Voici la commande lspci :
laptop-quentin:/etc# lspci
00:00.0 Host bridge: ATI Technologies Inc Unknown device 7930
00:01.0 PCI bridge: ATI Technologies Inc Unknown device 7932
00:12.0 SATA controller: ATI Technologies Inc SB600 Non-Raid-5 SATA
00:13.0 USB Controller: ATI Technologies Inc SB600 USB (OHCI0)
00:13.1 USB Controller: ATI Technologies Inc SB600 USB (OHCI1)
00:13.2 USB Controller: ATI Technologies Inc SB600 USB (OHCI2)
00:13.3 USB Controller: ATI Technologies Inc SB600 USB (OHCI3)
00:13.4 USB Controller: ATI Technologies Inc SB600 USB (OHCI4)
00:13.5 USB Controller: ATI Technologies Inc SB600 USB Controller (EHCI)
00:14.0 SMBus: ATI Technologies Inc SB600 SMBus (rev 14)
00:14.1 IDE interface: ATI Technologies Inc SB600 IDE
00:14.2 Audio device: ATI Technologies Inc SB600 Azalia
00:14.3 ISA bridge: ATI Technologies Inc SB600 PCI to LPC Bridge
00:14.4 PCI bridge: ATI Technologies Inc SB600 PCI to PCI Bridge
01:05.0 VGA compatible controller: ATI Technologies Inc Unknown device 7942
02:05.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
Et le dmesg (un peu long):
laptop-quentin:/etc# dmesg
Linux version 2.6.18-6-686 (Debian 2.6.18.dfsg.1-22) (dannf@debian.org) (gcc version 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)) #1 SMP Tue Jun 17 21:31:27 UTC 2008
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009dc00 (usable)
BIOS-e820: 000000000009dc00 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000ce000 - 00000000000d0000 (reserved)
BIOS-e820: 00000000000dc000 - 00000000000e0000 (reserved)
BIOS-e820: 00000000000e4000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000002fe90000 (usable)
BIOS-e820: 000000002fe90000 - 000000002fe9c000 (ACPI data)
BIOS-e820: 000000002fe9c000 - 000000002fe9d000 (ACPI NVS)
BIOS-e820: 000000002fe9d000 - 0000000030000000 (reserved)
BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
BIOS-e820: 00000000fec00000 - 00000000fec10000 (reserved)
BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
BIOS-e820: 00000000fff80000 - 0000000100000000 (reserved)
0MB HIGHMEM available.
766MB LOWMEM available.
found SMP MP-table at 000f7d50
On node 0 totalpages: 196240
DMA zone: 4096 pages, LIFO batch:0
Normal zone: 192144 pages, LIFO batch:31
DMI present.
ACPI: RSDP (v000 PTLTD ) @ 0x000f7d20
ACPI: RSDT (v001 SECCSD LH43STAR 0x06040000 LTP 0x00000000) @ 0x2fe92d4d
ACPI: FADT (v001 SEC HAINANII 0x06040000 SEC 0x000f4240) @ 0x2fe9bd4e
ACPI: MADT (v001 PTLTD APIC 0x06040000 LTP 0x00000000) @ 0x2fe9bdc2
ACPI: MCFG (v001 PTLTD MCFG 0x06040000 LTP 0x00000000) @ 0x2fe9be16
ACPI: HPET (v001 PTLTD HPETTBL 0x06040000 LTP 0x00000001) @ 0x2fe9be52
ACPI: SLIC (v001 SECCSD LH43STAR 0x06040000 LTP 0x00000000) @ 0x2fe9be8a
ACPI: SSDT (v001 PmRef Cpu0Tst 0x00003000 INTL 0x20050228) @ 0x2fe9423c
ACPI: SSDT (v001 PmRef Cpu1Tst 0x00003000 INTL 0x20050228) @ 0x2fe94196
ACPI: SSDT (v001 PmRef CpuPm 0x00003000 INTL 0x20050228) @ 0x2fe92d91
ACPI: DSDT (v001 ATI SB600 0x06040000 INTL 0x20050228) @ 0x00000000
ATI board detected. Disabling timer routing over 8254.
ACPI: PM-Timer IO Port: 0x8008
ACPI: Local APIC address 0xfee00000
ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
Processor #0 6:15 APIC version 20
ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled)
Processor #1 6:15 APIC version 20
ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
IOAPIC[0]: apic_id 2, version 33, address 0xfec00000, GSI 0-23
ACPI: IRQ9 used by override.
