Compilation de Gimp 2.8 qui pose problème
J’aimerais compiler sur Debian 6.0.5 Gimp 2.8.0 à partir de ces sources sur le site http://www.gimp.org/downloads/
Une fois celà fait, j’ouvre le fichier ‘install’ comme d’habitude et je suis les instructions.
Je commence par un ./configure, puis make. C’est à cette étape que ça bloque … il m’est répondu :
root@Guillaume-PC:/home/guillaume/Téléchargements/gimp-2.8.0# [b]make[/b] make: *** Pas de cibles spécifiées et aucun makefile n'a été trouvé. Arrêt.
Je vous donne le contenu du fichier ‘install’
[code]--------------------------------------
Installation instructions for GIMP 2.8
There are some basic steps to building and installing GIMP.
GIMP 2.8 replaces earlier GIMP 2.x versions. It is advised that you
uninstall them before installing GIMP 2.8. If you want to keep your
older GIMP 2.x installation in parallel to GIMP 2.8, you have to
choose a separate prefix which is not in your default library search
path.
GIMP 2.8 is fully backward compatible to all earlier GIMP 2.x version.
Plug-ins and scripts written for GIMP 2.6 or earlier GIMP 2.x versions
will continue to work and don’t need to be changed nor recompiled to
be used with GIMP 2.8.
The most important part is to make sure the requirements for a build
are fulfilled. We depend on a number of tools and libraries which are
listed below. For libraries this means you need to also have the
header files installed.
  • Unless you are experienced with building software from source, *
  • you should not attempt to build all these libraries yourself! *
  • We suggest that you check if your distributor has development *
  • packages of them and use these instead. *
  1. You need to have installed a recent version of pkg-config available
    from http://www.freedesktop.org/software/pkgconfig/.
  2. You need intltool (at least 0.40.1, but preferably a newer version).
    Intltool can be downloaded from
    http://ftp.gnome.org/pub/gnome/sources/intltool/
  3. You need to have GEGL version 0.2.0 or newer and babl version
    0.1.10 or newer. You can get them from http://gegl.org/ or clone
    them from the GNOME git repository:
    git://git.gnome.org/babl
    git://git.gnome.org/gegl
  4. You need to have installed GTK+ version 2.24.10 or newer.
    GIMP also need a recent versions of GLib (>= 2.30.2), GDK-Pixbuf
    (>= 2.24.1), and Pango (>= 1.29.4). Sources for these can be grabbed
    from ftp://ftp.gtk.org/.
  5. We use cairo >= 1.10.2, which is hosted at
    http://www.cairographics.org/.
  6. We require PangoCairo, a Pango backend using Cairo. Make sure you
    have Cairo, FreeType2 and fontconfig installed before you compile
    Pango. GIMP depends on freetype2 being newer than version 2.1.7
    and fontconfig 2.2.0 or newer. Older versions are known to have
    bugs that seriously affect the stability of GIMP.
  7. We use dbus-glib if available. Grab it from
    http://dbus.freedesktop.org/releases/dbus-glib/
  8. Access of remote files is implemented in the URI plug-in. There
    are several possible implementations for this. The implementation
    used is determined when you configure GIMP. By default the
    GIO/GVfs backend is used. If you don’t have GVfs support on your
    target platform, you should pass the ‘–without-gvfs’ option to
    configure. The configure script will then try to detect another
    method for accessing remote files.
  9. You may want to install other third party libraries or programs
    that are needed for some of the available plug-ins. We recommend
    to check that the following libraries are installed: lcms,
    libpng, libjpeg, libpoppler, libtiff, webkit, libmng, librsvg,
    libwmf, libz, libbzip2, libgs (Ghostscript), libaa and libjasper.
  10. The Python extension requires Python development headers to be
    present. You will also need PyGTK and the respective development
    headers.
  11. Configure GIMP by running the `configure’ script. You may want
    to pass some options to it, see below.
