Bonjour, la commande dmesg me donne le résultat suivant :
Linux version 2.6.18-3-686 (Debian 2.6.18-8) (waldi@debian.org) (gcc version 4.1 .2 20061115 (prerelease) (Debian 4.1.1-20)) #1 SMP Sun Dec 10 19:37:06 UTC 2006
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000001fff0000 (usable)
BIOS-e820: 000000001fff0000 - 000000001fff8000 (ACPI data)
BIOS-e820: 000000001fff8000 - 0000000020000000 (ACPI NVS)
BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
BIOS-e820: 00000000fff80000 - 0000000100000000 (reserved)
0MB HIGHMEM available.
511MB LOWMEM available.
On node 0 totalpages: 131056
DMA zone: 4096 pages, LIFO batch:0
Normal zone: 126960 pages, LIFO batch:31
DMI 2.3 present.
ACPI: RSDP (v000 AMI ) @ 0x000fa8c0
ACPI: RSDT (v001 AMIINT VIA_K7 0x00000010 MSFT 0x00000097) @ 0x1fff0000
ACPI: FADT (v001 AMIINT VIA_K7 0x00000011 MSFT 0x00000097) @ 0x1fff0030
ACPI: MADT (v001 AMIINT VIA_K7 0x00000009 MSFT 0x00000097) @ 0x1fff00c0
ACPI: DSDT (v001 VIA K7VT4 0x00001000 MSFT 0x0100000d) @ 0x00000000
ACPI: PM-Timer IO Port: 0x808
ACPI: Local APIC address 0xfee00000
ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
Processor #0 6:8 APIC version 16
ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
IOAPIC[0]: apic_id 2, version 3, address 0xfec00000, GSI 0-23
ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
ACPI: IRQ0 used by override.
ACPI: IRQ2 used by override.
ACPI: IRQ9 used by override.
Enabling APIC mode: Flat. Using 1 I/O APICs
Using ACPI (MADT) for SMP configuration information
Allocating PCI resources starting at 30000000 (gap: 20000000:dec00000)
Detected 1832.875 MHz processor.
Built 1 zonelists. Total pages: 131056
Kernel command line: root=/dev/hda1 ro
mapped APIC to ffffd000 (fee00000)
mapped IOAPIC to ffffc000 (fec00000)
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Initializing CPU#0
PID hash table entries: 2048 (order: 11, 8192 bytes)
Console: colour VGA+ 80x25
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 511544k/524224k available (1543k kernel code, 12036k reserved, 574k data , 196k init, 0k highmem)
Checking if this processor honours the WP bit even in supervisor mode... Ok.
Calibrating delay using timer specific routine.. 3669.75 BogoMIPS (lpj=7339505)
Security Framework v1.0.0 initialized
SELinux: Disabled at boot.
Capability LSM initialized
Mount-cache hash table entries: 512
CPU: After generic identify, caps: 0383fbff c1cbfbff 00000000 00000000 00000000 00000000 00000000
CPU: After vendor identify, caps: 0383fbff c1cbfbff 00000000 00000000 00000000 0 0000000 00000000
CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
CPU: L2 Cache: 256K (64 bytes/line)
CPU: After all inits, caps: 0383fbff c1cbfbff 00000000 00000420 00000000 0000000 0 00000000
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
Compat vDSO mapped to ffffe000.
Checking 'hlt' instruction... OK.
SMP alternatives: switching to UP code
Freeing SMP alternatives: 16k freed
ACPI: Core revision 20060707
CPU0: AMD Sempron(tm) 2600+ stepping 01
Total of 1 processors activated (3669.75 BogoMIPS).
