voici mon dmesg, je ne vois rien en ce qui concerne hdd
mes 2 lecteurs sont apparemment reconnus
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.25-2-686 (Debian 2.6.25-7) (maks@debian.org) (gcc version 4.1.3 20080623 (prerelease) (Debian 4.1.2-23)) #1 SMP Fri Jul 18 17:46:56 UTC 2008
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 0000000017ffc000 (usable)
[ 0.000000] BIOS-e820: 0000000017ffc000 - 0000000017fff000 (ACPI data)
[ 0.000000] BIOS-e820: 0000000017fff000 - 0000000018000000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved)
[ 0.000000] 0MB HIGHMEM available.
[ 0.000000] 383MB LOWMEM available.
[ 0.000000] Scan SMP from c0000000 for 1024 bytes.
[ 0.000000] Scan SMP from c009fc00 for 1024 bytes.
[ 0.000000] Scan SMP from c00f0000 for 65536 bytes.
[ 0.000000] Entering add_active_range(0, 0, 98300) 0 entries of 256 used
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0 -> 4096
[ 0.000000] Normal 4096 -> 98300
[ 0.000000] HighMem 98300 -> 98300
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[1] active PFN ranges
[ 0.000000] 0: 0 -> 98300
[ 0.000000] On node 0 totalpages: 98300
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 4064 pages, LIFO batch:0
[ 0.000000] Normal zone: 735 pages used for memmap
[ 0.000000] Normal zone: 93469 pages, LIFO batch:31
[ 0.000000] HighMem zone: 0 pages used for memmap
[ 0.000000] Movable zone: 0 pages used for memmap
[ 0.000000] DMI 2.3 present.
[ 0.000000] ACPI: RSDP 000F5690, 0014 (r0 ASUS )
[ 0.000000] ACPI: RSDT 17FFC000, 0030 (r1 ASUS P4S533-X 42302E31 MSFT 31313031)
[ 0.000000] ACPI: FACP 17FFC0C0, 0074 (r1 ASUS P4S533-X 42302E31 MSFT 31313031)
[ 0.000000] ACPI: DSDT 17FFC134, 287C (r1 ASUS P4S533-X 1000 MSFT 100000B)
[ 0.000000] ACPI: FACS 17FFF000, 0040
[ 0.000000] ACPI: BOOT 17FFC030, 0028 (r1 ASUS P4S533-X 42302E31 MSFT 31313031)
[ 0.000000] ACPI: APIC 17FFC058, 005A (r1 ASUS P4S533-X 42302E31 MSFT 31313031)
[ 0.000000] ACPI: PM-Timer IO Port: 0xe408
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[ 0.000000] Processor #0 15:0 APIC version 20
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 2, version 128, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl edge)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 20 low level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] Allocating PCI resources starting at 20000000 (gap: 18000000:e6c00000)
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000f0000
[ 0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 97533
[ 0.000000] Kernel command line: root=/dev/sda3 ro quiet vga=792
[ 0.000000] mapped APIC to ffffb000 (fee00000)
[ 0.000000] mapped IOAPIC to ffffa000 (fec00000)
[ 0.000000] Enabling fast FPU save and restore… done.
[ 0.000000] Enabling unmasked SIMD FPU exception support… done.
[ 0.000000] Initializing CPU#0
[ 0.000000] PID hash table entries: 2048 (order: 11, 8192 bytes)
[ 0.000000] Detected 1680.518 MHz processor.
[ 0.000044] Console: colour dummy device 80x25
[ 0.000050] console [tty0] enabled
[ 0.000632] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.001270] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.004000] Memory: 380232k/393200k available (1753k kernel code, 12364k reserved, 728k data, 252k init, 0k highmem)
[ 0.004000] virtual kernel memory layout:
[ 0.004000] fixmap : 0xfff4c000 - 0xfffff000 ( 716 kB)
[ 0.004000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.004000] vmalloc : 0xd8800000 - 0xff7fe000 ( 623 MB)
[ 0.004000] lowmem : 0xc0000000 - 0xd7ffc000 ( 383 MB)
[ 0.004000] .init : 0xc0375000 - 0xc03b4000 ( 252 kB)
[ 0.004000] .data : 0xc02b649a - 0xc036c640 ( 728 kB)
[ 0.004000] .text : 0xc0100000 - 0xc02b649a (1753 kB)
[ 0.004000] Checking if this processor honours the WP bit even in supervisor mode…Ok.
