Changement de la résolution d'une session vnc
salut a tous,
voila j’ai un serveur de test de compilation a mon taf, sur lequel se connectent les utilisateur via vnc.
pour l’instant la résoltion par default est 650x480. le but etant de la mettre par default en 1024x768
Lorsque l’on se connecte en vnc et qu’on clique sur “screen resolution”, j’ai ce message la “the x server does not support the XrandR extension. runtime resolution changes to the display siez are not available”
mon interface est gnome.
voila mon xorg.conf
Section "Files"
        FontPath        "/usr/share/fonts/X11/misc"
        FontPath        "/usr/X11R6/lib/X11/fonts/misc"
        FontPath        "/usr/share/fonts/X11/cyrillic"
        FontPath        "/usr/X11R6/lib/X11/fonts/cyrillic"
        FontPath        "/usr/share/fonts/X11/100dpi/:unscaled"
        FontPath        "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
        FontPath        "/usr/share/fonts/X11/75dpi/:unscaled"
        FontPath        "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
        FontPath        "/usr/share/fonts/X11/Type1"
        FontPath        "/usr/X11R6/lib/X11/fonts/Type1"
        FontPath        "/usr/share/fonts/X11/100dpi"
        FontPath        "/usr/X11R6/lib/X11/fonts/100dpi"
        FontPath        "/usr/share/fonts/X11/75dpi"
        FontPath        "/usr/X11R6/lib/X11/fonts/75dpi"
        # path to defoma fonts
        FontPath        "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
        Load    "bitmap"
        Load    "ddc"
        Load    "dri"
        Load    "extmod"
        Load    "freetype"
        Load    "glx"
        Load    "int10"
        Load    "vbe"
EndSection
Section "InputDevice"
        Identifier      "Generic Keyboard"
        Driver          "kbd"
        Option          "CoreKeyboard"
        Option          "XkbRules"      "xorg"
        Option          "XkbModel"      "pc104"
        Option          "XkbLayout"     "fr"
        Option          "XkbVariant"    "fr"
EndSection
        Identifier      "Configured Mouse"
        Driver          "mouse"
        Option          "CorePointer"
        Option          "Device"                "/dev/input/mice"
        Option          "Protocol"              "ImPS/2"
        Option          "Emulate3Buttons"       "true"
EndSection
Section "Device"
        Identifier      "Generic Video Card"
        Driver          "vesa"
        Option          "UseFBDev"              "true"
        Option "RandRRotation" "on"
        Option "RandR" "on"
EndSection
Section "Monitor"
        Identifier      "Generic Monitor"
        Option          "DPMS"
        HorizSync       28-51
        VertRefresh     43-60
EndSection
Section "Screen"
        Identifier      "Default Screen"
        Device          "Generic Video Card"
        Monitor         "Generic Monitor"
        DefaultDepth    24
        SubSection "Display"
                Depth           1
                Modes           "1024x768"
        EndSubSection
                Depth           4
                Modes           "1024x768"
        EndSubSection
                Depth           8
                Modes           "1024x768"
        EndSubSection
                Depth           15
                Modes           "1024x768"
        EndSubSection
                Depth           16
                Modes           "1024x768"
        EndSubSection
                Depth           24
                Modes           "1024x768"
        EndSubSection
EndSection
Section "ServerLayout"
        Identifier      "Default Layout"
        Screen          "Default Screen"
        InputDevice     "Generic Keyboard"
        InputDevice     "Configured Mouse"
EndSection
Section "DRI"
        Mode    0666
EndSection
j’ai essayer pas mal de changement dedans comme l’ajout de l’option xran… “true” ou “on” mais rien n’y fait…
merci par avance
personne ne peux m’aider?
Quel est le serveur VNC utilisé? Si c’est vncserver, iul se paramètre par /etc/vnc.conf.
les serveurs X récent (testing par exemple) supportent Xrandr.
Si tu peux, fait une mise à jour.
Mais par contre les modifications seront à faire à chaque connexion.
Par contre Xrandr avec driver vesa en frameBuffer, il faudrait te renseigner pour voir si c’est compatible.
En fait ça n’est pas clair ton message, utilises tu un serveur autonome ou bien utilises tu X11vnc?
