je ne peux pas lire une clé usb2:
27/08/2012 11:51:28 alpha30 kernel [330243.966876] usb 4-3: new high-speed USB device number 4 using ehci_hcd
27/08/2012 11:51:28 alpha30 kernel [330244.101224] usb 4-3: New USB device found, idVendor=0951, idProduct=1603
27/08/2012 11:51:28 alpha30 kernel [330244.101228] usb 4-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
27/08/2012 11:51:28 alpha30 kernel [330244.101232] usb 4-3: Product: DataTraveler 2.0
27/08/2012 11:51:28 alpha30 kernel [330244.101234] usb 4-3: Manufacturer: Kingston
27/08/2012 11:51:28 alpha30 kernel [330244.101237] usb 4-3: SerialNumber: 89900000000000006CB02B0F
27/08/2012 11:51:28 alpha30 kernel [330244.101581] scsi22 : usb-storage 4-3:1.0
27/08/2012 11:51:28 alpha30 mtp-probe checking bus 4, device 4: "/sys/devices/pci0000:00/0000:00:1d.7/usb4/4-3"
27/08/2012 11:51:28 alpha30 mtp-probe bus: 4, device: 4 was not an MTP device
27/08/2012 11:51:29 alpha30 kernel [330245.099921] scsi 22:0:0:0: Direct-Access Kingston DataTraveler 2.0 1.00 PQ: 0 ANSI: 2
27/08/2012 11:51:29 alpha30 kernel [330245.100643] sd 22:0:0:0: Attached scsi generic sg2 type 0
27/08/2012 11:51:29 alpha30 kernel [330245.101154] sd 22:0:0:0: [sdb] 7888896 512-byte logical blocks: (4.03 GB/3.76 GiB)
27/08/2012 11:51:29 alpha30 kernel [330245.101660] sd 22:0:0:0: [sdb] Write Protect is off
27/08/2012 11:51:29 alpha30 kernel [330245.101666] sd 22:0:0:0: [sdb] Mode Sense: 23 00 00 00
27/08/2012 11:51:29 alpha30 kernel [330245.102157] sd 22:0:0:0: [sdb] No Caching mode page present
27/08/2012 11:51:29 alpha30 kernel [330245.102161] sd 22:0:0:0: [sdb] Assuming drive cache: write through
27/08/2012 11:51:29 alpha30 kernel [330245.104775] sd 22:0:0:0: [sdb] No Caching mode page present
27/08/2012 11:51:29 alpha30 kernel [330245.104779] sd 22:0:0:0: [sdb] Assuming drive cache: write through
27/08/2012 11:51:29 alpha30 kernel [330245.198626] sdb: sdb1 sdb2
27/08/2012 11:51:29 alpha30 kernel [330245.200732] sd 22:0:0:0: [sdb] No Caching mode page present
27/08/2012 11:51:29 alpha30 kernel [330245.200736] sd 22:0:0:0: [sdb] Assuming drive cache: write through
27/08/2012 11:51:29 alpha30 kernel [330245.200740] sd 22:0:0:0: [sdb] Attached SCSI removable disk
27/08/2012 11:51:30 alpha30 usbmount[26299] /dev/sdb does not contain a filesystem or disklabel
27/08/2012 11:51:30 alpha30 usbmount[26322] executing command: mount -tvfat -osync,noexec,nodev,noatime,nodiratime /dev/sdb2 /media/usb0
27/08/2012 11:51:35 alpha30 usbmount[26329] executing command: mount -tvfat -osync,noexec,nodev,noatime,nodiratime /dev/sdb1 /media/usb0
ceci sur une:
root@alpha30:~# uname -r
3.5.0-20120813
root@alpha30:~#
machine 64 bits
nota sur ma 2.6.32 32bits c’est OK
bon appétit
A+
JB1
