Changement de matériel et Wifi
Ayant eu une panne sur mon précédent pc, j’ai récupéré le disque dur pour le changer de portable, et voici que je n’ai plus le pilote pour mon wifi…
Je n’arrive absolument pas à résoudre le soucis.
Si quelqu’un pouvait m’aider en me montrant le chemin ?
Ce serai fort aimable, merci !
Linux Debluz 2.6.32-5-amd64 #1 SMP Sun Sep 23 10:07:46 UTC 2012 x86_64 GNU/Linux
00:00.0 Host bridge: Advanced Micro Devices [AMD] Family 14h Processor Root Complex 00:01.0 VGA compatible controller: Advanced Micro Devices [AMD] nee ATI Device 9803 00:05.0 PCI bridge: Advanced Micro Devices [AMD] Family 14h Processor Root Port 00:06.0 PCI bridge: Advanced Micro Devices [AMD] Family 14h Processor Root Port 00:11.0 SATA controller: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 SATA Controller [AHCI mode] (rev 40) 00:12.0 USB controller: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 USB OHCI0 Controller 00:12.2 USB controller: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 USB EHCI Controller 00:13.0 USB controller: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 USB OHCI0 Controller 00:13.2 USB controller: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 USB EHCI Controller 00:14.0 SMBus: Advanced Micro Devices [AMD] nee ATI SBx00 SMBus Controller (rev 42) 00:14.2 Audio device: Advanced Micro Devices [AMD] nee ATI SBx00 Azalia (Intel HDA) (rev 40) 00:14.3 ISA bridge: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 LPC host controller (rev 40) 00:14.4 PCI bridge: Advanced Micro Devices [AMD] nee ATI SBx00 PCI to PCI Bridge (rev 40) 00:18.0 Host bridge: Advanced Micro Devices [AMD] Family 12h/14h Processor Function 0 (rev 43) 00:18.1 Host bridge: Advanced Micro Devices [AMD] Family 12h/14h Processor Function 1 00:18.2 Host bridge: Advanced Micro Devices [AMD] Family 12h/14h Processor Function 2 00:18.3 Host bridge: Advanced Micro Devices [AMD] Family 12h/14h Processor Function 3 00:18.4 Host bridge: Advanced Micro Devices [AMD] Family 12h/14h Processor Function 4 00:18.5 Host bridge: Advanced Micro Devices [AMD] Family 12h/14h Processor Function 6 00:18.6 Host bridge: Advanced Micro Devices [AMD] Family 12h/14h Processor Function 5 00:18.7 Host bridge: Advanced Micro Devices [AMD] Family 12h/14h Processor Function 7 01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller (rev 05) 02:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8188CE 802.11b/g/n WiFi Adapter (rev 01)
(je peux voir le pilote RTL8188CE mais je n’arrive pas à l’ajouter, trouver le dépot. Je n’ai pas l’habitude de cette distribution pour le moment.)
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 003 Device 002: ID 15d9:0a4c Trust International B.V. USB+PS/2 Optical Mouse Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 002 Device 003: ID 0bda:0138 Realtek Semiconductor Corp. Card reader Bus 002 Device 002: ID 04f2:b1d6 Chicony Electronics Co., Ltd Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
[code]# dmidecode 2.9
SMBIOS 2.6 present.
22 structures occupying 1364 bytes.
Table at 0xA7B22018.
