Clavier azerty qwerty
bonjour,
je viens de me rendre compte que mon clavier est passe en mode qwerty.
mais seulement quand je suis en mode graphique… j ai beau chercher, je ne trouve pas de solution…
j ai essaye de modifier mon xorg.conf, sans succes…
merci d avance :blush:
le voila
Section "Files"
EndSection
Section "Module"
    Load  "dbe"
    Load  "extmod"
    Load  "fbdevhw"
    Load  "glx"
    Load  "record"
    Load  "freetype"
    Load  "type1"
    Load  "dri"
EndSection
Section "InputDevice"
	Identifier	"Generic Keyboard"
	Driver		"kbd"
	Option		"CoreKeyboard"
	Option		"XkbRules"	"xorg"
	Option		"XkbModel"	"pc105"
	Option		"XkbLayout"	"fr"
	Option		"XkbVariant"	"latin9"
EndSection
	Identifier	"Configured Mouse"
	Driver		"mouse"
	Option		"CorePointer"
	Option		"Device"		"/dev/input/mice"
	Option		"Protocol"		"ImPS/2"
	Option		"Emulate3Buttons"	"true"
EndSection
Section "Device"
	Identifier	"ATI Technologies Inc RV350 AP [Radeon 9600]"
	# Other important bit. The radeon driver is mature enough, as been said in #xorg
    Driver      "radeon"
    VendorName  "ATI"
    BoardName   "ATI Radeon 9600 pro"
    # Options recommended on dri.freedesktop.org
    Option "AccelMethod" "XAA"
    Option "AGPMode" "8"
    Option "EnablePageFlip" "1"
    Option "ColorTiling" "1"
	BusID		"PCI:2:0:0"
EndSection
Section "Monitor"
	Identifier	"CM1555NEL"
	Option		"DPMS"
    # Those are the magic values that make it all work.
    HorizSync    31.4 - 53.6
    VertRefresh  56.0 - 86.9
    ## This allowed for resolutions in the 19AAxBBBB
    ## See also the Virtual directive in Display subsection below
    #VertRefresh 56.0 - 83.0v
EndSection
Section "Screen"
	Identifier	"Default Screen"
	Device		"ATI Technologies Inc RV350 AP [Radeon 9600]"
	Monitor		"CM1555NEL"
	DefaultDepth	24
	SubSection "Display"
		Modes		"1024x768" "800x600" "720x400" "640x480" "640x350"
	EndSubSection
EndSection
Section "ServerLayout"
	Identifier	"Default Layout"
	Screen		"Default Screen"
	InputDevice	"Generic Keyboard"
	InputDevice	"Configured Mouse"
EndSection
Section "DRI"
    Group       0
    Mode        0666
EndSection
À vue de nez, la configuration du clavier dans ton xorg.conf semble bonne.
Si ça ne le fait qu’en mode graphique, essaye de voir dans les options du clavier (sous Gnome, par exemple, c’est dans Système -> Préférences -> Clavier -> Agencements). :slightly_smiling:
en fait je suis sous kde4…
j ai un peu chercher de ce cote aussi… configuration systeme – clavier et souris – clavier
mais je ne trouve pas d entree pour configurer l agencement…
Lorsque j’étais sous KDE, j’avais une icône dans la barre des tâches qui me permettait de changer de clavier au vol (bien pratique pour les jeux en clavier qwerty :stuck_out_tongue:). (ah ben d’ailleurs, j’ai ça aussi sous Gnome, tiens.)
Je n’ai pas KDE d’installé sur ma config actuelle, mais de mémoire ça doit être dans le Centre de Contrôle, du côté des trucs régionaux. Si le français n’apparaît pas dans la liste, il faudrait peut-être que tu vérifies si le paquet de francisation de KDE est bien installé. Il s’agit du kde-i18n-fr.
merci!
il fallait en fait aller dans configuration du systeme => Region et langue => disposition du clavier…
