Carte TV Configuration
bonjour
j’ai une tour hpm7790
il y a une carte tv & de capture
à la commande : lspci -vnn
 Multimedia controller [0480]: Philips Semiconductors SAA7131/SAA7133/SAA7135 Video Broadcast Decoder [1131:7133] (rev d1)
	Subsystem: ASUSTeK Computer Inc. Device [1043:4871]
	Flags: bus master, medium devsel, latency 32, IRQ 16
	Memory at fdefe000 (32-bit, non-prefetchable) [size=2K]
	Capabilities: [40] Power Management version 2
	Kernel driver in use: saa7134
	Kernel modules: saa7134
à la commande : lspci -s 02:04.0 -n
02:04.0 0480: 1131:7133 (rev d1)
à la commande : dmesg
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Linux version 2.6.26-2-686 (Debian 2.6.26-21lenny4) (dannf@debian.org) (gcc version 4.1.3 20080704 (prerelease) (Debian 4.1.2-25)) #1 SMP Tue Mar 9 17:35:51 UTC 2010
[    0.000000] BIOS-provided physical RAM map:
[    0.000000]  BIOS-e820: 0000000000000000 - 0000000000098400 (usable)
[    0.000000]  BIOS-e820: 0000000000098400 - 00000000000a0000 (reserved)
[    0.000000]  BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[    0.000000]  BIOS-e820: 0000000000100000 - 000000007fedf800 (usable)
[    0.000000]  BIOS-e820: 000000007fedf800 - 000000007fee0000 (reserved)
[    0.000000]  BIOS-e820: 000000007fee0000 - 000000007fee3000 (ACPI NVS)
[    0.000000]  BIOS-e820: 000000007fee3000 - 000000007fef0000 (ACPI data)
[    0.000000]  BIOS-e820: 000000007fef0000 - 000000007ff00000 (reserved)
[    0.000000]  BIOS-e820: 00000000f0000000 - 00000000f4000000 (reserved)
[    0.000000]  BIOS-e820: 00000000fec00000 - 0000000100000000 (reserved)
[    0.000000] 1150MB HIGHMEM available.
[    0.000000] 896MB LOWMEM available.
[    0.000000] found SMP MP-table at [c00f5f50] 000f5f50
[    0.000000] Entering add_active_range(0, 0, 523999) 0 entries of 256 used
[    0.000000] Zone PFN ranges:
[    0.000000]   DMA             0 ->     4096
[    0.000000]   Normal       4096 ->   229376
[    0.000000]   HighMem    229376 ->   523999
[    0.000000] Movable zone start PFN for each node
[    0.000000] early_node_map[1] active PFN ranges
[    0.000000]     0:        0 ->   523999
[    0.000000] On node 0 totalpages: 523999
[    0.000000]   DMA zone: 32 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 4064 pages, LIFO batch:0
[    0.000000]   Normal zone: 1760 pages used for memmap
[    0.000000]   Normal zone: 223520 pages, LIFO batch:31
[    0.000000]   HighMem zone: 2302 pages used for memmap
[    0.000000]   HighMem zone: 292321 pages, LIFO batch:31
[    0.000000]   Movable zone: 0 pages used for memmap
[    0.000000] DMI present.
[    0.000000] ACPI: RSDP 000F8320, 0024 (r2 HPQOEM)
[    0.000000] ACPI: XSDT 7FEE30C0, 005C (r1 HPQOEM SLIC-CPC 42302E31 AWRD        0)
[    0.000000] ACPI: FACP 7FEE7A80, 00F4 (r3 HPQOEM SLIC-CPC 42302E31 AWRD        0)
[    0.000000] ACPI: DSDT 7FEE3280, 4791 (r1 HPQOEM SLIC-CPC     1000 MSFT  3000000)
[    0.000000] ACPI: FACS 7FEE0000, 0040
[    0.000000] ACPI: SLIC 7FEE7CC0, 0176 (r1 HPQOEM SLIC-CPC 42302E31 AWRD        0)
[    0.000000] ACPI: HPET 7FEE7E80, 0038 (r1 HPQOEM SLIC-CPC 42302E31 AWRD       98)
[    0.000000] ACPI: MCFG 7FEE7F00, 003C (r1 HPQOEM SLIC-CPC 42302E31 AWRD        0)
[    0.000000] ACPI: APIC 7FEE7BC0, 0084 (r1 HPQOEM SLIC-CPC 42302E31 AWRD        0)
[    0.000000] ACPI: SSDT 7FEE7F80, 01EF (r1 HPQOEM SLIC-CPC 42302E31 AWRD        0)
[    0.000000] ACPI: SSDT 7FEE84E0, 027D (r1 HPQOEM SLIC-CPC 42302E31 AWRD        0)
[    0.000000] ACPI: PM-Timer IO Port: 0x408
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] disabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x03] disabled)
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[    0.000000] ACPI: IOAPIC (id[0x04] address[0xfec00000] gsi_base[0])
[    0.000000] IOAPIC[0]: apic_id 4, version 32, address 0xfec00000, GSI 0-23
