Changement de dns
Bonjour debian land
Suite à un changement des serveurs DNS j’ai modifié le fichier resolv.conf (nameserver ip1 - nameserver ip2)
Je suis allé également modifier le fichier etc/network/interfaces mais je ne sais pas comment mettre mes deux serveurs DNS dns-nameservers ip1 ip2 ou dns-nameservers ip et dessous dns-nameservers ip2
If the resolvconf program is installed, you should not edit the resolv.conf configuration file manually as it will be dynamically changed by programs in the system. If you need to manually define the nameservers (as with a static inferface), add a line something like the following to the interfaces configuration file at /etc/network/interfaces:
http://wiki.debian.org/NetworkConfiguration#Defining_the_.28DNS.29_Nameservers
