suite du message :
“Vérifiez l’orthographe et essayez à nouveau.”
Bon, je crois qu’un petit coup de ménage s’impose dans mon
- /dev
- /media
- voir autre …
D’abord, c’est quoi ce cdda ?
Est-ce : xiph.org/paranoia/, soit cdparanoia, non je ne l’ai pas installé … ?
Est-ce : worldserver.oleane.com/rsn/test-cdda.html, ça m’étonnerait …
debian:/home/jcode# apt-cache search CDDA
alsaplayer - PCM player designed for ALSA
alsaplayer-alsa - PCM player designed for ALSA (ALSA output module)
alsaplayer-common - PCM player designed for ALSA (common files)
alsaplayer-daemon - PCM player designed for ALSA (non-interactive version)
alsaplayer-esd - PCM player designed for ALSA (EsounD output module)
alsaplayer-gtk - PCM player designed for ALSA (GTK version)
alsaplayer-jack - PCM player designed for ALSA (JACK output module)
alsaplayer-nas - PCM player designed for ALSA (NAS output module)
alsaplayer-oss - PCM player designed for ALSA (OSS output module)
alsaplayer-text - PCM player designed for ALSA (text version)
alsaplayer-xosd - PCM player designed for ALSA (osd version)
arson - KDE frontend for burning CDs
cdda2wav - Creates WAV files from audio CDs
cdrtools-doc - Documentation for the cdrtools package-suite
grip - GNOME-based CD-player/ripper/encoder
gstreamer0.8-gnomevfs - Gnome VFS plugin for GStreamer
gtoaster - Gnome Toaster, a GUI for creating CDs
libalsaplayer-dev - PCM player designed for ALSA (interface library, development files)
libalsaplayer0 - PCM player designed for ALSA (interface library)
libcdio-cdda-dev - library to read and control digital audio CDs (development files)
libcdio-cdda0 - library to read and control digital audio CDs
yaret - A console tool to turn CDs into encoded music
cdparanoia - An audio extraction tool for sampling CDs
libcdparanoia0 - Shared libraries for cdparanoia
libcdparanoia0-dev - Shared libraries for cdparanoia (development files)
Quelqu’un utilise cdda ? quelqu’un connait ce message d’erreur ?
Est-ce que je dois installer un des paquets ci-dessus, ou configurer/modifier/créer un lien pour que ça marche ?
ps : ça se produit quand je double click sur la fenetre gauche de l’explorateur de fichier, colonne “racourcis”, icon du “Disque audio” …
pratique.
