Carte Realtek rtl8192sevb
Je suis sous Debian squeeze 64bits et je rencontre un problème avec ma carte wifi
tt@debian-tt:~$ uname -a Linux debian-tt 2.6.32-5-amd64 #1 SMP Thu Nov 3 03:41:26 UTC 2011 x86_64 GNU/Linux tt@debian-tt:~$ uname -r 2.6.32-5-amd64
(etat actuelle de ma debian)
tt@debian-tt:~$ lspci | grep -i net 0e:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller (rev 02) 14:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8191SEvB Wireless LAN Controller (rev 10) tt@debian-tt:~$ lsmod | grep r8192se r8192se_pci 464374 0 tt@debian-tt:~$ sudo modinfo r8192se_pci [sudo] password for tt: filename: /lib/modules/2.6.32-5-amd64/updates/dkms/r8192se_pci.ko license: GPL version: 0015.0127.2010 author: Copyright(c) 2008 - 2010 Realsil Semiconductor Corporation <wlanfae@realtek.com> description: Linux driver for Realtek RTL819x WiFi cards srcversion: 238C41D1ADEF0CC67433491 alias: pci:v000010ECd00008174sv*sd*bc*sc*i* alias: pci:v000010ECd00008173sv*sd*bc*sc*i* alias: pci:v000010ECd00008172sv*sd*bc*sc*i* alias: pci:v000010ECd00008171sv*sd*bc*sc*i* depends: vermagic: 2.6.32-5-amd64 SMP mod_unload modversions parm: ifname: Net interface name, wlan%d=default (charp) parm: hwwep: Try to use hardware WEP support(default use hw. set 0 to use software security) (int) parm: channels: Channel bitmask for specific locales. NYI (int) tt@debian-tt:~$ sudo iwconfig wlan0 wlan0 802.11bg Nickname:"rtl8191SEVA2" Mode:Managed Frequency=2.457 GHz Access Point: Not-Associated Bit Rate:1 Mb/s Retry:on RTS thr:off Fragment thr:off Encryption key:off Power Management:off Link Quality=10/100 Signal level=0 dBm Noise level=-100 dBm Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0 Tx excessive retries:0 Invalid misc:0 Missed beacon:0
J’explique ce que j’ai fait :
le paquet firmware-realtek ne permettait pas de reconnaitre ma carte wifi
J’avais eu un problème pour installer le module via le site realtek
tt@debian-tt:~/Téléchargements/rtl_92ce_92se_92de_linux_mac80211_0004.0816.2011$ make make -C /lib/modules/2.6.32-5-amd64/build M=/home/tt/Téléchargements/rtl_92ce_92se_92de_linux_mac80211_0004.0816.2011 modules make[1]: entrant dans le répertoire « /usr/src/linux-headers-2.6.32-5-amd64 » CC [M] /home/tt/Téléchargements/rtl_92ce_92se_92de_linux_mac80211_0004.0816.2011/base.o /home/tt/Téléchargements/rtl_92ce_92se_92de_linux_mac80211_0004.0816.2011/base.c: In function ‘_rtl_init_mac80211’: /home/tt/Téléchargements/rtl_92ce_92se_92de_linux_mac80211_0004.0816.2011/base.c:320: error: ‘IEEE80211_HW_CONNECTION_MONITOR’ undeclared (first use in this function) /home/tt/Téléchargements/rtl_92ce_92se_92de_linux_mac80211_0004.0816.2011/base.c:320: error: (Each undeclared identifier is reported only once /home/tt/Téléchargements/rtl_92ce_92se_92de_linux_mac80211_0004.0816.2011/base.c:320: error: for each function it appears in.) /home/tt/Téléchargements/rtl_92ce_92se_92de_linux_mac80211_0004.0816.2011/base.c: In function ‘rtl_watchdog_wq_callback’: /home/tt/Téléchargements/rtl_92ce_92se_92de_linux_mac80211_0004.0816.2011/base.c:1258: error: implicit declaration of function ‘ieee80211_connection_loss’ make[4]: *** [/home/tt/Téléchargements/rtl_92ce_92se_92de_linux_mac80211_0004.0816.2011/base.o] Erreur 1 make[3]: *** [_module_/home/tt/Téléchargements/rtl_92ce_92se_92de_linux_mac80211_0004.0816.2011] Erreur 2 make[2]: *** [sub-make] Erreur 2 make[1]: *** [all] Erreur 2 make[1]: quittant le répertoire « /usr/src/linux-headers-2.6.32-5-amd64 » make: *** [all] Erreur 2
donc j’ai installe un .deb normalement concu pour ubuntu https://launchpad.net/~matt-price/+archive/mattprice/+packages
Après l’installation du .deb, le module etait opérationnel et j’ai obtenu la configuration que voici
Le probleme c’est que dans network-manager il y a toujours marqué : “Réseau sans fil déconnecté”
[EDIT : je rajoute mes fichier de config"]
[code]/etc/network/interfaces
This file describes the network interfaces available on your system
auto lo
iface lo inet loopback
The primary network interface
allow-hotplug eth0[/code]
[code]/etc/NetworkManager/NetworkManager.conf
[main]
plugins=ifupdown,keyfile
[ifupdown]
managed=false
Essaye http://boisson.homeip.net/debian/pool/squeeze/amd64/rtl8192se-dkms_2.6.0015.0127.2010_all.deb
Tout d’abord merci d’avoir pris le temps de me repondre
le paquet que tu me propose c’est le même que celui que j’avais téléchargé ici : https://launchpad.net/~matt-price/+archive/mattprice/+packages
Ce paquet a permis à ma debian de reconnaitre ma carte wifi. Mon problème est qu’il y a toujours marqué : “Réseau sans fil déconnecté” (et ce n’est pas une absence de connection parce que même quand je créer un nouveau réseau sans fil ben ya rien
Alors en parcourant le forum je suis tombe sur cet article : https://www.debian-fr.org/wlan0-reconnu-mais-refuse-de-demarrer-t36776.html
donc apparement le meme probleme que moi
[code]/var/log/dmesg (extrait)
[ 14.228449] rtl819xSE 0000:14:00.0: firmware: requesting RTL8192SE/rtl8192sfw.bin
[ 14.258471] rtl819xSE:request firmware fail!
