Clone(1) en périls (dcfldd/suite_tests)
Saluts,
Tests, avec " dcfldd " sur le clone(1) sda. Les commentaires seront les biens venus … si besoins …merci. :wink:
Surprise ce matin, connexion réseau HS … sur le clone(1).
Vérifications du dit réseau, connectiques, et tralala. Rien.
Redémarrage en live cd, Ok … la preuve … :033
Prochaines étapes :
1°)re-boot sur le clone(1) sda.
2°)si … kénini, re-boot sur sdb (la source), ce point logiquement ne posera aucun souci … 8)
[code] debian:~# cd /media/USB16Gio/clone-en-peril
debian:/media/USB16Gio/clone-en-peril# fdisk -l >> info-clone.txt
debian:/media/USB16Gio/clone-en-peril# ifconfig >> info-clone.txt
debian:/media/USB16Gio/clone-en-peril# lspci >> info-clone.txt
debian:/media/USB16Gio/clone-en-peril# lsusb >> info-clone.txt
debian:/media/USB16Gio/clone-en-peril# dmidecode >> info-clone.txt
debian:/media/USB16Gio/clone-en-peril# dmesg /var/log/messages >> info-clone.txt
debian:/media/USB16Gio/clone-en-peril# dmesg /var/log/syslog >> info-clone.txt
debian:/media/USB16Gio/clone-en-peril# dmesg /var/log/xorg.0.log >> info-clone.txt
debian:/media/USB16Gio/clone-en-peril# df -h >> info-clone.txt
debian:/media/USB16Gio/clone-en-peril# ps aux >> info-clone.txt
debian:/media/USB16Gio/clone-en-peril# cat /etc/network/interfaces
auto lo
iface lo inet loopback
debian:/media/USB16Gio/clone-en-peril# cat /etc/resolv.conf
BEGIN INFO
Modified_by: NetworkManager
Process: /usr/bin/NetworkManager
Process_id: 4149
END INFO
domain home
search home
nameserver 192.168.1.1
debian:/media/USB16Gio/clone-en-peril# ifconfig -a
eth0 Link encap:Ethernet HWaddr 00:16:17:ba:37:38
inet addr:192.168.1.12 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::216:17ff:feba:3738/64 Scope:Link
RX packets:1823 errors:0 dropped:0 overruns:0 frame:0
TX packets:1809 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:1165149 (1.1 MiB) TX bytes:205628 (200.8 KiB)
Interrupt:21 Base address:0xa000
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
RX packets:40 errors:0 dropped:0 overruns:0 frame:0
TX packets:40 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:2000 (1.9 KiB) TX bytes:2000 (1.9 KiB)
wlan0 Link encap:Ethernet HWaddr 00:16:b6:9b:86:64
BROADCAST MULTICAST MTU:1500 Metric:1
wmaster0 Link encap:UNSPEC HWaddr 00-16-B6-9B-86-64-00-00-00-00-00-00-00-00-00-00
debian:/media/USB16Gio/clone-en-peril# route -n
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
192.168.1.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
0.0.0.0 192.168.1.1 0.0.0.0 UG 0 0 0 eth0
debian:/media/USB16Gio/clone-en-peril# cat /var/log/bootstrap.log >> info-clone.txt
Piste … ici " rm 0bits " . Comme un " loreleil " et pas le contraire, j’ai effectuer cette Opération a chaud, :mrgreen: là, il a pas du aimer … le clone(1) … :laughing:
ps : rectification (fran.b) " rm /0bits "
Je vous en serre cinq … :wink:
Re,
Re-boot sur sda (clone(1)) … kénini, pas de connexions. 8)
Clés USB non reconnus, pas dans la merde pour enregistrer un rapports.
Voir et enregistrer les logs, avant re-boot sur sdb (source).
Essai sur cdrom … :115
edit : pas le temps, alors source, puis fsck sur clone(1) démonter.
re-boot sur la source, ok, connexions ok, clés usb ok.(cool ! azerty … Ouf … l’était temps)
4°) :
  • Clone(2).
Principe i [/i]:
dd (interne) source(1) de 1To … « clonage » ( et réduction vers ) dd interne(3) de 160 Gio .
bonjour,
il manque un truc dans ta signature, genre « une phrase c’est sujet, verbe, complément ».
personnellement je ne comprends rien a ton charabia, je ne sais pas de quoi tu parle, et j’ai pas envie de faire d’efforts de traduction. tu pourrais être plus clair stp?
merci.