Enabling APIC mode: Flat. Using 1 I/O APICs
ACPI: HPET id: 0x43538310 base: 0xfed00000
Using ACPI (MADT) for SMP configuration information
Allocating PCI resources starting at 40000000 (gap: 30000000:b0000000)
Detected 1666.795 MHz processor.
Built 1 zonelists. Total pages: 196240
Kernel command line: root=/dev/sda1 ro
mapped APIC to ffffd000 (fee00000)
mapped IOAPIC to ffffc000 (fec00000)
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Initializing CPU#0
PID hash table entries: 4096 (order: 12, 16384 bytes)
Console: colour VGA+ 80x25
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 769964k/784960k available (1541k kernel code, 14436k reserved, 580k data, 196k init, 0k highmem)
Checking if this processor honours the WP bit even in supervisor mode... Ok.
hpet0: at MMIO 0xfed00000 (virtual 0xf0800000), IRQs 2, 8, 0, 0
hpet0: 4 32-bit timers, 14318180 Hz
Using HPET for base-timer
Calibrating delay using timer specific routine.. 3336.58 BogoMIPS (lpj=6673162)
Security Framework v1.0.0 initialized
SELinux: Disabled at boot.
Capability LSM initialized
Mount-cache hash table entries: 512
CPU: After generic identify, caps: bfebfbff 20000000 00000000 00000000 0000e3bd 00000000 00000001
CPU: After vendor identify, caps: bfebfbff 20000000 00000000 00000000 0000e3bd 00000000 00000001
monitor/mwait feature present.
using mwait in idle threads.
CPU: L1 I cache: 32K, L1 D cache: 32K
CPU: L2 cache: 2048K
CPU: Physical Processor ID: 0
CPU: Processor Core ID: 0
CPU: After all inits, caps: bfebfbff 20000000 00000000 00000940 0000e3bd 00000000 00000001
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
Compat vDSO mapped to ffffe000.
Checking 'hlt' instruction... OK.
SMP alternatives: switching to UP code
ACPI: Core revision 20060707
CPU0: Intel(R) Core(TM)2 CPU T5500 @ 1.66GHz stepping 02
SMP alternatives: switching to SMP code
Booting processor 1/1 eip 3000
Initializing CPU#1
Calibrating delay using timer specific routine.. 3333.59 BogoMIPS (lpj=6667192)
CPU: Processor Core ID: 1
Intel machine check reporting enabled on CPU#1.
CPU1: Intel(R) Core(TM)2 CPU T5500 @ 1.66GHz stepping 02
Total of 2 processors activated (6670.17 BogoMIPS).
ENABLING IO-APIC IRQs
..TIMER: vector=0x31 apic1=0 pin1=0 apic2=-1 pin2=-1
..MP-BIOS bug: 8254 timer not connected to IO-APIC
...trying to set up timer (IRQ0) through the 8259A ... failed.
...trying to set up timer as Virtual Wire IRQ... works.
checking TSC synchronization across 2 CPUs: passed.
Brought up 2 CPUs
migration_cost=119
checking if image is initramfs... it is
Freeing initrd memory: 4781k freed
NET: Registered protocol family 16
ACPI: bus type pci registered
PCI: Using MMCONFIG
Setting up standard PCI resources
ACPI: Interpreter enabled
ACPI: Using IOAPIC for interrupt routing
ACPI: PCI Root Bridge [PCI0] (0000:00)
PCI: Probing PCI hardware (bus 00)
PCI: Ignoring BAR0-3 of IDE controller 0000:00:14.1
Boot video device is 0000:01:05.0
PCI: Transparent bridge - 0000:00:14.4
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: PCI Interrupt Link [LNKA] (IRQs 11) *0, disabled.
ACPI: PCI Interrupt Link [LNKB] (IRQs 10) *0, disabled.
ACPI: PCI Interrupt Link [LNKC] (IRQs 5) *0, disabled.
ACPI: PCI Interrupt Link [LNKD] (IRQs 5) *0, disabled.
ACPI: PCI Interrupt Link [LNKE] (IRQs 11) *0, disabled.
ACPI: PCI Interrupt Link [LNKF] (IRQs 10) *0, disabled.
ACPI: PCI Interrupt Link [LNKG] (IRQs 5) *0, disabled.
