Salut.
J’ai ce probleme sur l’un des ordinateurs de la maison, a chaque fois que je tente d’utiliser le lecteur de CD, le systeme freeze. Quand je tente de redemarrer X, ce message apparait jusqu’a ce que ca freeze completement :
J’ai tente de regarder certaines infos pour voir ce qui peut poser probleme, mais je ne comprends pas grand chose, si ca peut vous aider a me mettre sur la voie :
[quote]# uname -r
2.6.26-1-686[/quote]
[quote]# /etc/fstab: static file system information.
proc /proc proc defaults 0 0
/dev/sda2 / ext3 errors=remount-ro 0 1
/dev/sda3 /home xfs defaults 0 2
/dev/sda1 none swap sw 0 0
/dev/hdb /media/cdrom0 udf,iso9660 user,noauto 0 0[/quote]
[quote]# hdparm -I /dev/hdb
/dev/hdb:
ATAPI CD-ROM, with removable media
Model Number: HL-DT-ST DVD-ROM GDR-H30N
Serial Number:
Firmware Revision: 1.00
Standards:
Likely used CD-ROM ATAPI-1
Configuration:
DRQ response: 50us.
Packet size: 12 bytes
Capabilities:
LBA, IORDY(cannot be disabled)
DMA: mdma0 mdma1 mdma2 udma0 udma1 *udma2
Cycle time: min=120ns recommended=120ns
PIO: pio0 pio1 pio2 pio3 pio4
Cycle time: no flow control=227ns IORDY flow control=120ns[/quote]
[quote]# dmesg | grep hdb
[ 3.124114] hdb: HL-DT-ST DVD-ROM GDR-H30N, ATAPI CD/DVD-ROM drive
[ 3.180049] hdb: host max PIO5 wanted PIO255(auto-tune) selected PIO4
[ 3.180320] hdb: UDMA/33 mode selected
[ 5.003160] hdb: ATAPI 52X DVD-ROM drive, 198kB Cache
[ 485.813877] hdb: task_in_intr: status=0x51 { DriveReady SeekComplete Error }
[ 485.813877] hdb: task_in_intr: error=0x04 { AbortedCommand }
Quant a # cat /var/log/messages | grep hdb ca donne beaucoup de choses. Quelques extraits :
[quote]Mar 9 17:44:07 bucka kernel: [317200.061318] hdb: packet command error: error=0x54 { AbortedCommand LastFailedSense=0x05 }
Mar 9 17:44:07 bucka kernel: [317200.102349] hdb: packet command error: status=0x51 { DriveReady SeekComplete Error }[/quote]
[quote]Mar 9 17:47:08 bucka kernel: [317361.012021] hdb: irq timeout: status=0xd0 { Busy }
Mar 9 17:47:08 bucka kernel: [317366.016012] hdb: status timeout: status=0xd0 { Busy }
Mar 9 17:47:08 bucka kernel: [317371.020007] hdb: status timeout: status=0xd0 { Busy }
Mar 9 17:47:08 bucka kernel: [317376.024008] hdb: status timeout: status=0xd0 { Busy }
Mar 9 17:47:08 bucka kernel: [317381.028007] hdb: status timeout: status=0xd0 { Busy }
Mar 9 17:47:13 bucka kernel: [317386.144010] hdb: status timeout: status=0xd0 { Busy }
Mar 9 17:47:18 bucka kernel: [317391.284009] hdb: status timeout: status=0xd0 { Busy }
Mar 9 17:47:23 bucka kernel: [317396.288010] hdb: status timeout: status=0xd0 { Busy }
Mar 9 17:47:28 bucka kernel: [317401.296009] hdb: status timeout: status=0xd0 { Busy }[/quote]
[quote]Mar 9 17:50:46 bucka kernel: [ 3.124114] hdb: HL-DT-ST DVD-ROM GDR-H30N, ATAPI CD/DVD-ROM drive
Mar 9 17:50:46 bucka kernel: [ 3.180320] hdb: UDMA/33 mode selected
Mar 9 17:50:46 bucka kernel: [ 5.003160] hdb: ATAPI 52X DVD-ROM drive, 198kB Cache
Mar 9 17:58:17 bucka kernel: [ 485.813877] hdb: task_in_intr: status=0x51 { DriveReady SeekComplete Error }
Mar 9 17:58:17 bucka kernel: [ 485.813877] hdb: task_in_intr: error=0x04 { AbortedCommand }[/quote]
Le probleme etant que comme je dois redemarrer a la brutale apres le freeze, je ne sais pas si ces messages sont utiles, puisqu’apres reboot.
Voila, ca fonctionnait bien sous Ubuntu avant, donc je ne pense pas que le lecteur soit defectueux.
Merci de m’eclairer sur ce probleme.