ENABLING IO-APIC IRQs
..TIMER: vector=0x31 apic1=0 pin1=2 apic2=-1 pin2=-1
Brought up 1 CPUs
migration_cost=0
checking if image is initramfs... it is
Freeing initrd memory: 4865k freed
NET: Registered protocol family 16
ACPI: bus type pci registered
PCI: PCI BIOS revision 2.10 entry at 0xfda71, last bus=1
PCI: Using configuration type 1
Setting up standard PCI resources
ACPI: Interpreter enabled
ACPI: Using IOAPIC for interrupt routing
ACPI: PCI Root Bridge [PCI0] (0000:00)
PCI: Probing PCI hardware (bus 00)
Boot video device is 0000:01:00.0
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: Power Resource [URP1] (off)
ACPI: Power Resource [URP2] (off)
ACPI: Power Resource [FDDP] (off)
ACPI: Power Resource [LPTP] (off)
ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 7 10 *11 12 14 15)
ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 *10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKC] (IRQs *3 4 5 7 10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 *5 7 10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 7 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 7 10 11 12 14 15) *0, disabled.
Linux Plug and Play Support v0.97 (c) Adam Belay
pnp: PnP ACPI init
pnp: PnP ACPI: found 12 devices
PnPBIOS: Disabled by ACPI PNP
PCI: Using ACPI for IRQ routing
PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
PCI: Bridge: 0000:00:01.0
IO window: disabled.
MEM window: dde00000-dfefffff
PREFETCH window: d5d00000-ddcfffff
PCI: Setting latency timer of device 0000:00:01.0 to 64
NET: Registered protocol family 2
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 16384 bind 8192)
TCP reno registered
audit: initializing netlink socket (disabled)
audit(1169116933.840:1): initialized
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
PCI: Bypassing VIA 8237 APIC De-Assert Message
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
00:02: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
serio: i8042 AUX port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
mice: PS/2 mouse device common for all mice
TCP bic registered
NET: Registered protocol family 17
NET: Registered protocol family 8
NET: Registered protocol family 20
Using IPI No-Shortcut mode
ACPI: (supports S0 S1 S4 S5)
Freeing unused kernel memory: 196k freed
Time: tsc clocksource has been installed.
input: AT Translated Set 2 keyboard as /class/input/input0
SCSI subsystem initialized
libata version 2.00 loaded.
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
VP_IDE: IDE controller at PCI slot 0000:00:0f.1
ACPI: PCI Interrupt 0000:00:0f.1[A] -> GSI 20 (level, low) -> IRQ 169
PCI: VIA IRQ fixup for 0000:00:0f.1, from 255 to 9
VP_IDE: chipset revision 6
VP_IDE: not 100% native mode: will probe irqs later
VP_IDE: VIA vt8237 (rev 00) IDE UDMA133 controller on pci0000:00:0f.1
ide0: BM-DMA at 0xfc00-0xfc07, BIOS settings: hda:DMA, hdb:pio
ide1: BM-DMA at 0xfc08-0xfc0f, BIOS settings: hdc:DMA, hdd:pio
Probing IDE interface ide0...
usbcore: registered new driver usbfs
usbcore: registered new driver hub
USB Universal Host Controller Interface driver v3.0
via-rhine.c:v1.10-LK1.4.1 July-24-2006 Written by Donald Becker
hda: Maxtor 6L200P0, ATA DISK drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Probing IDE interface ide1...
