je continue de ramer, à en creuser la falaise!
Pour apparmor:
J’ai du recommencer la commande sudo aa-complain /usr/sbin/cupsd avant mes derniers essais.
dmesg
[10avril 12:32] usb 3-1: new full-speed USB device number 15 using xhci_hcd
[ +0,145793] usb 3-1: New USB device found, idVendor=04e8, idProduct=3301, bcdDevice= 1.00
[ +0,000014] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ +0,000005] usb 3-1: Product: ML-1660 Series
[ +0,000004] usb 3-1: Manufacturer: Samsung Electronics Co., Ltd.
[ +0,000003] usb 3-1: SerialNumber: Z4MSBKBZ501781A.
[ +0,004287] usblp 3-1:1.0: usblp0: USB Bidirectional printer dev 15 if 0 alt 0 proto 2 vid 0x04E8 pid 0x3301
[10avril 12:33] audit: type=1400 audit(1775817183.122:1171): apparmor="ALLOWED" operation="capable" class="cap" profile="/usr/sbin/cupsd" pid=511338 comm="usb" capability=12 capname="net_admin"
[ +0,000036] audit: type=1400 audit(1775817183.122:1172): apparmor="ALLOWED" operation="capable" class="cap" info="optional: no audit" error=-1 profile="/usr/sbin/cupsd" pid=511338 comm="usb" capability=21 capname="sys_admin"
[ +0,013583] usblp0: removed
[ +0,001247] usblp 3-1:1.0: usblp0: USB Bidirectional printer dev 15 if 0 alt 0 proto 2 vid 0x04E8 pid 0x3301
[10avril 13:10] audit: type=1400 audit(1775819425.762:1173): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="/usr/lib/cups/backend/cups-pdf" pid=514175 comm="apparmor_parser"
[ +0,000676] audit: type=1400 audit(1775819425.762:1174): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="/usr/sbin/cupsd" pid=514175 comm="apparmor_parser"
[ +0,000014] audit: type=1400 audit(1775819425.762:1175): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="/usr/sbin/cupsd//third_party" pid=514175 comm="apparmor_parser"
eric@leopard-1:/home/work/eric/Domestique_util/Eric/SANTE_Eric/Medical/2026$ lpr: connect: Connection refused
Is lpd daemon running?
jobs queued, but cannot start daemon.
Pour cupsd:
systemctl status cups
● cups.service - CUPS Scheduler
Loaded: loaded (/usr/lib/systemd/system/cups.service; enabled; preset: enabled)
Active: active (running) since Fri 2026-04-10 00:55:16 CEST; 12h ago
Invocation: 12d0b7f9b5d241379da5a32e21f25db3
TriggeredBy: ● cups.socket
● cups.path
Docs: man:cupsd(8)
Main PID: 485508 (cupsd)
Status: "Scheduler is running..."
Tasks: 3 (limit: 76722)
Memory: 3.3M (peak: 12.1M)
CPU: 313ms
CGroup: /system.slice/cups.service
├─485508 /usr/sbin/cupsd -l
└─511345 /usr/lib/cups/notifier/dbus dbus://
avril 10 00:55:16 leopard-1 systemd[1]: Starting cups.service - CUPS Scheduler...
avril 10 00:55:16 leopard-1 systemd[1]: Started cups.service - CUPS Scheduler.
Aujourd’hui je me suis contenté de tester la commande d’impression de xpdf (aucune impression et aucun fichier dans la file d’attente proposée par system-config-printer.
Je joins le fichier /var/log/cups/error_log (renommé ici en error_log.txt), en précisant qu’ à 0h55 l’ordinateur était en veille (et moi en sommeil).
error_log.txt (274,1 Ko)
Il me semble que plusieurs questions restent en suspens:
1 Comment préserver l’autorisation aa-complain pour cupsd?
(ou: qu’est-ce qui a bien pu annuler cette autorisation)
2 aaparmor est-il nécessaire?
3 Comment faire pour que l’imprimante soit accessibles aux commandes d’impression des logiciels? et en ligne de commande (pour les scripts d’impression).
Ce handicap devient très lourd ( impression d’ordonnances et de courriers juridiques notamment, impossibles depuis des semaines).
Encore merci pour votre aide.
PS
Je ne comprends pas comment /usr/sbin/cupsd peut être à la fois en mode complain (2e et 4e §) et en mode enforce (3e §).
$ sudo aa-status --show=all | egrep -v help | egrep -1i 'cups|lp'
/usr/bin/man
/usr/lib/x86_64-linux-gnu/lightdm/lightdm-guest-session
/usr/lib/x86_64-linux-gnu/lightdm/lightdm-guest-session//chromium
libreoffice-senddoc
27 profiles are in complain mode.
/usr/sbin/cups-browsed
/usr/sbin/cupsd
Xorg
1 processes are in enforce mode.
/usr/lib/cups/filter/rastertoqpdl (572194) /usr/sbin/cupsd//third_party
5 processes are in complain mode.
/usr/sbin/cups-browsed (555928)
/usr/sbin/cupsd (555925)
/usr/lib/cups/notifier/dbus (556994) /usr/sbin/cupsd
/usr/lib/cups/backend/ipp (572195) /usr/sbin/cupsd
/usr/lib/xorg/Xorg (1396) Xorg