ACPI: PCI Interrupt Link [LNKH] (IRQs 5) *0, disabled.
ACPI: Embedded Controller [H_EC] (gpe 3) interrupt mode.
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P2P_._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.AGP_._PRT]
Linux Plug and Play Support v0.97 (c) Adam Belay
pnp: PnP ACPI init
pnp: PnP ACPI: found 11 devices
PnPBIOS: Disabled by ACPI PNP
PCI: Using ACPI for IRQ routing
PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
pnp: 00:08: ioport range 0x220-0x22f has been reserved
pnp: 00:08: ioport range 0x40b-0x40b has been reserved
PCI: Ignore bogus resource 6 [0:0] of 0000:01:05.0
PCI: Bridge: 0000:00:01.0
IO window: 9000-9fff
MEM window: c0100000-c01fffff
PREFETCH window: d0000000-dfffffff
PCI: Bridge: 0000:00:14.4
IO window: a000-afff
MEM window: f0200000-f02fffff
PREFETCH window: f0300000-f03fffff
NET: Registered protocol family 2
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP reno registered
audit: initializing netlink socket (disabled)
audit(1219501547.200:1): initialized
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
hpet_resources: 0xfed00000 is busy
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
PNP: PS/2 Controller [PNP0303:KBC0,PNP0f13:MSE0] at 0x60,0x64 irq 1,12
i8042.c: Detected active multiplexing controller, rev 1.1.
serio: i8042 AUX0 port at 0x60,0x64 irq 12
serio: i8042 AUX1 port at 0x60,0x64 irq 12
serio: i8042 AUX2 port at 0x60,0x64 irq 12
serio: i8042 AUX3 port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
mice: PS/2 mouse device common for all mice
TCP bic registered
NET: Registered protocol family 17
NET: Registered protocol family 8
NET: Registered protocol family 20
Starting balanced_irq
Using IPI No-Shortcut mode
ACPI: (supports S0 S3 S4 S5)
Freeing unused kernel memory: 196k freed
Time: tsc clocksource has been installed.
ACPI (exconfig-0455): Dynamic SSDT Load - OemId [ PmRef] OemTableId [ Cpu0Ist] [20060707]
ACPI (exconfig-0455): Dynamic SSDT Load - OemId [ PmRef] OemTableId [ Cpu0Cst] [20060707]
ACPI: CPU0 (power states: C1[C1] C2[C2])
ACPI (exconfig-0455): Dynamic SSDT Load - OemId [ PmRef] OemTableId [ Cpu1Ist] [20060707]
ACPI (exconfig-0455): Dynamic SSDT Load - OemId [ PmRef] OemTableId [ Cpu1Cst] [20060707]
ACPI: CPU1 (power states: C1[C1] C2[C2])
ACPI Exception (acpi_processor-0681): AE_NOT_FOUND, Processor Device is not present [20060707]
ACPI: Getting cpuindex for acpiid 0x2
ACPI: Getting cpuindex for acpiid 0x3
ACPI: Getting cpuindex for acpiid 0x4
ACPI: Getting cpuindex for acpiid 0x5
ACPI: Getting cpuindex for acpiid 0x6
ACPI: Getting cpuindex for acpiid 0x7
ACPI Exception (acpi_thermal-0412): AE_NOT_FOUND, Invalid active threshold [0] [20060707]
ACPI: Thermal Zone [TZ00] (60 C)
ACPI: Thermal Zone [TZ01] (27 C)
Time: hpet clocksource has been installed.
input: AT Translated Set 2 keyboard as /class/input/input0
usbcore: registered new driver usbfs
usbcore: registered new driver hub
SCSI subsystem initialized
libata version 2.00 loaded.
