[quote=“debianhadic”][quote=“jakol”]
$ glxinfo | grep "direct rendering"
direct rendering: No (If you want to find out why, try setting LIBGL_DEBUG=verbose)
Tu peux t’arrêter la, tant que c’est comme ça compiz ne fonctionnera pas, donc cherche comment activé la 3D avec ta carte intel, tu devras sûrement rajouter une section [DEVICE] avec le driver “intel” pour commencer.[/quote]
Version: V1.20
Release Date: 04/03/2009
Address: 0xE5FB0
Runtime Size: 106576 bytes
ROM Size: 1024 kB
Characteristics:
ISA is supported
PCI is supported
PC Card (PCMCIA) is supported
PNP is supported
BIOS is upgradeable
BIOS shadowing is allowed
ESCD support is available
Boot from CD is supported
ACPI is supported
USB legacy is supported
AGP is supported
BIOS boot specification is supported
Targeted content distribution is supported
Handle 0x0001, DMI type 1, 27 bytes
System Information
Manufacturer: FUJITSU SIEMENS
Product Name: ESPRIMO Mobile V6505
Version: 20
Serial Number: YKKD070021
UUID: 5F6FAD60-8992-11DD-91F9-001F1603BFB4
Wake-up Type: Power Switch
SKU Number: Not Specified
Family: Not Specified
Handle 0x0002, DMI type 2, 17 bytes
Base Board Information
Product Name: D46
Version: 1B
Serial Number: 914K0Z1103G838019A3KS0B
Asset Tag: Tag 12345
Features:
Board is a hosting board
Board is replaceable
Location In Chassis: Not Applicable
Chassis Handle: 0x0003
Type: Motherboard
Contained Object Handles: 1
0x0000
Handle 0x0003, DMI type 3, 21 bytes
Chassis Information
Type: Notebook
Lock: Not Present
Version: A2040
Asset Tag: No Asset Tag
Boot-up State: Safe
Power Supply State: Safe
Thermal State: Safe
Security Status: None
OEM Information: 0x00001234
Height: Unspecified
Number Of Power Cords: Unspecified
Contained Elements: 0
Handle 0x0004, DMI type 4, 40 bytes
Processor Information
Socket Designation: U2E1
Type: Central Processor
Family:
Manufacturer: Intel
ID: 7A 06 01 00 FF FB EB BF
Version: CPU Version
Voltage: 3.3 V
External Clock: 200 MHz
Max Speed: 4096 MHz
Current Speed: 2000 MHz
Status: Populated, Enabled
Upgrade: ZIF Socket
L1 Cache Handle: 0x0005
L2 Cache Handle: 0x0006
L3 Cache Handle: Not Provided
Serial Number: Not Specified
Asset Tag: Not Specified
Part Number: Not Specified
Core Count: 2
Core Enabled: 2
Thread Count: 2
Characteristics:
64-bit capable
Handle 0x0005, DMI type 7, 19 bytes
Cache Information
Socket Designation: L1 Cache
Configuration: Enabled, Socketed, Level 1
Operational Mode: Write Back
Installed Size: 64 KB
Maximum Size: 64 KB
Supported SRAM Types:
Burst
Pipeline Burst
Asynchronous
Installed SRAM Type: Asynchronous
Speed: Unknown
Error Correction Type: Single-bit ECC
System Type: Data
Associativity: 8-way Set-associative
Handle 0x0006, DMI type 7, 19 bytes
Cache Information
Socket Designation: L2 Cache
Configuration: Enabled, Socketed, Level 2
Installed Size: 2048 KB
Maximum Size: 4096 KB
Burst
Pipeline Burst
Asynchronous
Installed SRAM Type: Burst
Speed: Unknown
System Type: Unified
Handle 0x0007, DMI type 8, 9 bytes
Port Connector Information
Internal Reference Designator: J19
Internal Connector Type: 9 Pin Dual Inline (pin 10 cut)
External Reference Designator: COM 1
External Connector Type: DB-9 male
Port Type: Serial Port 16550A Compatible
Handle 0x0008, DMI type 8, 9 bytes
Internal Reference Designator: J1A1