[ 0.004000] CPA: page pool initialized 1 of 1 pages preallocated
[ 0.084009] Calibrating delay using timer specific routine… 3365.02 BogoMIPS (lpj=6730046)
[ 0.084084] Security Framework initialized
[ 0.084092] SELinux: Disabled at boot.
[ 0.084098] Capability LSM initialized
[ 0.084125] Mount-cache hash table entries: 512
[ 0.084390] Initializing cgroup subsys ns
[ 0.084399] Initializing cgroup subsys cpuacct
[ 0.084436] CPU: Trace cache: 12K uops, L1 D cache: 8K
[ 0.084441] CPU: L2 cache: 256K
[ 0.084445] CPU: Hyper-Threading is disabled
[ 0.084451] Intel machine check architecture supported.
[ 0.084460] Intel machine check reporting enabled on CPU#0.
[ 0.084465] CPU0: Intel P4/Xeon Extended MCE MSRs (12) available
[ 0.084471] CPU0: Thermal monitoring enabled
[ 0.084484] Compat vDSO mapped to ffffe000.
[ 0.084499] Checking ‘hlt’ instruction… OK.
[ 0.100497] SMP alternatives: switching to UP code
[ 0.103711] Freeing SMP alternatives: 16k freed
[ 0.103721] ACPI: Core revision 20070126
[ 0.110651] CPU0: Intel® Pentium® 4 CPU 1400MHz stepping 0a
[ 0.110710] Total of 1 processors activated (3365.02 BogoMIPS).
[ 0.110813] ENABLING IO-APIC IRQs
[ 0.111009] …TIMER: vector=0x31 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.152009] Brought up 1 CPUs
[ 0.152009] CPU0 attaching sched-domain:
[ 0.152009] domain 0: span 01
[ 0.152009] groups: 01
[ 0.152009] net_namespace: 548 bytes
[ 0.152009] Booting paravirtualized kernel on bare hardware
[ 0.152009] NET: Registered protocol family 16
[ 0.152009] ACPI: bus type pci registered
[ 0.152009] PCI: PCI BIOS revision 2.10 entry at 0xf1060, last bus=1
[ 0.152009] PCI: Using configuration type 1
[ 0.152009] Setting up standard PCI resources
[ 0.157336] ACPI: EC: Look up EC in DSDT
[ 0.167568] ACPI: Interpreter enabled
[ 0.167576] ACPI: (supports S0 S1 S3 S4 S5)
[ 0.167604] ACPI: Using IOAPIC for interrupt routing
[ 0.188621] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.188905] pci 0000:00:02.0: Enabling SiS 96x SMBus
[ 0.189615] ACPI: PCI Interrupt Routing Table [_SB_.PCI0.PRT]
[ 0.190046] ACPI: PCI Interrupt Routing Table [_SB.PCI0.PCI1._PRT]
[ 0.263809] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[ 0.263976] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.264165] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 *10 11 12 14 15)
[ 0.264340] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 *5 6 7 10 11 12 14 15)
[ 0.264513] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 10 11 12 14 15) *9
[ 0.264685] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 11 12 14 15) *9
[ 0.264834] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.265006] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 10 11 12 14 15) *9
[ 0.265342] Linux Plug and Play Support v0.97 © Adam Belay
[ 0.265409] pnp: PnP ACPI init
[ 0.265431] ACPI: bus type pnp registered
[ 0.274976] pnp: PnP ACPI: found 17 devices
[ 0.274983] ACPI: ACPI bus type pnp unregistered
[ 0.274991] PnPBIOS: Disabled by ACPI PNP
[ 0.275490] PCI: Using ACPI for IRQ routing
[ 0.275498] PCI: If a device doesn’t work, try “pci=routeirq”. If it helps, post a report
[ 0.282220] ACPI: RTC can wake from S4
[ 0.282283] system 00:00: iomem range 0x0-0x9ffff could not be reserved
[ 0.282289] system 00:00: iomem range 0xf0000-0xfffff could not be reserved
[ 0.282294] system 00:00: iomem range 0x100000-0x17ffffff could not be reserved
[ 0.282299] system 00:00: iomem range 0xfec00000-0xfec000ff could not be reserved
[ 0.282304] system 00:00: iomem range 0xfee00000-0xfee00fff could not be reserved
[ 0.282317] system 00:02: ioport range 0xe400-0xe47f has been reserved
