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed1c000 - 00000000fed90000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] BIOS-e820: 00000000ff000000 - 0000000100000000 (reserved)
[ 0.000000] 1142MB HIGHMEM available.
[ 0.000000] 896MB LOWMEM available.
[ 0.000000] found SMP MP-table at [c00f7d50] 000f7d50
[ 0.000000] Entering add_active_range(0, 0, 521936) 0 entries of 256 used
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0 -> 4096
[ 0.000000] Normal 4096 -> 229376
[ 0.000000] HighMem 229376 -> 521936
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[1] active PFN ranges
[ 0.000000] 0: 0 -> 521936
[ 0.000000] On node 0 totalpages: 521936
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 4064 pages, LIFO batch:0
[ 0.000000] Normal zone: 1760 pages used for memmap
[ 0.000000] Normal zone: 223520 pages, LIFO batch:31
[ 0.000000] HighMem zone: 2286 pages used for memmap
[ 0.000000] HighMem zone: 290274 pages, LIFO batch:31
[ 0.000000] Movable zone: 0 pages used for memmap
[ 0.000000] DMI present.
[ 0.000000] ACPI: RSDP 000F7D20, 0024 (r2 PTLTD )
[ 0.000000] ACPI: XSDT 7F6D9F64, 0094 (r1 PacBel PBNB0001 6040000 LTP 0)
[ 0.000000] ACPI: FACP 7F6E1BD2, 00F4 (r3 INTEL CRESTLNE 6040000 ALAN 1)
[ 0.000000] ACPI: DSDT 7F6DBCB4, 5EAA (r2 INTEL CRESTLNE 6040000 MSFT 100000E)
[ 0.000000] ACPI: FACS 7F6E2FC0, 0040
[ 0.000000] ACPI: APIC 7F6E1CC6, 0068 (r1 INTEL CRESTLNE 6040000 LOHR 5A)
[ 0.000000] ACPI: HPET 7F6E1D2E, 0038 (r1 INTEL CRESTLNE 6040000 LOHR 5A)
[ 0.000000] ACPI: MCFG 7F6E1D66, 003C (r1 INTEL CRESTLNE 6040000 LOHR 5A)
[ 0.000000] ACPI: TCPA 7F6E1DA2, 0032 (r1 Intel CRESTLN 6040000 5A52)
[ 0.000000] ACPI: TMOR 7F6E1DD4, 0026 (r1 PTLTD 6040000 PTL 3)
[ 0.000000] ACPI: APIC 7F6E1DFA, 0068 (r1 PTLTD APIC 6040000 LTP 0)
[ 0.000000] ACPI: BOOT 7F6E1E62, 0028 (r1 PTLTD $SBFTBL$ 6040000 LTP 1)
[ 0.000000] ACPI: SLIC 7F6E1E8A, 0176 (r1 PacBel PBNB0001 6040000 LTP 0)
[ 0.000000] ACPI: SSDT 7F6DB665, 064F (r1 SataRe SataPri 1000 INTL 20050624)
[ 0.000000] ACPI: SSDT 7F6DAFD3, 0692 (r1 SataRe SataSec 1000 INTL 20050624)
[ 0.000000] ACPI: SSDT 7F6DA584, 025F (r1 PmRef Cpu0Tst 3000 INTL 20050624)
[ 0.000000] ACPI: SSDT 7F6DA4DE, 00A6 (r1 PmRef Cpu1Tst 3000 INTL 20050624)
[ 0.000000] ACPI: SSDT 7F6D9FF8, 04E6 (r1 PmRef CpuPm 3000 INTL 20050624)
[ 0.000000] ACPI: BIOS bug: multiple APIC/MADT found, using 0
[ 0.000000] ACPI: If "acpi_apic_instance=2" works better, notify linux-acpi@vger.kernel.org
[ 0.000000] ACPI: PM-Timer IO Port: 0x1008
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] Allocating PCI resources starting at 88000000 (gap: 80000000:60000000)
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000ce000
[ 0.000000] PM: Registered nosave memory: 00000000000ce000 - 00000000000d0000
[ 0.000000] PM: Registered nosave memory: 00000000000d0000 - 00000000000dc000
[ 0.000000] PM: Registered nosave memory: 00000000000dc000 - 0000000000100000
[ 0.000000] SMP: Allowing 2 CPUs, 0 hotplug CPUs
[ 0.000000] PERCPU: Allocating 37960 bytes of per cpu data
[ 0.000000] NR_CPUS: 8, nr_cpu_ids: 2
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 517858
[ 0.000000] Kernel command line: root=/dev/sda2 ro
[ 0.000000] mapped APIC to ffffb000 (fee00000)
[ 0.000000] mapped IOAPIC to ffffa000 (fec00000)
[ 0.000000] Enabling fast FPU save and restore... done.
[ 0.000000] Enabling unmasked SIMD FPU exception support... done.
[ 0.000000] Initializing CPU#0
[ 0.000000] PID hash table entries: 4096 (order: 12, 16384 bytes)
[ 0.000000] Extended CMOS year: 2000
[ 0.000000] Detected 1496.294 MHz processor.
[ 0.004000] Console: colour VGA+ 80x25
[ 0.004000] console [tty0] enabled
[ 0.004000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.004000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.004000] Memory: 2058468k/2087744k available (1769k kernel code, 27980k reserved, 752k data, 244k init, 1170240k highmem)
[ 0.004000] virtual kernel memory layout:
[ 0.004000] fixmap : 0xfff4c000 - 0xfffff000 ( 716 kB)
[ 0.004000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.004000] vmalloc : 0xf8800000 - 0xff7fe000 ( 111 MB)
[ 0.004000] lowmem : 0xc0000000 - 0xf8000000 ( 896 MB)
[ 0.004000] .init : 0xc037f000 - 0xc03bc000 ( 244 kB)
[ 0.004000] .data : 0xc02ba4ab - 0xc0376620 ( 752 kB)
[ 0.004000] .text : 0xc0100000 - 0xc02ba4ab (1769 kB)
[ 0.004000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.004000] CPA: page pool initialized 1 of 1 pages preallocated
[ 0.004000] hpet clockevent registered
[ 0.083945] Calibrating delay using timer specific routine.. 2997.12 BogoMIPS (lpj=5994252)
[ 0.084005] Security Framework initialized
[ 0.084005] SELinux: Disabled at boot.
