Encore:
0
[ 1.752607] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.752609] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.752612] usb usb1: Product: EHCI Host Controller
[ 1.752613] usb usb1: Manufacturer: Linux 3.2.0-4-686-pae ehci_hcd
[ 1.752615] usb usb1: SerialNumber: 0000:00:12.2
[ 1.752721] hub 1-0:1.0: USB hub found
[ 1.752726] hub 1-0:1.0: 6 ports detected
[ 1.752828] ehci_hcd 0000:00:13.2: EHCI Host Controller
[ 1.752837] ehci_hcd 0000:00:13.2: new USB bus registered, assigned bus number 3
[ 1.752845] ehci_hcd 0000:00:13.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[ 1.752866] ehci_hcd 0000:00:13.2: debug port 1
[ 1.752890] ehci_hcd 0000:00:13.2: irq 19, io mem 0xfcfff400
[ 1.760546] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.764053] ehci_hcd 0000:00:13.2: USB 2.0 started, EHCI 1.00
[ 1.764069] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.764072] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.764073] usb usb3: Product: EHCI Host Controller
[ 1.764075] usb usb3: Manufacturer: Linux 3.2.0-4-686-pae ehci_hcd
[ 1.764076] usb usb3: SerialNumber: 0000:00:13.2
[ 1.764153] hub 3-0:1.0: USB hub found
[ 1.764157] hub 3-0:1.0: 6 ports detected
[ 1.764250] pata_atiixp 0000:00:14.1: setting latency timer to 64
[ 1.764518] scsi0 : pata_atiixp
[ 1.765186] scsi1 : pata_atiixp
[ 1.766393] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xff00 irq 14
[ 1.766397] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xff08 irq 15
[ 1.766444] ohci_hcd 0000:00:12.0: OHCI Host Controller
[ 1.766455] ohci_hcd 0000:00:12.0: new USB bus registered, assigned bus number 4
[ 1.766479] ohci_hcd 0000:00:12.0: irq 16, io mem 0xfcffe000
[ 1.815577] xhci_hcd 0000:02:00.0: irq 44 for MSI/MSI-X
[ 1.815581] xhci_hcd 0000:02:00.0: irq 45 for MSI/MSI-X
[ 1.815585] xhci_hcd 0000:02:00.0: irq 46 for MSI/MSI-X
[ 1.815589] xhci_hcd 0000:02:00.0: irq 47 for MSI/MSI-X
[ 1.815592] xhci_hcd 0000:02:00.0: irq 48 for MSI/MSI-X
[ 1.815649] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.815651] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.815652] usb usb2: Product: xHCI Host Controller
[ 1.815653] usb usb2: Manufacturer: Linux 3.2.0-4-686-pae xhci_hcd
[ 1.815655] usb usb2: SerialNumber: 0000:02:00.0
[ 1.815714] xHCI xhci_add_endpoint called for root hub
[ 1.815715] xHCI xhci_check_bandwidth called for root hub
[ 1.815735] hub 2-0:1.0: USB hub found
[ 1.815740] hub 2-0:1.0: 2 ports detected
[ 1.815782] xhci_hcd 0000:02:00.0: xHCI Host Controller
[ 1.815786] xhci_hcd 0000:02:00.0: new USB bus registered, assigned bus number 5
[ 1.815807] usb usb5: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.815809] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.815810] usb usb5: Product: xHCI Host Controller
[ 1.815812] usb usb5: Manufacturer: Linux 3.2.0-4-686-pae xhci_hcd
[ 1.815813] usb usb5: SerialNumber: 0000:02:00.0
[ 1.815866] xHCI xhci_add_endpoint called for root hub
[ 1.815867] xHCI xhci_check_bandwidth called for root hub
[ 1.815885] hub 5-0:1.0: USB hub found
[ 1.815889] hub 5-0:1.0: 2 ports detected
[ 1.824047] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.824050] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.824051] usb usb4: Product: OHCI Host Controller
[ 1.824053] usb usb4: Manufacturer: Linux 3.2.0-4-686-pae ohci_hcd
[ 1.824054] usb usb4: SerialNumber: 0000:00:12.0
[ 1.824139] hub 4-0:1.0: USB hub found
[ 1.824145] hub 4-0:1.0: 3 ports detected
[ 1.824200] ohci_hcd 0000:00:12.1: OHCI Host Controller
