J’ai un problème avec une clé USB, c’elle-ci fonctionne très bien sous l’OS Windows mais sous Debian elle est inutilisable…
Voilà ce que donne un “dmesg”
[101699.522933] usb 5-7: new high speed USB device using ehci_hcd and address 6
[101699.666606] usb 5-7: configuration #1 chosen from 1 choice
[101699.666858] usb 5-7: New USB device found, idVendor=1976, idProduct=6025
[101699.666858] usb 5-7: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[101699.666858] usb 5-7: Product: Flash Disk
[101699.666858] usb 5-7: Manufacturer:
[101699.666858] usb 5-7: SerialNumber: 181749007EA09200
[101699.882493] Initializing USB Mass Storage driver...
[101699.884580] scsi2 : SCSI emulation for USB Mass Storage devices
[101699.885035] usbcore: registered new interface driver usb-storage
[101699.885041] USB Mass Storage support registered.
[101699.894763] usb-storage: device found at 6
[101699.894768] usb-storage: waiting for device to settle before scanning
[101705.354452] usb-storage: device scan complete
[101705.355056] scsi 2:0:0:0: Direct-Access Flash Disk 5.00 PQ: 0 ANSI: 2
[101705.395877] sd 2:0:0:0: [sdb] 1015808 512-byte hardware sectors (520 MB)
[101705.396561] sd 2:0:0:0: [sdb] Write Protect is off
[101705.396565] sd 2:0:0:0: [sdb] Mode Sense: 0b 00 00 08
[101705.396568] sd 2:0:0:0: [sdb] Assuming drive cache: write through
[101705.399816] sd 2:0:0:0: [sdb] 1015808 512-byte hardware sectors (520 MB)
[101705.400867] sd 2:0:0:0: [sdb] Write Protect is off
[101705.400872] sd 2:0:0:0: [sdb] Mode Sense: 0b 00 00 08
[101705.400875] sd 2:0:0:0: [sdb] Assuming drive cache: write through
[101705.400878] sdb: sdb1
[101705.402635] sd 2:0:0:0: [sdb] Attached SCSI removable disk
[101705.402690] sd 2:0:0:0: Attached scsi generic sg1 type 0
[101737.517372] usb 5-7: reset high speed USB device using ehci_hcd and address 6
[101769.714083] usb 5-7: reset high speed USB device using ehci_hcd and address 6
[101801.639023] usb 5-7: reset high speed USB device using ehci_hcd and address 6
[101833.828231] usb 5-7: reset high speed USB device using ehci_hcd and address 6
[101866.437689] usb 5-7: reset high speed USB device using ehci_hcd and address 6
[101873.406997] INFO: task vol_id:20330 blocked for more than 120 seconds.
[101873.407005] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[101873.407007] vol_id D 0000000000000082 0 20330 20318
[101873.407012] ffff81005b9f3c38 0000000000000086 0000000000000287 ffffffff8801d92d
[101873.407016] ffffffff805e0e00 ffff81002b8ec100 ffff8100141ecd40 ffff81002b8ec370
[101873.407020] 0000000007021800 ffff81002b8ec370 ffff81005c54c3a0 ffff810007021920
[101873.407023] Call Trace:
[101873.407087] [<ffffffff8801d92d>] :scsi_mod:scsi_dispatch_cmd+0x1e6/0x264
[101873.407099] [<ffffffff8021266d>] read_tsc+0x5/0x7
[101873.407103] [<ffffffff8024b9e8>] getnstimeofday+0x2f/0x83
[101873.407109] [<ffffffff80272fd4>] sync_page_killable+0x0/0x31
[101873.407115] [<ffffffff8043bf35>] io_schedule+0x63/0xa5
[101873.407121] [<ffffffff80272fcf>] sync_page+0x3c/0x41
[101873.407125] [<ffffffff80272fdd>] sync_page_killable+0x9/0x31
[101873.407128] [<ffffffff8043c149>] __wait_on_bit_lock+0x3f/0x71
[101873.407136] [<ffffffff80272f1c>] __lock_page_killable+0x5d/0x63