[ 0.282322] system 00:02: ioport range 0xe480-0xe4ff has been reserved
[ 0.282327] system 00:02: ioport range 0xe600-0xe61f has been reserved
[ 0.282331] system 00:02: ioport range 0x480-0x48f has been reserved
[ 0.282338] system 00:02: iomem range 0xffee0000-0xffefffff has been reserved
[ 0.282350] system 00:03: iomem range 0xfffe0000-0xffffffff could not be reserved
[ 0.282361] system 00:04: ioport range 0x4d0-0x4d1 has been reserved
[ 0.282383] system 00:10: ioport range 0x3f0-0x3f1 has been reserved
[ 0.282387] system 00:10: ioport range 0x290-0x297 has been reserved
[ 0.313495] PCI: Bridge: 0000:00:01.0
[ 0.313501] IO window: d000-dfff
[ 0.313509] MEM window: 0xd7000000-0xd7ffffff
[ 0.313516] PREFETCH window: 0x00000000e0000000-0x00000000febfffff
[ 0.313537] PCI: Setting latency timer of device 0000:00:01.0 to 64
[ 0.313585] NET: Registered protocol family 2
[ 0.313794] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.314172] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.314317] TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.314471] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.314477] TCP reno registered
[ 0.314979] checking if image is initramfs… it is
[ 0.816078] Switched to high resolution mode on CPU 0
[ 1.184356] Freeing initrd memory: 5723k freed
[ 1.184690] Simple Boot Flag at 0x3a set to 0x1
[ 1.185617] audit: initializing netlink socket (disabled)
[ 1.185645] type=2000 audit(1225824952.184:1): initialized
[ 1.185852] Total HugeTLB memory allocated, 0
[ 1.185984] VFS: Disk quotas dquot_6.5.1
[ 1.186029] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.186189] io scheduler noop registered
[ 1.186194] io scheduler anticipatory registered
[ 1.186197] io scheduler deadline registered
[ 1.186211] io scheduler cfq registered (default)
[ 1.186275] pci 0000:01:00.0: Boot video device
[ 1.186998] vesafb: framebuffer at 0xf0000000, mapped to 0xd8880000, using 4608k, total 131072k
[ 1.187004] vesafb: mode is 1024x768x24, linelength=3072, pages=55
[ 1.187008] vesafb: protected mode interface info at c000:545f
[ 1.187012] vesafb: pmi: set display start = c00c54f3, set palette = c00c553f
[ 1.187015] vesafb: pmi: ports = d810 d816 d854 d838 d83c d85c d800 d804 d8b0 d8b2 d8b4
[ 1.187027] vesafb: scrolling: redraw
[ 1.187031] vesafb: Truecolor: size=0:8:8:8, shift=0:16:8:0
[ 1.238365] Console: switching to colour frame buffer device 128x48
[ 1.289389] fb0: VESA VGA frame buffer device
[ 1.289592] isapnp: Scanning for PnP cards…
[ 1.600137] isapnp: No Plug & Play device found
[ 1.605250] Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
[ 1.605446] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.605631] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 1.606318] 00:0b: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.606601] 00:0c: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 1.608423] brd: module loaded
[ 1.608621] PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 1.609036] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.609046] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.609361] mice: PS/2 mouse device common for all mice
[ 1.609494] cpuidle: using governor ladder
[ 1.609498] cpuidle: using governor menu
[ 1.610237] TCP cubic registered
[ 1.610253] NET: Registered protocol family 1
[ 1.610270] NET: Registered protocol family 17
[ 1.610283] Using IPI No-Shortcut mode
[ 1.610599] registered taskstats version 1
[ 1.611258] Freeing unused kernel memory: 252k freed
[ 1.633571] input: AT Translated Set 2 keyboard as /class/input/input0
[ 1.870749] ACPI: Invalid PBLK length [5]
[ 1.871335] ACPI: ACPI0007:00 is registered as cooling_device0
[ 2.572199] No dock devices found.
