[quote=“fabrozor”]# modprobe sata_promise
dmesg
Linux version 2.6.18-3-686 (Debian 2.6.18-7) (waldi@debian.org) (gcc version 4.1.2 20061115 (prerelease) (Debian 4.1.1-20)) #1 SMP Mon Dec 4 16:41:14 UTC 2006
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000e8000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000003ff30000 (usable)
BIOS-e820: 000000003ff30000 - 000000003ff40000 (ACPI data)
BIOS-e820: 000000003ff40000 - 000000003fff0000 (ACPI NVS)
BIOS-e820: 000000003fff0000 - 0000000040000000 (reserved)
BIOS-e820: 00000000ffb80000 - 0000000100000000 (reserved)
127MB HIGHMEM available.
896MB LOWMEM available.
found SMP MP-table at 000ff780
On node 0 totalpages: 261936
DMA zone: 4096 pages, LIFO batch:0
Normal zone: 225280 pages, LIFO batch:31
HighMem zone: 32560 pages, LIFO batch:7
DMI 2.3 present.
ACPI: RSDP (v002 ACPIAM ) @ 0x000f9e30
ACPI: XSDT (v001 A M I OEMXSDT 0x10000414 MSFT 0x00000097) @ 0x3ff30100
ACPI: FADT (v003 A M I OEMFACP 0x10000414 MSFT 0x00000097) @ 0x3ff30290
ACPI: MADT (v001 A M I OEMAPIC 0x10000414 MSFT 0x00000097) @ 0x3ff30390
ACPI: OEMB (v001 A M I OEMBIOS 0x10000414 MSFT 0x00000097) @ 0x3ff40040
ACPI: DSDT (v001 P4P81 P4P81104 0x00000104 INTL 0x02002026) @ 0x00000000
ACPI: PM-Timer IO Port: 0x808
ACPI: Local APIC address 0xfee00000
ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
Processor #0 15:2 APIC version 20
ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
Processor #1 15:2 APIC version 20
ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
ACPI: IRQ0 used by override.
ACPI: IRQ2 used by override.
ACPI: IRQ9 used by override.
Enabling APIC mode: Flat. Using 1 I/O APICs
Using ACPI (MADT) for SMP configuration information
Allocating PCI resources starting at 50000000 (gap: 40000000:bfb80000)
Detected 2398.969 MHz processor.
Built 1 zonelists. Total pages: 261936
Kernel command line: root=/dev/hdb1 ro
mapped APIC to ffffd000 (fee00000)
mapped IOAPIC to ffffc000 (fec00000)
Enabling fast FPU save and restore… done.
Enabling unmasked SIMD FPU exception support… done.
Initializing CPU#0
PID hash table entries: 4096 (order: 12, 16384 bytes)
Console: colour VGA+ 80x25
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 1031004k/1047744k available (1543k kernel code, 16112k reserved, 574k data, 196k init, 130240k highmem)
Checking if this processor honours the WP bit even in supervisor mode… Ok.
Calibrating delay using timer specific routine… 4801.63 BogoMIPS (lpj=9603266)
Security Framework v1.0.0 initialized
SELinux: Disabled at boot.
Capability LSM initialized
Mount-cache hash table entries: 512
CPU: After generic identify, caps: bfebfbff 00000000 00000000 00000000 00004400 00000000 00000000
CPU: After vendor identify, caps: bfebfbff 00000000 00000000 00000000 00004400 00000000 00000000
CPU: Trace cache: 12K uops, L1 D cache: 8K
CPU: L2 cache: 512K
CPU: Physical Processor ID: 0
CPU: After all inits, caps: bfebfbff 00000000 00000000 00000080 00004400 00000000 00000000
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
CPU0: Intel P4/Xeon Extended MCE MSRs (12) available
CPU0: Thermal monitoring enabled
Compat vDSO mapped to ffffe000.
Checking ‘hlt’ instruction… OK.
SMP alternatives: switching to UP code
ACPI: Core revision 20060707
CPU0: Intel® Pentium® 4 CPU 2.40GHz stepping 09
SMP alternatives: switching to SMP code
Booting processor 1/1 eip 3000
Initializing CPU#1
Calibrating delay using timer specific routine… 4798.06 BogoMIPS (lpj=9596132)
CPU: L2 cache: 512K
Intel machine check reporting enabled on CPU#1.
