bon ben voila autre chose:
sa compile sa s’installe, mai aux reboot sa trouve pas le systeme de fichier (enfin le message est chian a recopier)
(de memoire il doit manquer un sacrer bout)
je supose que c est lier a grub2 car sa apparait droit dérière l’ecran du choix du kernel.
il ne trouve pas le disque, car j’ai rien toucher aux .config sauf le xen qui empêchai la config
j’utilise les UIID pour eviter les embrouilles, mai bon.
# menu.lst - See: grub(8), info grub, update-grub(8)
# grub-install(8), grub-floppy(8),
# grub-md5-crypt, /usr/share/doc/grub
# and /usr/share/doc/grub-legacy-doc/.
## default num
# Set the default entry to the entry number NUM. Numbering starts from 0, and
# the entry number 0 is the default if the command is not used.
# You can specify 'saved' instead of a number. In this case, the default entry
# is the entry saved with the command 'savedefault'.
# WARNING: If you are using dmraid do not change this entry to 'saved' or your
# array will desync and will not let you boot your system.
default 0
## timeout sec
# Set a timeout, in SEC seconds, before automatically booting the default entry
# (normally the first entry defined).
timeout 5
# Pretty colours
color cyan/blue white/blue
## password ['--md5'] passwd
# If used in the first section of a menu file, disable all interactive editing
# control (menu entry editor and command-line) and entries protected by the
# command 'lock'
# e.g. password topsecret
# password --md5 $1$gLhU0/$aW78kHK1QfV3P2b2znUoe/
# password topsecret
# examples
# title Windows 95/98/NT/2000
# root (hd0,0)
# makeactive
# chainloader +1
# title Linux
# root (hd0,1)
# kernel /vmlinuz root=/dev/hda2 ro
# Put static boot stanzas before and/or after AUTOMAGIC KERNEL LIST
### BEGIN AUTOMAGIC KERNELS LIST
## lines between the AUTOMAGIC KERNELS LIST markers will be modified
## by the debian update-grub script except for the default options below
## DO NOT UNCOMMENT THEM, Just edit them to your needs
## ## Start Default Options ##
## default kernel options
## default kernel options for automagic boot options
## If you want special options for specific kernels use kopt_x_y_z
## where x.y.z is kernel version. Minor versions can be omitted.
## e.g. kopt=root=/dev/hda1 ro
## kopt_2_6_8=root=/dev/hdc1 ro
## kopt_2_6_8_2_686=root=/dev/hdc2 ro
# kopt=root=UUID=95ff9af4-d807-49be-ae63-c282aef20560 ro
## default grub root device
## e.g. groot=(hd0,0)
# groot=(hd0,0)
## should update-grub create alternative automagic boot options
## e.g. alternative=true
## alternative=false
# alternative=true
## should update-grub lock alternative automagic boot options
## e.g. lockalternative=true
## lockalternative=false
## additional options to use with the default boot option, but not with the
## alternatives
## e.g. defoptions=vga=791 resume=/dev/hda5
# defoptions=quiet
## should update-grub lock old automagic boot options
## e.g. lockold=false
## lockold=true
# lockold=false
## Xen hypervisor options to use with the default Xen boot option
# xenhopt=
## Xen Linux kernel options to use with the default Xen boot option
# xenkopt=console=tty0
## altoption boot targets option
## multiple altoptions lines are allowed
## e.g. altoptions=(extra menu suffix) extra boot options
## altoptions=(single-user) single
# altoptions=(single-user mode) single
## controls how many kernels should be put into the menu.lst
## only counts the first occurence of a kernel, not the
## alternative kernel options
## e.g. howmany=all
## howmany=7
# howmany=all
## should update-grub create memtest86 boot option
## e.g. memtest86=true
## memtest86=false
# memtest86=true
## should update-grub adjust the value of the default booted system
## can be true or false
# updatedefaultentry=false
## should update-grub add savedefault to the default options
# savedefault=false
## ## End Default Options ##
title Chainload into GRUB 2
root (hd0,0)
kernel /grub/core.img
title ���������������������������������������������������������������������
