Casque détecté mais pas de son
Bonjour!
Je viens de faire une installation toute fraîche de Trixie stable 13.1 version kde et je n’ai pas de son lorsque je branche mon casque audio (prise mini-jack) de ma machine. Alsa mixer montre bien le changement (les hp passent en muet) lorsque je branche le casque mais le son ne sort pas… Help !
lspci -l donne ceci :
00:1f.3 Audio device: Intel Corporation Sunrise Point-LP HD Audio (rev 21)
        Subsystem: ASUSTeK Computer Inc. Device 1b60
        Flags: bus master, fast devsel, latency 32, IRQ 136, IOMMU group 10
        Memory at ef128000 (64-bit, non-prefetchable) [size=16K]
        Memory at ef100000 (64-bit, non-prefetchable) [size=64K]
        Capabilities: <access denied>
        Kernel driver in use: snd_hda_intel
        Kernel modules: snd_hda_intel, snd_soc_avs, snd_sof_pci_intel_skl
inxi -Fxxxmprz
System:
  Kernel: 6.12.48+deb13-amd64 arch: x86_64 bits: 64 compiler: gcc v: 14.2.0
    clocksource: tsc
  Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A wm: kwin_wayland vt: 1 dm: SDDM
    Distro: Debian GNU/Linux 13 (trixie)
Machine:
  Type: Convertible System: ASUSTeK product: UX370UAF v: 1.0
    serial: <superuser required>
  Mobo: ASUSTeK model: UX370UAF v: 1.0 serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends v: UX370UAF.310
    date: 04/17/2019
Battery:
  ID-1: BAT0 charge: 14.4 Wh (59.0%) condition: 24.4/39.0 Wh (62.5%)
    power: 3.8 W volts: 7.7 min: 7.7 model: ASUSTeK ASUS Battery type: Li-ion
    serial: N/A status: discharging cycles: 737
Memory:
  System RAM: total: 8 GiB available: 7.63 GiB used: 3.48 GiB (45.6%)
  Message: For most reliable report, use superuser + dmidecode.
  Array-1: capacity: 8 GiB slots: 2 modules: 2 EC: None
    max-module-size: 4 GiB note: est.
  Device-1: ChannelA-DIMM0 type: LPDDR3 detail: synchronous unbuffered
    (unregistered) size: 4 GiB speed: 2133 MT/s volts: curr: 1 min: 1.25
    max: 1.25 width (bits): data: 64 total: 64 manufacturer: Samsung
    part-no: K4E6E304EB-EGCG serial: <filter>
  Device-2: ChannelB-DIMM0 type: LPDDR3 detail: synchronous unbuffered
CPU:
  Info: dual core model: Intel Core i5-7200U bits: 64 type: MT MCP
    smt: enabled arch: Amber/Kaby Lake note: check rev: 9 cache: L1: 128 KiB
    L2: 512 KiB L3: 3 MiB
  Speed (MHz): avg: 400 min/max: 400/3100 cores: 1: 400 2: 400 3: 400 4: 400
    bogomips: 21599
  Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Graphics:
  Device-1: Intel HD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel
    arch: Gen-9.5 ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2
    bus-ID: 00:02.0 chip-ID: 8086:5916 class-ID: 0300
  Device-2: IMC Networks USB2.0 VGA UVC WebCam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 1-5:2 chip-ID: 13d3:5755
    class-ID: 0e02 serial: <filter>
  Display: wayland server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6
    compositor: kwin_wayland driver: X: loaded: modesetting unloaded: fbdev,vesa
    dri: iris gpu: i915 display-ID: 0
  Monitor-1: eDP-1 model: AU Optronics 0x422d res: mode: 1920x1080 hz: 60
    scale: 125% (1.25) to: 1536x864 dpi: 166 size: 293x165mm (11.54x6.5")
    diag: 336mm (13.2") modes: 1920x1080
  API: EGL v: 1.5 hw: drv: intel iris platforms: device: 0 drv: iris
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris wayland:
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.0.7-2 glx-v: 1.4
    direct-render: yes renderer: Mesa Intel HD Graphics 620 (KBL GT2)
    device-ID: 8086:5916 display-ID: :1.0
  API: Vulkan v: 1.4.309 layers: 3 surfaces: xcb,xlib,wayland device: 0
    type: integrated-gpu driver: mesa intel device-ID: 8086:5916 device: 1
    type: cpu driver: mesa llvmpipe device-ID: 10005:0000
  Info: Tools: api: clinfo, eglinfo, glxinfo, vulkaninfo
    de: kscreen-console,kscreen-doctor wl: wayland-info x11: xdriinfo,
    xdpyinfo, xprop, xrandr
Audio:
  Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:9d71
    class-ID: 0403
  API: ALSA v: k6.12.48+deb13-amd64 status: kernel-api
  Server-1: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse
    status: active 2: wireplumber status: active
Network:
  Device-1: Intel Wireless 8260 driver: iwlwifi v: kernel pcie:
    speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:24f3 class-ID: 0280
  IF: wlp1s0 state: up mac: <filter>
Bluetooth:
  Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 bus-ID: 1-8:3 chip-ID: 8087:0a2b
    class-ID: e001
  Report: hciconfig ID: hci0 rfk-id: 0 state: down
    bt-service: enabled,running rfk-block: hardware: no software: yes
    address: <filter>
Drives:
  Local Storage: total: 238.47 GiB used: 88.09 GiB (36.9%)
  ID-1: /dev/sda vendor: SanDisk model: SD8SN8U256G1002 size: 238.47 GiB
    speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 1002 scheme: GPT
Partition:
  ID-1: / size: 134.21 GiB used: 88.06 GiB (65.6%) fs: ext4 dev: /dev/sda5
  ID-2: /boot/efi size: 256 MiB used: 32.9 MiB (12.8%) fs: vfat
    dev: /dev/sda1
Swap:
  Alert: No swap data was found.
Sensors:
  System Temperatures: cpu: 36.0 C pch: 29.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 0
Repos:
  Packages: pm: dpkg pkgs: 3469
  Active apt repos in: /etc/apt/sources.list
    1: deb http://deb.debian.org/debian trixie main non-free-firmware
    2: deb-src http://deb.debian.org/debian trixie main non-free-firmware
    3: deb http://deb.debian.org/debian trixie-updates main non-free-firmware
    4: deb-src http://deb.debian.org/debian trixie-updates main non-free-firmware
    5: deb http://security.debian.org/debian-security/ trixie-security main non-free-firmware
    6: deb-src http://security.debian.org/debian-security/ trixie-security main non-free-firmware
    7: deb http://deb.debian.org/debian trixie-backports main non-free-firmware
    8: deb-src http://deb.debian.org/debian trixie-backports main non-free-firmware
Info:
  Processes: 235 Power: uptime: 36m states: freeze,mem,disk suspend: s2idle
    wakeups: 0 hibernate: platform Init: systemd v: 257 default: graphical
  Compilers: gcc: 14.2.0 Shell: Bash v: 5.2.37 running-in: konsole
    inxi: 3.3.38
Que dois-je faire ?
Merci par avance!
Ok vous cassez pas la tête j’ai trouvé la solution.
J’ai modifié /etc/default/grub comme ceci :
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash snd_hda_intel.model=headset-mode"
Lancer la commande :
grub-update
Au démarrage suivant, tout fonctionne.