[ 0.084005] Capability LSM initialized
[ 0.084005] Mount-cache hash table entries: 512
[ 0.084005] Initializing cgroup subsys ns
[ 0.084005] Initializing cgroup subsys cpuacct
[ 0.084005] Initializing cgroup subsys devices
[ 0.084005] CPU: L1 I cache: 32K, L1 D cache: 32K
[ 0.084005] CPU: L2 cache: 2048K
[ 0.084005] CPU: Physical Processor ID: 0
[ 0.084005] CPU: Processor Core ID: 0
[ 0.084005] Intel machine check architecture supported.
[ 0.084005] Intel machine check reporting enabled on CPU#0.
[ 0.084005] using mwait in idle threads.
[ 0.084005] Checking 'hlt' instruction... OK.
[ 0.100006] ACPI: Core revision 20080321
[ 0.115247] ENABLING IO-APIC IRQs
[ 0.115555] ..TIMER: vector=0x31 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.155370] CPU0: Intel(R) Core(TM)2 Duo CPU T5250 @ 1.50GHz stepping 0d
[ 0.156009] Booting processor 1/1 ip 6000
[ 0.164010] Initializing CPU#1
[ 0.164010] Calibrating delay using timer specific routine.. 2992.47 BogoMIPS (lpj=5984959)
[ 0.164010] CPU: L1 I cache: 32K, L1 D cache: 32K
[ 0.164010] CPU: L2 cache: 2048K
[ 0.164010] CPU: Physical Processor ID: 0
[ 0.164010] CPU: Processor Core ID: 1
[ 0.164010] Intel machine check architecture supported.
[ 0.164010] Intel machine check reporting enabled on CPU#1.
[ 0.244015] CPU1: Intel(R) Core(TM)2 Duo CPU T5250 @ 1.50GHz stepping 0d
[ 0.244015] checking TSC synchronization [CPU#0 -> CPU#1]: passed.
[ 0.248015] Brought up 2 CPUs
[ 0.248015] Total of 2 processors activated (5989.60 BogoMIPS).
[ 0.248015] CPU0 attaching sched-domain:
[ 0.248015] domain 0: span 0-1
[ 0.248015] groups: 0 1
[ 0.248015] CPU1 attaching sched-domain:
[ 0.248015] groups: 1 0
[ 0.248015] net_namespace: 660 bytes
[ 0.248015] Booting paravirtualized kernel on bare hardware
[ 0.248015] NET: Registered protocol family 16
[ 0.248015] ACPI: bus type pci registered
[ 0.248015] PCI: MCFG configuration 0: base e0000000 segment 0 buses 0 - 255
[ 0.248015] PCI: MCFG area at e0000000 reserved in E820
[ 0.248015] PCI: Using MMCONFIG for extended config space
[ 0.248113] PCI: Using configuration type 1 for base access
[ 0.248229] Setting up standard PCI resources
[ 0.256016] ACPI: EC: Look up EC in DSDT
[ 0.260016] ACPI: BIOS _OSI(Linux) query ignored
[ 0.260016] ACPI: DMI System Vendor: Packard Bell BV
[ 0.260016] ACPI: DMI Product Name: EasyNote MB65
[ 0.260016] ACPI: DMI Product Version: PB87Q04402
[ 0.260016] ACPI: DMI Board Name: PB2
[ 0.260016] ACPI: DMI BIOS Vendor: Phoenix Technologies LTD
[ 0.260016] ACPI: DMI BIOS Date: 08/30/2007
[ 0.260016] ACPI: Please send DMI info above to linux-acpi@vger.kernel.org
[ 0.260016] ACPI: If "acpi_osi=Linux" works better, please notify linux-acpi@vger.kernel.org
[ 0.261377] ACPI: Interpreter enabled
[ 0.261467] ACPI: (supports S0 S3 S4 S5)
[ 0.261854] ACPI: Using IOAPIC for interrupt routing
[ 0.264049] ACPI: EC: non-query interrupt received, switching to interrupt mode
[ 0.288018] ACPI: EC: GPE = 0x17, I/O: command/status = 0x66, data = 0x62
[ 0.288018] ACPI: EC: driver started in interrupt mode
[ 0.288018] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.289331] pci 0000:00:1f.0: quirk: region 1000-107f claimed by ICH6 ACPI/GPIO/TCO
[ 0.289437] pci 0000:00:1f.0: quirk: region 1180-11bf claimed by ICH6 GPIO
[ 0.292161] PCI: Transparent bridge - 0000:00:1e.0
[ 0.292308] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.292905] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEGP._PRT]
[ 0.292941] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP01._PRT]
[ 0.293174] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP02._PRT]
[ 0.293411] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP06._PRT]
[ 0.293670] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCIB._PRT]
[ 0.312942] ACPI: PCI Interrupt Link [LNKA] (IRQs 1 3 4 5 6 7 12 14 15) *11
[ 0.312942] ACPI: PCI Interrupt Link [LNKB] (IRQs 1 3 4 5 6 7 *11 12 14 15)
[ 0.314041] ACPI: PCI Interrupt Link [LNKC] (IRQs 1 3 4 *5 6 7 12 14 15)
[ 0.317124] ACPI: PCI Interrupt Link [LNKD] (IRQs 1 3 4 *5 6 7 11 12 14 15)
[ 0.318215] ACPI: PCI Interrupt Link [LNKE] (IRQs 1 3 4 5 6 7 12 14 15) *0, disabled.