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ2 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Enabling APIC mode:  Flat.  Using 1 I/O APICs
[    0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] Allocating PCI resources starting at 80000000 (gap: 7ff00000:70100000)
[    0.000000] PM: Registered nosave memory: 0000000000098000 - 0000000000099000
[    0.000000] PM: Registered nosave memory: 0000000000099000 - 00000000000a0000
[    0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000f0000
[    0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[    0.000000] SMP: Allowing 4 CPUs, 2 hotplug CPUs
[    0.000000] PERCPU: Allocating 37992 bytes of per cpu data
[    0.000000] NR_CPUS: 8, nr_cpu_ids: 4
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 519905
[    0.000000] Kernel command line: root=/dev/sda1 ro quiet
[    0.000000] mapped APIC to ffffb000 (fee00000)
[    0.000000] mapped IOAPIC to ffffa000 (fec00000)
[    0.000000] Enabling fast FPU save and restore... done.
[    0.000000] Enabling unmasked SIMD FPU exception support... done.
[    0.000000] Initializing CPU#0
[    0.000000] PID hash table entries: 4096 (order: 12, 16384 bytes)
[    0.000000] Detected 2133.995 MHz processor.
[    0.004000] Console: colour VGA+ 80x25
[    0.004000] console [tty0] enabled
[    0.004000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.004000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.004000] Memory: 2068032k/2095996k available (1771k kernel code, 26684k reserved, 750k data, 244k init, 1178492k highmem)
[    0.004000] virtual kernel memory layout:
[    0.004000]     fixmap  : 0xfff4c000 - 0xfffff000   ( 716 kB)
[    0.004000]     pkmap   : 0xff800000 - 0xffc00000   (4096 kB)
[    0.004000]     vmalloc : 0xf8800000 - 0xff7fe000   ( 111 MB)
[    0.004000]     lowmem  : 0xc0000000 - 0xf8000000   ( 896 MB)
[    0.004000]       .init : 0xc037f000 - 0xc03bc000   ( 244 kB)
[    0.004000]       .data : 0xc02bac75 - 0xc0376620   ( 750 kB)
[    0.004000]       .text : 0xc0100000 - 0xc02bac75   (1771 kB)
[    0.004000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[    0.004000] CPA: page pool initialized 1 of 1 pages preallocated
[    0.004000] hpet clockevent registered
[    0.083852] Calibrating delay using timer specific routine.. 4271.47 BogoMIPS (lpj=8542959)
[    0.083883] Security Framework initialized
[    0.083888] SELinux:  Disabled at boot.
[    0.083891] Capability LSM initialized
[    0.083904] Mount-cache hash table entries: 512
[    0.084005] Initializing cgroup subsys ns
[    0.084005] Initializing cgroup subsys cpuacct
[    0.084005] Initializing cgroup subsys devices
[    0.084005] CPU: L1 I cache: 32K, L1 D cache: 32K
[    0.084005] CPU: L2 cache: 2048K
[    0.084005] CPU: Physical Processor ID: 0
[    0.084005] CPU: Processor Core ID: 0
[    0.084005] Intel machine check architecture supported.
[    0.084005] Intel machine check reporting enabled on CPU#0.
[    0.084005] using mwait in idle threads.
[    0.084005] Checking 'hlt' instruction... OK.
[    0.100006] ACPI: Core revision 20080321
[    0.108006] ENABLING IO-APIC IRQs
[    0.108006] ..TIMER: vector=0x31 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.147652] CPU0: Intel(R) Core(TM)2 CPU          6400  @ 2.13GHz stepping 02
[    0.148009] Booting processor 1/1 ip 6000
[    0.156009] Initializing CPU#1
[    0.156009] Calibrating delay using timer specific routine.. 4267.85 BogoMIPS (lpj=8535713)
[    0.156009] CPU: L1 I cache: 32K, L1 D cache: 32K
[    0.156009] CPU: L2 cache: 2048K
[    0.156009] CPU: Physical Processor ID: 0
[    0.156009] CPU: Processor Core ID: 1
[    0.156009] Intel machine check architecture supported.
[    0.156009] Intel machine check reporting enabled on CPU#1.