  12. Build GIMP by running `make’. The use of GNU make is recommended.
    If you need to tweak the build to make it work with other flavours
    of make, we’d appreciate if you’d send us a patch with the changes.
  13. Install GIMP by running `make install’. In order to avoid clashes
    with other versions of GIMP, we install a binary called gimp-2.8.
    By default there’s also a link created so that you can type 'gimp’
    to start gimp-2.8.
Please make sure you don’t have any old GTK±2.x, jpeg, etc. libraries
lying around on your system, otherwise configure may fail to find the
new ones.
Generic instructions for configuring and compiling auto-configured
packages are included below. Here is an illustration of commands that
might be used to build and install GIMP. The actual configuration,
compilation and installation output is not shown.
% tar xvfz gimp-2.8.x.tar.gz # unpack the sources
% cd gimp-2.8.x # change to the toplevel directory
% ./configure # run the `configure’ script
% make # build GIMP
% make install # install GIMP
The configure' script examines your system, and adapts GIMP to run on it. The script has many options, some of which are described in the generic instructions included at the end of this file. All of the options can be listed using the command./configure --help’. There
are several special options the GIMP `configure’ script recognizes.
These are:
–enable-shared and --disable-shared. This option affects whether
shared libraries will be built or not. Shared libraries provide
for much smaller executables. The default is to enable shared
libraries. Disabling shared libraries is almost never a good idea.
–enable-debug and --disable-debug. This option causes the build
process to compile with debugging enabled. If debugging is
disabled, GIMP will instead be compiled with optimizations turned
on. The default is for debugging to be disabled. NOTE: This
option is intended primarily as a convenience for developers.
–enable-profile and --disable-profile. This options causes the build
process to compile with execution profiling enabled. The default is
for profiling to be disabled. NOTE: This option is intended primarily
–enable-ansi and --disable-ansi. This option causes stricter
ANSI C checking to be performed when compiling with GCC. The
default is for strict checking to be disabled. NOTE: This option
–with-gimpdir=DIR. This option changes the default directory
GIMP uses to search for its configuration files from ~/.gimp-2.8
(the directory .gimp-2.8 in the users home directory) to DIR.
–enable-binreloc. When compiled for Linux with this option enabled,
GIMP will be binary relocatable. Plug-ins and data files will
be searched relative to the gimp binary instead of in the paths
defined at compile time.
–with-shm=[none|sysv|posix|auto]. This option allows you to specify
how image data is transported between the core and plug-ins. Usually
the best way to do this is detected automatically.
–without-libtiff, --without-libjpeg, --without-libpng. configure
will bail out if libtiff, libjpeg or libpng can not be found. You
better fix the underlying problem and install these libraries with
their header files. If you absolutely want to compile GIMP without
support for TIFF, JPEG or PNG you need to explicitly disable
them using the options given above.
–without-libexif. If libexif is available, the JPEG plug-in will use
it to keep EXIF data in your JPEG files intact. If this is
causing any trouble at compile-time, you can build --without-libexif.
Get libexif from http://www.sourceforge.net/projects/libexif.
–without-aa. The AA plug-in needs libaa and configure checks for
its presence. Use --without-aa if you run into problems.
–without-libxpm. The XPM plug-in needs libxpm and configure checks
for its presence. If for some reason you don’t want to build the
XPM plug-in even though the library is installed, use
–without-libxpm to disable it explicitly.
–without-libmng. The MNG plug-in needs libmng and configure checks
MNG plug-in even though the library is installed, use
–without-libmng to disable it explicitly.
–without-wmf. The WMF plug-in needs libwmf2 and configure checks for
its presence. Use --without-wmf if you run into problems.
–without-webkit. If for some reason you don’t want to build the
Help Browser plug-in, you can use --without-webkit to disable
it explicitly.
–without-librsvg. If for some reason you want to build GIMP without
SVG support, you can build --without-librsvg.
–without-lcms. If for some reason you want to build GIMP without
using lcms for color support, you can build with --without-lcms.
