Si quelqu’un veut bien m’aider. Je voudrais passer du noyau Wheezie au noyau Jessie pour voir si ma carte wifi est prise en charge. Là j’écris sous windows. J’imagine bien que cela doit pouvoir se faire facilement en ligne de commande mais je ne trouve que des soluces obsolètes sur le net.
[quote][18:39:14]:~$ aptitude search linux-image
v linux-image -
v linux-image-2.6 -
p linux-image-2.6-486 - Linux for older PCs (dummy package)
p linux-image-2.6-686 - Linux for modern PCs (dummy package)
p linux-image-2.6-686-bigmem - Linux for PCs with 4GB+ RAM (dummy package
p linux-image-2.6-686-pae - Linux for modern PCs (dummy package)
p linux-image-2.6-amd64 - Linux for 64-bit PCs (dummy package)
p linux-image-2.6-openvz-686 - Linux 2.6 for modern PCs (meta-package), O
p linux-image-2.6-vserver-686 - Linux 2.6 for modern PCs (meta-package), L
p linux-image-2.6-vserver-686-big - Linux 2.6 for PCs with 4GB+ RAM (meta-pack
p linux-image-2.6-xen-686 - Linux 2.6 for modern PCs (meta-package), X
p linux-image-2.6.32-5-486 - Linux 2.6.32 for old PCs
i A linux-image-2.6.32-5-686 - Linux 2.6.32 for modern PCs
p linux-image-2.6.32-5-686-bigmem - Linux 2.6.32 for PCs with 4GB+ RAM
p linux-image-2.6.32-5-686-bigmem - Debugging infos for Linux 2.6.32-5-686-big
p linux-image-2.6.32-5-amd64 - Linux 2.6.32 for 64-bit PCs
p linux-image-2.6.32-5-openvz-686 - Linux 2.6.32 for modern PCs, OpenVZ suppor
p linux-image-2.6.32-5-openvz-686 - Debugging infos for Linux 2.6.32-5-openvz-
p linux-image-2.6.32-5-vserver-68 - Linux 2.6.32 for modern PCs, Linux-VServer
p linux-image-2.6.32-5-vserver-68 - Linux 2.6.32 for PCs with 4GB+ RAM, Linux-
p linux-image-2.6.32-5-vserver-68 - Debugging infos for Linux 2.6.32-5-vserver
p linux-image-2.6.32-5-xen-686 - Linux 2.6.32 for modern PCs, Xen dom0 supp
p linux-image-2.6.32-5-xen-686-db - Debugging infos for Linux 2.6.32-5-xen-686
p linux-image-2.6.37-rc4-clefagre - Linux kernel binary image for version 2.6.
v linux-image-3.10 -
p linux-image-3.10.1-fb-aufs - Linux kernel binary image for version 3.10
v linux-image-3.15 -
p linux-image-3.15.6-fb-aufs - Linux kernel binary image for version 3.15
p linux-image-3.16.0-0.bpo.4-586 - Linux 3.16 for older PCs
p linux-image-3.16.0-0.bpo.4-686- - Linux 3.16 for modern PCs
p linux-image-3.16.0-0.bpo.4-686- - Debugging symbols for Linux 3.16.0-0.bpo.4
p linux-image-3.16.0-0.bpo.4-amd6 - Linux 3.16 for 64-bit PCs
p linux-image-3.16.0-4-586 - Linux 3.16 for older PCs
p linux-image-3.16.0-4-686-pae - Linux 3.16 for modern PCs
p linux-image-3.16.0-4-686-pae-db - Debugging symbols for Linux 3.16.0-4-686-p
p linux-image-3.16.0-4-amd64 - Linux 3.16 for 64-bit PCs
p linux-image-3.19.0-trunk-586 - Linux 3.19 for older PCs
p linux-image-3.19.0-trunk-686-pa - Linux 3.19 for modern PCs
p linux-image-3.19.0-trunk-686-pa - Debugging symbols for Linux 3.19.0-trunk-6
p linux-image-3.19.0-trunk-amd64 - Linux 3.19 for 64-bit PCs
p linux-image-3.2.0-0.bpo.4-486 - Linux 3.2 for older PCs
p linux-image-3.2.0-0.bpo.4-686-p - Linux 3.2 for modern PCs
p linux-image-3.2.0-0.bpo.4-686-p - Debugging symbols for Linux 3.2.0-0.bpo.4-
p linux-image-3.2.0-0.bpo.4-amd64 - Linux 3.2 for 64-bit PCs
p linux-image-3.2.0-0.bpo.4-rt-68 - Linux 3.2 for modern PCs, PREEMPT_RT
p linux-image-3.2.0-0.bpo.4-rt-68 - Debugging symbols for Linux 3.2.0-0.bpo.4-
p linux-image-3.2.0-4-486 - Linux 3.2 for older PCs
i A linux-image-3.2.0-4-686-pae - Linux 3.2 for modern PCs
p linux-image-3.2.0-4-686-pae-dbg - Debugging symbols for Linux 3.2.0-4-686-pa
p linux-image-3.2.0-4-amd64 - Linux 3.2 for 64-bit PCs
p linux-image-3.2.0-4-rt-686-pae - Linux 3.2 for modern PCs, PREEMPT_RT
p linux-image-3.2.0-4-rt-686-pae- - Debugging symbols for Linux 3.2.0-4-rt-686
v linux-image-3.5 -
p linux-image-3.5.4-fb-aufs - Linux kernel binary image for version 3.5.
v linux-image-3.8 -
p linux-image-3.8.0-3.8.0-fb-aufs - Linux kernel binary image for version 3.8.
p linux-image-486 - Linux for older PCs (dummy package)
p linux-image-586 - Linux for older PCs (meta-package)
i linux-image-686 - Linux for modern PCs (dummy package)
p linux-image-686-bigmem - Linux for PCs with 4GB+ RAM (dummy package
i A linux-image-686-pae - Linux pour PC modernes - métapaquet
p linux-image-686-pae-dbg - Debugging symbols for Linux 686-pae config
p linux-image-amd64 - Linux for 64-bit PCs (meta-package)
p linux-image-openvz-686 - Linux for modern PCs (meta-package), OpenV
p linux-image-rt-686-pae - Linux for modern PCs (meta-package), PREEM
p linux-image-vserver-686 - Linux for modern PCs (meta-package), Linux
p linux-image-vserver-686-bigmem - Linux for PCs with 4GB+ RAM (meta-package)
p linux-image-xen-686 - Linux for modern PCs (meta-package), Xen d
[18:39:43]:~$[/quote]
[code]# aptitude install <le_noyau>[/code]
v linux-image -
v linux-image-2.6 -
v linux-image-3.5 -
v linux-image-3.8 -
bonjour.
installer le noyau des wheezy-backports
backports.debian.org/Instructions/
liste des paquets disponibles dans wheezy-backports
Merci, je tente ça dès que j’ai une connexion internet haut débit.
Beaucoup de carte wifi ne fonctionnent pas par défaut sur Debian car elles requièrent l’installation d’un firmware propriétaire.
Pour ta carte wifi il faut d’abord l’identifier avec par exemple la commande
Puis une fois la carte identifié on pourra identifier le firmware nécessaire (ce qui devrait nécessiter de modifier ton sources.list afin d’avoir accès aux sections contrib et non-free)