ahci 0000:00:12.0: version 2.0
ACPI: PCI Interrupt 0000:00:12.0[A] -> GSI 22 (level, low) -> IRQ 177
8139cp: 10/100 PCI Ethernet driver v1.2 (Mar 22, 2004)
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
ohci_hcd: 2005 April 22 USB 1.1 'Open' Host Controller (OHCI) Driver (PCI)
ahci 0000:00:12.0: AHCI 0001.0100 32 slots 4 ports 3 Gbps 0xf impl SATA mode
ahci 0000:00:12.0: flags: 64bit ncq ilck pm led clo pmp pio slum part
ata1: SATA max UDMA/133 cmd 0xF0830100 ctl 0x0 bmdma 0x0 irq 177
ata2: SATA max UDMA/133 cmd 0xF0830180 ctl 0x0 bmdma 0x0 irq 177
ata3: SATA max UDMA/133 cmd 0xF0830200 ctl 0x0 bmdma 0x0 irq 177
ata4: SATA max UDMA/133 cmd 0xF0830280 ctl 0x0 bmdma 0x0 irq 177
scsi0 : ahci
ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
ata1.00: ATA-7, max UDMA7, 234441648 sectors: LBA48 NCQ (depth 31/32)
ata1.00: ata1: dev 0 multi count 16
ata1.00: configured for UDMA/133
scsi1 : ahci
ata2: SATA link down (SStatus 0 SControl 300)
scsi2 : ahci
ata3: SATA link down (SStatus 0 SControl 300)
scsi3 : ahci
ata4: SATA link down (SStatus 0 SControl 300)
Vendor: ATA Model: SAMSUNG HM120JI Rev: YF10
Type: Direct-Access ANSI SCSI revision: 05
8139cp 0000:02:05.0: This (id 10ec:8139 rev 10) is not an 8139C+ compatible chip
ACPI: PCI Interrupt 0000:00:13.5[D] -> GSI 19 (level, low) -> IRQ 193
8139cp 0000:02:05.0: Try the "8139too" driver instead.
ehci_hcd 0000:00:13.5: EHCI Host Controller
ehci_hcd 0000:00:13.5: new USB bus registered, assigned bus number 1
ehci_hcd 0000:00:13.5: debug port 1
ehci_hcd 0000:00:13.5: irq 193, io mem 0xc0004400
ehci_hcd 0000:00:13.5: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 10 ports detected
8139too Fast Ethernet driver 0.9.27
SCSI device sda: 234441648 512-byte hdwr sectors (120034 MB)
sda: Write Protect is off
sda: Mode Sense: 00 3a 00 00
SCSI device sda: drive cache: write back
sda:<6>SB600_PATA: IDE controller at PCI slot 0000:00:14.1
ACPI: PCI Interrupt 0000:00:14.1[A] -> GSI 16 (level, low) -> IRQ 201
SB600_PATA: chipset revision 0
SB600_PATA: not 100% native mode: will probe irqs later
ide0: BM-DMA at 0x8420-0x8427, BIOS settings: hda:DMA, hdb:pio
Probing IDE interface ide0...
sda1 sda2 sda3
sd 0:0:0:0: Attached scsi disk sda
usb 1-6: new high speed USB device using ehci_hcd and address 2
usb 1-6: configuration #1 chosen from 1 choice
Initializing USB Mass Storage driver...
scsi4 : SCSI emulation for USB Mass Storage devices
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
usb-storage: device found at 2
usb-storage: waiting for device to settle before scanning
hda: DV-W28EC, ATAPI CD/DVD-ROM drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
ACPI: PCI Interrupt 0000:00:13.0[A] -> GSI 16 (level, low) -> IRQ 201
ohci_hcd 0000:00:13.0: OHCI Host Controller
ohci_hcd 0000:00:13.0: new USB bus registered, assigned bus number 2
ohci_hcd 0000:00:13.0: irq 201, io mem 0xc0005000
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:13.1[B] -> GSI 17 (level, low) -> IRQ 209
ohci_hcd 0000:00:13.1: OHCI Host Controller
ohci_hcd 0000:00:13.1: new USB bus registered, assigned bus number 3
ohci_hcd 0000:00:13.1: irq 209, io mem 0xc0006000
usb usb3: configuration #1 chosen from 1 choice
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:13.2[C] -> GSI 18 (level, low) -> IRQ 217
ohci_hcd 0000:00:13.2: OHCI Host Controller
ohci_hcd 0000:00:13.2: new USB bus registered, assigned bus number 4
ohci_hcd 0000:00:13.2: irq 217, io mem 0xc0007000
usb usb4: configuration #1 chosen from 1 choice
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:13.3[B] -> GSI 17 (level, low) -> IRQ 209
ohci_hcd 0000:00:13.3: OHCI Host Controller
ohci_hcd 0000:00:13.3: new USB bus registered, assigned bus number 5
ohci_hcd 0000:00:13.3: irq 209, io mem 0xc0008000
usb usb5: configuration #1 chosen from 1 choice
hub 5-0:1.0: USB hub found
hub 5-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:13.4[C] -> GSI 18 (level, low) -> IRQ 217
ohci_hcd 0000:00:13.4: OHCI Host Controller
ohci_hcd 0000:00:13.4: new USB bus registered, assigned bus number 6
ohci_hcd 0000:00:13.4: irq 217, io mem 0xc0009000
usb usb6: configuration #1 chosen from 1 choice
hub 6-0:1.0: USB hub found
hub 6-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:02:05.0[A] -> GSI 22 (level, low) -> IRQ 177
eth0: RealTek RTL8139 at 0xa000, 00:13:77:48:e7:f9, IRQ 177
eth0: Identified 8139 chip type 'RTL-8100B/8139D'
hda: ATAPI 24X DVD-ROM DVD-R-RAM CD-R/RW drive, 2000kB Cache, UDMA(33)
Uniform CD-ROM driver Revision: 3.20
Attempting manual resume
kjournald starting. Commit interval 5 seconds
EXT3-fs: mounted filesystem with ordered data mode.