[ 14.258473]
[ 14.258483] rtl819xSE:Firmware Download Fail!!a
[ 14.258485]
[ 14.265873] rtl819xSE 0000:14:00.0: firmware: requesting RTL8192SE/rtl8192sfw.bin
[ 14.269342] rtl819xSE:request firmware fail!
[ 14.269345]
[ 14.354432] rtl819xSE:Firmware Download Fail!!a
[ 14.354434]
[ 14.361835] rtl819xSE 0000:14:00.0: firmware: requesting RTL8192SE/rtl8192sfw.bin
[ 14.365136] rtl819xSE:request firmware fail!
[ 14.365139]
[ 14.365148] rtl819xSE:Firmware Download Fail!!a
[ 14.365149]
[ 14.365153] rtl819xSE:ERR!!! _rtl8192_sta_up(): initialization is failed![/code]
Donc mon problème a l’air ciblé mais je ne sais pas le résoudre
Le paquet contient les firmware je croyais, j’ai mis un peu de temps à bien faire fonctionner cette carte, voilà le firmware: http://boisson.homeip.net/debian/rtl8192sfw.bin
Au temps pour moi, le firmware est dans l’autre paquet que j’avais fait (rtl8192se-linux-2.6.0010.1020.2009-64bit) mais qui est compilé, prend directement le firmware dans le lien du message précédent, ça ira mieux.
Par “le précedent” tu entends : boisson.homeip.net/debian/pool/s … 10_all.deb ?
Si oui alors c’est celui que j’avais installé non ?
Sinon [petit HS pour savoir], un .bin ca s’execute comment ?
parce que dans le terminal
chmod +x fichier.bin
./fichier.bin
ca ne fonctionne pas toujours
C’est un firmware, pas un exécutable Linux. Il est chargé par le noyau dans le périphérique, et est exécuté par ce dernier.
Ah ok (désolé je m’interesse depuis peu au fond des choses de ce qui se passe sous ma debian ^^). Je vais essayer de me renseigner la dessus ^^. En tout cas merci
Tu as le firmware ici boisson.homeip.net/debian/
Ok merci
j’ai vu sur http://www.debian-fr.org/comment-installer-firmware-d-une-carte-reseau-t30111.html comment faire pour utiliser ton .bin
Je redemarre et croise les doigts :pray: [oui il prit mais c’est parce que je n’ai pas trouver de smilez croisant les doigts]
a toute et en tout cas merci
sans succès …
Il aurait peut-être que je supprime qqch ? (comme mes paquet de firmware realtek par ex.)
Pour l’installation du .bin je l’ai déplacer dans /lib/firmware … c’était peut-être pas la bonne démarche à suivre
D’après les messages du noyau cités plus haut, il s’attend à trouver le firmware dans /lib/firmware/RTL8192SE/rtl8192sfw.bin.
Oui, c’est là où il faut les mettre (je dis «les» car il y en a plusieurs qui sont fourni, mais un seul sert pour cette carte)
Ca a marché. Mille merci ! :slightly_smiling:
Je reviens sur le sujet car je galérais depuis plusieurs mois avec cette carte RTL8191SEvB avec Squeeze.
Donc un grand merci car il n’y a désormais plus de problème.
Pour ceux qui tomberait sur cette page et qui débute comme moi avec Debian, je simplifie :
Merci encore pour ces infos. Je pense que ce serait bien de les mettre sur la page wiki.debian.org/fr/WiFi où j’ai passé beaucoup de temps sans trouver de solutions.
Cette etape n’est pas necessaire il me semble
pourtant, je te cite : “donc j’ai installe un .deb normalement concu pour ubuntu launchpad.net/~matt-price/+arch … /+packages”
J’ai fait la même chose !
je ne comprends donc pas quand tu dis que cette étape n’est pas nécessaire (ou alors parles-tu juste du procédé d’installation en graphique avec Gdebi ?).
En tout cas ça marche !
Oui mais en fait grace au .bin que nous a fournis fran.b cette etape est devenue inutile je pense