[ 0.319398] ACPI: PCI Interrupt Link [LNKF] (IRQs 1 3 4 5 6 *7 11 12 14 15)
[ 0.320500] ACPI: PCI Interrupt Link [LNKG] (IRQs 1 3 4 *5 6 7 12 14 15)
[ 0.321522] ACPI: PCI Interrupt Link [LNKH] (IRQs 1 3 4 5 6 7 *11 12 14 15)
[ 0.323000] ACPI: Power Resource [QFAN] (off)
[ 0.323424] Linux Plug and Play Support v0.97 (c) Adam Belay
[ 0.327000] pnp: PnP ACPI init
[ 0.327000] ACPI: bus type pnp registered
[ 0.331512] pnp: PnP ACPI: found 11 devices
[ 0.331512] ACPI: ACPI bus type pnp unregistered
[ 0.331512] PnPBIOS: Disabled by ACPI PNP
[ 0.331514] PCI: Using ACPI for IRQ routing
[ 0.339475] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.339849] hpet0: 3 64-bit timers, 14318180 Hz
[ 0.341018] ACPI: RTC can wake from S4
[ 0.345365] system 00:01: iomem range 0xfed1c000-0xfed1ffff could not be reserved
[ 0.345470] system 00:01: iomem range 0xfed14000-0xfed17fff could not be reserved
[ 0.345575] system 00:01: iomem range 0xfed18000-0xfed18fff could not be reserved
[ 0.345679] system 00:01: iomem range 0xfed19000-0xfed19fff could not be reserved
[ 0.345784] system 00:01: iomem range 0xe0000000-0xefffffff could not be reserved
[ 0.345889] system 00:01: iomem range 0xfed20000-0xfed3ffff could not be reserved
[ 0.345994] system 00:01: iomem range 0xfed40000-0xfed44fff could not be reserved
[ 0.346099] system 00:01: iomem range 0xfed45000-0xfed8ffff could not be reserved
[ 0.346214] system 00:05: iomem range 0xfed00000-0xfed003ff could not be reserved
[ 0.346326] system 00:07: ioport range 0x680-0x69f has been reserved
[ 0.346419] system 00:07: ioport range 0x800-0x80f has been reserved
[ 0.346511] system 00:07: ioport range 0x1000-0x107f has been reserved
[ 0.346604] system 00:07: ioport range 0x1180-0x11bf has been reserved
[ 0.346694] system 00:07: ioport range 0x1640-0x164f has been reserved
[ 0.346788] system 00:07: ioport range 0xfe00-0xfe00 has been reserved
[ 0.377690] PCI: Failed to allocate mem resource #6:20000@e0000000 for 0000:01:00.0
[ 0.377795] PCI: Bridge: 0000:00:01.0
[ 0.377883] IO window: 2000-2fff
[ 0.377972] MEM window: 0xcc000000-0xceffffff
[ 0.378063] PREFETCH window: 0x00000000d0000000-0x00000000dfffffff
[ 0.378157] PCI: Bridge: 0000:00:1c.0
[ 0.378244] IO window: disabled.
[ 0.378335] MEM window: 0xf4100000-0xf41fffff
[ 0.378426] PREFETCH window: disabled.
[ 0.378520] PCI: Bridge: 0000:00:1c.1
[ 0.378610] IO window: 3000-3fff
[ 0.378703] MEM window: 0xf2000000-0xf3ffffff
[ 0.378796] PREFETCH window: 0x00000000f0000000-0x00000000f1ffffff
[ 0.378893] PCI: Bridge: 0000:00:1c.5
[ 0.378982] IO window: 4000-4fff
[ 0.379074] MEM window: 0xf4000000-0xf40fffff
[ 0.379167] PREFETCH window: disabled.
[ 0.379263] PCI: Bridge: 0000:00:1e.0
[ 0.379348] IO window: disabled.
[ 0.379441] MEM window: 0xf4200000-0xf42fffff
[ 0.381340] PREFETCH window: disabled.
[ 0.381340] ACPI: PCI Interrupt 0000:00:01.0[A] -> GSI 16 (level, low) -> IRQ 16
[ 0.381340] PCI: Setting latency timer of device 0000:00:01.0 to 64
[ 0.381340] ACPI: PCI Interrupt 0000:00:1c.0[A] -> GSI 17 (level, low) -> IRQ 17
[ 0.381340] PCI: Setting latency timer of device 0000:00:1c.0 to 64
[ 0.381340] ACPI: PCI Interrupt 0000:00:1c.1[B] -> GSI 16 (level, low) -> IRQ 16
[ 0.381340] PCI: Setting latency timer of device 0000:00:1c.1 to 64
[ 0.381340] ACPI: PCI Interrupt 0000:00:1c.5[B] -> GSI 16 (level, low) -> IRQ 16
[ 0.381340] PCI: Setting latency timer of device 0000:00:1c.5 to 64
[ 0.381340] PCI: Setting latency timer of device 0000:00:1e.0 to 64
[ 0.381340] NET: Registered protocol family 2
[ 0.393426] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.393901] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.394616] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.395004] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.395095] TCP reno registered
[ 0.397440] NET: Registered protocol family 1
[ 0.397698] checking if image is initramfs...<7>Switched to high resolution mode on CPU 1
[ 0.511352] Switched to high resolution mode on CPU 0
[ 0.956431] it is
[ 1.549439] Freeing initrd memory: 7494k freed
[ 1.552435] Simple Boot Flag at 0x36 set to 0x1
[ 1.552435] audit: initializing netlink socket (disabled)
[ 1.552435] type=2000 audit(1235664452.540:1): initialized
[ 1.552657] highmem bounce pool size: 64 pages
[ 1.552657] Total HugeTLB memory allocated, 0
[ 1.552657] VFS: Disk quotas dquot_6.5.1
[ 1.552657] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.552657] msgmni has been set to 1751
[ 1.554764] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 1.554869] io scheduler noop registered
[ 1.554958] io scheduler anticipatory registered
[ 1.555048] io scheduler deadline registered
[ 1.555155] io scheduler cfq registered (default)
[ 1.555458] pci 0000:01:00.0: Boot video device
[ 1.556432] PCI: Setting latency timer of device 0000:00:01.0 to 64
[ 1.556432] assign_interrupt_mode Found MSI capability
