[quote=“BelZéButh”]Salut,
Commences donc par décommenter cette ligne.
Relances le service, de part et d’autre.
Et quel est donc son retour dans son intégralité.
Voici :
[code]$ ssh -vvv bb_festival@prod.uuneek.com
OpenSSH_5.2p1, OpenSSL 0.9.8y 5 Feb 2013
debug1: Reading configuration data /etc/ssh_config
debug1: Applying options for *
debug2: ssh_connect: needpriv 0
debug1: Connecting to prod.uuneek.com [80.74.68.157] port 22.
debug2: fd 3 setting O_NONBLOCK
debug1: fd 3 clearing O_NONBLOCK
debug1: Connection established.
debug3: timeout: 9963 ms remain after connect
debug1: identity file /Users/theredled/.ssh/identity type -1
debug3: Not a RSA1 key file /Users/theredled/.ssh/id_rsa.
debug2: key_type_from_name: unknown key type '-----BEGIN’
debug3: key_read: missing keytype
debug3: key_read: missing whitespace
debug2: key_type_from_name: unknown key type '-----END’
debug1: identity file /Users/theredled/.ssh/id_rsa type 1
debug1: identity file /Users/theredled/.ssh/id_dsa type -1
debug1: Remote protocol version 2.0, remote software version OpenSSH_5.5p1 Debian-6+squeeze2
debug1: match: OpenSSH_5.5p1 Debian-6+squeeze2 pat OpenSSH*
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_5.2
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug2: kex_parse_kexinit: diffie-hellman-group-exchange-sha256,diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1
debug2: kex_parse_kexinit: ssh-rsa,ssh-dss
debug2: kex_parse_kexinit: aes128-ctr,aes192-ctr,aes256-ctr,arcfour256,arcfour128,aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,aes192-cbc,aes256-cbc,arcfour,rijndael-cbc@lysator.liu.se
debug2: kex_parse_kexinit: hmac-md5,hmac-sha1,umac-64@openssh.com,hmac-ripemd160,hmac-ripemd160@openssh.com,hmac-sha1-96,hmac-md5-96
debug2: kex_parse_kexinit: none,zlib@openssh.com,zlib
debug2: kex_parse_kexinit: first_kex_follows 0
debug2: kex_parse_kexinit: reserved 0
debug2: mac_setup: found hmac-md5
debug1: kex: server->client aes128-ctr hmac-md5 none
debug1: kex: client->server aes128-ctr hmac-md5 none
debug1: SSH2_MSG_KEX_DH_GEX_REQUEST(1024<1024<8192) sent
debug1: expecting SSH2_MSG_KEX_DH_GEX_GROUP
debug2: dh_gen_key: priv key bits set: 138/256
debug2: bits set: 511/1024
debug1: SSH2_MSG_KEX_DH_GEX_INIT sent
debug1: expecting SSH2_MSG_KEX_DH_GEX_REPLY
debug3: check_host_in_hostfile: filename /Users/theredled/.ssh/known_hosts
debug3: check_host_in_hostfile: match line 2
debug1: Host ‘prod.uuneek.com’ is known and matches the RSA host key.
debug1: Found key in /Users/theredled/.ssh/known_hosts:2
debug2: bits set: 514/1024
debug1: ssh_rsa_verify: signature correct
debug2: kex_derive_keys
debug2: set_newkeys: mode 1
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug2: set_newkeys: mode 0
debug1: SSH2_MSG_NEWKEYS received
debug1: SSH2_MSG_SERVICE_REQUEST sent
debug2: service_accept: ssh-userauth
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug2: key: /Users/theredled/.ssh/identity (0x0)
debug2: key: /Users/theredled/.ssh/id_rsa (0x100125690)
debug2: key: /Users/theredled/.ssh/id_dsa (0x0)
debug1: Authentications that can continue: publickey,password
debug3: start over, passed a different list publickey,password
debug3: preferred publickey,keyboard-interactive,password
debug3: authmethod_lookup publickey
debug3: remaining preferred: keyboard-interactive,password
debug3: authmethod_is_enabled publickey
debug1: Next authentication method: publickey
debug1: Trying private key: /Users/theredled/.ssh/identity
debug3: no such identity: /Users/theredled/.ssh/identity
debug1: Offering public key: /Users/theredled/.ssh/id_rsa
debug3: send_pubkey_test
debug2: we sent a publickey packet, wait for reply
debug1: Trying private key: /Users/theredled/.ssh/id_dsa
debug3: no such identity: /Users/theredled/.ssh/id_dsa
debug2: we did not send a packet, disable method
debug3: authmethod_lookup password
debug3: remaining preferred: ,password
debug3: authmethod_is_enabled password
debug1: Next authentication method: password
bb_festival@prod.uuneek.com’s password:
debug3: packet_send2: adding 48 (len 64 padlen 16 extra_pad 64)
debug2: we sent a password packet, wait for reply
debug1: Authentication succeeded (password).
debug1: channel 0: new [client-session]
debug3: ssh_session2_open: channel_new: 0
debug2: channel 0: send open
debug1: Requesting no-more-sessions@openssh.com
debug1: Entering interactive session.
debug1: channel 0: free: client-session, nchannels 1
debug3: channel 0: status: The following connections are open:
#0 client-session (t3 r-1 i0/0 o0/0 fd 5/6 cfd -1)
debug3: channel 0: close_fds r 5 w 6 e 7 c -1
Connection to prod.uuneek.com closed by remote host.
Connection to prod.uuneek.com closed.
Transferred: sent 1648, received 1800 bytes, in 0.0 seconds
Bytes per second: sent 458156.9, received 500414.1
debug1: Exit status -1
Je ne pense pas (je ne sais pas ce que c’est), je rentre un MDP tout simple.
[quote=“ricardo”]Pour les essais, commente aussi ces deux lignes :
PermitRootLogin no
StrictModes yes
Quitte à les décommenter ensuite si pas de résultat.[/quote]
Pas de changement…