[    0.236014] CPU1: Intel(R) Core(TM)2 CPU          6400  @ 2.13GHz stepping 02
[    0.236014] checking TSC synchronization [CPU#0 -> CPU#1]: passed.
[    0.240015] Brought up 2 CPUs
[    0.240015] Total of 2 processors activated (8539.33 BogoMIPS).
[    0.240015] CPU0 attaching sched-domain:
[    0.240015]  domain 0: span 0-1
[    0.240015]   groups: 0 1
[    0.240015] CPU1 attaching sched-domain:
[    0.240015]   groups: 1 0
[    0.240015] net_namespace: 660 bytes
[    0.240015] Booting paravirtualized kernel on bare hardware
[    0.240015] NET: Registered protocol family 16
[    0.240015] ACPI: bus type pci registered
[    0.240015] PCI: Found Intel Corporation 945G/GZ/P/PL Express Memory Controller Hub without MMCONFIG support.
[    0.263586] PCI: PCI BIOS revision 3.00 entry at 0xf1ea0, last bus=2
[    0.263588] PCI: Using configuration type 1 for base access
[    0.263605] Setting up standard PCI resources
[    0.264016] mtrr: your CPUs had inconsistent fixed MTRR settings
[    0.264016] mtrr: probably your BIOS does not setup all CPUs.
[    0.264016] mtrr: corrected configuration.
[    0.267356] ACPI: EC: Look up EC in DSDT
[    0.272510] ACPI: Interpreter enabled
[    0.272515] ACPI: (supports S0 S1 S3 S4 S5)
[    0.272531] ACPI: Using IOAPIC for interrupt routing
[    0.278810] ACPI: PCI Root Bridge [PCI0] (0000:00)
[    0.278810] PCI: Transparent bridge - 0000:00:1e.0
[    0.278810] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[    0.278810] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.HUB0._PRT]
[    0.290810] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 *5 7 9 10 11 12 14 15)
[    0.290810] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[    0.290810] ACPI: PCI Interrupt Link [LNKC] (IRQs *3 4 5 7 9 10 11 12 14 15)
[    0.290810] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 9 10 *11 12 14 15)
[    0.290810] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 9 *10 11 12 14 15)
[    0.290810] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[    0.290810] ACPI: PCI Interrupt Link [LNK0] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[    0.290810] ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 5 *7 9 10 11 12 14 15)
[    0.290810] Linux Plug and Play Support v0.97 (c) Adam Belay
[    0.290810] pnp: PnP ACPI init
[    0.290810] ACPI: bus type pnp registered
[    0.290810] pnp: PnP ACPI: found 13 devices
[    0.290810] ACPI: ACPI bus type pnp unregistered
[    0.290810] PnPBIOS: Disabled by ACPI PNP
[    0.294811] PCI: Using ACPI for IRQ routing
[    0.298547] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[    0.298552] hpet0: 3 64-bit timers, 14318180 Hz
[    0.298813] ACPI: RTC can wake from S4
[    0.305787] system 00:01: ioport range 0x4d0-0x4d1 has been reserved
[    0.305790] system 00:01: ioport range 0x800-0x87f has been reserved
[    0.305793] system 00:01: ioport range 0x294-0x297 has been reserved
[    0.305796] system 00:01: ioport range 0x880-0x88f has been reserved
[    0.305808] system 00:09: ioport range 0x400-0x4bf has been reserved
[    0.305816] system 00:0b: iomem range 0xf0000000-0xf3ffffff could not be reserved
[    0.305824] system 00:0c: iomem range 0xd4800-0xd7fff has been reserved
[    0.305827] system 00:0c: iomem range 0xf0000-0xf7fff could not be reserved
[    0.305830] system 00:0c: iomem range 0xf8000-0xfbfff could not be reserved
[    0.305833] system 00:0c: iomem range 0xfc000-0xfffff could not be reserved
[    0.305837] system 00:0c: iomem range 0xfed00000-0xfed000ff could not be reserved
[    0.305840] system 00:0c: iomem range 0x7fee0000-0x7fefffff could not be reserved
[    0.305843] system 00:0c: iomem range 0x0-0x9ffff could not be reserved
[    0.305847] system 00:0c: iomem range 0x100000-0x7fedffff could not be reserved
[    0.305850] system 00:0c: iomem range 0xfec00000-0xfec00fff could not be reserved
[    0.305854] system 00:0c: iomem range 0xfee00000-0xfee00fff could not be reserved
[    0.305857] system 00:0c: iomem range 0xffb00000-0xffb7ffff could not be reserved
[    0.305860] system 00:0c: iomem range 0xfff00000-0xffffffff could not be reserved
[    0.305863] system 00:0c: iomem range 0xe0000-0xeffff has been reserved
[    0.336182] PCI: Bridge: 0000:00:01.0
[    0.336182]   IO window: d000-dfff
[    0.336182]   MEM window: 0xfdd00000-0xfddfffff
[    0.336182]   PREFETCH window: 0x00000000e0000000-0x00000000efffffff
[    0.336182] PCI: Bridge: 0000:00:1e.0
[    0.336182]   IO window: e000-efff
[    0.336182]   MEM window: 0xfde00000-0xfdefffff
[    0.336182]   PREFETCH window: disabled.
