Clé 4G Huawei reconnue comme CD
ça fait 4 heures que je me bats avec ça et là, j’en peux plus. Je télécharge samedi matin la dernière version de debian disponible sur le site, la 9.1.0. et je l’ai installée.
J’ai une clé 4 G pour ma connection internet, une HUAWEI E3372 LTE MODEM.
Mon souci est qu’elle est reconnue comme CD, et non comme modem (en tout cas, c’est ce que je comprends)
Un dmesg:
[    8.045877] Adding 4835560k swap on /dev/sda2.  Priority:-1 extents:1 across:4835560k FS
[   12.182033] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   12.185842] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   12.229002] IPv6: ADDRCONF(NETDEV_UP): wlp11s0: link is not ready
[   69.396081] usb 4-3: new high-speed USB device number 2 using ehci-pci
[   69.545226] usb 4-3: New USB device found, idVendor=12d1, idProduct=1f01
[   69.545233] usb 4-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[   69.545238] usb 4-3: Product: HUAWEI_MOBILE
[   69.545243] usb 4-3: Manufacturer: HUAWEI_MOBILE
[   69.545247] usb 4-3: SerialNumber: 0123456789ABCDEF
[   69.658698] usb-storage 4-3:1.0: USB Mass Storage device detected
[   69.658957] scsi host2: usb-storage 4-3:1.0
[   69.659260] usbcore: registered new interface driver usb-storage
[   69.665086] usbcore: registered new interface driver uas
[   70.694200] scsi 2:0:0:0: CD-ROM            HUAWEI   Mass Storage     2.31 PQ: 0 ANSI: 2
[   70.695025] scsi 2:0:0:1: Direct-Access     HUAWEI   TF CARD Storage  2.31 PQ: 0 ANSI: 2
[   70.700255] sr 2:0:0:0: [sr1] scsi-1 drive
[   70.702032] sr 2:0:0:0: Attached scsi CD-ROM sr1
[   70.702508] sr 2:0:0:0: Attached scsi generic sg2 type 5
[   70.705640] sd 2:0:0:1: Attached scsi generic sg3 type 0
[   70.707131] sd 2:0:0:1: [sdb] Attached SCSI removable disk
[   72.835745] sr 2:0:0:0: [sr1] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[   72.835755] sr 2:0:0:0: [sr1] tag#0 Sense Key : Medium Error [current]
[   72.835762] sr 2:0:0:0: [sr1] tag#0 Add. Sense: Unrecovered read error
[   72.835771] sr 2:0:0:0: [sr1] tag#0 CDB: Read(10) 28 00 00 00 0f fc 00 00 02 00
[   72.835776] blk_update_request: critical medium error, dev sr1, sector 16368
[   72.842622] sr 2:0:0:0: [sr1] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[   72.842631] sr 2:0:0:0: [sr1] tag#0 Sense Key : Medium Error [current]
[   72.842638] sr 2:0:0:0: [sr1] tag#0 Add. Sense: Unrecovered read error
[   72.842646] sr 2:0:0:0: [sr1] tag#0 CDB: Read(10) 28 00 00 00 0f fc 00 00 02 00
[   72.842651] blk_update_request: critical medium error, dev sr1, sector 16368
[   72.842662] Buffer I/O error on dev sr1, logical block 2046, async page read
[   72.881746] sr 2:0:0:0: [sr1] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[   72.881756] sr 2:0:0:0: [sr1] tag#0 Sense Key : Medium Error [current]
[   72.881764] sr 2:0:0:0: [sr1] tag#0 Add. Sense: Unrecovered read error
[   72.881772] sr 2:0:0:0: [sr1] tag#0 CDB: Read(10) 28 00 00 00 0f fa 00 00 02 00
[   72.881777] blk_update_request: critical medium error, dev sr1, sector 16360
[   72.888628] sr 2:0:0:0: [sr1] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[   72.888635] sr 2:0:0:0: [sr1] tag#0 Sense Key : Medium Error [current]
[   72.888640] sr 2:0:0:0: [sr1] tag#0 Add. Sense: Unrecovered read error
[   72.888647] sr 2:0:0:0: [sr1] tag#0 CDB: Read(10) 28 00 00 00 0f fa 00 00 02 00
[   72.888651] blk_update_request: critical medium error, dev sr1, sector 16360
[   72.888659] Buffer I/O error on dev sr1, logical block 2045, async page read
il y a pleins de message sur internet relatifs au package usb-modeswitch, mais ce que je comprends, c’est qu’il n’est pas présent dans mon synaptics car apparemment devenu obsolete:
root@debian:/home/pascaline# apt-get install usb-modeswitch
Aucune version du paquet usb-modeswitch n'est disponible, mais il existe dans la base
de données. Cela signifie en général que le paquet est manquant, qu'il est devenu obsolète
ou qu'il n'est disponible que sur une autre source
E: Le paquet « usb-modeswitch » n'a pas de version susceptible d'être installée
Pour finir, j’arrive bien à me connecter sur internet via cette clé lorsque j’utilise un vieux live-cd de knoppix qui lui fonctionne à merveille, et de plus, lorsque je redémarre le pc sur debian, suite à ce live-cd, la connection se fait d’elle même. Mais je la perds dès que je débranche/rebranche ma clé usb.
Alors voilà où j’en suis.
Merci de votre aide
Le paquet usb-modeswitch existe bel et bien (de wheezy à sid).
Peut-être y a-t-il un souci du côté du fichier sources.list ?
C’est exactement ce que je viens de comprendre:
Je n’ai pas fait gaffe, comme je l’ai installé via CD, dans ma liste de dépots, j’avais uniquement le cd de coché et ces deux là qui n’étaient pas cochés dans synaptics:
deb http://deb.debian.org/debian/ stretch-updates main
deb http://security.debian.org/debian-security/ stretch/updates main
donc j’ai décoché le cd et coché ces deux derniers.
Apparemment je suis complètement à côté de la plaque en faisant cela.
Donc c’est bien cette ligne ci dessous que je dois mettre?
deb http://ftp.fr.debian.org/debian/ stable main contrib non-free ?
Pourquoi cette ligne alors dans le cd officiel qui induit fortement en erreur???
Merci de cette réponse rapide en tout cas
voir :
https://wiki.debian.org/fr/SourcesList#Exemple_:_fichier_sources.list