–without-poppler. If for some reason you don’t want to build the PDF
Import plug-in that uses libpoppler, you can use --without-poppler.
–without-print. If for some reason you don’t want to build the Print
plug-in based on the GtkPrint API, you can build with --without-print.
–without-gvfs. If you don’t want to use GIO/GVfs to access remote
files, you can pass --without-gvfs to the configure script.
–without-libcurl. If you don’t want to use libcurl to access remote
files, you can pass --without-libcurl to the configure script.
–without-alsa. If you don’t want to compile ALSA support into the
MIDI input controller module, you can use the --without-alsa option.
–without-dbus. If you want to build without D-Bus support, you can
pass --without-dbus to the configure script.
–without-linux-input. If you don’t want to compile the Linux Input
controller module, you can use the --without-linux-input option.
–without-hal. If you want to build the Linux Input controller module
without HAL support, you can use the --without-hal option.
–without-mac-twain. If you don’t want to compile the Mac OS X
TWAIN plug-in, you can use the --without-mac-twain option.
–with-gif-compression=[lzw|rle|none]. Allows to tune the compression
algorithm used by the GIF plug-in. If you are afraid of Unisys’ LZW
patent (which should have expired in most countries by now), you
can go for simple run-length encoding or even configure the plug-in
to create uncompressed GIFs.
–enable-gtk-doc. This option controls whether the libgimp API
references will be created using gtk-doc. The HTML pages are
included in a standard tarball, so you will only need this if you
are building from SVN.
–with-html-dir=PATH. This option allows to specify where the
libgimp API reference should be installed. You might want to modify
the path so it points to the place where glib and gtk+ installed
their API references so that the libgimp reference can link to
them.
–disable-mp. This option allows you to disable support for multiple
processors. It is enabled by default.
–with-sendmail=[PATH]. This option is used to tell GIMP where to find
the sendmail command. Normally this options don’t have to be used
because configure tries to find it in the usual places.
–with-desktop-dir=[PATH]. This option specifies where to install
desktop files. These files are used by desktop environments that
comply to the specs published at freedesktop.org. The default
value ${prefix}/share should be fine if your desktop environment
is installed in the same prefix as gimp. No files are installed
if you call configure with --without-desktop-dir.
–disable-default-binary. Use this option if you don’t want to make
gimp-2.8 the default GIMP installation. Otherwise a link called
gimp pointing to the gimp-2.8 executable will be installed.
–disable-gimp-console. Use this option if you don’t want the
gimp-console binary to be built in addition to the standard binary.
gimp-console is useful for command-line batch mode or as a server.
–disable-python. If for some reason you don’t want to build the
Python based PyGIMP plug-in, you can use --disable-python.
–without-script-fu. If for some reason you don’t want to build the
Script-Fu plug-in, you can use --without-script-fu.
–without-xmc. The X11 Mouse Cursor(XMC) plug-in needs libXcursor
and configure checks for its presence. If for some reason you
don’t want to build the XMC plug-in even though the library is
installed, use --without-xmc to disable it explicitly.
The `make’ command builds several things:
  • A bunch of public libraries in the directories starting with ‘libgimp’.
  • The plug-in programs in the ‘plug-ins’ directory.
  • Some modules in the ‘modules’ subdirectory.
  • The main GIMP program ‘gimp-2.8’ in `app’.
The make install' commands installs the GIMP header files associated with the libgimp libraries, the plug-ins, some data files and the GIMP executable. After runningmake install’ and assuming the build process
was successful you should be able to run `gimp’.
When ./configure fails
‘configure’ uses pkg-config, a tool that replaces the old foo-config
scripts. The most recent version is available from
‘configure’ tries to compile and run a short GTK+ program. There are
several reasons why this might fail:
  • pkg-config could not find the file ‘gtk±2.0.pc’ that gets installed
    with GTK. (This file is used to get information about where GTK+ is
    installed.)