[    0.336182] ACPI: PCI Interrupt 0000:00:01.0[A] -> GSI 16 (level, low) -> IRQ 16
[    0.336182] PCI: Setting latency timer of device 0000:00:01.0 to 64
[    0.336182] PCI: Setting latency timer of device 0000:00:1e.0 to 64
[    0.336182] NET: Registered protocol family 2
[    0.349690] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.349927] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.352231] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[    0.352415] TCP: Hash tables configured (established 131072 bind 65536)
[    0.352418] TCP reno registered
[    0.359708] NET: Registered protocol family 1
[    0.359831] checking if image is initramfs...<7>Switched to high resolution mode on CPU 1
[    9.534008] Switched to high resolution mode on CPU 0
[    9.964937]  it is
[    9.964937] Freeing initrd memory: 6052k freed
[    9.965923] audit: initializing netlink socket (disabled)
[    9.965923] type=2000 audit(1270233830.816:1): initialized
[    9.965923] highmem bounce pool size: 64 pages
[    9.965923] Total HugeTLB memory allocated, 0
[    9.965923] VFS: Disk quotas dquot_6.5.1
[    9.965923] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    9.965923] msgmni has been set to 1750
[    9.965923] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[    9.965923] io scheduler noop registered
[    9.965923] io scheduler anticipatory registered
[    9.965923] io scheduler deadline registered
[    9.965923] io scheduler cfq registered (default)
[    9.965923] pci 0000:01:00.0: Boot video device
[    9.965923] pci 0000:02:08.0: Firmware left e100 interrupts enabled; disabling
[    9.965923] PCI: Setting latency timer of device 0000:00:01.0 to 64
[    9.965923] assign_interrupt_mode Found MSI capability
[    9.965923] Allocate Port Service[0000:00:01.0:pcie00]
[    9.965923] isapnp: Scanning for PnP cards...
[   10.183292] isapnp: No Plug & Play device found
[   10.183293] hpet_resources: 0xfed00000 is busy
[   10.183293] Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
[   10.187293] brd: module loaded
[   10.187293] PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[   10.187293] serio: i8042 KBD port at 0x60,0x64 irq 1
[   10.187293] serio: i8042 AUX port at 0x60,0x64 irq 12
[   10.187293] mice: PS/2 mouse device common for all mice
[   10.187293] rtc_cmos 00:04: rtc core: registered rtc_cmos as rtc0
[   10.187293] rtc0: alarms up to one month
[   10.187293] cpuidle: using governor ladder
[   10.187293] cpuidle: using governor menu
[   10.187293] No iBFT detected.
[   10.187643] TCP cubic registered
[   10.187643] NET: Registered protocol family 17
[   10.187643] Using IPI No-Shortcut mode
[   10.187643] registered taskstats version 1
[   10.187643] rtc_cmos 00:04: setting system clock to 2010-04-02 18:43:51 UTC (1270233831)
[   10.187643] Freeing unused kernel memory: 244k freed
[   10.207856] input: AT Translated Set 2 keyboard as /class/input/input0
[   10.257279] ACPI: PNP0C0B:00 is registered as cooling_device0
[   10.257279] ACPI: Fan [FAN] (on)
[   10.263668] ACPI Error (psparse-0530): Method parse/execution failed [\_PR_.CPU0._PDC] (Node f7441658), AE_ALREADY_EXISTS
[   10.263668] ACPI: Marking method _PDC as Serialized because of AE_ALREADY_EXISTS error
[   10.263668] ACPI: ACPI0007:00 is registered as cooling_device1
[   10.263668] ACPI: SSDT 7FEE8410, 00CE (r1 HPQOEM SLIC-CPC 42302E31 AWRD        0)
[   10.263668] ACPI: ACPI0007:01 is registered as cooling_device2
[   10.263668] ACPI: LNXTHERM:01 is registered as thermal_zone0
[   10.263668] ACPI: Thermal Zone [THRM] (-269 C)
[   10.479532] usbcore: registered new interface driver usbfs
[   10.479532] usbcore: registered new interface driver hub
[   10.479532] usbcore: registered new device driver usb
[   10.479532] USB Universal Host Controller Interface driver v3.0
[   10.479532] ACPI: PCI Interrupt 0000:00:1d.0[A] -> GSI 23 (level, low) -> IRQ 23
[   10.479532] PCI: Setting latency timer of device 0000:00:1d.0 to 64
[   10.479532] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[   10.479532] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 1
[   10.479532] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000ff00
[   10.479532] usb usb1: configuration #1 chosen from 1 choice
[   10.479532] hub 1-0:1.0: USB hub found
[   10.479532] hub 1-0:1.0: 2 ports detected
[   10.503533] No dock devices found.