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
input: PC Speaker as /class/input/input1
Real Time Clock Driver v1.12ac
piix4_smbus 0000:00:14.0: Found 0000:00:14.0 device
Linux agpgart interface v0.101 (c) Dave Jones
ACPI: PCI Interrupt 0000:00:14.2[A] -> GSI 16 (level, low) -> IRQ 201
Vendor: Multi Model: Flash Reader Rev: 1.00
Type: Direct-Access ANSI SCSI revision: 00
sd 4:0:0:0: Attached scsi removable disk sdb
usb-storage: device scan complete
Synaptics Touchpad, model: 1, fw: 6.2, id: 0x25a0b1, caps: 0xa04713/0x200000
input: SynPS/2 Synaptics TouchPad as /class/input/input2
ts: Compaq touchscreen protocol output
hda_codec: Unknown model for ALC262, trying auto-probe from BIOS...
Adding 1502068k swap on /dev/sda3. Priority:-1 extents:1 across:1502068k
EXT3 FS on sda1, internal journal
loop: loaded (max 8 devices)
device-mapper: ioctl: 4.7.0-ioctl (2006-06-24) initialised: dm-devel@redhat.com
eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
ACPI: Battery Slot [BAT1] (battery present)
ACPI: AC Adapter [ADP1] (on-line)
ACPI: Power Button (FF) [PWRF]
ACPI: Power Button (CM) [PWRB]
ACPI: Lid Switch [LID0]
ACPI: Sleep Button (CM) [SLPB]
lp: driver loaded but no devices found
ppdev: user-space parallel port driver
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
IPv6 over IPv4 tunneling driver
Bluetooth: Core ver 2.10
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP ver 2.8
Bluetooth: L2CAP socket layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM ver 1.8
fglrx: module license 'Proprietary. (C) 2002 - ATI Technologies, Starnberg, GERMANY' taints kernel.
[fglrx] Maximum main memory to use for locked dma buffers: 679 MBytes.
[fglrx] vendor: 1002 device: 7942 count: 1
[fglrx] ioport: bar 4, base 0x9000, size: 0x100
ACPI: PCI Interrupt 0000:01:05.0[A] -> GSI 18 (level, low) -> IRQ 217
[fglrx] PAT is enabled successfully!
[fglrx] module loaded - fglrx 8.52.3 [Aug 1 2008] with 1 minors
[fglrx] Reserved FB block: Shared offset:0, size:1000000
[fglrx] Reserved FB block: Unshared offset:ff7b000, size:80000
[fglrx] Reserved FB block: Unshared offset:fffb000, size:5000
eth0: no IPv6 routers present
hda: tray open
end_request: I/O error, dev hda, sector 0
Buffer I/O error on device hda, logical block 0
Buffer I/O error on device hda, logical block 1
Buffer I/O error on device hda, logical block 2
Buffer I/O error on device hda, logical block 3
Buffer I/O error on device hda, logical block 4
Buffer I/O error on device hda, logical block 5
Buffer I/O error on device hda, logical block 6
Buffer I/O error on device hda, logical block 7
hda: tray open
hda: tray open
end_request: I/O error, dev hda, sector 4
hda: tray open
hda: tray open
hda: tray open
hda: tray open
hda: tray open
hda: tray open
hda: tray open
hda: tray open
sd 0:0:0:0: Attached scsi generic sg0 type 0
sd 4:0:0:0: Attached scsi generic sg1 type 0