hdc: PIONEER DVD-RW DVR-108, ATAPI CD/DVD-ROM drive
ide1 at 0x170-0x177,0x376 on irq 15
sata_via 0000:00:0f.0: version 2.0
ACPI: PCI Interrupt 0000:00:0f.0[B] -> GSI 20 (level, low) -> IRQ 169
sata_via 0000:00:0f.0: routed to hard irq line 10
ata1: SATA max UDMA/133 cmd 0xEC00 ctl 0xE802 bmdma 0xDC00 irq 169
ata2: SATA max UDMA/133 cmd 0xE400 ctl 0xE002 bmdma 0xDC08 irq 169
scsi0 : sata_via
ata1: SATA link down 1.5 Gbps (SStatus 0 SControl 300)
ATA: abnormal status 0x7F on port 0xEC07
scsi1 : sata_via
ata2: SATA link down 1.5 Gbps (SStatus 0 SControl 300)
ATA: abnormal status 0x7F on port 0xE407
ACPI: PCI Interrupt 0000:00:10.0[A] -> GSI 21 (level, low) -> IRQ 177
PCI: VIA IRQ fixup for 0000:00:10.0, from 11 to 1
uhci_hcd 0000:00:10.0: UHCI Host Controller
uhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 1
uhci_hcd 0000:00:10.0: irq 177, io base 0x0000c800
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:10.1[A] -> GSI 21 (level, low) -> IRQ 177
PCI: VIA IRQ fixup for 0000:00:10.1, from 11 to 1
uhci_hcd 0000:00:10.1: UHCI Host Controller
uhci_hcd 0000:00:10.1: new USB bus registered, assigned bus number 2
uhci_hcd 0000:00:10.1: irq 177, io base 0x0000cc00
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:10.2[B] -> GSI 21 (level, low) -> IRQ 177
PCI: VIA IRQ fixup for 0000:00:10.2, from 10 to 1
uhci_hcd 0000:00:10.2: UHCI Host Controller
uhci_hcd 0000:00:10.2: new USB bus registered, assigned bus number 3
uhci_hcd 0000:00:10.2: irq 177, io base 0x0000d000
usb usb3: configuration #1 chosen from 1 choice
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:10.3[B] -> GSI 21 (level, low) -> IRQ 177
PCI: VIA IRQ fixup for 0000:00:10.3, from 10 to 1
uhci_hcd 0000:00:10.3: UHCI Host Controller
uhci_hcd 0000:00:10.3: new USB bus registered, assigned bus number 4
uhci_hcd 0000:00:10.3: irq 177, io base 0x0000d400
usb usb4: configuration #1 chosen from 1 choice
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:12.0[A] -> GSI 23 (level, low) -> IRQ 185
eth0: VIA Rhine II at 0x1c000, 00:0b:6a:99:e1:11, IRQ 185.
eth0: MII PHY found at address 1, status 0x7869 advertising 05e1 Link 45e1.
ACPI: PCI Interrupt 0000:00:10.4[C] -> GSI 21 (level, low) -> IRQ 177
PCI: VIA IRQ fixup for 0000:00:10.4, from 3 to 1
ehci_hcd 0000:00:10.4: EHCI Host Controller
ehci_hcd 0000:00:10.4: new USB bus registered, assigned bus number 5
ehci_hcd 0000:00:10.4: irq 177, io mem 0xdfffbe00
ehci_hcd 0000:00:10.4: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb5: configuration #1 chosen from 1 choice
hub 5-0:1.0: USB hub found
hub 5-0:1.0: 8 ports detected
hda: max request size: 512KiB
hda: 398297088 sectors (203928 MB) w/8192KiB Cache, CHS=24792/255/63, UDMA(33)
hda: cache flushes supported
hda: hda1 hda2 hda3 hda4
hdc: ATAPI 40X DVD-ROM DVD-R CD-R/RW drive, 2000kB Cache, UDMA(33)
Uniform CD-ROM driver Revision: 3.20
ReiserFS: hda1: found reiserfs format "3.6" with standard journal
ReiserFS: hda1: using ordered data mode
ReiserFS: hda1: journal params: device hda1, size 8192, journal first block 18, max trans len 1024, max batch 900, max commit age 30, max trans age 30
ReiserFS: hda1: checking transaction log (hda1)
ReiserFS: hda1: Using r5 hash to sort names
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
input: PC Speaker as /class/input/input1
Linux agpgart interface v0.101 (c) Dave Jones
agpgart: Detected VIA KT400/KT400A/KT600 chipset
agpgart: AGP aperture is 64M @ 0xe0000000
Real Time Clock Driver v1.12ac
Floppy drive(s): fd0 is 1.44M
parport: PnPBIOS parport detected.