[   10.513825] SCSI subsystem initialized
[   10.543112] libata version 3.00 loaded.
[   10.547542] e100: Intel(R) PRO/100 Network Driver, 3.5.23-k4-NAPI
[   10.547542] e100: Copyright(c) 1999-2006 Intel Corporation
[   10.580622] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
[   10.580625] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.580628] usb usb1: Product: UHCI Host Controller
[   10.580630] usb usb1: Manufacturer: Linux 2.6.26-2-686 uhci_hcd
[   10.580631] usb usb1: SerialNumber: 0000:00:1d.0
[   10.584408] ACPI: PCI Interrupt 0000:00:1d.1[B] -> GSI 19 (level, low) -> IRQ 19
[   10.584408] PCI: Setting latency timer of device 0000:00:1d.1 to 64
[   10.584408] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[   10.584408] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 2
[   10.584408] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000fe00
[   10.584408] usb usb2: configuration #1 chosen from 1 choice
[   10.584408] hub 2-0:1.0: USB hub found
[   10.584408] hub 2-0:1.0: 2 ports detected
[   10.686449] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[   10.686453] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.686456] usb usb2: Product: UHCI Host Controller
[   10.686458] usb usb2: Manufacturer: Linux 2.6.26-2-686 uhci_hcd
[   10.686461] usb usb2: SerialNumber: 0000:00:1d.1
[   10.689671] ACPI: PCI Interrupt 0000:00:1d.2[C] -> GSI 18 (level, low) -> IRQ 18
[   10.689671] PCI: Setting latency timer of device 0000:00:1d.2 to 64
[   10.689671] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[   10.689671] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 3
[   10.689671] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000fd00
[   10.689671] usb usb3: configuration #1 chosen from 1 choice
[   10.689671] hub 3-0:1.0: USB hub found
[   10.689671] hub 3-0:1.0: 2 ports detected
[   10.813615] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   10.813618] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.813621] usb usb3: Product: UHCI Host Controller
[   10.813623] usb usb3: Manufacturer: Linux 2.6.26-2-686 uhci_hcd
[   10.813626] usb usb3: SerialNumber: 0000:00:1d.2
[   10.814078] ACPI: PCI Interrupt 0000:00:1d.3[D] -> GSI 16 (level, low) -> IRQ 16
[   10.814078] PCI: Setting latency timer of device 0000:00:1d.3 to 64
[   10.814078] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[   10.814078] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 4
[   10.814078] uhci_hcd 0000:00:1d.3: irq 16, io base 0x0000fc00
[   10.814078] usb usb4: configuration #1 chosen from 1 choice
[   10.814078] hub 4-0:1.0: USB hub found
[   10.814078] hub 4-0:1.0: 2 ports detected
[   10.953988] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[   10.953992] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.953995] usb usb4: Product: UHCI Host Controller
[   10.953997] usb usb4: Manufacturer: Linux 2.6.26-2-686 uhci_hcd
[   10.953999] usb usb4: SerialNumber: 0000:00:1d.3
[   10.954413] ACPI: PCI Interrupt 0000:00:1d.7[A] -> GSI 23 (level, low) -> IRQ 23
[   10.954413] PCI: Setting latency timer of device 0000:00:1d.7 to 64
[   10.954413] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[   10.954413] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 5
[   10.958414] PCI: cache line size of 32 is not supported by device 0000:00:1d.7
[   10.958414] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xfdfff000
[   10.994904] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
[   10.994977] usb usb5: configuration #1 chosen from 1 choice
[   10.995008] hub 5-0:1.0: USB hub found
[   10.995015] hub 5-0:1.0: 8 ports detected