CPU1: Intel P4/Xeon Extended MCE MSRs (12) available
CPU1: Thermal monitoring enabled
CPU1: Intel® Pentium® 4 CPU 2.40GHz stepping 09
Total of 2 processors activated (9599.69 BogoMIPS).
ENABLING IO-APIC IRQs
…TIMER: vector=0x31 apic1=0 pin1=2 apic2=-1 pin2=-1
checking TSC synchronization across 2 CPUs: passed.
Brought up 2 CPUs
migration_cost=7
checking if image is initramfs… it is
Freeing initrd memory: 4410k freed
NET: Registered protocol family 16
ACPI: bus type pci registered
PCI: PCI BIOS revision 2.10 entry at 0xf0031, last bus=2
PCI: Using configuration type 1
Setting up standard PCI resources
ACPI: Interpreter enabled
ACPI: Using IOAPIC for interrupt routing
ACPI: PCI Root Bridge [PCI0] (0000:00)
PCI: Probing PCI hardware (bus 00)
PCI quirk: region 0800-087f claimed by ICH4 ACPI/GPIO/TCO
PCI quirk: region 0480-04bf claimed by ICH4 GPIO
PCI: Ignoring BAR0-3 of IDE controller 0000:00:1f.1
Boot video device is 0000:01:00.0
PCI: Transparent bridge - 0000:00:1e.0
ACPI: PCI Interrupt Routing Table [_SB_.PCI0.PRT]
ACPI: PCI Interrupt Routing Table [_SB.PCI0.P0P4._PRT]
ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 10 *11 12 14 15)
ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 10 *11 12 14 15)
ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 6 7 10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 10 *11 12 14 15)
ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 *5 6 7 10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 *10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 *10 11 12 14 15)
Linux Plug and Play Support v0.97 © Adam Belay
pnp: PnP ACPI init
pnp: PnP ACPI: found 14 devices
ASUS P4P800 detected. Disabling PnPBIOS
PnPBIOS: Disabled
PCI: Using ACPI for IRQ routing
PCI: If a device doesn’t work, try “pci=routeirq”. If it helps, post a report
PCI: Cannot allocate resource region 0 of device 0000:00:00.0
pnp: 00:0a: ioport range 0x680-0x6ff has been reserved
pnp: 00:0a: ioport range 0x290-0x297 has been reserved
PCI: Bridge: 0000:00:01.0
IO window: d000-dfff
MEM window: fbe00000-fbefffff
PREFETCH window: d8000000-faffffff
PCI: Bridge: 0000:00:1e.0
IO window: e000-efff
MEM window: fbf00000-fbffffff
PREFETCH window: 50000000-500fffff
PCI: Setting latency timer of device 0000:00:1e.0 to 64
NET: Registered protocol family 2
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP reno registered
audit: initializing netlink socket (disabled)
audit(1170190593.008:1): initialized
highmem bounce pool size: 64 pages
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
isapnp: Scanning for PnP cards…
isapnp: No Plug & Play device found
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
00:06: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
00:07: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
PNP: PS/2 controller doesn’t have AUX irq; using default 12
serio: i8042 AUX port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
mice: PS/2 mouse device common for all mice
TCP bic registered
NET: Registered protocol family 17
NET: Registered protocol family 8
NET: Registered protocol family 20
Starting balanced_irq
Using IPI No-Shortcut mode
ACPI: (supports S0 S1 S3 S4 S5)
Freeing unused kernel memory: 196k freed
Time: tsc clocksource has been installed.
input: AT Translated Set 2 keyboard as /class/input/input0
usbcore: registered new driver usbfs
usbcore: registered new driver hub
USB Universal Host Controller Interface driver v3.0
ACPI: PCI Interrupt 0000:00:1d.0[A] -> GSI 16 (level, low) -> IRQ 169
PCI: Setting latency timer of device 0000:00:1d.0 to 64
uhci_hcd 0000:00:1d.0: UHCI Host Controller
uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 1
uhci_hcd 0000:00:1d.0: irq 169, io base 0x0000c480
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
ACPI: PCI Interrupt 0000:00:1d.1[b] -> GSI 19 (level, low) -> IRQ 177
PCI: Setting latency timer of device 0000:00:1d.1 to 64
uhci_hcd 0000:00:1d.1: UHCI Host Controller
uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 2
uhci_hcd 0000:00:1d.1: irq 177, io base 0x0000c800
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
8139cp: 10/100 PCI Ethernet driver v1.2 (Mar 22, 2004)
SCSI subsystem initialized
libata version 2.00 loaded.