[ 2.654534] SCSI subsystem initialized
[ 2.794618] libata version 3.00 loaded.
[ 2.840748] pata_sis 0000:00:02.5: version 0.5.2
[ 2.840799] ACPI: PCI Interrupt 0000:00:02.5[A] -> GSI 16 (level, low) -> IRQ 16
[ 2.859382] scsi0 : pata_sis
[ 2.876241] scsi1 : pata_sis
[ 2.877311] ata1: PATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xa400 irq 14
[ 2.877316] ata2: PATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0xa408 irq 15
[ 3.048656] ata1.00: ATA-7: Maxtor 6Y120P0, YAR41BW0, max UDMA/133
[ 3.048665] ata1.00: 240121728 sectors, multi 16: LBA
[ 3.048794] ata1.01: ATA-7: SAMSUNG SP0802N, TK100-24, max UDMA/100
[ 3.048798] ata1.01: 156368016 sectors, multi 16: LBA48
[ 3.064654] ata1.00: configured for UDMA/133
[ 3.072586] ata1.01: configured for UDMA/100
[ 3.082215] usbcore: registered new interface driver usbfs
[ 3.082269] usbcore: registered new interface driver hub
[ 3.090226] usbcore: registered new device driver usb
[ 3.090373] sis900.c: v1.08.10 Apr. 2 2006
[ 3.101988] ohci_hcd: 2006 August 04 USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 3.273175] Floppy drive(s): fd0 is 1.44M
[ 3.292003] FDC 0 is a post-1991 82077
[ 3.547913] ata2.00: ATAPI: SAMSUNG DVD-ROM SD-616F, FS05, max UDMA/33
[ 3.547913] ata2.01: ATAPI: SAMSUNG CD-R/RW SW-216B BS05 20010727, BS05, max MWDMA2
[ 3.711238] ata2.00: configured for UDMA/33
[ 3.882509] ata2.01: configured for PIO4
[ 3.882509] scsi 0:0:0:0: Direct-Access ATA Maxtor 6Y120P0 YAR4 PQ: 0 ANSI: 5
[ 3.882509] scsi 0:0:1:0: Direct-Access ATA SAMSUNG SP0802N TK10 PQ: 0 ANSI: 5
[ 3.882509] scsi 1:0:0:0: CD-ROM SAMSUNG DVD-ROM SD-616F FS05 PQ: 0 ANSI: 5
[ 3.882509] scsi 1:0:1:0: CD-ROM SAMSUNG CD-R/RW SW-216B BS05 PQ: 0 ANSI: 5
[ 3.882509] ACPI: PCI Interrupt 0000:00:03.0[A] -> GSI 20 (level, low) -> IRQ 20
[ 3.882509] ohci_hcd 0000:00:03.0: OHCI Host Controller
[ 3.882509] ohci_hcd 0000:00:03.0: new USB bus registered, assigned bus number 1
[ 3.882509] ohci_hcd 0000:00:03.0: irq 20, io mem 0xd6800000
[ 3.895511] Uniform Multi-Platform E-IDE driver
[ 3.895520] ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
[ 3.938823] usb usb1: configuration #1 chosen from 1 choice
[ 3.938823] hub 1-0:1.0: USB hub found
[ 3.938823] hub 1-0:1.0: 3 ports detected
[ 4.041232] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
[ 4.041232] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.041232] usb usb1: Product: OHCI Host Controller
[ 4.041232] usb usb1: Manufacturer: Linux 2.6.25-2-686 ohci_hcd
[ 4.041232] usb usb1: SerialNumber: 0000:00:03.0
[ 4.041232] ACPI: PCI Interrupt 0000:00:03.1[B] -> GSI 21 (level, low) -> IRQ 21
[ 4.041232] ohci_hcd 0000:00:03.1: OHCI Host Controller
[ 4.041232] ohci_hcd 0000:00:03.1: new USB bus registered, assigned bus number 2
[ 4.041232] ohci_hcd 0000:00:03.1: irq 21, io mem 0xd6000000
[ 4.095867] usb usb2: configuration #1 chosen from 1 choice
