Est-il possible de démarrer différents gestionnaires de fenêtres (fluxbox et wmii) depuis la console sans installer un gestionnaire de connexion (xdm, gdm, …) ? Lorsque l’on en a plusieurs d’installés, que fais la commande startx ?
startx [ [ client ] options … ] [ – [ server ] [ display ] options … ]
J’ai essayer un startx fluxbox mais voici le résultat : [code]# startx fluxbox
X.Org X Server 1.4.2
Release Date: 11 June 2008
X Protocol Version 11, Revision 0
Build Operating System: Linux Debian (xorg-server 2:1.4.2-9)
Current Operating System: Linux idjagiedas 2.6.26-1-686 #1 SMP Mon Dec 15 18:15:07 UTC 2008 i686
Build Date: 15 November 2008 05:39:59PM
Before reporting problems, check http://wiki.x.org
Module Loader present
Markers: (–) probed, (**) from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.0.log”, Time: Sat Dec 27 19:33:50 2008
(==) Using config file: “/etc/X11/xorg.conf”
(II) Module “ddc” already built-in
(II) Module “i2c” already built-in
finished output detect: 0
finished output detect: 1
finished all detect
before xf86InitialConfiguration
in RADEONProbeOutputModes
after xf86InitialConfiguration
(II) Module “ramdac” already built-in
Entering TV Save
Save TV timing tables
saveTimingTables: reading timing tables
TV Save done
init memmap
init common
init crtc1
init pll1
restore memmap
restore common
restore crtc1
restore pll1
restore LVDS
(EE) AIGLX error: dlopen of /usr/lib/dri/radeon_dri.so failed (/usr/lib/dri/radeon_dri.so: cannot open shared object file: No such file or directory)
(EE) AIGLX: reverting to software rendering
expected keysym, got circumflex: line 257 of fr
The XKEYBOARD keymap compiler (xkbcomp) reports:
Warning: Type “ONE_LEVEL” has 1 levels, but has 2 symbols
Ignoring extra symbols
Errors from xkbcomp are not fatal to the X server
xterm: bad command line option “xterm”
usage: xterm [-/+132] [-C] [-Sccn] [-T string] [-/+ah] [-/+ai] [-/+aw]
[-b number] [-/+bc] [-bcf milliseconds] [-bcn milliseconds] [-bd color]
[-/+bdc] [-bg color] [-bw number] [-/+cb] [-cc classrange] [-/+cjk_width]
[-class string] [-/+cm] [-/+cn] [-cr color] [-/+cu] [-/+dc]
[-display displayname] [-e command args ...] [-fa pattern] [-fb fontname]
[-/+fbb] [-/+fbx] [-fd pattern] [-fg color] [-fi fontname] [-fn fontname]
[-fs size] [-fw fontname] [-fwb fontname] [-fx fontname] [%geom] [#geom]
[-geometry geom] [-help] [-/+hm] [-/+hold] [-iconic] [-/+ie] [-/+im]
[-into windowId] [-/+j] [-/+k8] [-kt keyboardtype] [-/+l] [-/+lc]
[-lcc path] [-leftbar] [-lf filename] [-/+ls] [-/+mb] [-mc milliseconds]
[-/+mesg] [-/+mk_width] [-ms color] [-n string] [-name string] [-nb number]
[-/+nul] [-/+pc] [-/+pob] [-rightbar] [-/+rv] [-/+rvc] [-/+rw] [-/+s]
[-/+samename] [-/+sb] [-selbg color] [-selfg color] [-/+sf] [-/+si] [-/+sk]
[-sl number] [-/+sm] [-/+sp] [-/+t] [-ti termid] [-title string]
[-tm string] [-tn name] [-/+u8] [-/+ulc] [-/+ulit] [-/+ut] [-/+vb]
[-version] [-/+wc] [-/+wf] [-xrm resourcestring] [-ziconbeep percent]
Type xterm -help for a full description.
waiting for X server to shut down finished PLL2
Entering Restore TV
Restore TV PLL
Restore TVHV
Restore TV Restarts
Restore Timing Tables
Restore TV standard
Leaving Restore TV
FreeFontPath: FPE “/usr/share/fonts/X11/misc” refcount is 2, should be 1; fixing.
[/code]Après que j’ai tenté cette commande (qui ne marche donc pas), un startx simple me lance fluxbox et non plus wmii.
Pas contre je n’arrive plus à lancer wmii.
J’ai essayé de trouver les fichiers qui dissent à startx quel client il doit lancer et qui sont indiqué dans le man (fichiers .xinitrc et .xserverrc) mais ils ne semblent pas être sur mon ordinateur : [code]# find / -name .xinitrc
je up parce que je suis bien embêté, je ne peux plus démarrer ma session wmii.
merci pour tes réponses.
Je n’ai pas la librairie radeon_dri.so dans /usr/lib/ (ni même de répertoire dri dans /usr/lib).
Mais ce serait étrange que ce soit la cause du problème puisque je peux démarrer une session X avec un startx, c’est startx [client] qui ne marche pas et qui m’empêche de switcher entre fluxbox et wmii.
Par ailleurs, j’ai regarder dans les deux fichiers que tu m’as indiqué (/etc/X11/xinit/xinitrc qui renvoie à /etc/X11/Xsession).
Je ne comprend pas grand chose au fichier Xsession…
Je ne sais pas pour xinitrc. Je n’en ai pas chez moi (le paquet xinit n’est pas installé, j’utilise slim). Mais par contre j’ai un peu fouillé dans les méandres du /etc/Xsession qui source tout plein de fichiers dans /etc/Xsession.d/. Tout ça pour vérifier qu’il cherche la présence d’un fichier ~/.Xsession et l’utilise s’il existe (on peut aussi utiliser d’autres noms : .xsession, .sessionrc). J’imagine que xinitrc utilise le même principe
Donc je pense que le mieux, c’est de te faire un fichier .Xsession ou .xinitrc (quoique il faudrait vérifier pour ce dernier) : fluxbox.sourceforge.net/docbook/ … setup.html
Ensuite tu peux faire un petit script par exemple :
#startflux.sh
sed -i '#/usr/bin/wmii#/usr/bin/fluxbox#' .Xsession
startx
A adapter/améliorer comme tu le souhaites…