ACPI: PCI Interrupt 0000:00:1d.2[C] -> GSI 18 (level, low) -> IRQ 185
PCI: Setting latency timer of device 0000:00:1d.2 to 64
uhci_hcd 0000:00:1d.2: UHCI Host Controller
uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 3
uhci_hcd 0000:00:1d.2: irq 185, io base 0x0000c880
usb usb3: configuration #1 chosen from 1 choice
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:1d.3[A] -> GSI 16 (level, low) -> IRQ 169
PCI: Setting latency timer of device 0000:00:1d.3 to 64
uhci_hcd 0000:00:1d.3: UHCI Host Controller
uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 4
uhci_hcd 0000:00:1d.3: irq 169, io base 0x0000cc00
usb usb4: configuration #1 chosen from 1 choice
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:1d.7[D] -> GSI 23 (level, low) -> IRQ 193
PCI: Setting latency timer of device 0000:00:1d.7 to 64
ehci_hcd 0000:00:1d.7: EHCI Host Controller
ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 5
ehci_hcd 0000:00:1d.7: debug port 1
PCI: cache line size of 128 is not supported by device 0000:00:1d.7
ehci_hcd 0000:00:1d.7: irq 193, io mem 0xfbdffc00
ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb5: configuration #1 chosen from 1 choice
hub 5-0:1.0: USB hub found
hub 5-0:1.0: 8 ports detected
usb 2-2: new low speed USB device using uhci_hcd and address 2
8139cp 0000:02:0a.0: This (id 10ec:8139 rev 10) is not an 8139C+ compatible chip8139cp 0000:02:0a.0: Try the “8139too” driver instead.
sata_promise 0000:02:0b.0: version 1.04
ACPI: PCI Interrupt 0000:02:0b.0[A] -> GSI 23 (level, low) -> IRQ 193
8139too Fast Ethernet driver 0.9.27
ata1: SATA max UDMA/133 cmd 0xF8806200 ctl 0xF8806238 bmdma 0x0 irq 193
ata2: SATA max UDMA/133 cmd 0xF8806280 ctl 0xF88062B8 bmdma 0x0 irq 193
scsi0 : sata_promise
ata1: SATA link down (SStatus 0 SControl 300)
scsi1 : sata_promise
ata2: SATA link down (SStatus 0 SControl 0)
ACPI: PCI Interrupt 0000:02:0a.0[A] -> GSI 22 (level, low) -> IRQ 201
eth0: RealTek RTL8139 at 0xe800, 00:02:44:8f:00:1d, IRQ 201
eth0: Identified 8139 chip type 'RTL-8100B/8139D’
ICH5: IDE controller at PCI slot 0000:00:1f.1
PCI: Enabling device 0000:00:1f.1 (0005 -> 0007)
ACPI: PCI Interrupt 0000:00:1f.1[A] -> GSI 18 (level, low) -> IRQ 185
ICH5: chipset revision 2
ICH5: not 100% native mode: will probe irqs later
ide0: BM-DMA at 0xfc00-0xfc07, BIOS settings: hda:DMA, hdb:DMA
ide1: BM-DMA at 0xfc08-0xfc0f, BIOS settings: hdc:DMA, hdd:DMA
Probing IDE interface ide0…
usb 2-2: new low speed USB device using uhci_hcd and address 3
usb 2-2: configuration #1 chosen from 1 choice
usbcore: registered new driver hiddev
input: Logitech USB-PS/2 Optical Mouse as /class/input/input1
input: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-0000:00:1d.1-2
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.6:USB HID core driver
hda: ST380011A, ATA DISK drive
hdb: ST380011A, ATA DISK drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Probing IDE interface ide1…
hdc: SONY DVD RW AW-G170A, ATAPI CD/DVD-ROM drive
hdd: ASUS CRW-5232AS, ATAPI CD/DVD-ROM drive
ide1 at 0x170-0x177,0x376 on irq 15
hda: max request size: 512KiB
hda: 156301488 sectors (80026 MB) w/2048KiB Cache, CHS=16383/255/63, UDMA(100)
hda: cache flushes supported
hda: hda1 hda2
hdb: max request size: 512KiB
hdb: 156301488 sectors (80026 MB) w/2048KiB Cache, CHS=16383/255/63, UDMA(100)
hdb: cache flushes supported
hdb: hdb1 hdb2 < hdb5 >
hdc: ATAPI 48X DVD-ROM DVD-R-RAM CD-R/RW drive, 2048kB Cache, UDMA(66)
Uniform CD-ROM driver Revision: 3.20
hdd: ATAPI 52X CD-ROM CD-R/RW drive, 2048kB Cache, UDMA(33)
Attempting manual resume
kjournald starting. Commit interval 5 seconds
EXT3-fs: mounted filesystem with ordered data mode.