[ 4.095867] hub 2-0:1.0: USB hub found
[ 4.095867] hub 2-0:1.0: 3 ports detected
[ 4.196540] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 4.196540] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.196540] usb usb2: Product: OHCI Host Controller
[ 4.196540] usb usb2: Manufacturer: Linux 2.6.25-2-686 ohci_hcd
[ 4.196540] usb usb2: SerialNumber: 0000:00:03.1
[ 4.196540] ACPI: PCI Interrupt 0000:00:03.3[D] -> GSI 23 (level, low) -> IRQ 23
[ 4.196540] ehci_hcd 0000:00:03.3: EHCI Host Controller
[ 4.196540] ehci_hcd 0000:00:03.3: new USB bus registered, assigned bus number 3
[ 4.196540] PCI: cache line size of 128 is not supported by device 0000:00:03.3
[ 4.196540] ehci_hcd 0000:00:03.3: irq 23, io mem 0xd5800000
[ 4.204634] ehci_hcd 0000:00:03.3: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
[ 4.204864] usb usb3: configuration #1 chosen from 1 choice
[ 4.204908] hub 3-0:1.0: USB hub found
[ 4.204929] hub 3-0:1.0: 6 ports detected
[ 4.308765] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 4.308773] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.308778] usb usb3: Product: EHCI Host Controller
[ 4.308781] usb usb3: Manufacturer: Linux 2.6.25-2-686 ehci_hcd
[ 4.308785] usb usb3: SerialNumber: 0000:00:03.3
[ 4.310337] ACPI: PCI Interrupt 0000:00:04.0[A] -> GSI 19 (level, low) -> IRQ 19
[ 4.311780] 0000:00:04.0: Realtek RTL8201 PHY transceiver found at address 1.
[ 4.323444] 0000:00:04.0: Using transceiver found at address 1 as default
[ 4.324646] eth0: SiS 900 PCI Fast Ethernet at 0x8800, IRQ 19, 00:0c:6e:0c:e9:b4
[ 4.399830] Driver ‘sd’ needs updating - please use bus_type methods
[ 4.400008] sd 0:0:0:0: [sda] 240121728 512-byte hardware sectors (122942 MB)
[ 4.400037] sd 0:0:0:0: [sda] Write Protect is off
[ 4.400042] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 4.400087] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 4.400206] sd 0:0:0:0: [sda] 240121728 512-byte hardware sectors (122942 MB)
[ 4.400235] sd 0:0:0:0: [sda] Write Protect is off
[ 4.400239] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 4.400282] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 4.400288] sda: sda1 sda2 sda3 sda4 < sda5 sda6<4>Driver ‘sr’ needs updating - please use bus_type methods
[ 4.458803] sda7 sda8 sda9 >
[ 4.503390] sd 0:0:0:0: [sda] Attached SCSI disk
[ 4.503554] sd 0:0:1:0: [sdb] 156368016 512-byte hardware sectors (80060 MB)
[ 4.503583] sd 0:0:1:0: [sdb] Write Protect is off
[ 4.503588] sd 0:0:1:0: [sdb] Mode Sense: 00 3a 00 00
[ 4.503633] sd 0:0:1:0: [sdb] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 4.503747] sd 0:0:1:0: [sdb] 156368016 512-byte hardware sectors (80060 MB)
[ 4.503776] sd 0:0:1:0: [sdb] Write Protect is off
[ 4.503780] sd 0:0:1:0: [sdb] Mode Sense: 00 3a 00 00
[ 4.503824] sd 0:0:1:0: [sdb] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 4.503829] sdb: sdb1 sdb2 sdb3
