Bonjour !
Pour bien commencer je tiens à vous précisez quelques détails …
-> os: Debian 64bit Squeeze
-> uname: Linux serv-son 2.6.32-5-amd64 #1 SMP Mon Jan 16 16:22:28 UTC 2012 x86_64 GNU/Linux
-> lspci: 00:00.0 Host bridge: Intel Corporation Sandy Bridge DRAM Controller (rev 09)
00:01.0 PCI bridge: Intel Corporation Sandy Bridge PCI Express Root Port (rev 09)
00:02.0 VGA compatible controller: Intel Corporation Sandy Bridge Integrated Graphics Controller (rev 09)
00:16.0 Communication controller: Intel Corporation Cougar Point HECI Controller #1 (rev 04)
00:19.0 Ethernet controller: Intel Corporation 82579V Gigabit Network Connection (rev 05)
00:1a.0 USB Controller: Intel Corporation Cougar Point USB Enhanced Host Controller #2 (rev 05)
00:1b.0 Audio device: Intel Corporation Cougar Point High Definition Audio Controller (rev 05)
00:1c.0 PCI bridge: Intel Corporation Cougar Point PCI Express Root Port 1 (rev b5)
00:1c.1 PCI bridge: Intel Corporation Cougar Point PCI Express Root Port 2 (rev b5)
00:1c.2 PCI bridge: Intel Corporation Cougar Point PCI Express Root Port 3 (rev b5)
00:1c.3 PCI bridge: Intel Corporation Cougar Point PCI Express Root Port 4 (rev b5)
00:1c.4 PCI bridge: Intel Corporation Cougar Point PCI Express Root Port 5 (rev b5)
00:1c.6 PCI bridge: Intel Corporation 82801 PCI Bridge (rev b5)
00:1c.7 PCI bridge: Intel Corporation Cougar Point PCI Express Root Port 8 (rev b5)
00:1d.0 USB Controller: Intel Corporation Cougar Point USB Enhanced Host Controller #1 (rev 05)
00:1f.0 ISA bridge: Intel Corporation Cougar Point LPC Controller (rev 05)
00:1f.2 SATA controller: Intel Corporation Cougar Point 6 port SATA AHCI Controller (rev 05)
00:1f.3 SMBus: Intel Corporation Cougar Point SMBus Controller (rev 05)
03:00.0 USB Controller: Device 1b21:1042
05:00.0 SATA controller: JMicron Technology Corp. JMB362 AHCI Controller (rev 10)
06:00.0 USB Controller: Device 1b21:1042
07:00.0 PCI bridge: Device 1b21:1080 (rev 01)
08:00.0 Network controller: Atheros Communications Inc. AR9287 Wireless Network Adapter (rev 01)
08:01.0 Multimedia audio controller: VIA Technologies Inc. ICE1712 [Envy24] PCI Multi-Channel I/O Controller (rev 02)
08:02.0 FireWire (IEEE 1394): VIA Technologies, Inc. VT6306/7/8 [Fire II(M)] IEEE 1394 OHCI Controller (rev c0)
09:00.0 SATA controller: Marvell Technology Group Ltd. Device 9172 (rev 11)
Voilà qui est fait ! Maintenant ma question fait référence à un message de “syslog” que j’ai visualisé sur mon terminal:
Message from syslogd@serv-son at Jan 29 15:56:24 ...
kernel:[16504.966209] Disabling IRQ #17
Je comprend que ça fait référence à une désactivation du noyau kernel, mais je sait pas à qu’elle processus cela fait référence. Je me suis rendu compte ce matin que je n’avais pas appliqué les bon miroirs à “/etc/apt/sources.list”, maintenant c’est corrigé:
[code]#
deb-src cdrom:[Debian GNU/Linux 6.0.2.1 Squeeze - Official Multi-architecture i386/amd64/source DVD #1 20110626-16:56]/ squeeze main
deb cdrom:[Debian GNU/Linux 6.0.2.1 Squeeze - Official Multi-architecture i386/amd64/source DVD #1 20110626-16:56]/ squeeze main
Line commented out by installer because it failed to verify:
#deb http://security.debian.org/ squeeze/updates main
#deb-src http://security.debian.org/ squeeze/updates main
squeeze-updates, previously known as ‘volatile’
A network mirror was not selected during install. The following entries
are provided as examples, but you should amend them as appropriate
for your mirror of choice.
deb http://ftp.debian.org/debian/ squeeze-updates main
deb-src http://ftp.debian.org/debian/ squeeze-updates main
Miroir DebianD
deb http://ftp.fr.debian.org/debian/ squeeze-updates main
deb-src http://ftp.fr.debian.org/debian/ squeeze-updates main
Miroir sécurité
deb-src http://security.debian.org/ squeeze/updates main[/code]
Pour finir voilà un extrait de “/var/log/syslog”:
[ 2659.102123] No probe response from AP 00:17:33:4b:5e:9c after 500ms, disconnecting.
[ 2660.068335] wlan0: direct probe to AP 00:17:33:4b:5e:9c (try 1)
[ 2660.265457] wlan0: direct probe to AP 00:17:33:4b:5e:9c (try 2)
[ 2660.278219] wlan0: direct probe responded
[ 2660.278224] wlan0: authenticate with AP 00:17:33:4b:5e:9c (try 1)
[ 2660.477573] wlan0: authenticate with AP 00:17:33:4b:5e:9c (try 2)
[ 2660.491037] wlan0: authenticated
[ 2660.491063] wlan0: associate with AP 00:17:33:4b:5e:9c (try 1)
[ 2660.689183] wlan0: associate with AP 00:17:33:4b:5e:9c (try 2)
[ 2660.699601] wlan0: RX AssocResp from 00:17:33:4b:5e:9c (capab=0x411 status=0 aid=1)
[ 2660.699605] wlan0: associated
Je pense que ça as un rapport avec la connexion wifi mais en même temps je ne retrouve pas la référence “[16504.966209]” donc j’en suis pas certain. Peut être qu’il y’a une commande qui pourrait m’aider …
