Chroot user PURE FTPD ?
J’ai installé pure-ftpd TLS en mode standalone sur Debian Lenny.
Celui-ci utilise les utilisateurs du système. J’ai bien activé l’option pour chrooter les utilisateurs dans leur dossiers respectif:
VIRTUALCHROOT=TRUE
Cependant, les utilisateurs peuvent tout de même remonter dans les fichiers jusqu’au système. Auriez-vous une astuces / info / idée à ce sujet car je ne pense rien avoir oublié.
Merci d’avance pour vos réponses :slightly_smiling:
Bon week end.
Bonsoir,
pure-pw useradd TonUtilisateur -u ftpuser -d /home/ftpusers/TonUtilisateur
C’est le “-d” qui chroot ton utilisateur.
If you speak english, plus d’aide ici : http://download.pureftpd.org/pub/pure-ftpd/doc/README.Virtual-Users
Bon courage
download.pureftpd.org/pub/pure-ftpd/doc/FAQ
  • Shared directories and chroot.
-> I have a directory, say /var/incoming, that I want to be shared by every
user. But I want my users to be chrooted. So /var/incoming should be visible
in ‘joe’ and ‘john’ accounts, but those are chrooted. So, how to have the
content of /var/incoming visible in these accounts?
Making a symbolic link won’t work, because when you are chrooted, it means
that everything outside a base directory (your user’s home directory) won’t
be reachable, even though a symbolic link.
But all modern operating systems can mount local directories to several
locations. To have an exact duplicate of your /var/incoming directory
available in /home/john/incoming and /home/joe/incoming, use one of these
commands:
  • Linux : mount --bind /var/incoming /home/john/incoming
    mount --bind /var/incoming /home/joe/incoming
  • Solaris : mount -F lofs /var/incoming /home/john/incoming
    mount -F lofs /var/incoming /home/joe/incoming
  • FreeBSD : mount_null /var/incoming /home/john/incoming
    mount_null /var/incoming /home/joe/incoming
Another alternative is to compile Pure-FTPd with --with-virtualchroot as a
./configure option. With virtual chroot, symbolic links pointing outside a
chroot jail are followed.
Binary packages are compiled with this feature turned on.
