Carte reseau R8169
J’ai fraichement installé une debian netinstall 2.6.32-5-amd64
J’ai rencontré quelques soucis pendant l’install mirroir introuvable puis j’en ai pris un autre qui a fonctionner et paf introuvable.
Au bout de quelques essais je me decide a installer juste le noyaux, l’install c’est passé sans soucis :dance:
L’installation de l’interface graphique a galeré un peu mais au bout de quelques essais tous les paquets sont arrivé et tous fonctionne
je viens d’identifier la cause probable de ces soucis avec un cat /var/log/messages qui m’indique
Apr 5 18:19:46 debian kernel: [ 336.985633] ADDRCONF(NETDEV_UP): eth0: link is not ready Apr 5 18:19:48 debian kernel: [ 339.380671] r8169 0000:09:00.0: eth0: link up Apr 5 18:19:48 debian kernel: [ 339.381406] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready Apr 5 18:20:36 debian kernel: [ 387.164741] r8169 0000:09:00.0: eth0: link up Apr 5 18:21:46 debian kernel: [ 456.989482] r8169 0000:09:00.0: eth0: link up Apr 5 18:22:44 debian kernel: [ 515.048462] r8169 0000:09:00.0: eth0: link up Apr 5 18:23:15 debian kernel: [ 545.398430] r8169 0000:09:00.0: eth0: link down Apr 5 18:23:15 debian kernel: [ 545.398474] r8169 0000:09:00.0: eth0: link down Apr 5 18:23:15 debian kernel: [ 545.399201] ADDRCONF(NETDEV_UP): eth0: link is not ready Apr 5 18:23:17 debian kernel: [ 547.832829] r8169 0000:09:00.0: eth0: link up Apr 5 18:23:17 debian kernel: [ 547.833591] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready Apr 5 18:27:29 debian kernel: [ 799.470550] r8169 0000:09:00.0: eth0: link down Apr 5 18:27:29 debian kernel: [ 799.470593] r8169 0000:09:00.0: eth0: link down Apr 5 18:27:29 debian kernel: [ 799.471311] ADDRCONF(NETDEV_UP): eth0: link is not ready Apr 5 18:27:32 debian kernel: [ 801.869749] r8169 0000:09:00.0: eth0: link up Apr 5 18:27:32 debian kernel: [ 801.870488] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready Apr 5 18:29:22 debian kernel: [ 912.200333] r8169 0000:09:00.0: eth0: link up Apr 5 18:29:25 debian kernel: [ 914.601355] r8169 0000:09:00.0: eth0: link up Apr 5 18:30:13 debian kernel: [ 962.948601] r8169 0000:09:00.0: eth0: link up Apr 5 18:30:58 debian kernel: [ 1007.913694] r8169 0000:09:00.0: eth0: link up Apr 5 18:31:10 debian kernel: [ 1019.691428] r8169 0000:09:00.0: eth0: link up
j’ai réussi a trouver quelques info a savoir activer le WOL dans le bios
egalement ici : debian-fr.org/carte-reseau- … ilit=r8169
un peu vieux mais cela a l’air de correspondre.
j’aurais aimé avoir un retour sur la bonne marche à suivre (liens posté ci dessus ? ) afin de résoudre ces problèmes de drivers sans tenter trop de manip par crainte de tous casser au final et de re-galerer a l’install
Merci pour vos retours
bon ben desolé pour le post inutile
la solution ce trouve ici : ubuntuforums.org/showthread.php?t=1022411
cela a résolu mes problèmes
Fret