parport0: PC-style at 0x378 (0x778), irq 7, dma 0 [PCSPP,TRISTATE,COMPAT,EPP,ECP ,DMA]
FDC 0 is a post-1991 82077
ACPI: PCI Interrupt 0000:00:11.5[C] -> GSI 22 (level, low) -> IRQ 193
PCI: Setting latency timer of device 0000:00:11.5 to 64
input: ImExPS/2 Logitech Wheel Mouse as /class/input/input2
ts: Compaq touchscreen protocol output
Adding 979956k swap on /dev/hda2. Priority:-1 extents:1 across:979956k
device-mapper: ioctl: 4.7.0-ioctl (2006-06-24) initialised: dm-devel@redhat.com
kjournald starting. Commit interval 5 seconds
EXT3-fs warning: mounting fs with errors, running e2fsck is recommended
EXT3 FS on hda4, internal journal
EXT3-fs: mounted filesystem with ordered data mode.
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
IPv6 over IPv4 tunneling driver
eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
usbcore: registered new driver usblp
drivers/usb/class/usblp.c: v0.13: USB Printer Device Class driver
eth0: no IPv6 routers present
nvidia: module license 'NVIDIA' taints kernel.
ACPI: PCI Interrupt 0000:01:00.0[A] -> GSI 16 (level, low) -> IRQ 201
NVRM: loading NVIDIA Linux x86 Kernel Module 1.0-8776 Mon Oct 16 21:56:04 PDT 2006
agpgart: Found an AGP 3.5 compliant device at 0000:00:00.0.
agpgart: Putting AGP V3 device at 0000:00:00.0 into 8x mode
agpgart: Putting AGP V3 device at 0000:01:00.0 into 8x mode
usb 5-1: new high speed USB device using ehci_hcd and address 2
usb 5-1: configuration #1 chosen from 1 choice
Initializing USB Mass Storage driver...
scsi2 : SCSI emulation for USB Mass Storage devices
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
usb-storage: device found at 2
usb-storage: waiting for device to settle before scanning
Vendor: JetFlash Model: TS4GJFV30 Rev: 0.00
Type: Direct-Access ANSI SCSI revision: 02
usb-storage: device scan complete
SCSI device sda: 8060927 512-byte hdwr sectors (4127 MB)
sda: Write Protect is off
sda: Mode Sense: 00 00 00 00
sda: assuming drive cache: write through
sda: sda1
sd 2:0:0:0: Attached scsi removable disk sda
Désolé c’est un peu long… Mais on dirait bien que l’USB 2.0 ne pose pas de problème
Et pour les logs, voici ce que cela donne juste après la copie d’un fichier de 650Mo dans /var/log/syslog :
Jan 18 10:54:16 localhost kernel: usb 5-1: new high speed USB device using ehci_hcd and address 2
Jan 18 10:54:16 localhost kernel: usb 5-1: configuration #1 chosen from 1 choice
Jan 18 10:54:16 localhost kernel: Initializing USB Mass Storage driver...
Jan 18 10:54:16 localhost kernel: scsi2 : SCSI emulation for USB Mass Storage devices
Jan 18 10:54:16 localhost kernel: usbcore: registered new driver usb-storage
Jan 18 10:54:16 localhost kernel: USB Mass Storage support registered.