[ 4.507147] sd 0:0:1:0: [sdb] Attached SCSI disk
[ 4.510189] sr0: scsi3-mmc drive: 1x/48x cd/rw xa/form2 cdda tray
[ 4.510198] Uniform CD-ROM driver Revision: 3.20
[ 4.510315] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 4.513630] sr1: scsi3-mmc drive: 32x/32x writer cd/rw xa/form2 cdda tray
[ 4.513772] sr 1:0:1:0: Attached scsi CD-ROM sr1
[ 4.566923] hub 3-0:1.0: unable to enumerate USB device on port 2
[ 4.576397] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 4.576440] sd 0:0:1:0: Attached scsi generic sg1 type 0
[ 4.576476] sr 1:0:0:0: Attached scsi generic sg2 type 5
[ 4.576509] sr 1:0:1:0: Attached scsi generic sg3 type 5
[ 4.634759] ata2: DRQ=1 with device error, dev_stat 0x59
[ 4.634837] ata2.01: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x2 frozen
[ 4.635548] ata2.01: cmd a0/00:00:00:08:00/00:00:00:00:00/b0 tag 0 pio 16392 in
[ 4.635551] cdb 46 00 00 00 00 00 00 00 08 00 00 00 00 00 00 00
[ 4.635553] res 59/20:02:00:08:00/00:00:00:00:00/b0 Emask 0x2 (HSM violation)
[ 4.636261] ata2.01: status: { DRDY DRQ ERR }
[ 4.636655] ata2: soft resetting link
[ 4.891296] usb 2-1: new full speed USB device using ohci_hcd and address 2
[ 5.151761] usb 2-1: configuration #1 chosen from 1 choice
[ 5.153685] usb 2-1: New USB device found, idVendor=04b8, idProduct=010f
[ 5.153692] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.153696] usb 2-1: Product: EPSON Scanner 010F
[ 5.153700] usb 2-1: Manufacturer: EPSON
[ 5.362845] ata2.00: configured for UDMA/33
[ 5.539171] ata2.01: configured for PIO4
[ 5.539171] ata2: EH complete
[ 5.616364] ReiserFS: sda3: found reiserfs format “3.6” with standard journal
[ 5.616384] ReiserFS: sda3: using ordered data mode
[ 5.638269] ReiserFS: sda3: journal params: device sda3, size 8192, journal first block 18, max trans len 1024, max batch 900, max commit age 30, max trans age 30
[ 5.639821] ReiserFS: sda3: checking transaction log (sda3)
[ 5.675915] ReiserFS: sda3: Using r5 hash to sort names
[ 7.638643] udevd version 125 started
[ 8.219294] ata2: DRQ=1 with device error, dev_stat 0x59
[ 8.219354] ata2.01: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x2 frozen
[ 8.220123] ata2.01: cmd a0/00:00:00:08:00/00:00:00:00:00/b0 tag 0 pio 16392 in
[ 8.220126] cdb 46 00 00 00 00 00 00 00 08 00 00 00 00 00 00 00
[ 8.220128] res 59/20:02:00:08:00/00:00:00:00:00/b0 Emask 0x2 (HSM violation)
[ 8.220646] ata2.01: status: { DRDY DRQ ERR }
[ 8.221108] ata2: soft resetting link
[ 8.861160] ata2.00: configured for UDMA/33
[ 9.035252] ata2.01: configured for PIO4
[ 9.035308] ata2: EH complete
[ 9.747326] Linux agpgart interface v0.103
[ 9.774090] agpgart: Detected SiS chipset - id:1606
[ 9.778403] agpgart: AGP aperture is 64M @ 0xd8000000
[ 9.908709] sis96x_smbus 0000:00:02.1: SiS96x SMBus base address: 0xe600
