Bonjour à tous.
Je continue mes recherches. J’ai ciblé le répertoire qui m’intéresse, mais je ne trouve pas le moyen de le lire.
Voila ma démarche (liste de tous les endroits ou apparait mon appareil) :
[code]#/dev/.udev/db/
\x2fdevices\x2fpci0000:00\x2f0000:00:1d.7\x2fusb4\x2f4-3
N:bus/usb/004/004
S:char/189:387
M:189:387
#/dev/.udev/names
#/bus\x2fusb\x2f004\x2f004
\x2fclass\x2fusb_device\x2fusbdev4.4
#char\x2f252:10
\x2fclass\x2fusb_endpoint\x2fusbdev4.4_ep81
#char\x2f252:11
\x2fclass\x2fusb_endpoint\x2fusbdev4.4_ep02
#char\x2f252:12
\x2fclass\x2fusb_endpoint\x2fusbdev4.4_ep83
#char\x2f252:13
\x2fclass\x2fusb_endpoint\x2fusbdev4.4_ep00
#usbdev4.4_ep00
#usbdev4.4_ep02
#usbdev4.4_ep81
#usbdev4.4_ep83
#/dev/bus/usb/004
-004
#/dev/char
@252:10
@252:11
@252:12
@252:13
#/dev
-usbdev4.4_ep00
-usbdev4.4_ep02
-usbdev4.4_ep81
-usbdev4.4_ep83
#/var/log
messages
Nov 6 08:12:06 GAP2009 kernel: [ 992.300047] usb 4-3: new high speed USB device using ehci_hcd and address 4
Nov 6 08:12:06 GAP2009 kernel: [ 992.444214] usb 4-3: configuration #1 chosen from 1 choice
Nov 6 08:12:06 GAP2009 kernel: [ 992.444720] usb 4-3: New USB device found, idVendor=04a9, idProduct=314e
Nov 6 08:12:06 GAP2009 kernel: [ 992.444734] usb 4-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Nov 6 08:12:06 GAP2009 kernel: [ 992.444742] usb 4-3: Product: Canon Digital Camera
Nov 6 08:12:06 GAP2009 kernel: [ 992.444748] usb 4-3: Manufacturer: Canon Inc.
Nov 6 08:12:06 GAP2009 kernel: [ 992.444755] usb 4-3: SerialNumber: FE10A647AB754DF1A2276F4B6498DBB8
#/var/log
daemon.log
Nov 6 08:12:06 GAP2009 NetworkManager: [1257491526.951677] nm_hal_device_added(): New device added (hal udi is ‘/org/freedesktop/Hal/devices/usb_device_4a9_314e_FE10A647AB754DF1A2276F4B6498DBB8’).
Nov 6 08:12:07 GAP2009 NetworkManager: [1257491527.320325] nm_hal_device_added(): New device added (hal udi is ‘/org/freedesktop/Hal/devices/usb_device_4a9_314e_FE10A647AB754DF1A2276F4B6498DBB8_if0’).
Nov 6 08:12:07 GAP2009 NetworkManager: [1257491527.333640] nm_hal_device_added(): New device added (hal udi is ‘/org/freedesktop/Hal/devices/usb_device_4a9_314e_FE10A647AB754DF1A2276F4B6498DBB8_usbraw’).
#/proc/bus
devices
T: Bus=04 Lev=01 Prnt=01 Port=02 Cnt=01 Dev#= 4 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=04a9 ProdID=314e Rev= 0.02
S: Manufacturer=Canon Inc.
S: Product=Canon Digital Camera
S: SerialNumber=FE10A647AB754DF1A2276F4B6498DBB8
C:* #Ifs= 1 Cfg#= 1 Atr=c0 MxPwr= 2mA
I:* If#= 0 Alt= 0 #EPs= 3 Cls=06(still) Sub=01 Prot=01 Driver=(none)
E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=83(I) Atr=03(Int.) MxPS= 8 Ivl=32ms
J’en conclue donc qu’il est dans /dev/bus/usb/004/ -004.
J’ai beau chercher, je ne trouve pas le plus petit début de piste.
Comment lire son contenue avec un script bash ?
Aurais-je oublié une commande indispensable ?
Avez vous une petite idée ? Merci