[101873.407142] [<ffffffff8024740f>] wake_bit_function+0x0/0x23
[101873.407148] [<ffffffff80274de5>] generic_file_aio_read+0x2e2/0x4c8
[101873.407162] [<ffffffff8020bef9>] sysret_signal+0x2b/0x45
[101873.407169] [<ffffffff8029d436>] do_sync_read+0xce/0x113
[101873.407180] [<ffffffff802473e1>] autoremove_wake_function+0x0/0x2e
[101873.407190] [<ffffffff80229212>] enqueue_task+0x56/0x61
[101873.407196] [<ffffffff8022cd99>] sched_move_task+0xdb/0xe6
[101873.407204] [<ffffffff8029de34>] vfs_read+0xaa/0x152
[101873.407210] [<ffffffff8029df98>] sys_read+0x45/0x6e
[101873.407217] [<ffffffff8020be4a>] system_call_after_swapgs+0x8a/0x8f
[101873.407226]
[101898.939988] usb 5-7: reset high speed USB device using ehci_hcd and address 6
[101899.073972] sd 2:0:0:0: [sdb] Result: hostbyte=DID_ABORT driverbyte=DRIVER_OK,SUGGEST_OK
[101899.073981] end_request: I/O error, dev sdb, sector 1015680
[101899.073986] Buffer I/O error on device sdb, logical block 126960
[101931.444261] usb 5-7: reset high speed USB device using ehci_hcd and address 6
[101947.236058] usb 5-7: device descriptor read/64, error -110
[101963.297096] usb 5-7: device descriptor read/64, error -110
[101963.514155] usb 5-7: reset high speed USB device using ehci_hcd and address 6
[101979.561715] usb 5-7: device descriptor read/64, error -110
[101995.749724] usb 5-7: device descriptor read/64, error -110
[101995.965742] usb 5-7: reset high speed USB device using ehci_hcd and address 6
[102001.254861] usb 5-7: device descriptor read/8, error -110
[102006.927238] usb 5-7: device descriptor read/8, error -110
[102007.143140] usb 5-7: reset high speed USB device using ehci_hcd and address 6
[102012.360563] usb 5-7: device descriptor read/8, error -110
[102018.017160] usb 5-7: device descriptor read/8, error -110
[102018.121060] sd 2:0:0:0: Device offlined - not ready after error recovery
[102018.121079] sd 2:0:0:0: [sdb] Result: hostbyte=DID_ABORT driverbyte=DRIVER_OK,SUGGEST_OK
[102018.121083] end_request: I/O error, dev sdb, sector 1015680
[102018.121088] Buffer I/O error on device sdb, logical block 126960
[102018.121111] sd 2:0:0:0: rejecting I/O to offline device
[102018.121753] sd 2:0:0:0: rejecting I/O to offline device
[102018.121759] Buffer I/O error on device sdb, logical block 126960
[102018.122693] sd 2:0:0:0: rejecting I/O to offline device
[102018.122701] Buffer I/O error on device sdb, logical block 0
[102018.122717] sd 2:0:0:0: rejecting I/O to offline device
[102018.122719] Buffer I/O error on device sdb, logical block 1
[102018.122725] sd 2:0:0:0: rejecting I/O to offline device
[102018.122728] Buffer I/O error on device sdb, logical block 0
[102018.122737] sd 2:0:0:0: rejecting I/O to offline device
[102018.122739] Buffer I/O error on device sdb, logical block 0
[102018.122751] sd 2:0:0:0: rejecting I/O to offline device
[102018.122753] Buffer I/O error on device sdb, logical block 126975
[102018.122765] sd 2:0:0:0: rejecting I/O to offline device
[102018.122767] Buffer I/O error on device sdb, logical block 126975
[102018.122776] sd 2:0:0:0: rejecting I/O to offline device
[102018.122778] Buffer I/O error on device sdb, logical block 126975
[102018.122786] sd 2:0:0:0: rejecting I/O to offline device
[102018.122789] Buffer I/O error on device sdb, logical block 126975