[ 1.824206] ohci_hcd 0000:00:12.1: new USB bus registered, assigned bus number 6
[ 1.824218] ohci_hcd 0000:00:12.1: irq 16, io mem 0xfcffd000
[ 1.884043] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.884046] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.884048] usb usb6: Product: OHCI Host Controller
[ 1.884049] usb usb6: Manufacturer: Linux 3.2.0-4-686-pae ohci_hcd
[ 1.884050] usb usb6: SerialNumber: 0000:00:12.1
[ 1.884141] hub 6-0:1.0: USB hub found
[ 1.884147] hub 6-0:1.0: 3 ports detected
[ 1.884215] ohci_hcd 0000:00:13.0: OHCI Host Controller
[ 1.884222] ohci_hcd 0000:00:13.0: new USB bus registered, assigned bus number 7
[ 1.884241] ohci_hcd 0000:00:13.0: irq 18, io mem 0xfcffc000
[ 1.936448] ata2.00: ATA-8: SAMSUNG HD502HJ, 1AJ100E4, max UDMA/133
[ 1.936450] ata2.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 1.936456] ata2.01: ATAPI: TSSTcorp CDDVDW SH-S223F, SB00, max UDMA/100
[ 1.944021] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.944023] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.944025] usb usb7: Product: OHCI Host Controller
[ 1.944026] usb usb7: Manufacturer: Linux 3.2.0-4-686-pae ohci_hcd
[ 1.944027] usb usb7: SerialNumber: 0000:00:13.0
[ 1.944374] hub 7-0:1.0: USB hub found
[ 1.944381] hub 7-0:1.0: 3 ports detected
[ 1.944455] ata2.00: configured for UDMA/100
[ 1.944466] ohci_hcd 0000:00:13.1: OHCI Host Controller
[ 1.944472] ohci_hcd 0000:00:13.1: new USB bus registered, assigned bus number 8
[ 1.944483] ohci_hcd 0000:00:13.1: irq 18, io mem 0xfcffb000
[ 1.960342] ata2.01: configured for UDMA/100
[ 1.960681] scsi 1:0:0:0: Direct-Access ATA SAMSUNG HD502HJ 1AJ1 PQ: 0 ANSI: 5
[ 1.961364] scsi 1:0:1:0: CD-ROM TSSTcorp CDDVDW SH-S223F SB00 PQ: 0 ANSI: 5
[ 2.004042] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.004045] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.004046] usb usb8: Product: OHCI Host Controller
[ 2.004048] usb usb8: Manufacturer: Linux 3.2.0-4-686-pae ohci_hcd
[ 2.004049] usb usb8: SerialNumber: 0000:00:13.1
[ 2.004137] hub 8-0:1.0: USB hub found
[ 2.004144] hub 8-0:1.0: 3 ports detected
[ 2.004200] ohci_hcd 0000:00:14.5: OHCI Host Controller
[ 2.004206] ohci_hcd 0000:00:14.5: new USB bus registered, assigned bus number 9
[ 2.004217] ohci_hcd 0000:00:14.5: irq 18, io mem 0xfcffa000
[ 2.064025] usb usb9: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.064026] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.064028] usb usb9: Product: OHCI Host Controller
[ 2.064029] usb usb9: Manufacturer: Linux 3.2.0-4-686-pae ohci_hcd
[ 2.064030] usb usb9: SerialNumber: 0000:00:14.5
[ 2.064120] hub 9-0:1.0: USB hub found
[ 2.064125] hub 9-0:1.0: 2 ports detected
[ 2.064220] ahci 0000:00:11.0: version 3.0
[ 2.064326] ahci 0000:00:11.0: AHCI 0001.0100 32 slots 4 ports 3 Gbps 0xf impl SATA mode
[ 2.064330] ahci 0000:00:11.0: flags: 64bit ncq sntf ilck pm led clo pmp pio slum part ccc
[ 2.064730] scsi2 : ahci
[ 2.065029] scsi3 : ahci
[ 2.065156] scsi4 : ahci
[ 2.065256] scsi5 : ahci
[ 2.065377] ata3: SATA max UDMA/133 abar m1024@0xfcfffc00 port 0xfcfffd00 irq 22
[ 2.065381] ata4: SATA max UDMA/133 abar m1024@0xfcfffc00 port 0xfcfffd80 irq 22
[ 2.065384] ata5: SATA max UDMA/133 abar m1024@0xfcfffc00 port 0xfcfffe00 irq 22
[ 2.065387] ata6: SATA max UDMA/133 abar m1024@0xfcfffc00 port 0xfcfffe80 irq 22
[ 2.184023] usb 1-2: new high-speed USB device number 3 using ehci_hcd
[ 2.264022] Refined TSC clocksource calibration: 3817.137 MHz.