    Fix: Either make sure that this file is in the path where pkg-config
    looks for it (try ‘pkg-config --debug’ or add the location of
    gtk±2.0.pc to the environment variable PKG_CONFIG_PATH before running
    configure.
  • Libraries you installed are not found when you attempt to start GIMP.
    The details of how to fix this problem will depend on the system:
    On Linux and other systems using ELF libraries, add the directory to
    holding the library to /etc/ld.so.conf or to the environment variable
    LD_LIBRARY_PATH, and run ‘ldconfig’.
    On other systems, it may be necessary to encode this path
    into the executable, by setting the LDFLAGS environment variable
    before running configure. For example:
    LDFLAGS="-R/home/joe/lib" ./configure
    or
    LDFLAGS="-Wl,-rpath -Wl,/home/joe/lib" ./configure
  • An old version of the GTK+ libraries was found instead of
    your newly installed version. This commonly happens if a
    binary package of GTK+ was previously installed on your system,
    and you later compiled GTK+ from source.
    Fix: Remove the old libraries and include files. If you are afraid
    that removing the old libraries may break other packages supplied by
    your distributor, you can try installing GLib, GTK+ and other
    libraries in a different prefix after setting the environment
    variable PKG_CONFIG_LIBDIR to point to lib/pkgconfig/ in that new
    prefix so that it does not try to read the *.pc files from the
    default directory (/usr/lib/pkgconfig). However, removing the old
    packages is often the easier solution.
A detailed log of the ./configure output is written to the file
config.log. This may help diagnose problems.
When ./configure fails on plug-ins
There are some GIMP plug-ins that need additional third-party libraries
installed on your system. For example to compile the plug-ins that load
and save JPEG, PNG or TIFF files you need the related libraries and header
files installed, otherwise you’ll get a message that plug-in xyz will not
be built.
If you are sure that those libraries are correctly installed, but configure
fails to detect them, the following might help:
Set your LDFLAGS environment variable to look for the library in a certain
place, e.g. if you are working in a bash shell you would say:
export LDFLAGS="-L<path_to_library> -L<path_to_another_one>"
before you run configure.
Set your CPPFLAGS environment variable to look for the header file in a
certain place, e.g. if you are working in a bash shell you would say:
export CPPFLAGS="-I<path_to_header_file> -I<path_to_another_one>"
  Generic Instructions for Building Auto-Configured Packages
To compile this package:
  1. Configure the package for your system. In the directory that this
    file is in, type ./configure'. If you're usingcsh’ on an old
    version of System V, you might need to type sh configure' instead to preventcsh’ from trying to execute `configure’ itself.
The configure' shell script attempts to guess correct values for various system-dependent variables used during compilation, and creates the Makefile(s) (one in each subdirectory of the source directory). In some packages it creates a C header file containing system-dependent definitions. It also creates a fileconfig.status’
that you can run in the future to recreate the current configuration.
Running `configure’ takes a minute or two.
To compile the package in a different directory from the one
containing the source code, you must use GNU make. cd' to the directory where you want the object files and executables to go and runconfigure’ with the option --srcdir=DIR', where DIR is the directory that contains the source code. Using this option is actually unnecessary if the source code is in the parent directory of the one in which you are compiling;configure’ automatically checks
for the source code in `…’ if it does not find it in the current
directory.
By default, make install' will install the package's files in /usr/local/bin, /usr/local/lib, /usr/local/man, etc. You can specify an installation prefix other than /usr/local by givingconfigure’ the
option `–prefix=PATH’.
You can specify separate installation prefixes for machine-specific
files and machine-independent files. If you give configure' the option–exec-prefix=PATH’, the package will use PATH as the prefix
for installing programs and libraries. Normally, all files are
installed using the same prefix.
`configure’ ignores any other arguments that you give it.