[ 1.556432] Allocate Port Service[0000:00:01.0:pcie00]
[ 1.556432] Allocate Port Service[0000:00:01.0:pcie02]
[ 1.556432] Allocate Port Service[0000:00:01.0:pcie03]
[ 1.556432] PCI: Setting latency timer of device 0000:00:1c.0 to 64
[ 1.556432] Allocate Port Service[0000:00:1c.0:pcie00]
[ 1.556432] Allocate Port Service[0000:00:1c.0:pcie02]
[ 1.556432] Allocate Port Service[0000:00:1c.0:pcie03]
[ 1.556432] PCI: Setting latency timer of device 0000:00:1c.1 to 64
[ 1.556432] Allocate Port Service[0000:00:1c.1:pcie00]
[ 1.556432] Allocate Port Service[0000:00:1c.1:pcie02]
[ 1.556433] Allocate Port Service[0000:00:1c.1:pcie03]
[ 1.556433] PCI: Setting latency timer of device 0000:00:1c.5 to 64
[ 1.556433] assign_interrupt_mode Found MSI capability
[ 1.556433] Allocate Port Service[0000:00:1c.5:pcie00]
[ 1.556433] Allocate Port Service[0000:00:1c.5:pcie02]
[ 1.556433] Allocate Port Service[0000:00:1c.5:pcie03]
[ 1.556460] isapnp: Scanning for PnP cards...
[ 1.914885] isapnp: No Plug & Play device found
[ 1.920359] hpet_resources: 0xfed00000 is busy
[ 1.920359] Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
[ 1.924070] brd: module loaded
[ 1.924070] PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 1.927718] i8042.c: Detected active multiplexing controller, rev 1.1.
[ 1.929427] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.929519] serio: i8042 AUX0 port at 0x60,0x64 irq 12
[ 1.931681] serio: i8042 AUX1 port at 0x60,0x64 irq 12
[ 1.931771] serio: i8042 AUX2 port at 0x60,0x64 irq 12
[ 1.931860] serio: i8042 AUX3 port at 0x60,0x64 irq 12
[ 1.932133] mice: PS/2 mouse device common for all mice
[ 1.932133] rtc_cmos 00:08: rtc core: registered rtc_cmos as rtc0
[ 1.932133] rtc0: alarms up to one month, y3k
[ 1.932133] cpuidle: using governor ladder
[ 1.932133] cpuidle: using governor menu
[ 1.932133] No iBFT detected.
[ 1.932133] TCP cubic registered
[ 1.932133] NET: Registered protocol family 17
[ 1.932133] Using IPI No-Shortcut mode
[ 1.932133] registered taskstats version 1
[ 1.932463] rtc_cmos 00:08: setting system clock to 2009-02-26 16:07:34 UTC (1235664454)
[ 1.932463] Freeing unused kernel memory: 244k freed
[ 2.027833] input: AT Translated Set 2 keyboard as /class/input/input0
[ 2.094521] ACPI: Transitioning device [FAN] to D3
[ 2.094521] ACPI: PNP0C0B:00 is registered as cooling_device0
[ 2.094521] ACPI: Fan [FAN] (off)
[ 2.106522] ACPI: SSDT 7F6DAD57, 01B4 (r1 PmRef Cpu0Ist 3000 INTL 20050624)
[ 2.106522] ACPI: SSDT 7F6DA7E3, 04EF (r1 PmRef Cpu0Cst 3001 INTL 20050624)
[ 2.113688] Monitor-Mwait will be used to enter C-1 state
[ 2.113694] Monitor-Mwait will be used to enter C-2 state
[ 2.113700] Monitor-Mwait will be used to enter C-3 state
[ 2.113817] ACPI: CPU0 (power states: C1[C1] C2[C2] C3[C3])
[ 2.117817] ACPI: ACPI0007:00 is registered as cooling_device1
[ 2.117817] ACPI: Processor [CPU0] (supports 8 throttling states)
[ 2.117817] ACPI: SSDT 7F6DAF0B, 00C8 (r1 PmRef Cpu1Ist 3000 INTL 20050624)
[ 2.117817] ACPI: SSDT 7F6DACD2, 0085 (r1 PmRef Cpu1Cst 3000 INTL 20050624)
[ 2.117817] Marking TSC unstable due to: TSC halts in idle.
[ 2.121815] ACPI: CPU1 (power states: C1[C1] C2[C2] C3[C3])
[ 2.122228] ACPI: ACPI0007:01 is registered as cooling_device2
[ 2.122228] ACPI: Processor [CPU1] (supports 8 throttling states)
[ 2.125846] ACPI: LNXTHERM:01 is registered as thermal_zone0
[ 2.178128] ACPI: Thermal Zone [THRM] (54 C)
[ 2.637875] usbcore: registered new interface driver usbfs
[ 2.638011] usbcore: registered new interface driver hub
[ 2.638160] usbcore: registered new device driver usb
[ 2.648471] USB Universal Host Controller Interface driver v3.0
[ 2.649522] ACPI: PCI Interrupt 0000:00:1a.0[A] -> GSI 16 (level, low) -> IRQ 16
[ 2.649522] PCI: Setting latency timer of device 0000:00:1a.0 to 64
[ 2.649522] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[ 2.649522] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 2.649522] uhci_hcd 0000:00:1a.0: irq 16, io base 0x00001800
[ 2.649522] usb usb1: configuration #1 chosen from 1 choice
[ 2.649556] hub 1-0:1.0: USB hub found
[ 2.649651] hub 1-0:1.0: 2 ports detected
[ 2.754001] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.754099] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.754201] usb usb1: Product: UHCI Host Controller
[ 2.754290] usb usb1: Manufacturer: Linux 2.6.26-1-686 uhci_hcd
[ 2.754381] usb usb1: SerialNumber: 0000:00:1a.0
[ 2.756549] ACPI: PCI Interrupt 0000:00:1a.1[B] -> GSI 21 (level, low) -> IRQ 21
[ 2.756737] PCI: Setting latency timer of device 0000:00:1a.1 to 64
[ 2.756744] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[ 2.756871] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 2
[ 2.757015] uhci_hcd 0000:00:1a.1: irq 21, io base 0x00001820
[ 2.757229] usb usb2: configuration #1 chosen from 1 choice
[ 2.757365] hub 2-0:1.0: USB hub found
[ 2.757459] hub 2-0:1.0: 2 ports detected
[ 2.787535] No dock devices found.