Handle 0x0000, DMI type 0, 24 bytes
BIOS Information
Vendor: TOSHIBA
Version: 1.30
Release Date: 01/28/2011
Address: 0xF0000
Runtime Size: 64 kB
ROM Size: 2048 kB
Characteristics:
PCI is supported
BIOS is upgradeable
BIOS shadowing is allowed
Boot from CD is supported
Selectable boot is supported
BIOS ROM is socketed
EDD is supported
5.25"/1.2 MB floppy services are supported (int 13h)
3.5"/720 KB floppy services are supported (int 13h)
3.5"/2.88 MB floppy services are supported (int 13h)
Print screen service is supported (int 5h)
8042 keyboard services are supported (int 9h)
Serial services are supported (int 14h)
Printer services are supported (int 17h)
ACPI is supported
USB legacy is supported
BIOS boot specification is supported
Targeted content distribution is supported
BIOS Revision: 1.30
Firmware Revision: 1.30
Handle 0x0001, DMI type 1, 27 bytes
System Information
Manufacturer: TOSHIBA
Product Name: Satellite C660D
Version: PSC1YE-00Q001FR
Serial Number: 2B341719K
UUID: 84C38413-37F6-11E0-9CEB-1C75088A11AE
Wake-up Type: Power Switch
SKU Number: *
Family: ABCDEFGHIJKLMNOPQRSTUVWXYZ
Handle 0x0002, DMI type 2, 15 bytes
Base Board Information
Product Name: PWWBE
Version: 1.00
Serial Number: 0123456789AB
Asset Tag: NULL
Features:
Board is a hosting board
Board is replaceable
Location In Chassis: NULL
Chassis Handle: 0x0003
Type: Motherboard
Contained Object Handles: 0
Handle 0x0003, DMI type 3, 21 bytes
Chassis Information
Type: Notebook
Lock: Not Present
Version: N/A
Serial Number: None
Asset Tag: *
Boot-up State: Safe
Power Supply State: Safe
Thermal State: Safe
Security Status: None
OEM Information: 0x00000010
Height: Unspecified
Number Of Power Cords: 1
Contained Elements: 0
Handle 0x0004, DMI type 4, 42 bytes
Processor Information
Socket Designation: CPU 1
Type: Central Processor
Family:
Manufacturer: AMD E-240 Process
ID: 10 0F 50 00 FF FB 8B 07
Version: AMD E-240 Processor
Voltage: 1.3 V
External Clock: 100 MHz
Max Speed: 1500 MHz
Current Speed: 1500 MHz
Status: Populated, Enabled
Upgrade: None
L1 Cache Handle: 0x0005
L2 Cache Handle: 0x0006
L3 Cache Handle: Not Provided
Serial Number: To Be Filled By O.E.M.
Asset Tag: To Be Filled By O.E.M.
Part Number: To Be Filled By O.E.M.
Core Count: 1
Core Enabled: 1
Characteristics:
64-bit capable
Handle 0x0005, DMI type 7, 19 bytes
Cache Information
Socket Designation: L1-Cache
Configuration: Enabled, Not Socketed, Level 1
Operational Mode: Write Back
Installed Size: 64 KB
Maximum Size: 64 KB
Supported SRAM Types:
Unknown
Installed SRAM Type: Unknown
Speed: Unknown
Error Correction Type: None
System Type: Unified
Associativity: 2-way Set-associative
Handle 0x0006, DMI type 7, 19 bytes
Cache Information
Socket Designation: L2-Cache
Configuration: Enabled, Not Socketed, Level 2
Operational Mode: Varies With Memory Address
Installed Size: 512 KB
Maximum Size: 512 KB
Unknown
Speed: Unknown
System Type: Data
Associativity: 16-way Set-associative
Handle 0x0007, DMI type 126, 19 bytes
Inactive
Handle 0x0008, DMI type 8, 9 bytes
Port Connector Information
Internal Reference Designator: J1A1
Internal Connector Type: None
External Reference Designator: PS2Mouse