If your system requires unusual options for compilation or linking
that configure' doesn't know about, you can giveconfigure’ initial
values for some variables by setting them in the environment. In
Bourne-compatible shells, you can do that on the command line like
this:
CC=‘gcc -traditional’ DEFS=-D_POSIX_SOURCE ./configure
The make' variables that you might want to override with environment variables when runningconfigure’ are:
(For these variables, any value given in the environment overrides the
value that configure' would choose:) CC C compiler program. Default iscc’, or gcc' ifgcc’ is in your PATH.
INSTALL Program to use to install files.
Default is install' if you have it,cp’ otherwise.
INCLUDEDIR Directory for `configure’ to search for include files.
Default is /usr/include.
(For these variables, any value given in the environment is added to
the value that `configure’ chooses:)
DEFS Configuration options, in the form '-Dfoo -Dbar …'
LIBS Libraries to link with, in the form ‘-lfoo -lbar …’
If you need to do unusual things to compile the package, we encourage
you to teach `configure’ how to do them and mail the diffs to the
address given in the README so we can include them in the next
release.
  1. Type `make’ to compile the package.
  2. Type `make install’ to install programs, data files, and
    documentation.
  3. You can remove the program binaries and object files from the
    source directory by typing make clean'. To also remove the Makefile(s), the header file containing system-dependent definitions (if the package uses one), andconfig.status’ (all the files that
    configure' created), typemake distclean’.
The file configure.ac' is used as a template to createconfigure’ by
a program called autoconf'. You will only need it if you want to regenerateconfigure’ using a newer version of `autoconf’.[/code]
Et le contenu de mon terminal (pour voir le résultat du ./configure)
[code]root@Guillaume-PC:/home/guillaume/Téléchargements/gimp-2.8.0# ./configure
checking for a BSD-compatible install… /usr/bin/install -c
checking whether build environment is sane… yes
checking for a thread-safe mkdir -p… /bin/mkdir -p
checking for gawk… no
checking for mawk… mawk
checking whether make sets $(MAKE)… yes
checking whether make supports nested variables… yes
checking for gcc… gcc
checking whether the C compiler works… yes
checking for C compiler default output file name… a.out
checking for suffix of executables…
checking whether we are cross compiling… no
checking for suffix of object files… o
checking whether we are using the GNU C compiler… yes
checking whether gcc accepts -g… yes
checking for gcc option to accept ISO C89… none needed
checking for style of include used by make… GNU
checking dependency style of gcc… gcc3
checking whether gcc and cc understand -c and -o together… yes
checking build system type… i686-pc-linux-gnu
checking host system type… i686-pc-linux-gnu
checking how to print strings… printf
checking for a sed that does not truncate output… /bin/sed
checking for grep that handles long lines and -e… /bin/grep
checking for egrep… /bin/grep -E
checking for fgrep… /bin/grep -F
checking for ld used by gcc… /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld… yes
checking for BSD- or MS-compatible name lister (nm)… /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface… BSD nm
checking whether ln -s works… yes
checking the maximum length of command line arguments… 1572864
checking whether the shell understands some XSI constructs… yes
checking whether the shell understands “+=”… yes
checking how to convert i686-pc-linux-gnu file names to i686-pc-linux-gnu format… func_convert_file_noop
checking how to convert i686-pc-linux-gnu file names to toolchain format… func_convert_file_noop
checking for /usr/bin/ld option to reload object files… -r
checking for objdump… objdump
checking how to recognize dependent libraries… pass_all
checking for dlltool… no
checking how to associate runtime and link libraries… printf %s\n
checking for ar… ar
checking for archiver @FILE support… @
checking for strip… strip
checking for ranlib… ranlib
checking command to parse /usr/bin/nm -B output from gcc object… ok
checking for sysroot… no
checking for mt… mt
checking if mt is a manifest tool… no
checking how to run the C preprocessor… gcc -E
checking for ANSI C header files… yes
checking for sys/types.h… yes
checking for sys/stat.h… yes
checking for stdlib.h… yes
checking for string.h… yes
checking for memory.h… yes
checking for strings.h… yes