[ 2.264025] Switching to clocksource tsc
[ 2.384039] ata4: SATA link down (SStatus 0 SControl 300)
[ 2.556020] ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.556041] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.556060] ata5: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.556661] ata3.00: ATA-8: SAMSUNG HD161HJ, GF100-07, max UDMA7
[ 2.556664] ata3.00: 312581808 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 2.557135] ata5.00: ATA-8: ST3500418AS, CC46, max UDMA/133
[ 2.557137] ata5.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 31/32)
[ 2.557303] ata3.00: configured for UDMA/133
[ 2.557387] scsi 2:0:0:0: Direct-Access ATA SAMSUNG HD161HJ GF10 PQ: 0 ANSI: 5
[ 2.558423] ata5.00: configured for UDMA/133
[ 2.558486] scsi 4:0:0:0: Direct-Access ATA ST3500418AS CC46 PQ: 0 ANSI: 5
[ 2.574429] ata6.00: ATA-7: WDC WD3200AAKS-22SBA0, 12.01B01, max UDMA/133
[ 2.574431] ata6.00: 625142448 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 2.575169] ata6.00: configured for UDMA/133
[ 2.575232] scsi 5:0:0:0: Direct-Access ATA WDC WD3200AAKS-2 12.0 PQ: 0 ANSI: 5
[ 2.579804] sd 1:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/465 GiB)
[ 2.583057] sr0: scsi3-mmc drive: 40x/40x writer dvd-ram cd/rw xa/form2 cdda tray
[ 2.583059] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 2.583097] sd 1:0:0:0: [sda] Write Protect is off
[ 2.583100] sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.583116] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.583160] sr 1:0:1:0: Attached scsi CD-ROM sr0
[ 2.583420] sd 2:0:0:0: [sdb] 312581808 512-byte logical blocks: (160 GB/149 GiB)
[ 2.583454] sd 4:0:0:0: [sdc] 976773168 512-byte logical blocks: (500 GB/465 GiB)
[ 2.583465] sd 2:0:0:0: [sdb] Write Protect is off
[ 2.583467] sd 2:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 2.583483] sd 2:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.583489] sd 4:0:0:0: [sdc] Write Protect is off
[ 2.583491] sd 4:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[ 2.583498] sd 5:0:0:0: [sdd] 625142448 512-byte logical blocks: (320 GB/298 GiB)
[ 2.583507] sd 4:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.583539] sd 5:0:0:0: [sdd] Write Protect is off
[ 2.583542] sd 5:0:0:0: [sdd] Mode Sense: 00 3a 00 00
[ 2.583559] sd 5:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.591501] sda: sda1 sda2 sda3
[ 2.591728] sd 1:0:0:0: [sda] Attached SCSI disk
[ 2.597199] sdb: sdb1 sdb2 sdb3 sdb4
[ 2.597523] sd 1:0:0:0: Attached scsi generic sg0 type 0
[ 2.597563] sr 1:0:1:0: Attached scsi generic sg1 type 5
[ 2.597584] sd 2:0:0:0: [sdb] Attached SCSI disk
[ 2.597600] sd 2:0:0:0: Attached scsi generic sg2 type 0
[ 2.597632] sd 4:0:0:0: Attached scsi generic sg3 type 0
[ 2.597664] sd 5:0:0:0: Attached scsi generic sg4 type 0
[ 2.604240] sdd: sdd1 sdd2 < sdd5 >
[ 2.604297] sdc: sdc1 sdc2 sdc3
[ 2.604496] sd 5:0:0:0: [sdd] Attached SCSI disk
[ 2.604603] sd 4:0:0:0: [sdc] Attached SCSI disk
[ 3.444415] PM: Starting manual resume from disk
[ 3.444417] PM: Hibernation image partition 8:17 present
[ 3.444418] PM: Looking for hibernation image.
[ 3.444610] PM: Image not found (code -22)