[ 2.818077] SCSI subsystem initialized
[ 2.836068] libata version 3.00 loaded.
[ 2.866077] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.866077] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.866077] usb usb2: Product: UHCI Host Controller
[ 2.866077] usb usb2: Manufacturer: Linux 2.6.26-1-686 uhci_hcd
[ 2.866077] usb usb2: SerialNumber: 0000:00:1a.1
[ 2.866077] ACPI: PCI Interrupt 0000:00:1a.7[C] -> GSI 18 (level, low) -> IRQ 18
[ 2.868999] PCI: Setting latency timer of device 0000:00:1a.7 to 64
[ 2.869006] ehci_hcd 0000:00:1a.7: EHCI Host Controller
[ 2.869142] ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 3
[ 2.874081] ehci_hcd 0000:00:1a.7: debug port 1
[ 2.874175] PCI: cache line size of 32 is not supported by device 0000:00:1a.7
[ 2.874195] ehci_hcd 0000:00:1a.7: irq 18, io mem 0xf4504000
[ 2.887072] ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
[ 2.887296] usb usb3: configuration #1 chosen from 1 choice
[ 2.887436] hub 3-0:1.0: USB hub found
[ 2.887530] hub 3-0:1.0: 4 ports detected
[ 2.914466] ricoh-mmc: Ricoh MMC Controller disabling driver
[ 2.914466] ricoh-mmc: Copyright(c) Philip Langdale
[ 2.917894] sdhci: Secure Digital Host Controller Interface driver
[ 2.917992] sdhci: Copyright(c) Pierre Ossman
[ 2.993735] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.993835] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.993939] usb usb3: Product: EHCI Host Controller
[ 2.994030] usb usb3: Manufacturer: Linux 2.6.26-1-686 ehci_hcd
[ 2.994121] usb usb3: SerialNumber: 0000:00:1a.7
[ 2.997457] ACPI: PCI Interrupt 0000:00:1d.0[A] -> GSI 23 (level, low) -> IRQ 23
[ 2.997457] PCI: Setting latency timer of device 0000:00:1d.0 to 64
[ 2.997457] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 2.997457] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 4
[ 2.997457] uhci_hcd 0000:00:1d.0: irq 23, io base 0x00001840
[ 2.997457] usb usb4: configuration #1 chosen from 1 choice
[ 2.997457] hub 4-0:1.0: USB hub found
[ 2.997457] hub 4-0:1.0: 2 ports detected
[ 3.100930] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.101029] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.101131] usb usb4: Product: UHCI Host Controller
[ 3.101220] usb usb4: Manufacturer: Linux 2.6.26-1-686 uhci_hcd
[ 3.101310] usb usb4: SerialNumber: 0000:00:1d.0
[ 3.102159] ACPI: PCI Interrupt 0000:00:1d.1[B] -> GSI 19 (level, low) -> IRQ 19
[ 3.102159] PCI: Setting latency timer of device 0000:00:1d.1 to 64
[ 3.102159] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 3.102159] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 5
[ 3.102159] uhci_hcd 0000:00:1d.1: irq 19, io base 0x00001860
[ 3.102159] usb usb5: configuration #1 chosen from 1 choice
[ 3.102159] hub 5-0:1.0: USB hub found
[ 3.102159] hub 5-0:1.0: 2 ports detected
[ 3.205167] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.205260] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.205363] usb usb5: Product: UHCI Host Controller
[ 3.205451] usb usb5: Manufacturer: Linux 2.6.26-1-686 uhci_hcd
[ 3.205541] usb usb5: SerialNumber: 0000:00:1d.1
[ 3.208645] ACPI: PCI Interrupt 0000:00:1d.2[C] -> GSI 18 (level, low) -> IRQ 18
[ 3.208645] PCI: Setting latency timer of device 0000:00:1d.2 to 64
[ 3.208645] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 3.208645] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 6
[ 3.208645] uhci_hcd 0000:00:1d.2: irq 18, io base 0x00001880
[ 3.208645] usb usb6: configuration #1 chosen from 1 choice
[ 3.208645] hub 6-0:1.0: USB hub found
[ 3.208645] hub 6-0:1.0: 2 ports detected
[ 3.284020] usb 3-1: new high speed USB device using ehci_hcd and address 2
[ 3.308907] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.309002] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.309104] usb usb6: Product: UHCI Host Controller
[ 3.309193] usb usb6: Manufacturer: Linux 2.6.26-1-686 uhci_hcd
[ 3.309283] usb usb6: SerialNumber: 0000:00:1d.2
[ 3.312628] ACPI: PCI Interrupt 0000:00:1d.7[A] -> GSI 23 (level, low) -> IRQ 23
[ 3.312628] PCI: Setting latency timer of device 0000:00:1d.7 to 64
[ 3.312628] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 3.312628] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 7
[ 3.316610] ehci_hcd 0000:00:1d.7: debug port 1
[ 3.316610] PCI: cache line size of 32 is not supported by device 0000:00:1d.7
[ 3.316610] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xf4504400
[ 3.408616] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
[ 3.408661] usb usb7: configuration #1 chosen from 1 choice
[ 3.408661] hub 7-0:1.0: USB hub found
[ 3.408661] hub 7-0:1.0: 6 ports detected
[ 3.430256] usb 3-1: configuration #1 chosen from 1 choice
[ 3.433104] usb 3-1: New USB device found, idVendor=04f2, idProduct=b024
[ 3.433104] usb 3-1: New USB device strings: Mfr=2, Product=1, SerialNumber=3
[ 3.433104] usb 3-1: Product: USB 2.0 Camera
[ 3.433104] usb 3-1: Manufacturer: Chicony Electronics Co., Ltd.
