Quand j’edite( en tant qu’utilisateur normal et en tant que root), avec vim(ou vi), sous la Debian etch, mes fichiers texts ou scripts(php, java, …), la coloration syntactique est inexistante.
Le fichier /etc/vim/vimrc , est comme suit:
[quote]" All system-wide defaults are set in $VIMRUNTIME/debian.vim (usually just
" /usr/share/vim/vimcurrent/debian.vim) and sourced by the call to :runtime
" you can find below. If you wish to change any of those settings, you should
" do it in this file (/etc/vim/vimrc), since debian.vim will be overwritten
" everytime an upgrade of the vim packages is performed. It is recommended to
" make changes after sourcing debian.vim since it alters the value of the
" ‘compatible’ option.
" This line should not be removed as it ensures that various options are
" properly set to work with the Vim-related packages available in Debian.
runtime! debian.vim
" Uncomment the next line to make Vim more Vi-compatible
" NOTE: debian.vim sets ‘nocompatible’. Setting ‘compatible’ changes numerous
" options, so any other options should be set AFTER setting ‘compatible’.
"set compatible
" Vim5 and later versions support syntax highlighting. Uncommenting the next
" line enables syntax highlighting by default.
syntax on
" If using a dark background within the editing area and syntax highlighting
" turn on this option as well
"set background=dark
" Uncomment the following to have Vim jump to the last position when
" reopening a file
"if has(“autocmd”)
" au BufReadPost * if line("’"") > 0 && line("’"") <= line("$")
" | exe “normal g’”" | endif
"endif
" Uncomment the following to have Vim load indentation rules according to the
" detected filetype. Per default Debian Vim only load filetype specific
" plugins.
“if has(“autocmd”)
” filetype indent on
"endif
" The following are commented out as they cause vim to behave a lot
" differently from regular Vi. They are highly recommended though.
"set showcmd " Show (partial) command in status line.
"set showmatch " Show matching brackets.
"set ignorecase " Do case insensitive matching
"set smartcase " Do smart case matching
"set incsearch " Incremental search
"set autowrite " Automatically save before commands like :next and :make
"set hidden " Hide buffers when they are abandoned
"set mouse=a " Enable mouse usage (all modes) in terminals
" Source a global configuration file if available
" XXX Deprecated, please move your changes here in /etc/vim/vimrc
if filereadable("/etc/vim/vimrc.local")
source /etc/vim/vimrc.local
endif[/quote]
Ma question est donc:
Quel script, dois-je ajouter au fichier vimrc, pour activer la coloration syntactique avec vim(ou vi) ?
Merci d’avance pour l’aide.