Internal Connector Type: None
External Reference Designator: Keyboard
External Connector Type: Circular DIN-8 male
Port Type: Keyboard Port
Handle 0x0009, DMI type 8, 9 bytes
External Reference Designator: PS/2 Mouse
Port Type: Mouse Port
Handle 0x000A, DMI type 9, 13 bytes
System Slot Information
Designation: PEG Slot J6B2
Type: 32-bit PCI Express
Current Usage: Available
Length: Long
Characteristics:
5.0 V is provided
3.3 V is provided
Handle 0x000B, DMI type 9, 13 bytes
Designation: PCI Express Slot J6B1
Current Usage: In Use
Length: Long
Characteristics:
5.0 V is provided
3.3 V is provided
Handle 0x000C, DMI type 9, 13 bytes
Designation: PCI Express Slot J6D1
Length: Long
Characteristics:
5.0 V is provided
3.3 V is provided
Handle 0x000D, DMI type 9, 13 bytes
Designation: PCI Express Slot J8B3
Length: Long
Characteristics:
5.0 V is provided
3.3 V is provided
Handle 0x000E, DMI type 9, 13 bytes
Designation: PCI Express Slot J8D1
Length: Long
Characteristics:
5.0 V is provided
3.3 V is provided
Handle 0x000F, DMI type 9, 13 bytes
Designation: PCI Express Slot J7B1
Length: Long
Characteristics:
5.0 V is provided
3.3 V is provided
Handle 0x0010, DMI type 9, 13 bytes
Designation: PCI Express Slot 6
Length: Long
Characteristics:
5.0 V is provided
3.3 V is provided
Handle 0x0011, DMI type 10, 6 bytes
On Board Device Information
Type: Sound
Status: Disabled
Description: HD-Audio
Handle 0x0012, DMI type 11, 5 bytes
OEM Strings
String 1: This is the Intel Cantiga
String 2: Chipset CRB Platform
Handle 0x0013, DMI type 12, 5 bytes
System Configuration Options
Option 1: Jumper settings can be described here.
Handle 0x0014, DMI type 15, 29 bytes
System Event Log
Area Length: 16 bytes
Header Start Offset: 0x0000
Header Length: 16 bytes
Data Start Offset: 0x0010
Access Method: General-purpose non-volatile data functions
Access Address: 0x0000
Status: Valid, Not Full
Change Token: 0x00000001
Header Format: Type 1
Supported Log Type Descriptors: 3
Descriptor 1: POST error
Data Format 1: POST results bitmap
Descriptor 2: Single-bit ECC memory error
Data Format 2: Multiple-event
Descriptor 3: Multi-bit ECC memory error
Data Format 3: Multiple-event
Handle 0x0015, DMI type 16, 15 bytes
Physical Memory Array
Use: System Memory
Error Correction Type: None
Maximum Capacity: 4 GB
Error Information Handle: Not Provided
Number Of Devices: 2
Handle 0x0016, DMI type 17, 27 bytes
Memory Device
Array Handle: 0x0015
Error Information Handle: No Error
Total Width: Unknown
Data Width: Unknown
Size: No Module Installed
Form Factor: SODIMM
Set: 1
Locator: M1
Bank Locator: Bank 0
Type: Unknown
Type Detail: Synchronous
Speed: 800 MHz (1.2 ns)
Manufacturer:
Serial Number:
Asset Tag:
Part Number:
Handle 0x0017, DMI type 17, 27 bytes
Memory Device
Total Width: 8 bits
Data Width: 64 bits
Form Factor: SODIMM
Set: 1
Locator: M2
Bank Locator: Bank 1
Type: DDR2
Manufacturer: CE00000000000000
Serial Number: 8745833C
Asset Tag: 0836
Part Number: M4 70T5663QZ3-CF7
Handle 0x0018, DMI type 18, 23 bytes
32-bit Memory Error Information
Type: OK
Granularity: Unknown
Operation: Unknown
Vendor Syndrome: Unknown
Memory Array Address: Unknown
Device Address: Unknown
Resolution: Unknown
Handle 0x0019, DMI type 18, 23 bytes
Type: OK
Operation: Unknown
Resolution: Unknown