checking for inttypes.h… yes
checking for stdint.h… yes
checking for unistd.h… yes
checking for dlfcn.h… yes
checking for objdir… .libs
checking if gcc supports -fno-rtti -fno-exceptions… no
checking for gcc option to produce PIC… -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works… yes
checking if gcc static flag -static works… yes
checking if gcc supports -c -o file.o… yes
checking if gcc supports -c -o file.o… (cached) yes
checking whether the gcc linker (/usr/bin/ld) supports shared libraries… yes
checking whether -lc should be explicitly linked in… no
checking dynamic linker characteristics… GNU/Linux ld.so
checking how to hardcode library paths into programs… immediate
checking whether stripping libraries is possible… yes
checking if libtool supports shared libraries… yes
checking whether to build shared libraries… yes
checking whether to build static libraries… no
checking whether to enable maintainer-specific portions of Makefiles… yes
checking for pkg-config… /usr/bin/pkg-config
checking pkg-config is at least version 0.16… yes
checking for target architecture… i686-pc-linux-gnu
checking for some Win32 platform… no
checking for native Win32… no
checking whether make sets $(MAKE)… (cached) yes
checking for special C compiler options needed for large files… no
checking for _FILE_OFFSET_BITS value needed for large files… 64
checking whether to turn on debugging… no
checking whether to turn on profiling… no
checking whether gcc understands -Wdeclaration-after-statement… yes
checking whether gcc understands -Wmissing-prototypes… yes
checking whether gcc understands -Werror=missing-prototypes… yes
checking whether gcc understands -Wstrict-prototypes… yes
checking whether gcc understands -Wmissing-declarations… yes
checking whether gcc understands -Winit-self… yes
checking whether gcc understands -Wpointer-arith… yes
checking whether gcc understands -Wold-style-definition… yes
checking whether gcc understands -Wmissing-format-attribute… yes
checking whether gcc understands -Wformat-security… yes
checking whether gcc understands -Wformat-non-literal… no
checking whether gcc understands -fno-common… yes
checking whether gcc understands -fdiagnostics-show-option… yes
checking whether gcc understands --omg-optimized… no
checking whether gcc understands --disable-instructions… no
checking for ANSI C header files… (cached) yes
checking for sys/wait.h that is POSIX.1 compatible… yes
checking whether time.h and sys/time.h may both be included… yes
checking sys/param.h usability… yes
checking sys/param.h presence… yes
checking for sys/param.h… yes
checking sys/time.h usability… yes
checking sys/time.h presence… yes
checking for sys/time.h… yes
checking sys/times.h usability… yes
checking sys/times.h presence… yes
checking for sys/times.h… yes
checking for sys/wait.h… (cached) yes
checking for unistd.h… (cached) yes
checking for pid_t… yes
checking for vprintf… yes
checking for _doprnt… no
checking for size_t… yes
checking for working alloca.h… yes
checking for alloca… yes
checking for fsync… yes
checking for difftime… yes
checking for mmap… yes
checking whether binary relocation support should be enabled… no
checking for _NL_MEASUREMENT_MEASUREMENT… yes
checking whether NLS is requested… yes
checking for intltool >= 0.40.1… 0.41.1 found
checking for intltool-update… /usr/bin/intltool-update
checking for intltool-merge… /usr/bin/intltool-merge
checking for intltool-extract… /usr/bin/intltool-extract
checking for xgettext… /usr/bin/xgettext
checking for msgmerge… /usr/bin/msgmerge
checking for msgfmt… /usr/bin/msgfmt
checking for gmsgfmt… /usr/bin/msgfmt
checking for perl… /usr/bin/perl
checking for perl >= 5.8.1… 5.10.1
checking for XML::Parser… ok
checking locale.h usability… yes
checking locale.h presence… yes
checking for locale.h… yes
checking for LC_MESSAGES… yes
checking libintl.h usability… yes
checking libintl.h presence… yes
checking for libintl.h… yes
checking for ngettext in libc… yes
checking for dgettext in libc… yes
checking for bind_textdomain_codeset… yes
checking for msgfmt… (cached) /usr/bin/msgfmt
checking for dcgettext… yes
checking if msgfmt accepts -c… yes
checking for gmsgfmt… (cached) /usr/bin/msgfmt
checking for xgettext… (cached) /usr/bin/xgettext
checking for iso-codes… yes
checking for BABL… no
configure: error: Package requirements (babl >= 0.1.10) were not met:
No package ‘babl’ found
Consider adjusting the PKG_CONFIG_PATH environment variable if you
installed software in a non-standard prefix.