[   11.095469] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[   11.095473] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   11.095476] usb usb5: Product: EHCI Host Controller
[   11.095478] usb usb5: Manufacturer: Linux 2.6.26-2-686 ehci_hcd
[   11.095480] usb usb5: SerialNumber: 0000:00:1d.7
[   11.121369] ahci 0000:00:1f.2: version 3.0
[   11.121389] ACPI: PCI Interrupt 0000:00:1f.2[B] -> GSI 19 (level, low) -> IRQ 19
[   11.386447] usb 5-5: new high speed USB device using ehci_hcd and address 2
[   11.670357] usb 5-5: configuration #1 chosen from 1 choice
[   11.670357] usb 5-5: New USB device found, idVendor=058f, idProduct=6362
[   11.670357] usb 5-5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[   11.670357] usb 5-5: Product: Mass Storage Device
[   11.670357] usb 5-5: Manufacturer: Generic
[   11.670357] usb 5-5: SerialNumber: 058F312D81B
[   12.738743] ahci 0000:00:1f.2: AHCI 0001.0100 32 slots 4 ports 3 Gbps 0xf impl RAID mode
[   12.738747] ahci 0000:00:1f.2: flags: 64bit ncq led clo
[   12.738752] PCI: Setting latency timer of device 0000:00:1f.2 to 64
[   12.742718] scsi0 : ahci
[   12.742718] scsi1 : ahci
[   12.742718] scsi2 : ahci
[   12.742718] scsi3 : ahci
[   12.743188] ata1: SATA max UDMA/133 abar m1024@0xfdffe000 port 0xfdffe100 irq 222
[   12.743188] ata2: SATA max UDMA/133 abar m1024@0xfdffe000 port 0xfdffe180 irq 222
[   12.743188] ata3: SATA max UDMA/133 abar m1024@0xfdffe000 port 0xfdffe200 irq 222
[   12.743188] ata4: SATA max UDMA/133 abar m1024@0xfdffe000 port 0xfdffe280 irq 222
[   13.066633] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[   13.070587] ata1.00: ATA-7: SAMSUNG HD400LJ, ZZ100-15, max UDMA7
[   13.070587] ata1.00: 781422768 sectors, multi 0: LBA48 NCQ (depth 31/32)
[   13.071208] ata1.00: configured for UDMA/133
[   13.391199] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[   13.394299] ata2.00: ATAPI: TSSTcorpCD/DVDW TS-H653L, 0414, max UDMA/33, ATAPI AN
[   13.394302] ata2.00: applying bridge limits
[   13.397396] ata2.00: configured for UDMA/33
[   13.715218] ata3: SATA link down (SStatus 0 SControl 300)
[   14.490150] ata4: SATA link down (SStatus 0 SControl 300)
[   14.490139] scsi 0:0:0:0: Direct-Access     ATA      SAMSUNG HD400LJ  ZZ10 PQ: 0 ANSI: 5
[   14.491070] scsi 1:0:0:0: CD-ROM            TSSTcorp CD/DVDW TS-H653L 0414 PQ: 0 ANSI: 5
[   14.494139] ACPI: PCI Interrupt 0000:02:08.0[A] -> GSI 20 (level, low) -> IRQ 20
[   14.759104] e100: eth0: e100_probe: addr 0xfdefd000, irq 20, MAC addr 00:1a:92:2a:7d:86
[   14.762595] ACPI: PCI Interrupt 0000:02:01.0[A] -> GSI 20 (level, low) -> IRQ 20
[   14.814595] ohci1394: fw-host0: OHCI-1394 1.0 (PCI): IRQ=[20]  MMIO=[fdeff000-fdeff7ff]  Max Packet=[1024]  IR/IT contexts=[8/8]
[   14.826597] Uniform Multi-Platform E-IDE driver
[   14.826597] ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
[   14.826598] ICH7: IDE controller (0x8086:0x27df rev 0x01) at  PCI slot 0000:00:1f.1
[   14.826598] ACPI: PCI Interrupt 0000:00:1f.1[A] -> GSI 18 (level, low) -> IRQ 18
[   14.826598] ICH7: not 100% native mode: will probe irqs later
[   14.826598] ICH7: IDE port disabled
[   14.826598]     ide0: BM-DMA at 0xfb00-0xfb07
[   14.826598] Probing IDE interface ide0...
[   14.846568] Driver 'sd' needs updating - please use bus_type methods
[   14.846568] sd 0:0:0:0: [sda] 781422768 512-byte hardware sectors (400088 MB)
[   14.846568] sd 0:0:0:0: [sda] Write Protect is off
[   14.846568] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[   14.846568] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[   14.846568]  sda:<4>Driver 'sr' needs updating - please use bus_type methods
[   14.854916]  sda1 sda2 sda3 <<6>Initializing USB Mass Storage driver...
