Compilation gtk+2.0
La compilation de gtk+2.0 se termine par le message d’erreur suivant :Cannot load module /home/eol/sources/gtk+2.0-2.18.9/modules/input/im-am-et.la: /home/eol/sources/gtk+2.0-2.18.9/modules/input/.libs/: cannot read file data: Is a directory /home/eol/sources/gtk+2.0-2.18.9/modules/input/im-am-et.la does not export GTK+ IM module API: /home/eol/sources/gtk+2.0-2.18.9/modules/input/.libs/: cannot read file data: Is a directory Cannot load module /home/eol/sources/gtk+2.0-2.18.9/modules/input/im-cedilla.la: /home/eol/sources/gtk+2.0-2.18.9/modules/input/.libs/: cannot read file data: Is a directory /home/eol/sources/gtk+2.0-2.18.9/modules/input/im-cedilla.la does not export GTK+ IM module API: /home/eol/sources/gtk+2.0-2.18.9/modules/input/.libs/: cannot read file data: Is a directory Cannot load module /home/eol/sources/gtk+2.0-2.18.9/modules/input/im-cyrillic-translit.la: /home/eol/sources/gtk+2.0-2.18.9/modules/input/.libs/: cannot read file data: Is a directory /home/eol/sources/gtk+2.0-2.18.9/modules/input/im-cyrillic-translit.la does not export GTK+ IM module API: /home/eol/sources/gtk+2.0-2.18.9/modules/input/.libs/: cannot read file data: Is a directory Cannot load module /home/eol/sources/gtk+2.0-2.18.9/modules/input/im-inuktitut.la: /home/eol/sources/gtk+2.0-2.18.9/modules/input/.libs/: cannot read file data: Is a directory /home/eol/sources/gtk+2.0-2.18.9/modules/input/im-inuktitut.la does not export GTK+ IM module API: /home/eol/sources/gtk+2.0-2.18.9/modules/input/.libs/: cannot read file data: Is a directory Cannot load module /home/eol/sources/gtk+2.0-2.18.9/modules/input/im-ipa.la: /home/eol/sources/gtk+2.0-2.18.9/modules/input/.libs/: cannot read file data: Is a directory /home/eol/sources/gtk+2.0-2.18.9/modules/input/im-ipa.la does not export GTK+ IM module API: /home/eol/sources/gtk+2.0-2.18.9/modules/input/.libs/: cannot read file data: Is a directory Cannot load module /home/eol/sources/gtk+2.0-2.18.9/modules/input/im-multipress.la: /home/eol/sources/gtk+2.0-2.18.9/modules/input/.libs/: cannot read file data: Is a directory /home/eol/sources/gtk+2.0-2.18.9/modules/input/im-multipress.la does not export GTK+ IM module API: /home/eol/sources/gtk+2.0-2.18.9/modules/input/.libs/: cannot read file data: Is a directory Cannot load module /home/eol/sources/gtk+2.0-2.18.9/modules/input/im-thai.la: /home/eol/sources/gtk+2.0-2.18.9/modules/input/.libs/: cannot read file data: Is a directory /home/eol/sources/gtk+2.0-2.18.9/modules/input/im-thai.la does not export GTK+ IM module API: /home/eol/sources/gtk+2.0-2.18.9/modules/input/.libs/: cannot read file data: Is a directory Cannot load module /home/eol/sources/gtk+2.0-2.18.9/modules/input/im-ti-er.la: /home/eol/sources/gtk+2.0-2.18.9/modules/input/.libs/: cannot read file data: Is a directory /home/eol/sources/gtk+2.0-2.18.9/modules/input/im-ti-er.la does not export GTK+ IM module API: /home/eol/sources/gtk+2.0-2.18.9/modules/input/.libs/: cannot read file data: Is a directory Cannot load module /home/eol/sources/gtk+2.0-2.18.9/modules/input/im-ti-et.la: /home/eol/sources/gtk+2.0-2.18.9/modules/input/.libs/: cannot read file data: Is a directory /home/eol/sources/gtk+2.0-2.18.9/modules/input/im-ti-et.la does not export GTK+ IM module API: /home/eol/sources/gtk+2.0-2.18.9/modules/input/.libs/: cannot read file data: Is a directory Cannot load module /home/eol/sources/gtk+2.0-2.18.9/modules/input/im-viqr.la: /home/eol/sources/gtk+2.0-2.18.9/modules/input/.libs/: cannot read file data: Is a directory /home/eol/sources/gtk+2.0-2.18.9/modules/input/im-viqr.la does not export GTK+ IM module API: /home/eol/sources/gtk+2.0-2.18.9/modules/input/.libs/: cannot read file data: Is a directory Cannot load module /home/eol/sources/gtk+2.0-2.18.9/modules/input/im-xim.la: /home/eol/sources/gtk+2.0-2.18.9/modules/input/.libs/: cannot read file data: Is a directory /home/eol/sources/gtk+2.0-2.18.9/modules/input/im-xim.la does not export GTK+ IM module API: /home/eol/sources/gtk+2.0-2.18.9/modules/input/.libs/: cannot read file data: Is a directory make[3]: *** [gtk.immodules] Erreur 1 make[3]: quittant le répertoire « /home/eol/sources/gtk+2.0-2.18.9/modules/input » make[2]: *** [all-recursive] Erreur 1 make[2]: quittant le répertoire « /home/eol/sources/gtk+2.0-2.18.9/modules » make[1]: *** [all-recursive] Erreur 1 make[1]: quittant le répertoire « /home/eol/sources/gtk+2.0-2.18.9 » make: *** [all] Erreur 2Quelqu’un aurait-il connaissance de la possibilité ou non de corriger une telle erreur?
Je comprends qu’il y a une tentative de lire des infos d’un fichier
mais que cette tentative échoue car le fichier en question serait un répertoire.
C’est ça?
