je ne comprends pas pourquoi mais ma carte reseau wifi passe de eth1 a eth2 de temps en temps, resultat je doit modifier mes parametres reseau et redemarrer c’est ultra-chiant:
ma carte est une :Intel® PRO/Wireless 2200BG sous debian 2.6.15-1-686
voici mon /etc/network/interfaces:
auto lo
iface lo inet loopback
This is a list of hotpluggable network interfaces.
They will be activated automatically by the hotplug subsystem.
mapping eth2
script grep
map eth2
The primary network interface
allow-hotplug eth2
iface eth2 inet static
address 192.168.0.103
netmask 255.255.255.0
network 192.168.0.0
broadcast 192.168.0.255
gateway 192.168.0.254
wireless-key ###########################
wireless-essid Mon_reseau
# dns-* options are implemented by the resolvconf package, if installed
dns-nameservers 212.27.32.5
adrien@X31:~$ sudo iwconfig
lo no wireless extensions.
eth0 no wireless extensions.
eth1 no wireless extensions.
eth2 IEEE 802.11b ESSID:"Mon_reseau"
Mode:Managed Frequency:2.462 GHz Access Point: 00:07:CB:50:A7:E1
Bit Rate=11 Mb/s Tx-Power=20 dBm
Retry limit:7 RTS thr:off Fragment thr:off
Encryption key:0123-4567-8998-7654-3210-0123-45 Security mode:open
Power Management:off
Link Quality=86/100 Signal level=-44 dBm Noise level=-86 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:10
sit0 no wireless extensions.
je ne comprends pas pourquoi !!!
Y-a-t-il un truc qui m’echappe ?
aswat