[   14.866818] scsi4 : SCSI emulation for USB Mass Storage devices
[   14.866916] usb-storage: device found at 2
[   14.866916] usb-storage: waiting for device to settle before scanning
[   14.866818] usbcore: registered new interface driver usb-storage
[   14.866818] USB Mass Storage support registered.
[   14.884667]  sda5 >
[   14.884797] sd 0:0:0:0: [sda] Attached SCSI disk
[   14.891122] sr0: scsi3-mmc drive: 40x/40x writer dvd-ram cd/rw xa/form2 cdda tray
[   14.891126] Uniform CD-ROM driver Revision: 3.20
[   14.891193] sr 1:0:0:0: Attached scsi CD-ROM sr0
[   14.902819] sd 0:0:0:0: Attached scsi generic sg0 type 0
[   14.902819] sr 1:0:0:0: Attached scsi generic sg1 type 5
[   15.434392] ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
[   15.766250] PM: Starting manual resume from disk
[   15.826240] kjournald starting.  Commit interval 5 seconds
[   15.826240] EXT3-fs: mounted filesystem with ordered data mode.
[   16.395599] ieee1394: Host added: ID:BUS[0-00:1023]  GUID[0011d8000118a604]
[   17.692371] udevd version 125 started
[   18.218962] Linux agpgart interface v0.103
[   18.343118] input: Power Button (FF) as /class/input/input1
[   18.387218] ACPI: Power Button (FF) [PWRF]
[   18.387275] input: Power Button (CM) as /class/input/input2
[   18.453055] ACPI: Power Button (CM) [PWRB]
[   18.868235] input: PC Speaker as /class/input/input3
[   18.896801] ACPI: PCI Interrupt 0000:00:1f.3[B] -> GSI 19 (level, low) -> IRQ 19
[   18.992453] Linux video capture interface: v2.00
[   19.030223] saa7130/34: v4l2 driver version 0.2.15 loaded
[   19.030223] ACPI: PCI Interrupt 0000:02:04.0[A] -> GSI 16 (level, low) -> IRQ 16
[   19.030223] saa7133[0]: found at 0000:02:04.0, rev: 209, irq: 16, latency: 32, mmio: 0xfdefe000
[   19.030223] saa7133[0]: subsystem: 1043:4871, board: ASUS P7131 4871 [card=111,autodetected]
[   19.030223] saa7133[0]: board init: gpio is 0
[   19.121357] input: PS2++ Logitech Wheel Mouse as /class/input/input4
[   19.179235] saa7133[0]: i2c eeprom 00: 43 10 71 48 54 20 1c 00 43 43 a9 1c 55 d2 b2 92
[   19.179245] saa7133[0]: i2c eeprom 10: ff ff ff 0f ff 20 ff ff ff ff ff ff ff ff ff ff
[   19.179254] saa7133[0]: i2c eeprom 20: 01 40 01 02 03 00 01 03 08 ff 00 cf ff ff ff ff
[   19.179262] saa7133[0]: i2c eeprom 30: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[   19.179271] saa7133[0]: i2c eeprom 40: ff 21 00 c2 96 10 03 22 15 50 ff ff ff ff ff ff
[   19.179279] saa7133[0]: i2c eeprom 50: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[   19.179287] saa7133[0]: i2c eeprom 60: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[   19.179296] saa7133[0]: i2c eeprom 70: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[   19.179304] saa7133[0]: i2c eeprom 80: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[   19.179312] saa7133[0]: i2c eeprom 90: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[   19.179321] saa7133[0]: i2c eeprom a0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[   19.179329] saa7133[0]: i2c eeprom b0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[   19.179337] saa7133[0]: i2c eeprom c0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[   19.179346] saa7133[0]: i2c eeprom d0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[   19.179354] saa7133[0]: i2c eeprom e0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[   19.179362] saa7133[0]: i2c eeprom f0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[   19.274645] ACPI: PCI Interrupt 0000:00:1b.0[A] -> GSI 16 (level, low) -> IRQ 16
[   19.274645] PCI: Setting latency timer of device 0000:00:1b.0 to 64
[   19.307574] hda_codec: Unknown model for ALC883, trying auto-probe from BIOS...