root
title When you have verified GRUB 2 works, you can use this command to
root
title complete the upgrade: upgrade-from-grub-legacy
root
root
title Debian GNU/Linux, kernel 2.6.30-2-686-bigmem
root (hd0,0)
kernel /vmlinuz-2.6.30-2-686-bigmem root=UUID=95ff9af4-d807-49be-ae63-c282aef20560 ro quiet
initrd /initrd.img-2.6.30-2-686-bigmem
title Debian GNU/Linux, kernel 2.6.30-2-686-bigmem (single-user mode)
root (hd0,0)
kernel /vmlinuz-2.6.30-2-686-bigmem root=UUID=95ff9af4-d807-49be-ae63-c282aef20560 ro single
root (hd0,0)
kernel /vmlinuz-2.6.30-2-686 root=UUID=95ff9af4-d807-49be-ae63-c282aef20560 ro quiet
title Debian GNU/Linux, kernel 2.6.30-2-686 (single-user mode)
root (hd0,0)
kernel /vmlinuz-2.6.30-2-686 root=UUID=95ff9af4-d807-49be-ae63-c282aef20560 ro single
title Debian GNU/Linux, kernel 2.6.26.cust.21.min.gcc4
root (hd0,0)
kernel /vmlinuz-2.6.26.cust.21.min.gcc4 root=UUID=95ff9af4-d807-49be-ae63-c282aef20560 ro quiet
initrd /initrd.img-2.6.26.cust.21.min.gcc4
title Debian GNU/Linux, kernel 2.6.26.cust.21.min.gcc4 (single-user mode)
root (hd0,0)
kernel /vmlinuz-2.6.26.cust.21.min.gcc4 root=UUID=95ff9af4-d807-49be-ae63-c282aef20560 ro single
title Debian GNU/Linux, kernel 2.6.26.cust.01.bigmem.min.gcc4
root (hd0,0)
kernel /vmlinuz-2.6.26.cust.01.bigmem.min.gcc4 root=UUID=95ff9af4-d807-49be-ae63-c282aef20560 ro quiet
initrd /initrd.img-2.6.26.cust.01.bigmem.min.gcc4
title Debian GNU/Linux, kernel 2.6.26.cust.01.bigmem.min.gcc4 (single-user mode)
root (hd0,0)
kernel /vmlinuz-2.6.26.cust.01.bigmem.min.gcc4 root=UUID=95ff9af4-d807-49be-ae63-c282aef20560 ro single
title Debian GNU/Linux, kernel 2.6.26-2-686-bigmem
root (hd0,0)
kernel /vmlinuz-2.6.26-2-686-bigmem root=UUID=95ff9af4-d807-49be-ae63-c282aef20560 ro quiet
initrd /initrd.img-2.6.26-2-686-bigmem
title Debian GNU/Linux, kernel 2.6.26-2-686-bigmem (single-user mode)
root (hd0,0)
kernel /vmlinuz-2.6.26-2-686-bigmem root=UUID=95ff9af4-d807-49be-ae63-c282aef20560 ro single
root (hd0,0)
kernel /vmlinuz-2.6.26-2-686 root=UUID=95ff9af4-d807-49be-ae63-c282aef20560 ro quiet
title Debian GNU/Linux, kernel 2.6.26-2-686 (single-user mode)
root (hd0,0)
kernel /vmlinuz-2.6.26-2-686 root=UUID=95ff9af4-d807-49be-ae63-c282aef20560 ro single
### END DEBIAN AUTOMAGIC KERNELS LIST
y a plein de fichier dans ce répertoie je fait un ls
$ ls /boot/grub/
915resolution.mod blocklist.mod cpuid.mod efiemu.mod gzio.mod kernel.img memdisk.mod ntfs.mod play.mod search.mod ufs2.mod video.mod
acpi.mod boot.img crc.mod elf.mod halt.mod keystatus.mod memrw.mod ohci.mod png.mod serial.mod uhci.mod videotest.mod
affs.mod boot.mod datehook.mod ext2.mod handler.lst linux16.mod menu.lst part_acorn.mod probe.mod setjmp.mod unicode.pf2 xfs.mod
afs_be.mod bsd.mod date.mod extcmd.mod handler.mod linux.mod menu.lst~ part_amiga.mod pxeboot.img sfs.mod usb_keyboard.mod xnu.mod
afs.mod bufio.mod datetime.mod fat.mod hdparm.mod lnxboot.img menu.lst_backup_by_grub2_postinst part_apple.mod pxecmd.mod sh.mod usb.mod xnu_uuid.mod
aout.mod cat.mod default font.mod hello.mod loadenv.mod minicmd.mod part_gpt.mod pxe.mod sleep.mod usbms.mod zfsinfo.mod
ata.mod cdboot.img device.map fs_file.mod help.mod loopback.mod minix.mod partmap.lst raid5rec.mod tar.mod usbtest.mod zfs.mod
ata_pthru.mod chain.mod diskboot.img fshelp.mod hexdump.mod lsmmap.mod mmap.mod part_msdos.mod raid6rec.mod terminfo.mod vbeinfo.mod
at_keyboard.mod cmp.mod dm_nv.mod fs.lst hfs.mod ls.mod moddep.lst part_sun.mod raid.mod test.mod vbe.mod
befs_be.mod command.lst drivemap.mod fs_uuid.mod hfsplus.mod lspci.mod msdospart.mod parttool.lst read.mod tga.mod vbetest.mod
befs.mod configfile.mod echo.mod gfxterm.mod iso9660.mod lua.mod multiboot.mod parttool.mod reboot.mod true.mod vga.mod
biosdisk.mod core.img efiemu32.o gptsync.mod jfs.mod lvm.mod normal.mod password.mod reiserfs.mod udf.mod vga_text.mod
bitmap.mod cpio.mod efiemu64.o grub.cfg jpeg.mod mdraid.mod ntfscomp.mod pci.mod scsi.mod ufs1.mod video_fb.mod
une idée ?
