Que donnent les logs?
Et sans filtrer avec grep, ça peut cacher des informations utiles.
Par exemple les développeurs ont sournoisement activé par défaut une option du module i915 qui désactive l’accélération matérielle pour les GPU i8xx, ce qui apparaissait ainsi dans les logs :
code intel(0): Chipset: “852GM/855GM”
(==) intel(0): Shadow buffer enabled, GPU acceleration disabled.[/code]
En forçant l’option idoine à off, l’accélération est revenue.
Pour la liste des options, voir man savage.
bonjour,
me renvoi :
[ 21.577] (II) Loading extension MIT-SCREEN-SAVER
[ 24.249] (EE) AIGLX error: dlopen of /usr/lib/i386-linux-gnu/dri/savage_dri.so failed (/usr/lib/i386-linux-gnu/dri/savage_dri.so: cannot open shared object file: No such file or directory)
[ 24.249] (EE) AIGLX: reverting to software rendering
Et
me renvoi :
[ 21.464] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 21.464] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 21.464] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 21.464] (WW) The directory "/usr/share/fonts/X11/Type1" does not exist.
[ 21.465] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 21.465] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 21.465] (WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist.
[ 21.465] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 21.465] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 21.465] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 21.465] (WW) The directory "/usr/share/fonts/X11/Type1" does not exist.
[ 21.465] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[ 21.465] (WW) Disabling Mouse0
[ 21.465] (WW) Disabling Keyboard0
Au vu de ces infos je me demandais si il serait encore possible d’installer Squeeze + Backport (malgré que wheezy soit la stable de rigueur.?
D’avance merci pour vos réponses .
Daan.
Dans la mesure où les paquets Mesa de squeeze-backports sont en version 7 et contiennent le support pour les GPU Savage, rien ne t’en empêche. Mais c’est squeeze, l’ancienne stable, avec les inconvénients qui vont avec.
À quel inconvénient pense tu ?
Combien de temps le backport de squeeze est il maintenu ?