ts: Compaq touchscreen protocol output
Linux agpgart interface v0.101 © Dave Jones
agpgart: Detected an Intel 865 Chipset.
agpgart: AGP aperture is 256M @ 0x60000000
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
input: PC Speaker as /class/input/input2
Real Time Clock Driver v1.12ac
Floppy drive(s): fd0 is 1.44M
intel_rng: FWH not detected
ACPI: PCI Interrupt 0000:00:1f.3[B] -> GSI 17 (level, low) -> IRQ 209
FDC 0 is a post-1991 82077
parport: PnPBIOS parport detected.
parport0: PC-style at 0x378 (0x778), irq 7, dma 3 [PCSPP,TRISTATE,COMPAT,EPP,ECP,DMA]
ACPI: PCI Interrupt 0000:02:0d.0[A] -> GSI 21 (level, low) -> IRQ 217
Adding 3036244k swap on /dev/hdb5. Priority:-1 extents:1 across:3036244k
EXT3 FS on hdb1, internal journal
loop: loaded (max 8 devices)
device-mapper: ioctl: 4.7.0-ioctl (2006-06-24) initialised: dm-devel@redhat.com
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
IPv6 over IPv4 tunneling driver
eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
ACPI: Power Button (FF) [PWRF]
ACPI: Power Button (CM) [PWRB]
eth0: no IPv6 routers present
lp0: using parport0 (interrupt-driven).
ppdev: user-space parallel port driver
[drm] Initialized drm 1.0.1 20051102
ACPI: PCI Interrupt 0000:01:00.0[A] -> GSI 16 (level, low) -> IRQ 169
[drm] Initialized radeon 1.25.0 20060524 on minor 0
agpgart: Found an AGP 3.0 compliant device at 0000:00:00.0.
agpgart: Putting AGP V3 device at 0000:00:00.0 into 4x mode
agpgart: Putting AGP V3 device at 0000:01:00.0 into 4x mode
[drm] Setting GART location based on new memory map
[drm] Loading R300 Microcode
[drm] writeback test succeeded in 1 usecs
UDF-fs: No VRS found
ISO 9660 Extensions: Microsoft Joliet Level 3
ISO 9660 Extensions: RRIP_1991A
hdd: tray open
end_request: I/O error, dev hdd, sector 0
Buffer I/O error on device hdd, logical block 0
Buffer I/O error on device hdd, logical block 1
Buffer I/O error on device hdd, logical block 2
Buffer I/O error on device hdd, logical block 3
Buffer I/O error on device hdd, logical block 4
Buffer I/O error on device hdd, logical block 5
Buffer I/O error on device hdd, logical block 6
Buffer I/O error on device hdd, logical block 7
hdd: tray open
hdd: tray open
end_request: I/O error, dev hdd, sector 4
hdd: tray open
hdd: tray open
hdd: tray open
hdd: tray open
hdd: tray open
hdd: tray open
hdd: tray open
hdd: tray open
hdd: tray open
printk: 8 messages suppressed.
hdd: tray open
hdd: tray open
hdd: tray open
hdd: tray open
hdd: tray open
hdd: tray open
hdd: tray open
hdd: tray open
hdd: tray open
hdd: tray open
Warning: /proc/ide/hd?/settings interface is obsolete, and will be removed soon!NTFS driver 2.1.27 [Flags: R/W MODULE].
NTFS volume version 3.1.
NTFS volume version 3.1.[/quote]
donne moi la vertion de ton noyeaux ???
uname -a[/b]