Jan 18 10:54:16 localhost kernel: usb-storage: device found at 2
Jan 18 10:54:16 localhost kernel: usb-storage: waiting for device to settle before scanning
Jan 18 10:54:21 localhost kernel: Vendor: JetFlash Model: TS4GJFV30 Rev: 0.00
Jan 18 10:54:21 localhost kernel: Type: Direct-Access ANSI SCSI revision: 02
Jan 18 10:54:21 localhost kernel: usb-storage: device scan complete
Jan 18 10:54:21 localhost kernel: SCSI device sda: 8060927 512-byte hdwr sectors (4127 MB)
Jan 18 10:54:21 localhost kernel: sda: Write Protect is off
Jan 18 10:54:21 localhost kernel: sda: Mode Sense: 00 00 00 00
Jan 18 10:54:21 localhost kernel: sda: assuming drive cache: write through
Jan 18 10:54:21 localhost kernel: sda: sda1
Jan 18 10:54:21 localhost kernel: sd 2:0:0:0: Attached scsi removable disk sda
Jan 18 11:00:09 localhost gconfd (root-4215): démarrage (version 2.16.0), pid 4215 utilisateur « root »
Jan 18 11:00:09 localhost gconfd (root-4215): Adresse « xml:readonly:/etc/gconf/gconf.xml.mandatory » résolue vers une source de configuration en lecture seule à la position 0
Jan 18 11:00:09 localhost gconfd (root-4215): Adresse « xml:readwrite:/root/.gconf » résolue vers une source de configuration accessible en écriture à la position 1
Jan 18 11:00:09 localhost gconfd (root-4215): Adresse « xml:readonly:/etc/gconf/gconf.xml.defaults » résolue vers une source de configuration en lecture seule à la position 2
Jan 18 11:00:09 localhost gconfd (root-4215): Adresse « xml:readonly:/var/lib/gconf/debian.defaults » résolue vers une source de configuration en lecture seule à la position 3
Jan 18 11:00:09 localhost gconfd (root-4215): Adresse « xml:readonly:/var/lib/gconf/defaults » résolue vers une source de configuration en lecture seule à la position 4
Jan 18 11:01:09 localhost gconfd (root-4215): Le serveur GConf n'est pas en cours d'utilisation, arrêt.
Jan 18 11:01:09 localhost gconfd (root-4215): Sortie
Jan 18 11:03:23 localhost gconfd (root-4229): démarrage (version 2.16.0), pid 4229 utilisateur « root »
Jan 18 11:03:23 localhost gconfd (root-4229): Adresse « xml:readonly:/etc/gconf/gconf.xml.mandatory » résolue vers une source de configuration en lecture seule à la position 0
Jan 18 11:03:23 localhost gconfd (root-4229): Adresse « xml:readwrite:/root/.gconf » résolue vers une source de configuration accessible en écriture à la position 1
Jan 18 11:03:23 localhost gconfd (root-4229): Adresse « xml:readonly:/etc/gconf/gconf.xml.defaults » résolue vers une source de configuration en lecture seule à la position 2
Jan 18 11:03:23 localhost gconfd (root-4229): Adresse « xml:readonly:/var/lib/gconf/debian.defaults » résolue vers une source de configuration en lecture seule à la position 3
Jan 18 11:03:23 localhost gconfd (root-4229): Adresse « xml:readonly:/var/lib/gconf/defaults » résolue vers une source de configuration en lecture seule à la position 4
Jan 18 11:05:23 localhost gconfd (root-4229): Le serveur GConf n'est pas en cours d'utilisation, arrêt.
Jan 18 11:05:23 localhost gconfd (root-4229): Sortie
Jan 18 11:06:12 localhost kernel: usb 5-1: USB disconnect, address 2
Jan 18 11:06:18 localhost gconfd (root-4264): démarrage (version 2.16.0), pid 4264 utilisateur « root »
Jan 18 11:06:18 localhost gconfd (root-4264): Adresse « xml:readonly:/etc/gconf/gconf.xml.mandatory » résolue vers une source de configuration en lecture seule à la position 0
Jan 18 11:06:18 localhost gconfd (root-4264): Adresse « xml:readwrite:/root/.gconf » résolue vers une source de configuration accessible en écriture à la position 1
Jan 18 11:06:18 localhost gconfd (root-4264): Adresse « xml:readonly:/etc/gconf/gconf.xml.defaults » résolue vers une source de configuration en lecture seule à la position 2
Jan 18 11:06:18 localhost gconfd (root-4264): Adresse « xml:readonly:/var/lib/gconf/debian.defaults » résolue vers une source de configuration en lecture seule à la position 3
Jan 18 11:06:18 localhost gconfd (root-4264): Adresse « xml:readonly:/var/lib/gconf/defaults » résolue vers une source de configuration en lecture seule à la position 4
Voilà, désolé pour le gros pavé…
Et merci pour votre aide