Alternatively, you may set the environment variables BABL_CFLAGS
and BABL_LIBS to avoid the need to call pkg-config.
See the pkg-config man page for more details.
Merci et encore merci à celui qui saura résoudre mon problème :smiley:
edit : tant qu’on y est … le contenu de l’archive, j’y vois quand même ‘makefile’ moi …
root@Guillaume-PC:/home/guillaume# ls Téléchargements/gimp-2.8.0 acinclude.m4 config.h.win32 HACKING modules aclocal.m4 config.log INSTALL NEWS app config.sub install-sh NEWS.pre-2-0 AUTHORS configure libgimp NEWS.pre-2-2 authors.dtd configure.ac libgimpbase NEWS.pre-2-4 authors.xml COPYING libgimpcolor NEWS.pre-2-6 authors.xsl cursors libgimpconfig plug-ins build data libgimpmath po ChangeLog depcomp libgimpmodule po-libgimp ChangeLog.pre-1-0 desktop libgimpthumb po-plug-ins ChangeLog.pre-1-2 devel-docs libgimpwidgets po-python ChangeLog.pre-2-0 docs LICENSE po-script-fu ChangeLog.pre-2-2 etc ltmain.sh po-tips ChangeLog.pre-2-4 gimp.pc.in m4macros py-compile ChangeLog.pre-2-6 gimpthumb.pc.in Makefile.am README compile gimpui.pc.in Makefile.in README.i18n config.guess gimp-zip.in menus themes config.h.in gtk-doc.make missing tools
as-tu vu ça ?
compilation-gimp-2-8-pour-la-stable-plus-que-de-l-aide-t38716.html#p395025
Je vois bien, mais c’est pour nettoyer ou revenir en arrière. Je viens de voir, (tant qu’à faire) que ça ne concerne pas que Gimp apparemment, à chaque fois que je veux compiler, j’ai ce message d’erreur, je viens de voir ça avec Pidgin …
edit : merci de t’intéresser à mon problème quand même :slightly_smiling:
Bon, alors, j’ai lancé le script, et l’erreur reste la même … :confused:
[code]
Beaucoup de texte avant …
Alternatively, you may set the environment variables LIBFFI_CFLAGS
and LIBFFI_LIBS to avoid the need to call pkg-config.
Step : 1/10
end of configure
type [Enter] to continue or Ctrl-C to leave
make: *** Pas de cibles spécifiées et aucun makefile n’a été trouvé. Arrêt.
Step : 1/10
end of make
make: *** Pas de règle pour fabriquer la cible « install ». Arrêt.
Step : 1/10
end of make install
type [Enter] to continue or Ctrl-C to leave[/code]
[quote]configure: error: Package requirements (babl >= 0.1.10) were not met:
No package ‘babl’ found[/quote]
Avec
sur Squeeze
ça devrait au moins résoudre ce problème
pourquoi ne pas faire un bon sources.list avec sid dedans tu auras la 2.8 sans passer par la compilation
Pas la peine d’une Sid, il est sur testing
tt@debian-tt:~$ apt-cache policy gimp gimp: Installé : 2.8.0-2+b1 Candidat : 2.8.0-2+b1 Table de version : *** 2.8.0-2+b1 0 990 http://ftp.fr.debian.org/debian/ wheezy/main amd64 Packages 90 http://ftp.fr.debian.org/debian/ sid/main amd64 Packages 100 /var/lib/dpkg/status 2.6.10-1+squeeze3 0 980 http://ftp.fr.debian.org/debian/ squeeze/main amd64 Packages 980 http://security.debian.org/ squeeze/updates/main amd64 Packages
Mais peut être que tu ne veux pas toucher a ton sources.list et aux dependances
Merci pour toutes vos réponses :slightly_smiling:
Excusez pour le retard, en fait, j’ai pas tellement envie de faire des modifications du sources.list.