[   19.327864] tuner 1-004b: chip found @ 0x96 (saa7133[0])
[   19.407588] tda829x 1-004b: setting tuner address to 61
[   19.492321] tda829x 1-004b: type set to tda8290+75a
[   20.360867] usb-storage: device scan complete
[   20.360867] scsi 4:0:0:0: Direct-Access     Generic  USB SD Reader    1.00 PQ: 0 ANSI: 0
[   20.360867] scsi 4:0:0:1: Direct-Access     Generic  USB CF Reader    1.01 PQ: 0 ANSI: 0
[   20.360867] scsi 4:0:0:2: Direct-Access     Generic  USB SM Reader    1.02 PQ: 0 ANSI: 0
[   20.360867] scsi 4:0:0:3: Direct-Access     Generic  USB MS Reader    1.03 PQ: 0 ANSI: 0
[   20.360867] sd 4:0:0:0: [sdb] Attached SCSI removable disk
[   20.360867] sd 4:0:0:0: Attached scsi generic sg2 type 0
[   20.362776] sd 4:0:0:1: [sdc] Attached SCSI removable disk
[   20.362811] sd 4:0:0:1: Attached scsi generic sg3 type 0
[   20.364890] sd 4:0:0:2: [sdd] Attached SCSI removable disk
[   20.364922] sd 4:0:0:2: Attached scsi generic sg4 type 0
[   20.365013] sd 4:0:0:3: [sde] Attached SCSI removable disk
[   20.365013] sd 4:0:0:3: Attached scsi generic sg5 type 0
[   22.840657] saa7133[0]: dsp access error
[   22.900703] saa7133[0]: registered device video0 [v4l2]
[   22.900727] saa7133[0]: registered device vbi0
[   23.209621] dvb_init() allocating 1 frontend
[   23.388510] DVB: registering new adapter (saa7133[0])
[   23.388514] DVB: registering adapter 0 frontend 0 (Philips TDA10046H DVB-T)...
[   23.462701] tda1004x: setting up plls for 48MHz sampling clock
[   23.745508] tda1004x: found firmware revision 20 -- ok
[   24.115683] Adding 4128664k swap on /dev/sda5.  Priority:-1 extents:1 across:4128664k
[   24.169890] saa7134 ALSA driver for DMA sound loaded
[   24.169890] saa7133[0]/alsa: saa7133[0] at 0xfdefe000 irq 16 registered as card -1
[   24.485512] EXT3 FS on sda1, internal journal
[   24.995316] loop: module loaded
[   25.095672] fglrx: module license 'Proprietary. (C) 2002 - ATI Technologies, Starnberg, GERMANY' taints kernel.
[   25.121253] [fglrx] Maximum main memory to use for locked dma buffers: 1898 MBytes.
[   25.121253] [fglrx]   vendor: 1002 device: 7181 count: 1
[   25.121253] [fglrx] ioport: bar 4, base 0xde00, size: 0x100
[   25.121253] ACPI: PCI Interrupt 0000:01:00.0[A] -> GSI 16 (level, low) -> IRQ 16
[   25.121253] PCI: Setting latency timer of device 0000:01:00.0 to 64
[   25.121253] [fglrx] Driver built-in PAT support is enabled successfully
[   25.121253] [fglrx] module loaded - fglrx 8.59.2 [Mar 13 2009] with 1 minors
[   26.550617] e100: eth0: e100_watchdog: link up, 100Mbps, full-duplex
[   29.329751] NET: Registered protocol family 10
[   29.329751] lo: Disabled Privacy Extensions
[   30.093928] lp: driver loaded but no devices found
[   30.129927] ppdev: user-space parallel port driver
[   40.204758] eth0: no IPv6 routers present
[   49.095240] [fglrx] Firegl kernel thread PID: 3125
[   49.096180] [fglrx] Gart USWC size:949 M.
[   49.096180] [fglrx] Gart cacheable size:60 M.
[   49.096180] [fglrx] Reserved FB block: Shared offset:0, size:1000000
[   49.096180] [fglrx] Reserved FB block: Unshared offset:fefe000, size:102000
[   49.096180] [fglrx] Reserved FB block: Unshared offset:1fffb000, size:5000
[   58.441069] eth0: no IPv6 routers present
KMplayer dans la configuration donne “ASUS P7131 4871”
aprés avoir suivi les instruction du site
doc.ubuntu-fr.org/hauppauge_wintv-hvr-1100
et de
linuxtv.org/
l’application "Device Manager"
voir piéce jointe
il reste apparemment des elements pas configurer
j’ai tester comme ça avec Kaffeine, j’ai eu 17 chaines (tf1, france2,3,5, arte m6,w9,tmc,lcp, etc), depuis j’ai installer les pilote ati x1600 de chez amd, je n’est plus que 5 chaines (france2,3,5, arte,lcp)
est ce possible que l’installation de la carte graphique ATI pause probleme ou simple coïncidence.
la carte tv et ati sont 2 cartes differentes
merci pour votre aide