External Connector Type: PS/2
Port Type: Mouse Port
Handle 0x0009, DMI type 8, 9 bytes
External Reference Designator: Keyboard
Port Type: Keyboard Port
Handle 0x000A, DMI type 9, 17 bytes
System Slot Information
Designation: J6B2
Type: x16 PCI Express
Current Usage: In Use
Length: Long
Characteristics:
3.3 V is provided
Opening is shared
PME signal is supported
Handle 0x000B, DMI type 10, 6 bytes
On Board Device Information
Type: Sound
Status: Disabled
Description: Realtek HDA-00
Handle 0x000C, DMI type 11, 5 bytes
OEM Strings
String 1: PSC1YE-00Q001FR,SSC1Y00Q001FR
String 2: drMhOHt133HWr
String 3: 9Dv9ggZz-B8+A
String 4: 9i4fv1JR0KI2Q
Handle 0x000D, DMI type 12, 5 bytes
System Configuration Options
Option 1: SMI:00B0C102
Option 2: DSN: Z V1FJF8SD
Option 3: DSN:M471B5773DH0-CH9 42066AAA
Option 4: DSN:7498
Handle 0x000E, DMI type 16, 15 bytes
Physical Memory Array
Use: System Memory
Maximum Capacity: 8 GB
Error Information Handle: Not Provided
Number Of Devices: 2
Handle 0x0010, DMI type 17, 28 bytes
Memory Device
Array Handle: 0x000E
Total Width: 64 bits
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: A1_DIMM0
Bank Locator: A1_BANK0
Type:
Type Detail: Synchronous
Speed: 1333 MHz (0.8 ns)
Manufacturer: A1_Manufacturer0
Serial Number: A1_SerNum0
Asset Tag: A1_AssetTagNum0
Part Number: Array1_PartNumber0
Handle 0x0012, DMI type 17, 28 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: A1_DIMM1
Bank Locator: A1_BANK1
Type:
Manufacturer: Samsung
Serial Number: 42066AAA
Asset Tag: A1_AssetTagNum1
Part Number: M471B5773DH0-CH9
Handle 0x000F, DMI type 19, 15 bytes
Memory Array Mapped Address
Starting Address: 0x00000000000
Ending Address: 0x000FFFFFFFF
Range Size: 4 GB
Physical Array Handle: 0x000E
Partition Width: 0
Handle 0x0011, DMI type 20, 19 bytes
Memory Device Mapped Address
Starting Address: 0x00080000000
Range Size: 2 GB
Physical Device Handle: 0x0010
Memory Array Mapped Address Handle: 0x000F
Partition Row Position: 1
Handle 0x0013, DMI type 20, 19 bytes
Ending Address: 0x0007FFFFFFF
Range Size: 2 GB
Physical Device Handle: 0x0012
Handle 0x0014, DMI type 32, 20 bytes
System Boot Information
Status: No errors detected
Handle 0x0015, DMI type 127, 4 bytes
End Of Table[/code]
Il y a un paquet firmware-realtek dans les dépôts non-free, mais je ne vois pas ta carte dans la liste :
[ul] * Realtek RTL8192E boot code (RTL8192E/boot.img)
  • Realtek RTL8192E init data (RTL8192E/data.img)
  • Realtek RTL8192E main code (RTL8192E/main.img)
  • Realtek RTL8192SU firmware, version 902B (RTL8192SU/rtl8192sfw.bin)
  • Realtek RTL8105E-1 firmware (rtl_nic/rtl8105e-1.fw)
  • Realtek RTL8111D-1/RTL8168D-1 firmware (rtl_nic/rtl8168d-1.fw)
  • Realtek RTL8111D-2/RTL8168D-2 firmware (rtl_nic/rtl8168d-2.fw)
  • Realtek RTL8168E-1 firmware (rtl_nic/rtl8168e-1.fw)
  • Realtek RTL8168E-2 firmware (rtl_nic/rtl8168e-2.fw)
  • Realtek RTL8168E-3 firmware (rtl_nic/rtl8168e-3.fw)
  • Realtek RTL8192SU/RTL8712U firmware (rtlwifi/rtl8712u.bin)[/ul]
Il y a des paquets plus récents dans les backports et dans sid.
Si ça ne marche pas, tu peux voir chez Realtek :
http://www.realtek.com.tw/downloads/
Il est ici : realtek.com.tw/downloads/dow … =true#2722
