CLAVIER bluetooth reconnu, connexion éphémère
je cherche à utiliser un clavier bluetooth sur ma Jessie.
Avec la méthode Appairage avec bluetoothctl du wiki ([I Challenge Thee] j’obtiens les résultats suivants, optimistes jusqu’à la commande de connexion qui bégaie:
  5 $bluetoothctl
  6 [NEW] Controller 80:19:34:42:75:DD ChromeLinux_B22F [default]
  7 [bluetooth]# power on
  8 Changing power on succeeded
  9 [bluetooth]# devices
 10 [bluetooth]# scan on
 11 Discovery started
 12 [CHG] Controller 80:19:34:42:75:DD Discovering: yes
 13 [NEW] Device 03:A1:00:05:44:98 SBT 3.0 A1
 14 [bluetooth]# pair 03:A1:00:05:44:98
 15 Attempting to pair with 03:A1:00:05:44:98
 16 [CHG] Device 03:A1:00:05:44:98 Connected: yes
 17 [CHG] Device 03:A1:00:05:44:98 Connected: no
 18 [CHG] Device 03:A1:00:05:44:98 Connected: yes
 19 [CHG] Device 03:A1:00:05:44:98 Connected: no
 20 [CHG] Device 03:A1:00:05:44:98 Connected: yes
 21 [CHG] Device 03:A1:00:05:44:98 Connected: no
 22 [CHG] Device 03:A1:00:05:44:98 Connected: yes
 23 Failed to pair: org.bluez.Error.AuthenticationFailed
 24 [CHG] Device 03:A1:00:05:44:98 Connected: no
 25 [bluetooth]# trust 03:A1:00:05:44:98
 26 [CHG] Device 03:A1:00:05:44:98 Trusted: yes
 27 Changing 03:A1:00:05:44:98 trust succeeded
 28 [bluetooth]# connect 03:A1:00:05:44:98
 29 Attempting to connect to 03:A1:00:05:44:98
 30 [CHG] Device 03:A1:00:05:44:98 Connected: yes
 31 [CHG] Device 03:A1:00:05:44:98 Modalias: usb:v099Ap0500d011B
 32 [CHG] Device 03:A1:00:05:44:98 UUIDs:
 33 00001124-0000-1000-8000-00805f9b34fb
 34 00001200-0000-1000-8000-00805f9b34fb
35 Failed to connect: org.bluez.Error.Failed
 36 [CHG] Device 03:A1:00:05:44:98 Connected: no
 37 [bluetooth]#
Ensuite j’ai mis à 1 le réglage suivant, dans /etc/default/bluetooth
HID2HCI_ENABLED=1
sans plus de succès.
(Il s’agit d’un clavier de la marque SilverCrest, acheté chez Aldi)
EDIT
Voici la suite des commandes et leurs résultats:
$bluetoothctl
Discovery started
Failed to pair: org.bluez.Error.ConnectionAttemptFailed
C’est toujours assez acrobatique regarde :
https://wiki.archlinux.org/index.php/bluetooth#Bluetoothctl
https://askubuntu.com/questions/763939/bluetoothctl-what-is-a-bluetooth-agent
