Carte wifi sur hp probook 450 g2
ma carte wifi n’est pas réconnu après avoir installer debian 7 sur mon laptop hp probook 450 g2
la commande lspci me donne
00:00.0 Host bridge: Intel Corporation Haswell-ULT DRAM Controller (rev 0b) 00:02.0 VGA compatible controller: Intel Corporation Haswell-ULT Integrated Graphics Controller (rev 0b) 00:03.0 Audio device: Intel Corporation Device 0a0c (rev 0b) 00:14.0 USB controller: Intel Corporation Lynx Point-LP USB xHCI HC (rev 04) 00:16.0 Communication controller: Intel Corporation Lynx Point-LP HECI #0 (rev 04) 00:1b.0 Audio device: Intel Corporation Lynx Point-LP HD Audio Controller (rev 04) 00:1c.0 PCI bridge: Intel Corporation Lynx Point-LP PCI Express Root Port 1 (rev e4) 00:1c.1 PCI bridge: Intel Corporation Lynx Point-LP PCI Express Root Port 2 (rev e4) 00:1c.2 PCI bridge: Intel Corporation Lynx Point-LP PCI Express Root Port 3 (rev e4) 00:1c.3 PCI bridge: Intel Corporation Lynx Point-LP PCI Express Root Port 4 (rev e4) 00:1c.4 PCI bridge: Intel Corporation Lynx Point-LP PCI Express Root Port 5 (rev e4) 00:1d.0 USB controller: Intel Corporation Lynx Point-LP USB EHCI #1 (rev 04) 00:1f.0 ISA bridge: Intel Corporation Lynx Point-LP LPC Controller (rev 04) 00:1f.2 SATA controller: Intel Corporation Lynx Point-LP SATA Controller 1 [AHCI mode] (rev 04) 00:1f.6 Signal processing controller: Intel Corporation Lynx Point-LP Thermal (rev 04) 07:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. Device 5227 (rev 01) 08:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 10) 09:00.0 Network controller: Realtek Semiconductor Co., Ltd. Device b723 0a:00.0 Display controller: Advanced Micro Devices [AMD] nee ATI Device 6901
j’ai essayer avec cette manip
mais j’ai rien eu
geekeries.de-labrusse.fr/?p=1786
la commande ifconfig -a montre seulement le eth0 et lo
:confused:
installer le paquetage firmware-realtek => backport
Regarde aussi, dans les options du BIOS, si la carte WiFi est bien activée .
le package est déjà installer est ifconfig -a retourne toujours eth0 et lo seulement
j’ai vérifier aussi au niveau bios , elle bien activer
