[quote=“fran.b”]Tu peux donner un lspci -n??
Il me semble que les drivers des cartes acx ont été intégrés dans le noyau…[/quote]
Je suppose que tu veux plutôt dire lspci -nn
Voici la réponse :
00:00.0 RAM memory [0500]: nVidia Corporation MCP61 LPC Bridge [10de:03e2] (rev a1)
00:01.0 ISA bridge [0601]: nVidia Corporation MCP61 LPC Bridge [10de:03e1] (rev a2)
00:01.1 SMBus [0c05]: nVidia Corporation MCP61 SMBus [10de:03eb] (rev a2)
00:01.2 RAM memory [0500]: nVidia Corporation MCP61 Memory Controller [10de:03f5] (rev a2)
00:02.0 USB Controller [0c03]: nVidia Corporation MCP61 USB Controller [10de:03f1] (rev a3)
00:02.1 USB Controller [0c03]: nVidia Corporation MCP61 USB Controller [10de:03f2] (rev a3)
00:04.0 PCI bridge [0604]: nVidia Corporation MCP61 PCI bridge [10de:03f3] (rev a1)
00:05.0 Audio device [0403]: nVidia Corporation MCP61 High Definition Audio [10de:03f0] (rev a2)
00:06.0 IDE interface [0101]: nVidia Corporation MCP61 IDE [10de:03ec] (rev a2)
00:07.0 Bridge [0680]: nVidia Corporation MCP61 Ethernet [10de:03ef] (rev a2)
00:08.0 IDE interface [0101]: nVidia Corporation MCP61 SATA Controller [10de:03f6] (rev a2)
00:08.1 IDE interface [0101]: nVidia Corporation MCP61 SATA Controller [10de:03f6] (rev a2)
00:09.0 PCI bridge [0604]: nVidia Corporation MCP61 PCI Express bridge [10de:03e8] (rev a2)
00:0b.0 PCI bridge [0604]: nVidia Corporation MCP61 PCI Express bridge [10de:03e9] (rev a2)
00:0c.0 PCI bridge [0604]: nVidia Corporation MCP61 PCI Express bridge [10de:03e9] (rev a2)
00:18.0 Host bridge [0600]: Advanced Micro Devices [AMD] K10 [Opteron, Athlon64, Sempron] HyperTransport Configuration [1022:1200]
00:18.1 Host bridge [0600]: Advanced Micro Devices [AMD] K10 [Opteron, Athlon64, Sempron] Address Map [1022:1201]
00:18.2 Host bridge [0600]: Advanced Micro Devices [AMD] K10 [Opteron, Athlon64, Sempron] DRAM Controller [1022:1202]
00:18.3 Host bridge [0600]: Advanced Micro Devices [AMD] K10 [Opteron, Athlon64, Sempron] Miscellaneous Control [1022:1203]
00:18.4 Host bridge [0600]: Advanced Micro Devices [AMD] K10 [Opteron, Athlon64, Sempron] Link Control [1022:1204]
01:09.0 Network controller [0280]: Texas Instruments ACX 100 22Mbps Wireless Interface [104c:8400]
02:00.0 VGA compatible controller [0300]: nVidia Corporation GT218 [GeForce 210] [10de:0a65] (rev a2)
02:00.1 Audio device [0403]: nVidia Corporation High Definition Audio Controller [10de:0be3] (rev a1)
lspci -k donne :
00:00.0 RAM memory: nVidia Corporation MCP61 LPC Bridge (rev a1)
00:01.0 ISA bridge: nVidia Corporation MCP61 LPC Bridge (rev a2)
00:01.1 SMBus: nVidia Corporation MCP61 SMBus (rev a2)
Kernel driver in use: nForce2_smbus
Kernel modules: i2c-nforce2
00:01.2 RAM memory: nVidia Corporation MCP61 Memory Controller (rev a2)
00:02.0 USB Controller: nVidia Corporation MCP61 USB Controller (rev a3)
Kernel driver in use: ohci_hcd
00:02.1 USB Controller: nVidia Corporation MCP61 USB Controller (rev a3)
Kernel driver in use: ehci_hcd
00:04.0 PCI bridge: nVidia Corporation MCP61 PCI bridge (rev a1)
00:05.0 Audio device: nVidia Corporation MCP61 High Definition Audio (rev a2)
Kernel driver in use: HDA Intel
Kernel modules: snd-hda-intel
00:06.0 IDE interface: nVidia Corporation MCP61 IDE (rev a2)
Kernel driver in use: pata_amd
Kernel modules: pata_amd
00:07.0 Bridge: nVidia Corporation MCP61 Ethernet (rev a2)
Kernel driver in use: forcedeth
Kernel modules: forcedeth
00:08.0 IDE interface: nVidia Corporation MCP61 SATA Controller (rev a2)
Kernel driver in use: sata_nv
Kernel modules: sata_nv
00:08.1 IDE interface: nVidia Corporation MCP61 SATA Controller (rev a2)
00:09.0 PCI bridge: nVidia Corporation MCP61 PCI Express bridge (rev a2)
Kernel driver in use: pcieport
Kernel modules: shpchp
00:0b.0 PCI bridge: nVidia Corporation MCP61 PCI Express bridge (rev a2)
00:0c.0 PCI bridge: nVidia Corporation MCP61 PCI Express bridge (rev a2)
00:18.0 Host bridge: Advanced Micro Devices [AMD] K10 [Opteron, Athlon64, Sempron] HyperTransport Configuration
00:18.1 Host bridge: Advanced Micro Devices [AMD] K10 [Opteron, Athlon64, Sempron] Address Map
00:18.2 Host bridge: Advanced Micro Devices [AMD] K10 [Opteron, Athlon64, Sempron] DRAM Controller
Kernel modules: amd64_edac_mod
00:18.3 Host bridge: Advanced Micro Devices [AMD] K10 [Opteron, Athlon64, Sempron] Miscellaneous Control
00:18.4 Host bridge: Advanced Micro Devices [AMD] K10 [Opteron, Athlon64, Sempron] Link Control
01:09.0 Network controller: Texas Instruments ACX 100 22Mbps Wireless Interface
02:00.0 VGA compatible controller: nVidia Corporation GT218 [GeForce 210] (rev a2)
Kernel driver in use: nvidia
Kernel modules: nvidia-current, nvidiafb, nouveau
02:00.1 Audio device: nVidia Corporation High Definition Audio Controller (rev a1)
Cordialement,
