Bonjours.
Je voudrai me mettre a Qt sous code block comme ide.
problème l’ide ne troue pas le dossier qt voir l’ image jointe .
code block a été compiler a la main, c’est pas celui des dépot
J’ai installer qt des dépot:
$ dpkg -l |grep qt
ii libdbusmenu-qt2 0.9.0-1 amd64 Qt implementation of the DBusMenu protocol
ii libindicate-qt1 0.2.5.91-5 amd64 Qt bindings for libindicate
ii libntrack-qt4-1 016-1.1 amd64 Qt 4 API for ntrack
ii libpolkit-qt-1-1 0.103.0-1 amd64 PolicyKit-qt-1 library
ii libqt4-dbus:amd64 4:4.8.2+dfsg-6 amd64 Qt 4 D-Bus module
ii libqt4-declarative:amd64 4:4.8.2+dfsg-6 amd64 Qt 4 Declarative module
ii libqt4-declarative-gestures:amd64 4:4.8.2+dfsg-6 amd64 Qt 4 gestures QML plugin
ii libqt4-declarative-particles:amd64 4:4.8.2+dfsg-6 amd64 Qt 4 particles QML plugin
ii libqt4-designer:amd64 4:4.8.2+dfsg-6 amd64 Qt 4 designer module
ii libqt4-dev 4:4.8.2+dfsg-6 amd64 Qt 4 development files
ii libqt4-dev-bin 4:4.8.2+dfsg-6 amd64 Qt 4 development programs
ii libqt4-help:amd64 4:4.8.2+dfsg-6 amd64 Qt 4 help module
ii libqt4-network:amd64 4:4.8.2+dfsg-6 amd64 Qt 4 network module
ii libqt4-opengl:amd64 4:4.8.2+dfsg-6 amd64 Qt 4 OpenGL module
ii libqt4-opengl-dev 4:4.8.2+dfsg-6 amd64 Qt 4 OpenGL library development files
ii libqt4-qt3support:amd64 4:4.8.2+dfsg-6 amd64 Qt 3 compatibility library for Qt 4
ii libqt4-script:amd64 4:4.8.2+dfsg-6 amd64 Qt 4 script module
ii libqt4-scripttools:amd64 4:4.8.2+dfsg-6 amd64 Qt 4 script tools module
ii libqt4-sql:amd64 4:4.8.2+dfsg-6 amd64 Qt 4 SQL module
ii libqt4-sql-mysql:amd64 4:4.8.2+dfsg-6 amd64 Qt 4 MySQL database driver
ii libqt4-sql-sqlite:amd64 4:4.8.2+dfsg-6 amd64 Qt 4 SQLite 3 database driver
ii libqt4-svg:amd64 4:4.8.2+dfsg-6 amd64 Qt 4 SVG module
ii libqt4-test:amd64 4:4.8.2+dfsg-6 amd64 Qt 4 test module
ii libqt4-xml:amd64 4:4.8.2+dfsg-6 amd64 Qt 4 XML module
ii libqt4-xmlpatterns:amd64 4:4.8.2+dfsg-6 amd64 Qt 4 XML patterns module
ii libqtcore4:amd64 4:4.8.2+dfsg-6 amd64 Qt 4 core module
ii libqtgui4:amd64 4:4.8.2+dfsg-6 amd64 Qt 4 GUI module
ii libqtwebkit-dev 2.2.1-5 amd64 Web content engine library for Qt - development files
ii libqtwebkit4:amd64 2.2.1-5 amd64 Web content engine library for Qt
ii qt-sdk 2 all Complete Qt Software Development Kit
ii qt4-demos 4:4.8.2+dfsg-6 amd64 Qt 4 examples and demos
ii qt4-designer 4:4.8.2+dfsg-6 amd64 graphical designer for Qt 4 applications
ii qt4-dev-tools 4:4.8.2+dfsg-6 amd64 Qt 4 development tools
ii qt4-doc 4:4.8.2+dfsg-6 all Qt 4 API documentation
ii qt4-doc-html 4:4.8.2+dfsg-6 all Qt 4 API documentation (HTML format)
ii qt4-linguist-tools 4:4.8.2+dfsg-6 amd64 Qt 4 Linguist tools
ii qt4-qmake 4:4.8.2+dfsg-6 amd64 Qt 4 qmake Makefile generator tool
ii qt4-qmlviewer 4:4.8.2+dfsg-6 amd64 Qt 4 QML viewer
ii qtcreator 2.5.0-2 amd64 lightweight integrated development environment (IDE) for Qt
ii qtcreator-doc 2.5.0-2 all documentation for Qt Creator IDE
normalment qt-sdk devrai suffire mai bon …?
j’ai chercher sur le net , pas mal de lien parle de ce problème. surtout sous windows … pour les tuto il ne son plus maintenu (pour ceux que j’ai croiser)
