Mon objectif est d’installer les drivers nvidia http://fr.download.nvidia.com/XFree86/Linux-x86_64/319.60/NVIDIA-Linux-x86_64-319.60.run
Voici ma config :
$ uname -a
Linux debian 3.2.0-4-amd64 #1 SMP Debian 3.2.46-1 x86_64 GNU/Linux
$ lspci
00:00.0 Host bridge: Intel Corporation Haswell DRAM Controller (rev 06)
00:01.0 PCI bridge: Intel Corporation Haswell PCI Express x16 Controller (rev 06)
00:02.0 VGA compatible controller: Intel Corporation Haswell Integrated Graphics Controller (rev 06)
00:03.0 Audio device: Intel Corporation Haswell HD Audio Controller (rev 06)
00:14.0 USB controller: Intel Corporation Lynx Point USB xHCI Host Controller (rev 04)
00:16.0 Communication controller: Intel Corporation Lynx Point MEI Controller #1 (rev 04)
00:1a.0 USB controller: Intel Corporation Lynx Point USB Enhanced Host Controller #2 (rev 04)
00:1b.0 Audio device: Intel Corporation Lynx Point High Definition Audio Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation Lynx Point PCI Express Root Port #1 (rev d4)
00:1c.3 PCI bridge: Intel Corporation Lynx Point PCI Express Root Port #4 (rev d4)
00:1d.0 USB controller: Intel Corporation Lynx Point USB Enhanced Host Controller #1 (rev 04)
00:1f.0 ISA bridge: Intel Corporation Lynx Point LPC Controller (rev 04)
00:1f.2 SATA controller: Intel Corporation Lynx Point 6-port SATA Controller 1 [AHCI mode] (rev 04)
00:1f.3 SMBus: Intel Corporation Lynx Point SMBus Controller (rev 04)
01:00.0 VGA compatible controller: NVIDIA Corporation Device 1004 (rev a1)
01:00.1 Audio device: NVIDIA Corporation Device 0e1a (rev a1)
03:00.0 Ethernet controller: Atheros Communications Inc. Device e091 (rev 10)
$ lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 8087:8008 Intel Corp.
Bus 002 Device 002: ID 8087:8000 Intel Corp.
Bus 003 Device 003: ID 045e:0023 Microsoft Corp. Trackball Optical
Bus 003 Device 004: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 003 Device 005: ID 0b05:4c82 ASUSTek Computer, Inc.
Voici mon problème que l’on retrouve dans le fichier make.log :
[i]DKMS make.log for nvidia-319.60 for kernel 3.2.0-4-amd64 (x86_64)
samedi 5 octobre 2013, 09:44:28 (UTC+0200)
gcc-version-check failed:
The compiler used to compile the kernel (gcc
4.6) does not exactly match the current compiler
(gcc 4.7). The Linux 2.6 kernel module loader
rejects kernel modules built with a version of gcc
that does not exactly match that of the compiler
used to build the running kernel.
If you know what you are doing and want to override
the gcc version check, you can do so by setting the
IGNORE_CC_MISMATCH environment variable to “1”.
In any other case, set the CC environment variable
to the name of the compiler that was used to compile
the kernel.
*** Failed CC version check. Bailing out! ***
make[1]: *** [build-sanity-checks] Erreur 1
make: *** [module] Erreur 2[/i]
Donc j’ai vérifié dans le gestionnaire de paquet et je trouve installé gcc-4.6 et gcc-4.7
Je me dis "pourquoi ne pas supprimer la version 4.6 ?"
Et bien cette procédure effacera également linux-header-3.2.0-4-amd64 et linux-headers-amd64.
Et je suis pas certain que je dois procéder à cette suppression.
Comment obliger le fichier .run de chez nvidia à utiliser la version 4.7 ?
Merci de votre aide
Stefan
Ps : Je vous met aussi le fichier log de nvidia-installer :
[i]nvidia-installer log file '/var/log/nvidia-installer.log’
creation time: Sat Oct 5 09:44:16 2013
installer version: 319.60
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
nvidia-installer command line:
./nvidia-installer
Using: nvidia-installer ncurses user interface
-> License accepted.
-> Installing NVIDIA driver version 319.60.
-> There appears to already be a driver installed on your system (version: 319.60). As part of installing this driver (version: 319.60), the existing driver will be uninstalled. Are you sure you want to continue? (‘no’ will abort installation) (Answer: Yes)
-> Would you like to register the kernel module sources with DKMS? This will allow DKMS to automatically build a new module, if you install a different kernel later. (Answer: Yes)
-> Installing both new and classic TLS OpenGL libraries.
-> Installing both new and classic TLS 32bit OpenGL libraries.
-> Install NVIDIA’s 32-bit compatibility OpenGL libraries? (Answer: Yes)
-> Parsing log file:
-> done.
-> Validating previous installation:
-> done.
-> Uninstalling NVIDIA Accelerated Graphics Driver for Linux-x86_64 (1.0-31960 (319.60)):
-> DKMS module detected; removing…
-> done.
-> Uninstallation of existing driver: NVIDIA Accelerated Graphics Driver for Linux-x86_64 (319.60) is complete.
-> Searching for conflicting X files:
-> done.
-> Searching for conflicting OpenGL files:
-> done.
-> Installing ‘NVIDIA Accelerated Graphics Driver for Linux-x86_64’ (319.60):
executing: ‘/sbin/ldconfig’…
executing: ‘/sbin/depmod -aq’…
ignored deprecated option -q
-> done.
-> Driver file installation is complete.
-> Installing DKMS kernel module:
ERROR: Failed to run /usr/sbin/dkms build -m nvidia -v 319.60 -k 3.2.0-4-amd64:
Kernel preparation unnecessary for this kernel. Skipping…
Building module:
cleaning build area…
make KERNELRELEASE=3.2.0-4-amd64 module KERNEL_UNAME=3.2.0-4-amd64…(bad exit status: 2)
Error! Bad return status for module build on kernel: 3.2.0-4-amd64 (x86_64)
Consult /var/lib/dkms/nvidia/319.60/build/make.log for more information.
-> error.
ERROR: Failed to install the kernel module through DKMS. No kernel module was installed; please try installing again without DKMS, or check the DKMS logs for more information.
ERROR: Installation has failed. Please see the file ‘/var/log/nvidia-installer.log’ for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at nvidia.com.[/i]
cool