Handle 0x001A, DMI type 19, 15 bytes
Memory Array Mapped Address
Starting Address: 0x00000000000
Ending Address: 0x0007FFFFFFF
Range Size: 2 GB
Physical Array Handle: 0x0015
Partition Width: 0
Handle 0x001B, DMI type 20, 19 bytes
Memory Device Mapped Address
Ending Address: 0x000000003FF
Range Size: 1 kB
Physical Device Handle: 0x0016
Memory Array Mapped Address Handle: 0x001A
Partition Row Position: Unknown
Interleave Position: Unknown
Interleaved Data Depth: Unknown
Handle 0x001C, DMI type 20, 19 bytes
Range Size: 2 GB
Physical Device Handle: 0x0017
Handle 0x001D, DMI type 22, 26 bytes
Portable Battery
Manufacturer: Foxlink
Manufacture Date: Samsung
Serial Number: e00513402C37C32001754
Name:
Chemistry: Lithium Ion
Design Capacity: 48840 mWh
Design Voltage: 11100 mV
SBDS Version: 00
Maximum Error: Unknown
OEM-specific Information: 0x00000000
Handle 0x001E, DMI type 23, 13 bytes
System Reset
Status: Enabled
Watchdog Timer: Present
Boot Option: Do Not Reboot
Boot Option On Limit: Do Not Reboot
Reset Count: Unknown
Reset Limit: Unknown
Timer Interval: Unknown
Timeout: Unknown
Handle 0x001F, DMI type 24, 5 bytes
Hardware Security
Power-On Password Status: Disabled
Keyboard Password Status: Unknown
Administrator Password Status: Disabled
Front Panel Reset Status: Unknown
Handle 0x0020, DMI type 25, 9 bytes
System Power Controls
Next Scheduled Power-on: 12-31 23:59:59
Handle 0x0021, DMI type 26, 20 bytes
Voltage Probe
Description: Voltage Probe
Status: OK
Maximum Value: Unknown
Minimum Value: Unknown
Resolution: Unknown
Tolerance: Unknown
Accuracy: Unknown
Handle 0x0022, DMI type 27, 12 bytes
Cooling Device
Temperature Probe Handle: 0x0023
Type: Fan
Status: OK
Handle 0x0023, DMI type 28, 20 bytes
Temperature Probe
Description: Temperature Probe
Status: OK
Minimum Value Unknown
Resolution: Unknown
Tolerance: Unknown
Accuracy: Unknown
Handle 0x0024, DMI type 29, 20 bytes
Electrical Current Probe
Description: Electrical Current Probe
Status: OK
Resolution: Unknown
Tolerance: Unknown
Accuracy: Unknown
Handle 0x0025, DMI type 30, 6 bytes
Out-of-band Remote Access
Manufacturer Name: Intel
Inbound Connection: Disabled
Outbound Connection: Enabled
Handle 0x0026, DMI type 32, 20 bytes
System Boot Information
Status: No errors detected
Handle 0x0027, DMI type 39, 22 bytes
System Power Supply
Power Unit Group: 1
Name: To Be Defined By O.E.M
Manufacturer: To Be Defined By O.E.M
Serial Number: To Be Defined By O.E.M
Asset Tag: To Be Defined By O.E.M
Model Part Number: To Be Defined By O.E.M
Revision: 2.50
Max Power Capacity: Unknown
Status: Present, Unknown
Type: Unknown
Input Voltage Range Switching: Unknown
Plugged: Yes
Hot Replaceable: No
Input Voltage Probe Handle: 0x0021
Cooling Device Handle: 0x0022
Input Current Probe Handle: 0x0024
Handle 0x0028, DMI type 129, 8 bytes
OEM-specific Type
Header and Data:
81 08 28 00 01 01 02 01
Strings:
Intel_ASF
Intel_ASF_001
Handle 0x0029, DMI type 136, 6 bytes
OEM-specific Type
Header and Data:
88 06 29 00 FF FF
Handle 0x002A, DMI type 150, 14 bytes
OEM-specific Type
Header and Data:
96 0E 2A 00 01 01 00 00 00 00 00 00 00 00
Strings:
ABSOLUTE(PHOENIX) CLM
Handle 0x002B, DMI type 200, 7 bytes
OEM-specific Type
Header and Data:
C8 07 2B 00 01 02 03
Strings:
17C0
0001
Handle 0x002C, DMI type 127, 4 bytes
End Of Table