La machine sur laquelle je voudrais installer Gimp est le PC de famille et mon père à besoin de Gimp 2.8 (apparemment, y’a un truc nouveau dans 2.8 qui lui est indispensable). Et moi, j’exige la stabilité ( ^^ )
Même en corrigeant les erreurs rencontrées dans ./configure, il me sort toujours qu’il ne trouve pas de makefile … :confused:
[quote=“gguillaume017”]Merci pour toutes vos réponses :slightly_smiling:
Même en corrigeant les erreurs rencontrées dans ./configure, il me sort toujours qu’il ne trouve pas de makefile … :/[/quote]
pourtant ! tout est là :
No package 'babl' found
ça y est, mais je comprends pas :013
J’ai fait, bien sûr un sudo apt-get install babl
Et ça ne me sort rien, pas trouvé, je connais à la compilation que le fait de lire le fichier ‘install’
Avec libbabl-0.0-0 comme l’a suggéré lann?
Je viens de tomber la dessus en cherchant à installer libbabl 0.1.10 (la version 0.0.0 ne fonctionne pas)
compilation-gimp-2-8-pour-la-stable-plus-que-de-l-aide-t38716.html#p390574
Donc, je peux oublier Gimp 2.8, à moins de la testing soit assez stable, à vous de me dire ^^
Mais sinon, mon problème de “make file non trouvé” blabla, ça peut venir d’où ?
Pour compiler, il faut la plus part du temps le fichier en -dev :
libbabl-0.0-0-dev
Alfafa
C’est fait, mais Gimp 2.8 demande une version plus récente qui ne se trouve pas dans les dépôts .:confused:
Normale, il me semble que Gnome partage une grande partie des librairies de GIMP. Donc il faut une grosse mise à jour pour que ça marche. Autrement dit, il faut passer à une version plus à jour.
Je ne suis pas spécialiste de la compilation de prog, mais je ne pense pas qu’il y a pas d’autre moyens…
Ou alors… l’installation en chroot… que je prévoie d’essayer en m’inspirant de l’article suivant :
installation-chroot-32-bits-transparent-t14673.html
Mais au lieu d’installer une 32bits, je vais insaller une sid qui me permettera de faire tourner les quelques prog que j’aimerais plus récent !
Ben, je pourrais encore passer sur la testing si elle est pas trop boguée, mais j’ai pas moyen de le savoir ^^
et pourquoi ne pas installer une testing ou sid via une VM ? comme ca pas de prob pour les progs plus a jours
et la derniere tirer par les cheveuuuuuux , installer sur clef usb le gimp 2.8 pour windows et faire focntionner via wine … mais là j’ai rien dis !! :005 c’est pas moi :005 :005
Tu m’as pris pour un jambon :stuck_out_tongue: Wine ! baaah !
Ben, au pire, vous savez vous tous si testing (je connais pas son nom de code …) est assez stable pour une utilisation au quotidien ?
tu devrais foncer , si tu ne veux pas rajouter une petite ligne testing dans ton sources.list pourquoi ne pas partitioner ton HDD et y installer celle ci …
Je considère qu’elle est stable, toute façon, ça reste Debian … J’ai jamais connu un seul bogue :slightly_smiling:
Bon, ben, merci pour l’aide en tout cas :slightly_smiling:
