Oui pour la première demande.
J’ai compris que je devrais répéter la commande après avoir tapé “mount”. Si c’est bien ça, voici le résultat:
[quote]root@nexus:/home/carlos# mount
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
udev on /dev type devtmpfs (rw,relatime,size=10240k,nr_inodes=213658,mode=755)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run type tmpfs (rw,nosuid,noexec,relatime,size=413000k,mode=755)
/dev/disk/by-uuid/a4013b25-f58f-49d9-8752-8b1fab310e2f on / type ext4 (rw,relatime,errors=remount-ro,user_xattr,barrier=1,data=ordered)
tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
/dev/sde1 on /media/usb0 type ext3 (rw,nodev,noexec,noatime,nodiratime,sync,errors=continue,barrier=1,data=ordered)
tmpfs on /run/shm type tmpfs (rw,nosuid,nodev,noexec,relatime,size=1645300k)
/dev/sdb3 on /media/Arquivo type ext4 (rw,relatime,user_xattr,acl,barrier=1,data=ordered)
fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)
/dev/sdd5 on /media/DADOS_XP type fuseblk (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other,blksize=4096)
/dev/sdc3 on /media/Imagens type ext4 (rw,relatime,user_xattr,acl,barrier=1,data=ordered)
/dev/sdc2 on /media/Lucid type ext4 (rw,relatime,user_xattr,acl,barrier=1,data=ordered)
/dev/sda3 on /media/Pessoais type ext4 (rw,relatime,user_xattr,acl,barrier=1,data=ordered)
/dev/sdb4 on /media/dados type ext3 (rw,relatime,errors=continue,barrier=1,data=ordered)
/dev/sda2 on /media/sdd2 type ext4 (rw,relatime,user_xattr,barrier=1,data=ordered)
/dev/sdd1 on /media/windows type fuseblk (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other,blksize=4096)
rpc_pipefs on /var/lib/nfs/rpc_pipefs type rpc_pipefs (rw,relatime)
binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,nosuid,nodev,noexec,relatime)
/dev/sdf1 on /media/TOSHIBA EXT type fuseblk (rw,nosuid,nodev,relatime,user_id=0,group_id=0,default_permissions,allow_other,blksize=4096)
root@nexus:/home/carlos# for i in sde1 sdf1 sdg1 ; do
mount /dev/${i} /mnt
ls -l /mnt
umount /dev/${i}
done
Donc ta première commande ne marche plus.
Les disques: Deux disques externes branchés aux deux portes usb3, une clé branché à une porte usb d’un hub et tous les disques internes.