Saluts,
Mon clone(1) est à nouveau fonctionnel ! :033
pc-1-loreleil@Debian-pc-1:~$ mount
/dev/sdb5 on / type ext3 (rw,errors=remount-ro)
tmpfs on /lib/init/rw type tmpfs (rw,nosuid,mode=0755)
proc on /proc type proc (rw,noexec,nosuid,nodev)
sysfs on /sys type sysfs (rw,noexec,nosuid,nodev)
udev on /dev type tmpfs (rw,mode=0755)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
devpts on /dev/pts type devpts (rw,noexec,nosuid,gid=5,mode=620)
/dev/sdb10 on /home type ext3 (rw)
/dev/sdb9 on /tmp type ext3 (rw)
/dev/sdb6 on /usr type ext3 (rw)
/dev/sdb7 on /var type ext3 (rw)
fusectl on /sys/fs/fuse/connections type fusectl (rw)
/dev/sdc5 on /media/USB16Gio type ext3 (rw,nosuid,nodev,uhelper=hal)
/dev/sr0 on /media/cdrom0 type iso9660 (rw,noexec,nosuid,nodev,user=pc-1-loreleil)
root@Debian-pc-1:/home/pc-1-loreleil# fdisk -l
Disk /dev/sda: 1000.2 GB, 1000204886016 bytes
255 heads, 63 sectors/track, 121601 cylinders
Disk identifier: 0x00025ee5
   Device Boot      Start         End      Blocks   Id  System
/dev/sda2               1       51316   412192769    5  Extended
/dev/sda5   *           1         171     1372160   83  Linux
/dev/sda6             172        1137     7756800   83  Linux
/dev/sda7            1137        1502     2928640   83  Linux
/dev/sda8            1502        1752     2004992   82  Linux swap / Solaris
/dev/sda9            1752        1800      389120   83  Linux
/dev/sda10           1800       51316   397735936   83  Linux
Disk /dev/sdb: 1000.2 GB, 1000204886016 bytes
/dev/sdb2               1       51316   412192769    5  Extended
/dev/sdb5   *           1         171     1372160   83  Linux
/dev/sdb6             172        1137     7756800   83  Linux
/dev/sdb7            1137        1502     2928640   83  Linux
/dev/sdb8            1502        1752     2004992   82  Linux swap / Solaris
/dev/sdb9            1752        1800      389120   83  Linux
/dev/sdb10           1800       51316   397735936   83  Linux
root@Debian-pc-1:/home/pc-1-loreleil# df -h
Sys. de fichiers    Taille  Uti. Disp. Uti% Monté sur
/dev/sdb5             1,3G  348M  884M  29% /
tmpfs                 502M     0  502M   0% /lib/init/rw
udev                  497M  252K  496M   1% /dev
tmpfs                 502M     0  502M   0% /dev/shm
/dev/sdb10            374G  3,0G  352G   1% /home
/dev/sdb9             368M   11M  339M   3% /tmp
/dev/sdb6             7,3G  4,3G  2,7G  63% /usr
/dev/sdb7             2,8G  1,3G  1,4G  49% /var
/dev/sdc5              15G  3,7G   11G  27% /media/USB16Gio
/dev/sr0              376M  376M     0 100% /media/cdrom0
root@Debian-pc-1:/home/pc-1-loreleil#  blkid
/dev/sdb5: UUID="ee1fa486-1f91-4dac-8a91-9b11173a0a69" TYPE="ext3" SEC_TYPE="ext2"
/dev/sdb6: UUID="21b1aa02-0531-48e5-9606-65fdbfaf319d" TYPE="ext3" SEC_TYPE="ext2"
/dev/sdb7: UUID="d817de8b-8579-4b96-99be-4519e6439a9b" TYPE="ext3" SEC_TYPE="ext2"
/dev/sdb8: UUID="445ea6ca-b49d-408c-80dc-81cba7b31fc6" TYPE="swap"
/dev/sdb9: UUID="4032cefa-d784-417c-8bd3-b99a56396436" TYPE="ext3"
