Compilation du kernel 2.6.34 erreur visant Lguest !
Bonjour lors de ma compilation du kernel j’ai une erreur donc je ne connais pas l’existence serez-vous en dire plus pour résoudre ce problème ?
cordialement
make[3]: entrant dans le répertoire « /usr/src/linux-2.6.34/Documentation/lguest » cc -m32 -Wall -Wmissing-declarations -Wmissing-prototypes -O3 -I../../include -I../../arch/x86/include -U_FORTIFY_SOURCE lguest.c -o lguest In file included from /usr/include/sys/eventfd.h:12, from lguest.c:21: ../../include/linux/file.h:22: error: expected declaration specifiers or â...â before âfmode_tâ In file included from lguest.c:21: /usr/include/sys/eventfd.h: In function âeventfd_file_createâ: /usr/include/sys/eventfd.h:50: error: âENOSYSâ undeclared (first use in this function) /usr/include/sys/eventfd.h:50: error: (Each undeclared identifier is reported only once /usr/include/sys/eventfd.h:50: error: for each function it appears in.) /usr/include/sys/eventfd.h: In function âeventfd_ctx_fdgetâ: /usr/include/sys/eventfd.h:55: error: âENOSYSâ undeclared (first use in this function) /usr/include/sys/eventfd.h: In function âeventfd_signalâ: /usr/include/sys/eventfd.h:60: error: âENOSYSâ undeclared (first use in this function) /usr/include/sys/eventfd.h: In function âeventfd_ctx_readâ: /usr/include/sys/eventfd.h:71: error: âENOSYSâ undeclared (first use in this function) /usr/include/sys/eventfd.h: At top level: /usr/include/sys/eventfd.h:75: error: expected declaration specifiers or â...â before âwait_queue_tâ /usr/include/sys/eventfd.h: In function âeventfd_ctx_remove_wait_queueâ: /usr/include/sys/eventfd.h:77: error: âENOSYSâ undeclared (first use in this function) In file included from /usr/include/fcntl.h:34, from lguest.c:22: /usr/include/bits/fcntl.h: At top level: /usr/include/bits/fcntl.h:159: error: redefinition of âstruct flockâ /usr/include/bits/fcntl.h:174: error: redefinition of âstruct flock64â lguest.c: In function âcreate_threadâ: lguest.c:1026: warning: implicit declaration of function âeventfdâ make[3]: *** [lguest] Erreur 1 make[3]: quittant le répertoire « /usr/src/linux-2.6.34/Documentation/lguest » make[2]: *** [debian/stamp/build/kernel] Erreur 2 make[2]: quittant le répertoire « /usr/src/linux-2.6.34 » make[1]: *** [debian/stamp/do-build-arch] Erreur 2 make[1]: quittant le répertoire « /usr/src/linux-2.6.34 » dpkg-buildpackage: échec: debian/rules build a produit une erreur de sortie de type 2 make: *** [debian/stamp/build/buildpackage] Erreur 2
Pourquoi as-tu besoin de compiler le 2.6.34 ?
Il faut supprimer lguest dans le dossier du nouveau noyau. Par contre je sais plus où il se trouve… Fait une petite recherche dans le nouveau kernel (dossier).
search.php?st=0&sk=t&sd=d&sr=posts&keywords=lguest&fid[]=3