[ 3.433104] usb 3-1: SerialNumber: SN0001
[ 3.511455] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.511550] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.511651] usb usb7: Product: EHCI Host Controller
[ 3.511738] usb usb7: Manufacturer: Linux 2.6.26-1-686 ehci_hcd
[ 3.511827] usb usb7: SerialNumber: 0000:00:1d.7
[ 3.513539] ACPI: PCI Interrupt 0000:06:00.0[A] -> GSI 17 (level, low) -> IRQ 17
[ 3.513539] PCI: Setting latency timer of device 0000:06:00.0 to 64
[ 3.513539] sky2 0000:06:00.0: v1.21 addr 0xf4000000 irq 17 Yukon-FE (0xb7) rev 3
[ 3.515858] sky2 eth0: addr 00:1b:24:a3:b5:2b
[ 3.517698] ACPI: PCI Interrupt 0000:07:01.0[A] -> GSI 16 (level, low) -> IRQ 16
[ 3.533777] Clocksource tsc unstable (delta = -321853033 ns)
[ 3.569443] ohci1394: fw-host0: OHCI-1394 1.1 (PCI): IRQ=[16] MMIO=[f4200000-f42007ff] Max Packet=[2048] IR/IT contexts=[4/4]
[ 3.581517] ata_piix 0000:00:1f.2: version 2.12
[ 3.585072] sdhci: SDHCI controller found at 0000:07:01.1 [1180:0822] (rev 19)
[ 3.581517] ACPI: PCI Interrupt 0000:00:1f.2[B] -> GSI 19 (level, low) -> IRQ 19
[ 3.581517] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 3.585393] ACPI: PCI Interrupt 0000:07:01.1[B] -> GSI 17 (level, low) -> IRQ 17
[ 3.585449] mmc0: Will use DMA mode even though HW doesn't fully claim to support it.
[ 3.587619] mmc0: SDHCI at 0xf4200800 irq 17 DMA
[ 3.587768] ricoh-mmc: Ricoh MMC controller found at 0000:07:01.2 [1180:0843] (rev 1)
[ 3.587894] ricoh-mmc: Controller is now disabled.
[ 3.593424] Uniform Multi-Platform E-IDE driver
[ 3.593424] ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
[ 3.737621] PCI: Setting latency timer of device 0000:00:1f.2 to 64
[ 3.741566] scsi0 : ata_piix
[ 3.749566] scsi1 : ata_piix
[ 3.749566] ata1: SATA max UDMA/133 cmd 0x18f8 ctl 0x18cc bmdma 0x18e0 irq 19
[ 3.749566] ata2: SATA max UDMA/133 cmd 0x18f0 ctl 0x18c8 bmdma 0x18e8 irq 19
[ 3.800203] udev: renamed network interface eth0 to eth1
[ 4.152964] usb 4-1: new low speed USB device using uhci_hcd and address 2
[ 4.224787] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 4.233226] ata1.00: ATA-7: ST9200420AS, 3.AAA, max UDMA/133
[ 4.233226] ata1.00: 390721968 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 4.248968] ata1.00: configured for UDMA/133
[ 4.326405] usb 4-1: configuration #1 chosen from 1 choice
[ 4.343546] usb 4-1: New USB device found, idVendor=093a, idProduct=2510
[ 4.343546] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.343546] usb 4-1: Product: USB OPTICAL MOUSE
[ 4.343546] usb 4-1: Manufacturer: PIXART
[ 4.378067] usbcore: registered new interface driver hiddev
[ 4.391348] input: PIXART USB OPTICAL MOUSE as /class/input/input1
[ 4.391348] input,hidraw0: USB HID v1.11 Mouse [PIXART USB OPTICAL MOUSE] on usb-0000:00:1d.0-1
[ 4.391348] usbcore: registered new interface driver usbhid
[ 4.391348] usbhid: v2.6:USB HID core driver
[ 4.583308] ata2: SATA link down (SStatus 0 SControl 0)
[ 4.583573] scsi 0:0:0:0: Direct-Access ATA ST9200420AS 3.AA PQ: 0 ANSI: 5
[ 4.594585] ICH8M: IDE controller (0x8086:0x2850 rev 0x03) at PCI slot 0000:00:1f.1
[ 4.594585] ACPI: PCI Interrupt 0000:00:1f.1[A] -> GSI 19 (level, low) -> IRQ 19
[ 4.594585] ICH8M: not 100% native mode: will probe irqs later
[ 4.594585] ide0: BM-DMA at 0x18a0-0x18a7
[ 4.594585] ide1: BM-DMA at 0x18a8-0x18af
[ 4.594585] Probing IDE interface ide0...