/dev/sdb10: UUID="a6e601a2-0925-4a53-8273-35d399c852a4" TYPE="ext3" SEC_TYPE="ext2"
/dev/sda5: UUID="ee1fa486-1f91-4dac-8a91-9b11173a0a69" TYPE="ext3"
/dev/sda6: UUID="21b1aa02-0531-48e5-9606-65fdbfaf319d" TYPE="ext3" SEC_TYPE="ext2"
/dev/sda7: UUID="d817de8b-8579-4b96-99be-4519e6439a9b" TYPE="ext3" SEC_TYPE="ext2"
/dev/sda8: UUID="445ea6ca-b49d-408c-80dc-81cba7b31fc6" TYPE="swap"
/dev/sda9: UUID="4032cefa-d784-417c-8bd3-b99a56396436" TYPE="ext3" SEC_TYPE="ext2"
/dev/sda10: UUID="a6e601a2-0925-4a53-8273-35d399c852a4" TYPE="ext3" SEC_TYPE="ext2"
/dev/sdc5: LABEL="USB16Gio" UUID="3b7e37e4-d474-4dfa-a4f5-6b9b7d15e109" TYPE="ext3"
root@Debian-pc-1:/home/pc-1-loreleil# cat /etc/fstab
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
proc            /proc           proc    defaults        0       0
# / was on /dev/sda5 during installation
UUID=ee1fa486-1f91-4dac-8a91-9b11173a0a69 /               ext3    errors=remount-ro 0       1
# /home was on /dev/sda10 during installation
UUID=a6e601a2-0925-4a53-8273-35d399c852a4 /home           ext3    defaults        0       2
# /tmp was on /dev/sda9 during installation
UUID=4032cefa-d784-417c-8bd3-b99a56396436 /tmp            ext3    defaults        0       2
# /usr was on /dev/sda6 during installation
UUID=21b1aa02-0531-48e5-9606-65fdbfaf319d /usr            ext3    defaults        0       2
# /var was on /dev/sda7 during installation
UUID=d817de8b-8579-4b96-99be-4519e6439a9b /var            ext3    defaults        0       2
# swap was on /dev/sda8 during installation
UUID=445ea6ca-b49d-408c-80dc-81cba7b31fc6 none            swap    sw              0       0
/dev/scd0       /media/cdrom0   udf,iso9660 user,noauto     0       0
/dev/scd1       /media/cdrom1   udf,iso9660 user,noauto     0       0
#/home/vsftpd/dossier1           /media/donnees/dossier1         none  bind,defaults,auto     0    0
#/home/vsftpd/dossier2          /media/donnees/dossier2         none  bind,defaults,auto     0    0
root@Debian-pc-1:/home/pc-1-loreleil# cat /etc/mtab
/dev/sdb5 / ext3 rw,errors=remount-ro 0 0
tmpfs /lib/init/rw tmpfs rw,nosuid,mode=0755 0 0
proc /proc proc rw,noexec,nosuid,nodev 0 0
sysfs /sys sysfs rw,noexec,nosuid,nodev 0 0
udev /dev tmpfs rw,mode=0755 0 0
tmpfs /dev/shm tmpfs rw,nosuid,nodev 0 0
devpts /dev/pts devpts rw,noexec,nosuid,gid=5,mode=620 0 0
/dev/sdb10 /home ext3 rw 0 0
/dev/sdb9 /tmp ext3 rw 0 0
/dev/sdb6 /usr ext3 rw 0 0
/dev/sdb7 /var ext3 rw 0 0
fusectl /sys/fs/fuse/connections fusectl rw 0 0
/dev/sdc5 /media/USB16Gio ext3 rw,nosuid,nodev,uhelper=hal 0 0
/dev/sr0 /media/cdrom0 iso9660 rw,noexec,nosuid,nodev,user=pc-1-loreleil 0 0
[code]pc-1-loreleil@Debian-pc-1:~$ mount
/dev/sdb5: UUID=« ee1fa486-1f91-4dac-8a91-9b11173a0a69 » TYPE=« ext3 » SEC_TYPE=« ext2 »
/dev/sda5: UUID=« ee1fa486-1f91-4dac-8a91-9b11173a0a69 » TYPE=« ext3 »
pc-1-loreleil@Debian-pc-1:~$ uptime 11:29:46 up 50 min, 3 users, load average: 0.00, 0.05, 0.09 pc-1-loreleil@Debian-pc-1:~$
« dcfldd » … :023
