/usr/src/# df -h
Sys. de fich. Tail. Occ. Disp. %Occ. Monté sur
/dev/sda3 471M 380M 68M 85% /
tmpfs 503M 0 503M 0% /lib/init/rw
udev 10M 80K 10M 1% /dev
tmpfs 503M 0 503M 0% /dev/shm
/dev/sda2 92M 9,4M 78M 11% /boot
/dev/sda11 7,6M 1,5M 5,8M 20% /debianedufreespace
/dev/sda9 1,9G 35M 1,8G 2% /skole/backup
/dev/sda10 132G 188M 125G 1% /skole/tjener/home0
/dev/sda5 1,4G 1,3G 13M 100% /usr
/dev/sda6 2,8G 851M 1,8G 32% /var
/dev/sda8 122M 5,6M 110M 5% /var/spool/squid
et
[code]/usr/src/# fdisk -l
Disk /dev/sda: 160.0 GB, 160041885696 bytes
255 heads, 63 sectors/track, 19457 cylinders
/dev/sda1 * 1 784 6297448+ c W95 FAT32 (LBA)
/dev/sda2 785 796 96390 83 Linux
/dev/sda3 797 858 498015 83 Linux
/dev/sda4 859 19457 149396467+ 5 Extended
/dev/sda5 859 1036 1429753+ 83 Linux
/dev/sda6 1037 1401 2931831 83 Linux
/dev/sda7 1402 1776 3012156 82 Linux swap / Solaris
/dev/sda8 1777 1792 128488+ 83 Linux
/dev/sda9 1793 2035 1951866 83 Linux
/dev/sda10 2036 19456 139934151 83 Linux
/dev/sda11 19457 19457 8001 83 Linux[/code]
en plus lorsque je fais :
/usr/src/# ls -la
total 12
drwxrwxrwx 3 root src 4096 2007-04-18 16:26 .
drwxr-xr-x 12 root root 4096 2007-04-16 17:55 ..
lrwxrwxrwx 1 root root 26 2007-04-18 16:26 linux-2.6.18-4-amd64 -> /home/user1/linux-2.6.18.4
drwxr-xr-x 3 root root 4096 2006-12-02 15:34 modules
j’espère que j’étais clair
en attendant tes (vos) contributions ,
merci enormement.