[ 4.623812] Driver 'sd' needs updating - please use bus_type methods
[ 4.623812] sd 0:0:0:0: [sda] 390721968 512-byte hardware sectors (200050 MB)
[ 4.623812] sd 0:0:0:0: [sda] Write Protect is off
[ 4.623812] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 4.623812] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 4.623812] sda: sda1 sda2 sda3 < sda5 >
[ 4.693085] sd 0:0:0:0: [sda] Attached SCSI disk
[ 4.859324] ieee1394: Host added: ID:BUS[0-00:1023] GUID[00004ce056241b00]
[ 5.330501] hda: Optiarc DVD RW AD-7530B, ATAPI CD/DVD-ROM drive
[ 6.001754] hda: host max PIO4 wanted PIO255(auto-tune) selected PIO4
[ 6.002064] hda: UDMA/33 mode selected
[ 6.006581] Probing IDE interface ide1...
[ 6.573823] ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
[ 6.573823] ide1 at 0x170-0x177,0x376 on irq 15
[ 6.611849] hda: ATAPI 24X DVD-ROM DVD-R-RAM CD-R/RW drive, 2048kB Cache
[ 6.611849] Uniform CD-ROM driver Revision: 3.20
[ 6.777350] PM: Starting manual resume from disk
[ 6.816771] EXT3-fs: INFO: recovery required on readonly filesystem.
[ 6.816771] EXT3-fs: write access will be enabled during recovery.
[ 10.924414] kjournald starting. Commit interval 5 seconds
[ 10.924414] EXT3-fs: sda2: orphan cleanup on readonly fs
[ 10.924414] ext3_orphan_cleanup: deleting unreferenced inode 2572480
[ 10.924414] ext3_orphan_cleanup: deleting unreferenced inode 5242896
[ 10.924414] EXT3-fs: sda2: 2 orphan inodes deleted
[ 10.924414] EXT3-fs: recovery complete.
[ 10.953448] EXT3-fs: mounted filesystem with ordered data mode.
[ 12.542454] udevd version 125 started
[ 13.393166] Linux agpgart interface v0.103
[ 13.621984] ACPI: Battery Slot [BAT1] (battery absent)
[ 13.703131] input: Power Button (FF) as /class/input/input2
[ 13.756100] ACPI: Power Button (FF) [PWRF]
[ 13.756292] input: Lid Switch as /class/input/input3
[ 13.820527] ACPI: Lid Switch [LID]
[ 13.820527] input: Power Button (CM) as /class/input/input4
[ 13.876588] ACPI: Power Button (CM) [PWRB]
[ 13.876859] ACPI: AC Adapter [ACAD] (on-line)
[ 14.041674] ACPI: device:04 is registered as cooling_device3
[ 14.042070] input: Video Bus as /class/input/input5
[ 14.094221] ACPI: Video Device [VGA] (multi-head: yes rom: no post: no)
[ 14.475977] Linux video capture interface: v2.00
[ 14.601850] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.03 (30-Apr-2008)
[ 14.602061] iTCO_wdt: failed to reset NO_REBOOT flag, reboot disabled by hardware
[ 14.602192] iTCO_wdt: No card detected
[ 14.817307] uvcvideo: Found UVC 1.00 device USB 2.0 Camera (04f2:b024)
[ 14.821631] input: USB 2.0 Camera as /class/input/input6
[ 14.851585] usbcore: registered new interface driver uvcvideo
[ 14.851683] USB Video Class driver (v0.1.0)
[ 14.971005] iwl3945: Intel(R) PRO/Wireless 3945ABG/BG Network Connection driver for Linux, 1.2.26ks
[ 14.971005] iwl3945: Copyright(c) 2003-2008 Intel Corporation
[ 14.971014] ACPI: PCI Interrupt 0000:02:00.0[A] -> GSI 16 (level, low) -> IRQ 16
[ 14.971244] PCI: Setting latency timer of device 0000:02:00.0 to 64
[ 14.971273] iwl3945: Detected Intel Wireless WiFi Link 3945ABG
[ 15.031760] iwl3945: Tunable channels: 13 802.11bg, 23 802.11a channels
[ 15.046307] phy0: Selected rate control algorithm 'iwl-3945-rs'
[ 15.177519] ACPI: PCI Interrupt 0000:00:1b.0[A] -> GSI 22 (level, low) -> IRQ 22
[ 15.177519] PCI: Setting latency timer of device 0000:00:1b.0 to 64
[ 15.193519] input: PC Speaker as /class/input/input7
[ 15.584780] ACPI: PCI interrupt for device 0000:02:00.0 disabled
[ 15.584780] ACPI: PCI Interrupt 0000:00:1f.3[C] -> GSI 19 (level, low) -> IRQ 19
[ 15.648778] udev: renamed network interface wlan0 to eth2
[ 15.792165] Synaptics Touchpad, model: 1, fw: 6.3, id: 0x81a0b2, caps: 0xa04713/0x200000
[ 15.836489] input: SynPS/2 Synaptics TouchPad as /class/input/input8
[ 46.448123] Adding 2345448k swap on /dev/sda5. Priority:-1 extents:1 across:2345448k
[ 46.832693] EXT3 FS on sda2, internal journal
[ 47.071453] loop: module loaded
[ 47.265268] device-mapper: uevent: version 1.0.3
[ 47.265268] device-mapper: ioctl: 4.13.0-ioctl (2007-10-18) initialised: dm-devel@redhat.com
[ 50.970774] NET: Registered protocol family 10
[ 50.970774] lo: Disabled Privacy Extensions
[ 51.234131] lp: driver loaded but no devices found
[ 51.291865] ppdev: user-space parallel port driver
[ 55.430621] Bluetooth: Core ver 2.11
[ 55.430946] NET: Registered protocol family 31
[ 55.431042] Bluetooth: HCI device and connection manager initialized
[ 55.431137] Bluetooth: HCI socket layer initialized
[ 55.484003] Bluetooth: L2CAP ver 2.9
[ 55.484102] Bluetooth: L2CAP socket layer initialized
[ 55.650140] Bluetooth: RFCOMM socket layer initialized
[ 55.650140] Bluetooth: RFCOMM TTY layer initialized
[ 55.650140] Bluetooth: RFCOMM ver 1.8
[ 55.838193] ACPI: PCI Interrupt 0000:02:00.0[A] -> GSI 16 (level, low) -> IRQ 16
[ 55.838578] PM: Writing back config space on device 0000:02:00.0 at offset 1 (was 100102, writing 100106)
[ 55.838881] firmware: requesting iwlwifi-3945-1.ucode
[ 55.981453] Registered led device: iwl-phy0:radio
[ 55.981453] Registered led device: iwl-phy0:assoc
[ 55.981453] Registered led device: iwl-phy0:RX
[ 55.981453] Registered led device: iwl-phy0:TX
[ 55.998273] ADDRCONF(NETDEV_UP): eth2: link is not ready
[ 56.009798] sky2 eth1: enabling interface
[ 56.013799] ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 57.849870] sky2 eth1: Link is up at 100 Mbps, full duplex, flow control rx
[ 57.849870] ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[ 72.718201] eth1: no IPv6 routers present
[ 77.764057] CPU0 attaching NULL sched-domain.