[ 10.321566] input: Power Button (FF) as /class/input/input1
[ 10.352894] ACPI: Power Button (FF) [PWRF]
[ 10.353025] input: Power Button (CM) as /class/input/input2
[ 10.384872] ACPI: Power Button (CM) [PWRB]
[ 10.961767] ACPI: PCI Interrupt 0000:00:02.7[C] -> GSI 18 (level, low) -> IRQ 18
[ 11.384883] intel8x0_measure_ac97_clock: measured 52248 usecs
[ 11.384891] intel8x0: clocking to 48000
[ 11.984460] input: PC Speaker as /class/input/input3
[ 12.431553] rtc_cmos 00:06: rtc core: registered rtc_cmos as rtc0
[ 12.431591] rtc0: alarms up to one month
[ 12.544500] gameport: NS558 PnP Gameport is pnp00:0f/gameport0, io 0x200, speed 828kHz
[ 13.041941] input: ImExPS/2 Logitech Wheel Mouse as /class/input/input4
[ 13.068831] parport_pc 00:0a: reported by Plug and Play ACPI
[ 13.068889] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE]
[ 13.906789] Adding 1951888k swap on /dev/sda2. Priority:-1 extents:1 across:1951888k
[ 20.567651] loop: module loaded
[ 26.735551] ReiserFS: sda1: found reiserfs format “3.6” with standard journal
[ 26.735551] ReiserFS: sda1: using ordered data mode
[ 26.739517] ReiserFS: sda1: journal params: device sda1, size 8192, journal first block 18, max trans len 1024, max batch 900, max commit age 30, max trans age 30
[ 26.740079] ReiserFS: sda1: checking transaction log (sda1)
[ 26.747786] ReiserFS: sda1: Using r5 hash to sort names
[ 26.764773] ReiserFS: sda6: found reiserfs format “3.6” with standard journal
[ 26.764773] ReiserFS: sda6: using ordered data mode
[ 26.774992] ReiserFS: sda6: journal params: device sda6, size 8192, journal first block 18, max trans len 1024, max batch 900, max commit age 30, max trans age 30
[ 26.775644] ReiserFS: sda6: checking transaction log (sda6)
[ 26.820710] ReiserFS: sda6: Using r5 hash to sort names
[ 26.865966] ReiserFS: sda8: found reiserfs format “3.6” with standard journal
[ 26.865966] ReiserFS: sda8: using ordered data mode
[ 26.870125] ReiserFS: sda8: journal params: device sda8, size 8192, journal first block 18, max trans len 1024, max batch 900, max commit age 30, max trans age 30
[ 26.870623] ReiserFS: sda8: checking transaction log (sda8)
[ 26.960567] ReiserFS: sda8: Using r5 hash to sort names
[ 27.001325] ReiserFS: sdb3: found reiserfs format “3.6” with standard journal
[ 27.001325] ReiserFS: sdb3: using ordered data mode
[ 27.008099] ReiserFS: sdb3: journal params: device sdb3, size 8192, journal first block 18, max trans len 1024, max batch 900, max commit age 30, max trans age 30
[ 27.008099] ReiserFS: sdb3: checking transaction log (sdb3)
[ 27.038571] ReiserFS: sdb3: Using r5 hash to sort names
[ 27.545344] ip_tables: © 2000-2006 Netfilter Core Team
[ 27.638876] nf_conntrack version 0.5.0 (6144 buckets, 24576 max)
[ 30.393221] NET: Registered protocol family 10
[ 30.394368] lo: Disabled Privacy Extensions
[ 30.876511] eth0: Media Link On 100mbps full-duplex