[102018.122797] sd 2:0:0:0: rejecting I/O to offline device
[102018.122806] sd 2:0:0:0: rejecting I/O to offline device
[102018.122816] sd 2:0:0:0: rejecting I/O to offline device
[102018.122825] sd 2:0:0:0: rejecting I/O to offline device
[102018.122834] sd 2:0:0:0: rejecting I/O to offline device
[102018.122843] sd 2:0:0:0: rejecting I/O to offline device
[102018.122851] sd 2:0:0:0: rejecting I/O to offline device
[102018.122860] sd 2:0:0:0: rejecting I/O to offline device
[102018.122868] sd 2:0:0:0: rejecting I/O to offline device
[102018.122881] sd 2:0:0:0: rejecting I/O to offline device
[102018.122890] sd 2:0:0:0: rejecting I/O to offline device
[102018.122898] sd 2:0:0:0: rejecting I/O to offline device
[102018.122945] sd 2:0:0:0: rejecting I/O to offline device
[102018.122954] sd 2:0:0:0: rejecting I/O to offline device
[102018.122963] sd 2:0:0:0: rejecting I/O to offline device
[102018.122971] sd 2:0:0:0: rejecting I/O to offline device
[102018.122979] sd 2:0:0:0: rejecting I/O to offline device
[102018.122987] sd 2:0:0:0: rejecting I/O to offline device
[102018.122995] sd 2:0:0:0: rejecting I/O to offline device
[102018.123004] sd 2:0:0:0: rejecting I/O to offline device
[102018.123012] sd 2:0:0:0: rejecting I/O to offline device
[102018.123020] sd 2:0:0:0: rejecting I/O to offline device
[102018.123028] sd 2:0:0:0: rejecting I/O to offline device
[102018.123036] sd 2:0:0:0: rejecting I/O to offline device
[102018.123044] sd 2:0:0:0: rejecting I/O to offline device
[102018.123053] sd 2:0:0:0: rejecting I/O to offline device
[102018.123061] sd 2:0:0:0: rejecting I/O to offline device
[102018.123069] sd 2:0:0:0: rejecting I/O to offline device
[102018.123077] sd 2:0:0:0: rejecting I/O to offline device
[102018.123085] sd 2:0:0:0: rejecting I/O to offline device
[102018.123093] sd 2:0:0:0: rejecting I/O to offline device
[102018.123373] usb 5-7: USB disconnect, address 6
[102018.241061] usb 5-7: new high speed USB device using ehci_hcd and address 7
[102034.190333] usb 5-7: device descriptor read/64, error -110
[102050.670786] usb 5-7: device descriptor read/64, error -110
[102050.903850] usb 5-7: new high speed USB device using ehci_hcd and address 8
[102066.627609] usb 5-7: device descriptor read/64, error -110
[102082.972800] usb 5-7: device descriptor read/64, error -110
[102083.188829] usb 5-7: new high speed USB device using ehci_hcd and address 9
[102088.213457] usb 5-7: device descriptor read/8, error -110
[102093.862931] usb 5-7: device descriptor read/8, error -110
[102094.107195] usb 5-7: new high speed USB device using ehci_hcd and address 10
[102099.343332] usb 5-7: device descriptor read/8, error -110
[102105.036750] usb 5-7: device descriptor read/8, error -110
[102105.159908] hub 5-0:1.0: unable to enumerate USB device on port 7
[102105.605021] usb 4-1: new full speed USB device using uhci_hcd and address 4
[102121.518207] usb 4-1: device descriptor read/64, error -110
[102138.004496] usb 4-1: device descriptor read/64, error -110
[102138.254906] usb 4-1: new full speed USB device using uhci_hcd and address 5
[102153.978703] usb 4-1: device descriptor read/64, error -110
Quelqu’un à t’il une idée pour la faire fonctionner … ?
Merci de votre aide