[ 77.764057] CPU1 attaching NULL sched-domain.
[ 77.767815] CPU0 attaching sched-domain:
[ 77.767822] domain 0: span 0-1
[ 77.767825] groups: 0 1
[ 77.767831] CPU1 attaching sched-domain:
[ 77.767834] domain 0: span 0-1
[ 77.767837] groups: 1 0
lsmod:
Module Size Used by
iwl3945 78772 0
rfcomm 28272 0
l2cap 17248 5 rfcomm
bluetooth 44900 4 rfcomm,l2cap
ppdev 6468 0
parport_pc 22500 0
lp 8164 0
parport 30988 3 ppdev,parport_pc,lp
ipv6 235300 14
acpi_cpufreq 6796 1
cpufreq_conservative 5960 0
cpufreq_ondemand 6476 1
cpufreq_stats 3776 0
freq_table 4224 3 acpi_cpufreq,cpufreq_ondemand,cpufreq_stats
cpufreq_userspace 3172 0
cpufreq_powersave 1856 0
dm_snapshot 14340 0
dm_mirror 15104 0
dm_log 8452 1 dm_mirror
dm_mod 46184 3 dm_snapshot,dm_mirror,dm_log
sbp2 18572 0
loop 12748 0
joydev 8480 0
arc4 1824 2
ecb 2624 2
crypto_blkcipher 15236 1 ecb
i2c_i801 7920 0
pcspkr 2432 0
i2c_core 19828 1 i2c_i801
snd_hda_intel 324248 4
psmouse 32336 0
serio_raw 4740 0
snd_pcm_oss 32800 0
snd_mixer_oss 12320 1 snd_pcm_oss
firmware_class 6816 1 iwl3945
mac80211 139680 1 iwl3945
uvcvideo 45704 0
snd_pcm 62596 3 snd_hda_intel,snd_pcm_oss
snd_seq_dummy 2660 0
iTCO_wdt 9508 0
led_class 3908 1 iwl3945
compat_ioctl32 1312 1 uvcvideo
snd_seq_oss 24992 0
cfg80211 21576 2 iwl3945,mac80211
videodev 27520 1 uvcvideo
snd_seq_midi 5728 0
v4l1_compat 12260 2 uvcvideo,videodev
snd_rawmidi 18496 1 snd_seq_midi
snd_seq_midi_event 6432 2 snd_seq_oss,snd_seq_midi
snd_seq 41456 6 snd_seq_dummy,snd_seq_oss,snd_seq_midi,snd_seq_midi_event
snd_timer 17800 3 snd_pcm,snd_seq
snd_seq_device 6380 5 snd_seq_dummy,snd_seq_oss,snd_seq_midi,snd_rawmidi,snd_seq
snd 45604 15 snd_hda_intel,snd_pcm_oss,snd_mixer_oss,snd_pcm,snd_seq_oss,snd_rawmidi,snd_seq,snd_timer,snd_seq_device
soundcore 6368 1 snd
snd_page_alloc 7816 2 snd_hda_intel,snd_pcm
container 3456 0
video 16432 0
output 2912 1 video
ac 4196 0
button 6096 0
battery 10180 0
intel_agp 22332 0
agpgart 28776 1 intel_agp
evdev 8000 8
ext3 105512 1
jbd 39444 1 ext3
mbcache 7108 1 ext3
ide_cd_mod 27652 0
cdrom 30176 1 ide_cd_mod
sd_mod 22200 3
piix 6568 0 [permanent]
usbhid 35904 0
hid 33184 1 usbhid
ff_memless 4392 1 usbhid
ide_pci_generic 3908 0 [permanent]
ide_core 96168 3 ide_cd_mod,piix,ide_pci_generic
ata_piix 14180 2
sdhci 13060 0
ricoh_mmc 3680 0
mmc_core 39932 1 sdhci
ohci1394 24944 0
ieee1394 75800 2 sbp2,ohci1394
ata_generic 4676 0
libata 140384 2 ata_piix,ata_generic
scsi_mod 129356 3 sbp2,sd_mod,libata
dock 8304 1 libata
sky2 37380 0
ehci_hcd 28428 0
uhci_hcd 18672 0
usbcore 118160 5 uvcvideo,usbhid,ehci_hcd,uhci_hcd
thermal 15228 0
processor 32576 4 acpi_cpufreq,thermal
fan 4164 0
thermal_sys 10856 4 video,thermal,processor,fan
mon dossier firmware:
total 576
-rw-r--r-- 1 root root 115108 fév 2 01:44 ipw3945.ucode
-rw-r--r-- 1 root root 149816 fév 2 03:53 iwlwifi-3945-1.ucode
-rw-r--r-- 1 root root 149816 fév 2 02:31 iwlwifi-3945-2.ucode
-rw-r--r-- 1 root root 149816 fév 2 03:52 iwlwifi-3945.ucode
@ymer, rien n’y change
