J’ai ce message à la suite de lancement de “make”. Je comprends alors que la compilation a échoué donc je demande qui pourra m’aider à résoudre ce problème. merci
`Makefile’ is up to date.
make[1]: Entering directory /home/exim-4.60/build-Linux-i386' /bin/sh ../scripts/Configure-config.h "make" make[2]: Entering directory/home/exim-4.60/build-Linux-i386’
make[2]: « buildconfig » est à jour.
make[2]: Leaving directory `/home/exim-4.60/build-Linux-i386’
Building configuration file config.h
config.h built
make[2]: Entering directory /home/exim-4.60/build-Linux-i386/pcre' gcc pcre_maketables.c gcc dftables.c ./dftables chartables.c gcc chartables.c gcc pcre_fullinfo.c gcc pcre_get.c gcc pcre_globals.c gcc pcre_compile.c gcc pcre_config.c gcc pcre_exec.c gcc pcre_printint.c gcc pcre_study.c gcc pcre_tables.c gcc pcre_try_flipped.c gcc pcre_version.c rm -f libpcre.a ar cq libpcre.a ranlib libpcre.a gcc pcretest.c gcc -o ../pcretest pcretest.o libpcre.a make[2]: Leaving directory/home/exim-4.60/build-Linux-i386/pcre’
/bin/sh …/scripts/Configure-eximon
eximon script built
gcc -DCOMPILE_UTILITY spool_in.c
In file included from exim.h:425,
from spool_in.c:14:
dbstuff.h:103:16: db.h: No such file or directory
from spool_in.c:14:
dbstuff.h:529: error: syntax error before "DB"
dbstuff.h:529: warning: no semicolon at end of struct or union
dbstuff.h:531: error: syntax error before ‘}’ token
dbstuff.h:531: warning: data definition has no type or storage class
In file included from exim.h:429,
from spool_in.c:14:
dbfunctions.h:13: error: syntax error before ‘’ token
dbfunctions.h:14: error: syntax error before '’ token
dbfunctions.h:15: error: syntax error before ‘’ token
dbfunctions.h:15: error: syntax error before "open_db"
dbfunctions.h:15: warning: data definition has no type or storage class
dbfunctions.h:16: error: syntax error before '’ token
dbfunctions.h:17: error: syntax error before ‘’ token
dbfunctions.h:18: error: syntax error before '’ token
make[1]: *** [util-spool_in.o] Erreur 1
make[1]: Leaving directory `/home/exim-4.60/build-Linux-i386’
make: *** [go] Erreur 2
