Bon après pas mal de bidouilles foireuses,intall debian stable et testing, re-fedora et re-arch… Je suis repassé en stable et là, un demi-miracle, une petite vingtaines de secondes après le prompt et ma souris et clavier actifs.
petite question en passant.
après avoir fait tout ces essais de distributions, j’en ai profité pour essayer de remettre conky avec mes vieux conkyrc, mais pas moyen de d’utiliser lm-sensors sur debian?
[quote]#sensors-detect
sensors-detect revision 6209 (2014-01-14 22:51:58 +0100)
System: ASUS All Series
Board: ASUSTeK COMPUTER INC. AM1M-A
This program will help you determine which kernel modules you need
to load to use lm_sensors most effectively. It is generally safe
and recommended to accept the default answers to all questions,
unless you know what you’re doing.
Some south bridges, CPUs or memory controllers contain embedded sensors.
Do you want to scan for them? This is totally safe. (YES/no):
Module cpuid loaded successfully.
Silicon Integrated Systems SIS5595… No
VIA VT82C686 Integrated Sensors… No
VIA VT8231 Integrated Sensors… No
AMD K8 thermal sensors… No
AMD Family 10h thermal sensors… No
AMD Family 11h thermal sensors… No
AMD Family 12h and 14h thermal sensors… No
AMD Family 15h thermal sensors… No
AMD Family 15h power sensors… No
AMD Family 16h power sensors… Success!
(driver `fam15h_power’)
Intel digital thermal sensor… No
Intel AMB FB-DIMM thermal sensor… No
VIA C7 thermal sensor… No
VIA Nano thermal sensor… No
Some Super I/O chips contain embedded sensors. We have to write to
standard I/O ports to probe them. This is usually safe.
Do you want to scan for Super I/O sensors? (YES/no):
Probing for Super-I/O at 0x2e/0x2f
Trying family National Semiconductor/ITE'... No Trying familySMSC’… No
Trying family VIA/Winbond/Nuvoton/Fintek'... No Trying familyITE’… Yes
Found unknown chip with ID 0x8623
(logical device 4 has address 0x290, could be sensors)
Probing for Super-I/O at 0x4e/0x4f
Trying family VIA/Winbond/Nuvoton/Fintek'... No Trying familyITE’… No
Some systems (mainly servers) implement IPMI, a set of common interfaces
through which system health data may be retrieved, amongst other things.
We first try to get the information from SMBIOS. If we don’t find it
there, we have to read from arbitrary I/O ports to probe for such
interfaces. This is normally safe. Do you want to scan for IPMI
interfaces? (YES/no):
Probing for IPMI BMC KCS' at 0xca0... No Probing forIPMI BMC SMIC’ at 0xca8… No
Some hardware monitoring chips are accessible through the ISA I/O ports.
We have to write to arbitrary I/O ports to probe them. This is usually
safe though. Yes, you do have ISA I/O ports even if you do not have any
ISA slots! Do you want to scan the ISA I/O ports? (YES/no):
Probing for National Semiconductor LM78' at 0x290... No Probing forNational Semiconductor LM79’ at 0x290… No
Probing for Winbond W83781D' at 0x290... No Probing forWinbond W83782D’ at 0x290… No
Lastly, we can probe the I2C/SMBus adapters for connected hardware
monitoring devices. This is the most risky part, and while it works
reasonably well on most systems, it has been reported to cause trouble
on some systems.
Do you want to probe the I2C/SMBus adapters now? (YES/no):
Using driver `i2c-piix4’ for device 0000:00:14.0: AMD Hudson-2 SMBus
Module i2c-dev loaded successfully.
Next adapter: SMBus PIIX4 adapter at 0b00 (i2c-0)
Do you want to scan it? (YES/no/selectively):
Client found at address 0x50
Probing for Analog Devices ADM1033'... No Probing forAnalog Devices ADM1034’… No
Probing for SPD EEPROM'... Yes (confidence 8, not a hardware monitoring chip) Probing forEDID EEPROM’… No
Next adapter: SMBus PIIX4 adapter at 0b20 (i2c-1)
Next adapter: Radeon i2c bit bus 0x90 (i2c-2)
Do you want to scan it? (yes/NO/selectively):
Next adapter: Radeon i2c bit bus 0x91 (i2c-3)
Next adapter: Radeon i2c bit bus 0x92 (i2c-4)
Next adapter: Radeon i2c bit bus 0x93 (i2c-5)
Next adapter: Radeon i2c bit bus 0x94 (i2c-6)
Next adapter: Radeon i2c bit bus 0x95 (i2c-7)
Next adapter: Radeon i2c bit bus 0x96 (i2c-8)
Next adapter: Radeon i2c bit bus 0x97 (i2c-9)
Now follows a summary of the probes I have just done.
Just press ENTER to continue:
Driver `fam15h_power’ (autoloaded):
- Chip `AMD Family 16h power sensors’ (confidence: 9)
No modules to load, skipping modules configuration.
Unloading i2c-dev… OK
Unloading cpuid… OK
ça fonctionne pourtant sur fedora
Bertrand
